Series Catagory
darkcloud784
Post Mon Dec 24, 2012 6:40 am
Series Catagory
So, I recently started using serviio. I love it, however I have found that things dont get sorted properly sometimes. Even following the naming rules as pointed out in the FAQ. For instance, I have the entire Avatar: The Last AirBender series. This is how my files are named (format wise)
Avatar The Last Airbender - 1x01 - The Boy in the Iceberg
Avatar The Last Airbender - 1x02 - The Avatar Returns
Avatar The Last Airbender - 1x03 - The Southern Air Temple
Avatar The Last Airbender - 2x01 - The Avatar State
Avatar The Last Airbender - 2x02 - The Cave of Two Lovers
None of theses show up as a series, although they are all formatted naming wise correctly (to the best of my knowledge) I even tried using FileBot to rename them according to the series with TheTVDB. They all match correctly and all meta tags are included. Here's my MediaInfo information. Please let me know if I'm doing this incorrectly, renaming all 61 episodes manually will be a pain in the ***.
Unique ID : 40130211466082388541091174067414482025 (0x1E30CC2F19FC909F94F9A48597CBBC69)
Complete name : I:\Movies3\Avatar The Last Air Bender\Avatar The Last Airbender - 1x01 - The Boy in the Iceberg.mkv
Format : Matroska
Format version : Version 1
File size : 229 MiB
Duration : 23mn 29s
Overall bit rate : 1 362 Kbps
Writing application : HandBrake 0.9.3
Format : AVC
Format profile : Main@L3.0
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 23mn 29s
Bit rate : 759 Kbps
Nominal bit rate : 907 Kbps
Width : 718 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Original display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.073
Stream size : 127 MiB (56%)
Writing library : x264 core 65
Encoding settings : cabac=1 / ref=2 / deblock=1:0:0 / analyse=0x1:0x111 / me=umh / subme=6 / psy_rd=1.0:0.0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=2 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=0 / keyint=300 / keyint_min=30 / scenecut=40(pre) / rc=2pass / bitrate=907 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Color primaries : BT.601 NTSC
Matrix coefficients : BT.601
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 23mn 29s
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 32.3 MiB (14%)
Language : English
Default : Yes
Forced : No
Audio #2
Format : AC-3
Codec ID : A_AC3
Duration : 23mn 29s
Bit rate : 192 Kbps
Bit depth : 16 bits
Language : French
Default : Yes
Forced : No
Audio #3
Format : AC-3
Codec ID : A_AC3
Duration : 23mn 29s
Bit rate : 192 Kbps
Bit depth : 16 bits
Language : Spanish
Default : Yes
Forced : No
Post Mon Dec 24, 2012 11:52 am
Re: Series Catagory
There is a few topics regarding series recently, possibly the service is down.
darkcloud784
Post Mon Dec 24, 2012 7:13 pm
Re: Series Catagory
zip wrote:There is a few topics regarding series recently, possibly the service is down.
:( I would assume this means that you would take a look at it and see if it can be fixed?
Post Tue Dec 25, 2012 10:35 am
Re: Series Catagory
I'm away this week, will check on a few days.
Users browsing this forum: Google [Bot] and 58 guests
