Online Content Profile
armstma1
Post Fri Jan 04, 2013 5:07 pm
Newbie here but i'm VERY impressed with serviio it works brilliantly!
However i cannot get the ONLINE streams to play on my KISS 1600 player (i know its quite old) the online content plays ok on my Sony TV etc just not on the KISS player.
Is it possible to create a custom profile to enable this to work? if so how?
If i can get this working i'll definately buy the Pro version!
I'm running serviio on an old Pentium 4 3.0GHz so only want to re-encode where i have too.
PS tried a few of the default ones but no luck.
armstma1
Post Tue Jan 15, 2013 9:43 pm
Re: Online Content Profile
anyone?
Post Wed Jan 16, 2013 7:37 am
armstma1
Post Wed Jan 16, 2013 6:52 pm
thanks
http-get:*:audio/mp3:*,
http-get:*:audio/wma:*,
http-get:*:audio/x-ms-wma:*,
http-get:*:audio/wav:*,
http-get:*:audio/ogg:*,
http-get:*:audio/mpeg:*,
http-get:*:audio/mp4:*,
http-get:*:video/mpg:*,
http-get:*:video/mpeg:*,
http-get:*:video/mp2:*,
http-get:*:video/mp4:*,
http-get:*:video/divx:*,
http-get:*:video/xvid:*,
http-get:*:video/wmv:*,
http-get:*:video/x-ms-wmv:*,
http-get:*:video/asf:*,
http-get:*:video/x-ms-asf:*,
http-get:*:video/avi:*,
http-get:*:image/jpg:*,
http-get:*:image/gif:*,
http-get:*:image/png:*,
http-get:*:image/bmp:*
I know i need to edit profiles.xml which i have started on but how do i translate the above into the correct format?
armstma1
Post Mon Jan 21, 2013 6:22 pm
Have i posted this in the wrong section?
Post Mon Jan 21, 2013 7:59 pm
Did you try any other profiles? eg DirecTV?
armstma1
Post Tue Jan 22, 2013 10:28 am
Yes I tried every one they all say codec not supported.
I presume you don't need to restart serviio after changing?
Sent from my HTC One X using Tapatalk 2
Post Tue Jan 22, 2013 12:49 pm
Hmm, so possibly the device doesn't play well with trascoded content..
armstma1
Post Tue Jan 22, 2013 7:48 pm
Everything else works fine DivX mp4 etc
Is there a tutorial for making a profile.xml addition?
Post Tue Jan 22, 2013 10:59 pm
Check the support page on the website
armstma1
Post Wed Jan 23, 2013 4:59 pm
zip wrote:Check the support page on the website
I did but to be honest it lost me!
A script to convert from upnp tools output would be a godsend!
Post Wed Jan 23, 2013 5:20 pm
DirecTV profile produces files that should be playable according to this protocl info. If it doesn't there is something else, possibly on the devices side, that is making it fail
armstma1
Post Wed Feb 20, 2013 6:41 pm
Sounds like this is obsolete now then?
Can anyone recommend a suitable replacement?
Post Wed Feb 20, 2013 6:43 pm
Does the DitrecTV profile work for you?
armstma1
Post Thu Feb 21, 2013 8:34 pm
Yes for everything except online streaming, it works on PS3 but not this.
Return to Feature requests
