file does not play on B651T3W
vaki
Post Wed Jan 09, 2013 8:52 pm
Hi!
sorry if this is not the right place for this question.
I have several mkv files that I can not play on a Samsung B651T3W.
I selected the Samsung B-series profile in the transcoding profile option, but does't work..
Attached is the Information after run ffmpeg -i :
ffmpeg version N-48610-gb23aff6 Copyright (c) 2000-2013 the FFmpeg developers
  built on Jan  7 2013 22:42:59 with gcc 4.7.2 (GCC)
  configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-av
isynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enab
le-libass --enable-libbluray --enable-libcaca --enable-libfreetype --enable-libg
sm --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --e
nable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --e
nable-libtheora --enable-libtwolame --enable-libvo-aacenc --enable-libvo-amrwben
c --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-
libxvid --enable-zlib
  libavutil      52. 13.100 / 52. 13.100
  libavcodec     54. 86.100 / 54. 86.100
  libavformat    54. 59.106 / 54. 59.106
  libavdevice    54.  3.102 / 54.  3.102
  libavfilter     3. 32.100 /  3. 32.100
  libswscale      2.  1.103 /  2.  1.103
  libpostproc    52.  2.100 / 52.  2.100
[matroska,webm @ 00000000020c69a0] max_analyze_duration 5000000 reached at 50050
00
[matroska,webm @ 00000000020c69a0] Could not find codec parameters for stream 5
(Subtitle: hdmv_pgs_subtitle): unspecified size
Consider increasing the value for the 'analyzeduration' and 'probesize' options
[matroska,webm @ 00000000020c69a0] Could not find codec parameters for stream 6
Input #0, matroska,webm, from 'd:\peliculas\alta definicion\La Chaqueta Met+ílic
a [www.newpct.com][toni32].mkv':
    title           : La Chaqueta Met+ílica [www.newpct.com][toni32]
    creation_time   : 1970-01-01 00:00:02
  Duration: 01:56:30.88, start: 0.000000, bitrate: 5420 kb/s
    Stream #0:0: Video: h264 (High), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], 23.9
8 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
    Stream #0:1(spa): Audio: ac3, 48000 Hz, 5.1(side), fltp, 448 kb/s (default)
(forced)
      title           : Ac3 Castellano [www.newpct.com][toni32]
    Stream #0:2(eng): Audio: ac3, 48000 Hz, 5.1(side), fltp, 448 kb/s
      title           : Ac3 Ingles [www.newpct.com][toni32]
    Stream #0:3(spa): Subtitle: subrip
      title           : Subitulos Castellano [www.newpct.com][toni32]
    Stream #0:4(eng): Subtitle: subrip
      title           : Subtitulos Ingles [www.newpct.com][toni32]
    Stream #0:5(spa): Subtitle: hdmv_pgs_subtitle
      title           : Subtitulos Forzados Castellano [www.newpct.com][toni32]
    Stream #0:6(eng): Subtitle: hdmv_pgs_subtitle
can someone help me out?
should recode the video stream to any specific format?
thanks in advance!
slyguy42o
Post Fri Jan 11, 2013 11:10 pm
Re: file does not play on B651T3W
is it just specific mkv's that wont play? or all?
Also can you post a detailed log please?
vaki
Post Mon Jan 14, 2013 8:15 pm
Yes It's certainly files, all of them with the same video stream properties.
The file with which I'm testing is "La Chaqueta Metálica [www.newpct.com][toni32].mkv"
Here is the log file:
2013-01-14 21:13:04,908 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2013-01-14 21:13:04,924 INFO  [MediaServer] ------------------------------------------------------------------------
2013-01-14 21:13:04,924 INFO  [MediaServer] Serviio DLNA media streaming server v 1.1 (rev. 6ba0dd933a8e+)
2013-01-14 21:13:04,924 INFO  [MediaServer] Petr Nejedly 2009-2012
2013-01-14 21:13:04,924 INFO  [MediaServer] http://www.serviio.org
2013-01-14 21:13:04,924 INFO  [MediaServer] Java 1.7.0_05-Oracle Corporation
2013-01-14 21:13:04,924 INFO  [MediaServer] OS Windows 7 amd64 6.1
2013-01-14 21:13:04,924 INFO  [MediaServer] File encoding: windows-1252
2013-01-14 21:13:04,924 INFO  [MediaServer] Headless mode enabled: true
2013-01-14 21:13:04,924 INFO  [MediaServer] User: SERVIDOR$
2013-01-14 21:13:04,924 INFO  [MediaServer] User home dir: C:\
2013-01-14 21:13:04,924 INFO  [MediaServer] Temp dir: C:\Windows\TEMP\
2013-01-14 21:13:05,033 INFO  [WebServer] Socket buffer set to 65535 bytes
2013-01-14 21:13:05,033 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2013-01-14 21:13:05,064 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2013-01-14 21:13:05,064 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2013-01-14 21:13:05,080 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2013-01-14 21:13:05,095 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2013-01-14 21:13:05,875 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2013-01-14 21:13:05,875 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2013-01-14 21:13:05,875 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2013-01-14 21:13:05,875 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2013-01-14 21:13:05,875 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2013-01-14 21:13:05,875 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2013-01-14 21:13:05,875 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2013-01-14 21:13:05,875 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2013-01-14 21:13:05,875 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2013-01-14 21:13:05,875 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.1.sql' has been run
2013-01-14 21:13:05,875 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.2.sql' has been run
2013-01-14 21:13:05,875 DEBUG [DBLogDAOImpl] Checking if script 'script-1.0.sql' has been run
2013-01-14 21:13:05,875 DEBUG [DBLogDAOImpl] Checking if script 'script-1.1.sql' has been run
2013-01-14 21:13:05,891 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2013-01-14 21:13:05,907 DEBUG [LicenseValidator] Validating license file (348 bytes)
2013-01-14 21:13:06,000 INFO  [MediaServer] ------------------------------------------------------------------------
2013-01-14 21:13:06,000 INFO  [MediaServer] License: FREE
2013-01-14 21:13:06,219 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2013-01-14 21:13:06,265 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2013-01-14 21:13:06,936 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2013-01-14 21:13:06,936 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2013-01-14 21:13:06,952 DEBUG [ServiioConsole] Initializing Serviio Console
2013-01-14 21:13:06,983 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44332
2013-01-14 21:13:06,983 INFO  [ServiioConsole] Starting Serviio Console
2013-01-14 21:13:07,030 DEBUG [SwingHelper] Choosing java look and feel: com.sun.java.swing.plaf.windows.WindowsLookAndFeel
2013-01-14 21:13:07,077 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2013-01-14 21:13:07,482 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2013-01-14 21:13:07,482 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2013-01-14 21:13:07,810 INFO  [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2013-01-14 21:13:07,810 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2013-01-14 21:13:08,215 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2013-01-14 21:13:08,215 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2013-01-14 21:13:08,465 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2013-01-14 21:13:08,465 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2013-01-14 21:13:08,637 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2013-01-14 21:13:08,637 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2013-01-14 21:13:09,276 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D/E-series)' (id=7)
2013-01-14 21:13:09,276 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2013-01-14 21:13:09,323 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2013-01-14 21:13:09,323 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012
2013-01-14 21:13:10,041 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2013-01-14 21:13:10,041 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 10
2013-01-14 21:13:10,789 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2013-01-14 21:13:10,789 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2013-01-14 21:13:11,086 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2013-01-14 21:13:11,086 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 14
2013-01-14 21:13:11,257 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2013-01-14 21:13:11,257 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 15
2013-01-14 21:13:11,289 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2013-01-14 21:13:11,289 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 16
2013-01-14 21:13:11,445 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2013-01-14 21:13:11,445 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 17
2013-01-14 21:13:11,491 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2013-01-14 21:13:11,491 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 18
2013-01-14 21:13:11,803 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2013-01-14 21:13:11,803 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011
2013-01-14 21:13:11,913 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2013-01-14 21:13:11,913 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2010
2013-01-14 21:13:12,178 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2013-01-14 21:13:12,178 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 20
2013-01-14 21:13:12,474 INFO  [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2013-01-14 21:13:12,474 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2009
2013-01-14 21:13:12,583 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2013-01-14 21:13:12,583 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 22
2013-01-14 21:13:12,630 INFO  [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2013-01-14 21:13:12,630 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011a
2013-01-14 21:13:13,176 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2013-01-14 21:13:13,176 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011
2013-01-14 21:13:13,239 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2013-01-14 21:13:13,239 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2010
2013-01-14 21:13:13,317 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2013-01-14 21:13:13,317 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012us
2013-01-14 21:13:13,410 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2013-01-14 21:13:13,410 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011us
2013-01-14 21:13:13,519 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2013-01-14 21:13:13,519 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonySTR
2013-01-14 21:13:13,660 INFO  [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2013-01-14 21:13:13,660 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonyCMT
2013-01-14 21:13:13,738 INFO  [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2013-01-14 21:13:13,769 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2013-01-14 21:13:13,769 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile flv_player
2013-01-14 21:13:14,176 INFO  [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2013-01-14 21:13:14,176 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo
2013-01-14 21:13:14,410 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo' (id=serviigo)
2013-01-14 21:13:14,410 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile wp8
2013-01-14 21:13:14,566 INFO  [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2013-01-14 21:13:14,940 INFO  [Device] Created UPnP Device with UUID: df29ffd2-c48d-3270-8b52-589b786ca617, bound address: 192.168.1.25
2013-01-14 21:13:14,956 INFO  [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2013-01-14 21:13:14,956 INFO  [PluginCompilerThread] Started looking for plugins
2013-01-14 21:13:14,956 INFO  [UpdateChecker] Checking if a new version is available
2013-01-14 21:13:14,971 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2013-01-14 21:13:14,971 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2013-01-14 21:13:15,065 DEBUG [DCRawWrapper] Invoking DCRAW to check if it exists of path C:\Program Files\Serviio\bin\\..\lib/dcraw.exe
2013-01-14 21:13:15,065 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/dcraw.exe
2013-01-14 21:13:15,112 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2013-01-14 21:13:15,112 DEBUG [AbstractTranscodingDeliveryEngine] Deleting temporary transcoded files from: F:\Transcoding Temp\Serviio
2013-01-14 21:13:15,127 INFO  [WebServer] WebServer starting on port 8895
2013-01-14 21:13:15,143 DEBUG [DiscoveryManager] UPNP device df29ffd2-c48d-3270-8b52-589b786ca617 (192.168.1.25) is available
2013-01-14 21:13:15,143 INFO  [EventDispatcher] Starting EventDispatcher
2013-01-14 21:13:15,143 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-01-14 21:13:15,143 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-01-14 21:13:15,143 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2013-01-14 21:13:15,158 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.1.25, timeout = 0
2013-01-14 21:13:15,628 INFO  [RendererSearchSender] Searching for Renderer devices, will multicast on 1 NICs
2013-01-14 21:13:15,628 DEBUG [RendererSearchSender] Multicasting SSDP M-SEARCH using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.1.25, timeout = 0
2013-01-14 21:13:15,628 DEBUG [RendererSearchSender] Sending 1 'm-search' messages
2013-01-14 21:13:15,644 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.25:52383
2013-01-14 21:13:15,644 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.25
2013-01-14 21:13:15,644 DEBUG [DiscoveryAdvertisementNotifier] Found 1 network interfaces to advertise on
2013-01-14 21:13:15,644 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.1.25, timeout = 0
2013-01-14 21:13:15,660 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device df29ffd2-c48d-3270-8b52-589b786ca617
2013-01-14 21:13:15,660 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.25:52383
2013-01-14 21:13:15,660 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.25
2013-01-14 21:13:17,626 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:07 (advertisement duration is 1800 sec.)
2013-01-14 21:13:21,629 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2013-01-14 21:13:21,921 DEBUG [ServiioConsole] Retrieving console settings
2013-01-14 21:13:22,025 DEBUG [ServiioConsole] Setting console locale to be: es
2013-01-14 21:13:22,035 INFO  [Messages] Loaded console message bundle for locale: es
2013-01-14 21:13:22,165 DEBUG [ServiioFrameView] Initializing main frame
2013-01-14 21:13:22,180 DEBUG [ServiioFrameView] System tray is supported
2013-01-14 21:13:22,414 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups
2013-01-14 21:13:22,717 DEBUG [RepositoryDAOImpl] Reading all Repositories
2013-01-14 21:13:22,735 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups for Repository (id = 1)
2013-01-14 21:13:22,782 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-01-14 21:13:23,114 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2013-01-14 21:13:23,313 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups
2013-01-14 21:13:23,615 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type AUDIO
2013-01-14 21:13:23,631 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type VIDEO
2013-01-14 21:13:24,124 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2013-01-14 21:13:24,129 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=0, titleKey=pc5dczc_media_library, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = null
2013-01-14 21:13:24,147 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A, titleKey=audio, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2013-01-14 21:13:24,152 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_A, titleKey=artists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-14 21:13:24,159 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,164 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistsForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,171 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForArtistCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,176 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForArtistAndAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,181 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=AL_A, titleKey=album_artists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-14 21:13:24,187 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListAlbumArtistInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,193 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListAlbumArtistsForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,198 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForAlbumArtistCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,204 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,210 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-14 21:13:24,215 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=MUSIC_TRACK, idPrefix=FOL, recursive=true, cacheRegion=local_default
2013-01-14 21:13:24,221 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_G, titleKey=genres, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-14 21:13:24,226 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioGenresByNameCommand, containerClass=MUSIC_GENRE, itemClass=null, idPrefix=GEN, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,232 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForGenreCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,237 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_C, titleKey=composers, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-14 21:13:24,243 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListComposerInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,248 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListComposersForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=COM, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,254 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForComposerCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,259 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForComposerAndAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,264 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_T, titleKey=titles, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-14 21:13:24,272 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,285 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForInitialCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,291 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_R, titleKey=random, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2013-01-14 21:13:24,296 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListRandomSongsCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=no_cache
2013-01-14 21:13:24,302 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_PL, titleKey=playlists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-14 21:13:24,308 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioPlaylistsCommand, containerClass=PLAYLIST_CONTAINER, itemClass=null, idPrefix=PL, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,314 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForPlaylistCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,319 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_OF, titleKey=online, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2013-01-14 21:13:24,326 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioOnlineContentCommand, containerClass=STORAGE_FOLDER, itemClass=MUSIC_TRACK, idPrefix=FOL, recursive=true, cacheRegion=no_cache
2013-01-14 21:13:24,331 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_S, titleKey=All songs, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2013-01-14 21:13:24,337 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAllSongsCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,343 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_AS, titleKey=Artist Songs, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2013-01-14 21:13:24,348 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistsByNameCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART_S, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,354 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForArtistCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,359 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_ALB, titleKey=All albums, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2013-01-14 21:13:24,365 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAllAlbumsCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,371 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,377 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I, titleKey=image, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2013-01-14 21:13:24,382 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_A, titleKey=albums, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-14 21:13:24,389 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListFlatImageFoldersByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,394 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForFolderCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,399 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-14 21:13:24,406 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImageFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=PHOTO, idPrefix=FOL, recursive=true, cacheRegion=local_default
2013-01-14 21:13:24,411 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_Y, titleKey=year, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-14 21:13:24,417 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=YEAR, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,423 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForCreationYearCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,429 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_T, titleKey=month, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-14 21:13:24,435 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=YEAR, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,441 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationMonthsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=MON, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,447 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForCreationMonthAndYearCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,453 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_PL, titleKey=playlists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-14 21:13:24,459 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagePlaylistsCommand, containerClass=PLAYLIST_CONTAINER, itemClass=null, idPrefix=PL, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,465 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForPlaylistCommand, containerClass=null, itemClass=PHOTO, idPrefix=S, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,471 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_OF, titleKey=online, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2013-01-14 21:13:24,476 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImageOnlineContentCommand, containerClass=STORAGE_FOLDER, itemClass=PHOTO, idPrefix=FOL, recursive=true, cacheRegion=no_cache
2013-01-14 21:13:24,482 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_AI, titleKey=All images, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2013-01-14 21:13:24,488 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListAllImagesCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,494 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V, titleKey=video, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2013-01-14 21:13:24,500 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_T, titleKey=titles, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-14 21:13:24,506 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,511 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForInitialCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,518 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_M, titleKey=movies, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-14 21:13:24,523 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListMovieVideosByNameCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,530 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_S, titleKey=series, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-14 21:13:24,535 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListSeriesByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=SER, recursive=false, cacheRegion=local_resetafterplay
2013-01-14 21:13:24,541 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListSeasonsForSeriesCommand, containerClass=CONTAINER, itemClass=null, idPrefix=SSN, recursive=false, cacheRegion=local_resetafterplay
2013-01-14 21:13:24,547 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListEpisodesForSeriesSeasonCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_resetafterplay
2013-01-14 21:13:24,553 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-14 21:13:24,559 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=VIDEO_ITEM, idPrefix=FOL, recursive=true, cacheRegion=local_default
2013-01-14 21:13:24,565 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_LV, titleKey=last_viewed, class=CONTAINER, cacheRegion=local_resetafterplay, browsable = null, editable = true
2013-01-14 21:13:24,571 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListLastViewedVideosCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_resetafterplay
2013-01-14 21:13:24,576 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_LA, titleKey=last_added, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-14 21:13:24,583 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListLastAddedVideosCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,588 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_G, titleKey=genres, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-14 21:13:24,595 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoGenresByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=GEN, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,601 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForGenreCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,607 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_A, titleKey=actors, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-14 21:13:24,613 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListActorInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,620 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListActorsForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,625 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForActorCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,632 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_D, titleKey=directors, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-14 21:13:24,637 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListDirectorInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,643 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListDirectorsForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,649 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForDirectorCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,655 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_P, titleKey=producers, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-14 21:13:24,662 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducerInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,668 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducersForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,675 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForProducerCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,680 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_PL, titleKey=playlists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-14 21:13:24,687 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoPlaylistsCommand, containerClass=PLAYLIST_CONTAINER, itemClass=null, idPrefix=PL, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,693 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForPlaylistCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=S, recursive=false, cacheRegion=local_default
2013-01-14 21:13:24,699 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_OF, titleKey=online, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2013-01-14 21:13:24,705 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoOnlineContentCommand, containerClass=STORAGE_FOLDER, itemClass=VIDEO_ITEM, idPrefix=FOL, recursive=true, cacheRegion=no_cache
2013-01-14 21:13:24,709 INFO  [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: es
2013-01-14 21:13:25,224 DEBUG [RepositoryDAOImpl] Reading all Repositories
2013-01-14 21:13:25,224 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups for Repository (id = 1)
2013-01-14 21:13:25,224 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-01-14 21:13:25,239 DEBUG [ServiioConsole] Reading application data
2013-01-14 21:13:25,239 DEBUG [RepositoryView$LibraryStatusCheckerThread] Starting library status checking thread
2013-01-14 21:13:25,458 DEBUG [DiscoveryAdvertisementNotifier] Found 1 network interfaces to advertise on
2013-01-14 21:13:25,458 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.1.25, timeout = 0
2013-01-14 21:13:25,458 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device df29ffd2-c48d-3270-8b52-589b786ca617
2013-01-14 21:13:27,423 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:07 (advertisement duration is 1800 sec.)
2013-01-14 21:13:35,443 DEBUG [DiscoveryAdvertisementNotifier] Found 1 network interfaces to advertise on
2013-01-14 21:13:35,443 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.1.25, timeout = 0
2013-01-14 21:13:35,443 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device df29ffd2-c48d-3270-8b52-589b786ca617
2013-01-14 21:13:37,409 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:04:02 (advertisement duration is 1800 sec.)
2013-01-14 21:13:41,631 INFO  [FeedUpdaterThread] Started looking for information about online resources
2013-01-14 21:13:41,631 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-01-14 21:13:41,631 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-01-14 21:13:41,632 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2013-01-14 21:13:41,632 DEBUG [RepositoryDAOImpl] Reading all Repositories
2013-01-14 21:13:41,632 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2013-01-14 21:13:41,633 DEBUG [RepositoryDAOImpl] Reading all Repositories
2013-01-14 21:13:41,633 INFO  [PlaylistMaintainerThread] Started looking playlist changes
2013-01-14 21:13:41,635 DEBUG [PlaylistDAOImpl] Reading all Playlists
2013-01-14 21:13:41,636 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Peliculas
2013-01-14 21:13:41,636 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Peliculas\Alta Definicion
2013-01-14 21:13:41,637 DEBUG [LibraryAdditionsCheckerThread] Found file 'Contagio [DVDrip][AC3 5.1 Español Castellano][2011][www.newpct.com].avi', checking if it's already in the Library
2013-01-14 21:13:41,637 DEBUG [LibraryUpdatesCheckerThread] Looking for removed playlist files in repository: D:\Peliculas
2013-01-14 21:13:41,637 DEBUG [PlaylistDAOImpl] Reading Playlists for Repository (id = 1)
2013-01-14 21:13:41,638 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Contagio [DVDrip][AC3 5.1 Español Castellano][2011][www.newpct.com].avi
2013-01-14 21:13:41,638 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Peliculas\Contagio [DVDrip][AC3 5.1 Español Castellano][2011][www.newpct.com].avi, ignore case: true
2013-01-14 21:13:41,652 DEBUG [LibraryUpdatesCheckerThread] Looking for removed/updated files in repository: D:\Peliculas
2013-01-14 21:13:41,652 DEBUG [MediaItemDAOImpl] Reading MediaItems for Repository (id = 1)
2013-01-14 21:13:41,678 DEBUG [MediaItemDAOImpl] Media item Contagio [DVDrip][AC3 5.1 Español Castellano][2011][www.newpct.com].avi already exists in DB
2013-01-14 21:13:41,678 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Peliculas\La chaqueta metálica [MicroHD][1080 px][AC3 5.1-Castellano-Ingles+Subs]
2013-01-14 21:13:41,678 DEBUG [LibraryAdditionsCheckerThread] Found file 'La Chaqueta Metálica [www.newpct.com][toni32].mkv', checking if it's already in the Library
2013-01-14 21:13:41,678 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item La Chaqueta Metálica [www.newpct.com][toni32].mkv
2013-01-14 21:13:41,678 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Peliculas\La chaqueta metálica [MicroHD][1080 px][AC3 5.1-Castellano-Ingles+Subs]\La Chaqueta Metálica [www.newpct.com][toni32].mkv, ignore case: true
2013-01-14 21:13:41,679 DEBUG [MediaItemDAOImpl] Media item La Chaqueta Metálica [www.newpct.com][toni32].mkv already exists in DB
2013-01-14 21:13:41,680 DEBUG [LibraryAdditionsCheckerThread] Found file 'Lo Imposible [DVDScreener]www.newpct.com.avi', checking if it's already in the Library
2013-01-14 21:13:41,680 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Lo Imposible [DVDScreener]www.newpct.com.avi
2013-01-14 21:13:41,680 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Peliculas\Lo Imposible [DVDScreener]www.newpct.com.avi, ignore case: true
2013-01-14 21:13:41,680 DEBUG [MediaItemDAOImpl] Media item Lo Imposible [DVDScreener]www.newpct.com.avi already exists in DB
2013-01-14 21:13:41,681 DEBUG [LibraryAdditionsCheckerThread] Found file 'Los juegos del hambre.avi', checking if it's already in the Library
2013-01-14 21:13:41,681 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Los juegos del hambre.avi
2013-01-14 21:13:41,681 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Peliculas\Los juegos del hambre.avi, ignore case: true
2013-01-14 21:13:41,681 DEBUG [MediaItemDAOImpl] Media item Los juegos del hambre.avi already exists in DB
2013-01-14 21:13:41,681 DEBUG [LibraryAdditionsCheckerThread] Found file 'Los vengadores.avi', checking if it's already in the Library
2013-01-14 21:13:41,681 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Los vengadores.avi
2013-01-14 21:13:41,681 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2013-01-14 21:13:41,682 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Peliculas\Los vengadores.avi, ignore case: true
2013-01-14 21:13:41,683 DEBUG [MediaItemDAOImpl] Media item Los vengadores.avi already exists in DB
2013-01-14 21:13:41,683 DEBUG [LibraryAdditionsCheckerThread] Found file 'Prometheus [DVDrip][AC3 5.1 Español Castellano][2012][www.newpct.com].avi', checking if it's already in the Library
2013-01-14 21:13:41,683 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Prometheus [DVDrip][AC3 5.1 Español Castellano][2012][www.newpct.com].avi
2013-01-14 21:13:41,683 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Peliculas\Prometheus [DVDrip][AC3 5.1 Español Castellano][2012][www.newpct.com].avi, ignore case: true
2013-01-14 21:13:41,684 DEBUG [MediaItemDAOImpl] Media item Prometheus [DVDrip][AC3 5.1 Español Castellano][2012][www.newpct.com].avi already exists in DB
2013-01-14 21:13:41,684 DEBUG [LibraryAdditionsCheckerThread] Found file 'Safe [BluRayRIP][Español Castellano Ac3 5.1][2012][www.newpct.com].avi', checking if it's already in the Library
2013-01-14 21:13:41,684 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Safe [BluRayRIP][Español Castellano Ac3 5.1][2012][www.newpct.com].avi
2013-01-14 21:13:41,684 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Peliculas\Safe [BluRayRIP][Español Castellano Ac3 5.1][2012][www.newpct.com].avi, ignore case: true
2013-01-14 21:13:41,685 DEBUG [MediaItemDAOImpl] Media item Safe [BluRayRIP][Español Castellano Ac3 5.1][2012][www.newpct.com].avi already exists in DB
2013-01-14 21:13:41,685 DEBUG [LibraryAdditionsCheckerThread] Found file 'Ted [BluRayRIP][Español Castellano][2012][www.newpct.com].avi', checking if it's already in the Library
2013-01-14 21:13:41,685 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Ted [BluRayRIP][Español Castellano][2012][www.newpct.com].avi
2013-01-14 21:13:41,685 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Peliculas\Ted [BluRayRIP][Español Castellano][2012][www.newpct.com].avi, ignore case: true
2013-01-14 21:13:41,686 DEBUG [MediaItemDAOImpl] Media item Ted [BluRayRIP][Español Castellano][2012][www.newpct.com].avi already exists in DB
2013-01-14 21:13:41,686 DEBUG [LibraryAdditionsCheckerThread] Found file 'The Mechanic [DVDRIP][Español Castellano][www.newpct.com].avi', checking if it's already in the Library
2013-01-14 21:13:41,686 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item The Mechanic [DVDRIP][Español Castellano][www.newpct.com].avi
2013-01-14 21:13:41,686 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Peliculas\The Mechanic [DVDRIP][Español Castellano][www.newpct.com].avi, ignore case: true
2013-01-14 21:13:41,687 DEBUG [MediaItemDAOImpl] Media item The Mechanic [DVDRIP][Español Castellano][www.newpct.com].avi already exists in DB
2013-01-14 21:13:41,687 DEBUG [RepositoryDAOImpl] Marking Repository 1 as scanned with current timestamp
2013-01-14 21:13:41,703 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type AUDIO
2013-01-14 21:13:41,707 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type VIDEO
2013-01-14 21:13:41,708 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type IMAGE
2013-01-14 21:13:41,710 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1) and extractor EMBEDDED
2013-01-14 21:13:41,731 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1) and extractor COVER_IMAGE_IN_FOLDER
2013-01-14 21:13:41,733 DEBUG [MediaItemDAOImpl] Getting file of media item 2
2013-01-14 21:13:41,733 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 2) and extractor EMBEDDED
2013-01-14 21:13:41,734 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 2) and extractor COVER_IMAGE_IN_FOLDER
2013-01-14 21:13:41,735 DEBUG [MediaItemDAOImpl] Getting file of media item 3
2013-01-14 21:13:41,736 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3) and extractor EMBEDDED
2013-01-14 21:13:41,737 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3) and extractor COVER_IMAGE_IN_FOLDER
2013-01-14 21:13:41,738 DEBUG [MediaItemDAOImpl] Getting file of media item 4
2013-01-14 21:13:41,738 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 4) and extractor EMBEDDED
2013-01-14 21:13:41,739 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 4) and extractor COVER_IMAGE_IN_FOLDER
2013-01-14 21:13:41,740 DEBUG [MediaItemDAOImpl] Getting file of media item 5
2013-01-14 21:13:41,740 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 5) and extractor EMBEDDED
2013-01-14 21:13:41,741 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 5) and extractor COVER_IMAGE_IN_FOLDER
2013-01-14 21:13:41,742 DEBUG [MediaItemDAOImpl] Getting file of media item 6
2013-01-14 21:13:41,743 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 6) and extractor EMBEDDED
2013-01-14 21:13:41,743 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 6) and extractor COVER_IMAGE_IN_FOLDER
2013-01-14 21:13:41,745 DEBUG [MediaItemDAOImpl] Getting file of media item 7
2013-01-14 21:13:41,745 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7) and extractor EMBEDDED
2013-01-14 21:13:41,746 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7) and extractor COVER_IMAGE_IN_FOLDER
2013-01-14 21:13:41,747 DEBUG [MediaItemDAOImpl] Getting file of media item 94
2013-01-14 21:13:41,747 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 94) and extractor EMBEDDED
2013-01-14 21:13:41,748 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 94) and extractor COVER_IMAGE_IN_FOLDER
2013-01-14 21:13:41,750 DEBUG [MediaItemDAOImpl] Getting file of media item 95
2013-01-14 21:13:41,750 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 95) and extractor EMBEDDED
2013-01-14 21:13:41,751 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 95) and extractor COVER_IMAGE_IN_FOLDER
2013-01-14 21:13:41,752 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 1)
2013-01-14 21:13:41,770 DEBUG [RepositoryDAOImpl] Marking Repository 1 as scanned with current timestamp
2013-01-14 21:14:41,637 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-01-14 21:14:41,637 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
Post Tue Jan 15, 2013 6:05 pm
the log doesn't show playing the file. Are you using the Samsung B series profile?
vaki
Post Wed Jan 16, 2013 9:11 pm
sorry !! here its the new log:
2013-01-16 21:50:31,916 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2013-01-16 21:50:31,926 INFO  [MediaServer] ------------------------------------------------------------------------
2013-01-16 21:50:31,926 INFO  [MediaServer] Serviio DLNA media streaming server v 1.1 (rev. 6ba0dd933a8e+)
2013-01-16 21:50:31,926 INFO  [MediaServer] Petr Nejedly 2009-2012
2013-01-16 21:50:31,926 INFO  [MediaServer] http://www.serviio.org
2013-01-16 21:50:31,926 INFO  [MediaServer] Java 1.7.0_05-Oracle Corporation
2013-01-16 21:50:31,926 INFO  [MediaServer] OS Windows 7 amd64 6.1
2013-01-16 21:50:31,926 INFO  [MediaServer] File encoding: windows-1252
2013-01-16 21:50:31,926 INFO  [MediaServer] Headless mode enabled: true
2013-01-16 21:50:31,926 INFO  [MediaServer] User: SERVIDOR$
2013-01-16 21:50:31,926 INFO  [MediaServer] User home dir: C:\
2013-01-16 21:50:31,926 INFO  [MediaServer] Temp dir: C:\Windows\TEMP\
2013-01-16 21:50:32,046 INFO  [WebServer] Socket buffer set to 65535 bytes
2013-01-16 21:50:32,056 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2013-01-16 21:50:32,086 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2013-01-16 21:50:32,086 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2013-01-16 21:50:32,096 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2013-01-16 21:50:32,106 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2013-01-16 21:50:32,956 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2013-01-16 21:50:32,956 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2013-01-16 21:50:32,956 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2013-01-16 21:50:32,956 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2013-01-16 21:50:32,956 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2013-01-16 21:50:32,956 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2013-01-16 21:50:32,956 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2013-01-16 21:50:32,956 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2013-01-16 21:50:32,956 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2013-01-16 21:50:32,956 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.1.sql' has been run
2013-01-16 21:50:32,956 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.2.sql' has been run
2013-01-16 21:50:32,956 DEBUG [DBLogDAOImpl] Checking if script 'script-1.0.sql' has been run
2013-01-16 21:50:32,956 DEBUG [DBLogDAOImpl] Checking if script 'script-1.1.sql' has been run
2013-01-16 21:50:32,976 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2013-01-16 21:50:32,986 DEBUG [LicenseValidator] Validating license file (348 bytes)
2013-01-16 21:50:33,086 INFO  [MediaServer] ------------------------------------------------------------------------
2013-01-16 21:50:33,086 INFO  [MediaServer] License: FREE
2013-01-16 21:50:33,306 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2013-01-16 21:50:33,356 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2013-01-16 21:50:34,066 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2013-01-16 21:50:34,066 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2013-01-16 21:50:34,616 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2013-01-16 21:50:34,616 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2013-01-16 21:50:34,936 INFO  [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2013-01-16 21:50:34,936 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2013-01-16 21:50:35,166 DEBUG [ServiioConsole] Initializing Serviio Console
2013-01-16 21:50:35,196 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44332
2013-01-16 21:50:35,196 INFO  [ServiioConsole] Starting Serviio Console
2013-01-16 21:50:35,256 DEBUG [SwingHelper] Choosing java look and feel: com.sun.java.swing.plaf.windows.WindowsLookAndFeel
2013-01-16 21:50:35,306 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2013-01-16 21:50:35,426 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2013-01-16 21:50:35,426 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2013-01-16 21:50:35,746 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2013-01-16 21:50:35,746 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2013-01-16 21:50:36,038 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2013-01-16 21:50:36,048 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2013-01-16 21:50:36,608 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D/E-series)' (id=7)
2013-01-16 21:50:36,608 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2013-01-16 21:50:36,638 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2013-01-16 21:50:36,638 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012
2013-01-16 21:50:37,398 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2013-01-16 21:50:37,398 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 10
2013-01-16 21:50:38,228 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2013-01-16 21:50:38,228 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2013-01-16 21:50:38,578 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2013-01-16 21:50:38,578 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 14
2013-01-16 21:50:38,768 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2013-01-16 21:50:38,778 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 15
2013-01-16 21:50:38,808 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2013-01-16 21:50:38,808 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 16
2013-01-16 21:50:38,978 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2013-01-16 21:50:38,978 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 17
2013-01-16 21:50:39,028 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2013-01-16 21:50:39,038 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 18
2013-01-16 21:50:39,378 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2013-01-16 21:50:39,378 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011
2013-01-16 21:50:39,508 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2013-01-16 21:50:39,508 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2010
2013-01-16 21:50:39,810 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2013-01-16 21:50:39,810 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 20
2013-01-16 21:50:40,140 INFO  [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2013-01-16 21:50:40,150 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2009
2013-01-16 21:50:40,270 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2013-01-16 21:50:40,270 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 22
2013-01-16 21:50:40,330 INFO  [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2013-01-16 21:50:40,330 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011a
2013-01-16 21:50:40,890 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2013-01-16 21:50:40,890 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011
2013-01-16 21:50:40,980 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2013-01-16 21:50:40,980 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2010
2013-01-16 21:50:41,050 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2013-01-16 21:50:41,050 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012us
2013-01-16 21:50:41,160 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2013-01-16 21:50:41,160 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011us
2013-01-16 21:50:41,270 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2013-01-16 21:50:41,280 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonySTR
2013-01-16 21:50:41,450 INFO  [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2013-01-16 21:50:41,450 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonyCMT
2013-01-16 21:50:41,540 INFO  [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2013-01-16 21:50:41,580 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2013-01-16 21:50:41,580 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile flv_player
2013-01-16 21:50:42,020 INFO  [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2013-01-16 21:50:42,020 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo
2013-01-16 21:50:42,280 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo' (id=serviigo)
2013-01-16 21:50:42,280 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile wp8
2013-01-16 21:50:42,450 INFO  [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2013-01-16 21:50:42,850 INFO  [Device] Created UPnP Device with UUID: df29ffd2-c48d-3270-8b52-589b786ca617, bound address: 192.168.1.25
2013-01-16 21:50:42,870 INFO  [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2013-01-16 21:50:42,870 INFO  [PluginCompilerThread] Started looking for plugins
2013-01-16 21:50:42,870 INFO  [UpdateChecker] Checking if a new version is available
2013-01-16 21:50:42,880 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2013-01-16 21:50:42,880 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2013-01-16 21:50:43,200 DEBUG [DCRawWrapper] Invoking DCRAW to check if it exists of path C:\Program Files\Serviio\bin\\..\lib/dcraw.exe
2013-01-16 21:50:43,200 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/dcraw.exe
2013-01-16 21:50:43,270 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2013-01-16 21:50:43,270 DEBUG [AbstractTranscodingDeliveryEngine] Deleting temporary transcoded files from: F:\Transcoding Temp\Serviio
2013-01-16 21:50:43,290 INFO  [WebServer] WebServer starting on port 8895
2013-01-16 21:50:43,300 DEBUG [DiscoveryManager] UPNP device df29ffd2-c48d-3270-8b52-589b786ca617 (192.168.1.25) is available
2013-01-16 21:50:43,300 INFO  [EventDispatcher] Starting EventDispatcher
2013-01-16 21:50:43,300 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-01-16 21:50:43,300 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-01-16 21:50:43,310 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2013-01-16 21:50:43,331 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.1.25, timeout = 0
2013-01-16 21:50:43,763 INFO  [RendererSearchSender] Searching for Renderer devices, will multicast on 1 NICs
2013-01-16 21:50:43,763 DEBUG [RendererSearchSender] Multicasting SSDP M-SEARCH using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.1.25, timeout = 0
2013-01-16 21:50:43,773 DEBUG [RendererSearchSender] Sending 1 'm-search' messages
2013-01-16 21:50:43,783 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.25:59810
2013-01-16 21:50:43,783 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.25
2013-01-16 21:50:43,793 DEBUG [DiscoveryAdvertisementNotifier] Found 1 network interfaces to advertise on
2013-01-16 21:50:43,793 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.1.25, timeout = 0
2013-01-16 21:50:43,793 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device df29ffd2-c48d-3270-8b52-589b786ca617
2013-01-16 21:50:43,803 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.25:59810
2013-01-16 21:50:43,803 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.25
2013-01-16 21:50:44,303 DEBUG [RendererSearchSender] Received search response: location: http://192.168.1.40:52235/dmr/SamsungMRDesc.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2013-01-16 21:50:44,303 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer d77fcf8a-4085-016d-9875-c100b108b138 from address /192.168.1.40:1027
2013-01-16 21:50:44,313 DEBUG [RendererManager] Adding renderer Renderer [uuid=d77fcf8a-4085-016d-9875-c100b108b138, ipAddress=192.168.1.40, name=Samsung DTV DMR, profileId=2, manuallyAdded=false, forcedProfile=false, enabled=true, accessGroupId=1] to list of active renderers
2013-01-16 21:50:44,413 DEBUG [WebServer] Incoming connection from /192.168.1.40:4930
2013-01-16 21:50:44,413 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:50:44,413 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device df29ffd2-c48d-3270-8b52-589b786ca617 from 192.168.1.40 (headers = [HOST: 192.168.1.25:8895,USER-AGENT: SamsungWiselinkPro/1.0,ACCEPT-LANGUAGE: en-us])
2013-01-16 21:50:44,413 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.1.25:8895,USER-AGENT: SamsungWiselinkPro/1.0,ACCEPT-LANGUAGE: en-us]
2013-01-16 21:50:44,423 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:50:44,503 DEBUG [WebServer] Incoming connection from /192.168.1.40:4931
2013-01-16 21:50:44,503 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:50:44,503 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device df29ffd2-c48d-3270-8b52-589b786ca617 from 192.168.1.40 (headers = [HOST: 192.168.1.25:8895,USER-AGENT: SamsungWiselinkPro/1.0,ACCEPT-LANGUAGE: en-us])
2013-01-16 21:50:44,503 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.1.25:8895,USER-AGENT: SamsungWiselinkPro/1.0,ACCEPT-LANGUAGE: en-us]
2013-01-16 21:50:44,593 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Samsung TV (B-series)'
2013-01-16 21:50:45,293 DEBUG [RendererSearchSender] Received search response: location: http://192.168.1.40:52235/dmr/SamsungMRDesc.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2013-01-16 21:50:45,293 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer d77fcf8a-4085-016d-9875-c100b108b138 from address /192.168.1.40:1027
2013-01-16 21:50:45,603 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:07 (advertisement duration is 1800 sec.)
2013-01-16 21:50:49,784 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2013-01-16 21:50:49,796 DEBUG [ServiioConsole] Retrieving console settings
2013-01-16 21:50:49,898 DEBUG [ServiioConsole] Setting console locale to be: es
2013-01-16 21:50:49,907 INFO  [Messages] Loaded console message bundle for locale: es
2013-01-16 21:50:50,040 DEBUG [ServiioFrameView] Initializing main frame
2013-01-16 21:50:50,057 DEBUG [ServiioFrameView] System tray is supported
2013-01-16 21:50:50,186 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups
2013-01-16 21:50:50,489 DEBUG [RepositoryDAOImpl] Reading all Repositories
2013-01-16 21:50:50,509 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups for Repository (id = 1)
2013-01-16 21:50:50,560 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-01-16 21:50:50,988 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2013-01-16 21:50:51,185 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups
2013-01-16 21:50:51,488 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type AUDIO
2013-01-16 21:50:51,505 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type VIDEO
2013-01-16 21:50:51,997 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2013-01-16 21:50:52,002 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=0, titleKey=pc5dczc_media_library, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = null
2013-01-16 21:50:52,020 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A, titleKey=audio, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2013-01-16 21:50:52,025 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_A, titleKey=artists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-16 21:50:52,033 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,038 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistsForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,045 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForArtistCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,050 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForArtistAndAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,056 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=AL_A, titleKey=album_artists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-16 21:50:52,061 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListAlbumArtistInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,067 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListAlbumArtistsForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,073 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForAlbumArtistCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,078 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,086 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-16 21:50:52,091 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=MUSIC_TRACK, idPrefix=FOL, recursive=true, cacheRegion=local_default
2013-01-16 21:50:52,098 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_G, titleKey=genres, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-16 21:50:52,103 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioGenresByNameCommand, containerClass=MUSIC_GENRE, itemClass=null, idPrefix=GEN, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,110 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForGenreCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,115 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_C, titleKey=composers, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-16 21:50:52,122 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListComposerInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,128 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListComposersForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=COM, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,134 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForComposerCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,140 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForComposerAndAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,146 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_T, titleKey=titles, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-16 21:50:52,152 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,157 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForInitialCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,163 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_R, titleKey=random, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2013-01-16 21:50:52,169 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListRandomSongsCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=no_cache
2013-01-16 21:50:52,175 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_PL, titleKey=playlists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-16 21:50:52,181 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioPlaylistsCommand, containerClass=PLAYLIST_CONTAINER, itemClass=null, idPrefix=PL, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,188 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForPlaylistCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,194 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_OF, titleKey=online, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2013-01-16 21:50:52,200 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioOnlineContentCommand, containerClass=STORAGE_FOLDER, itemClass=MUSIC_TRACK, idPrefix=FOL, recursive=true, cacheRegion=no_cache
2013-01-16 21:50:52,207 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_S, titleKey=All songs, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2013-01-16 21:50:52,212 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAllSongsCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,218 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_AS, titleKey=Artist Songs, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2013-01-16 21:50:52,224 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistsByNameCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART_S, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,230 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForArtistCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,236 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_ALB, titleKey=All albums, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2013-01-16 21:50:52,243 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAllAlbumsCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,249 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,255 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I, titleKey=image, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2013-01-16 21:50:52,261 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_A, titleKey=albums, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-16 21:50:52,268 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListFlatImageFoldersByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,274 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForFolderCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,279 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-16 21:50:52,287 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImageFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=PHOTO, idPrefix=FOL, recursive=true, cacheRegion=local_default
2013-01-16 21:50:52,293 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_Y, titleKey=year, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-16 21:50:52,300 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=YEAR, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,305 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForCreationYearCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,312 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_T, titleKey=month, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-16 21:50:52,318 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=YEAR, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,324 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationMonthsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=MON, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,330 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForCreationMonthAndYearCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,337 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_PL, titleKey=playlists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-16 21:50:52,343 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagePlaylistsCommand, containerClass=PLAYLIST_CONTAINER, itemClass=null, idPrefix=PL, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,349 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForPlaylistCommand, containerClass=null, itemClass=PHOTO, idPrefix=S, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,355 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_OF, titleKey=online, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2013-01-16 21:50:52,361 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImageOnlineContentCommand, containerClass=STORAGE_FOLDER, itemClass=PHOTO, idPrefix=FOL, recursive=true, cacheRegion=no_cache
2013-01-16 21:50:52,368 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_AI, titleKey=All images, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2013-01-16 21:50:52,374 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListAllImagesCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,380 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V, titleKey=video, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2013-01-16 21:50:52,386 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_T, titleKey=titles, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-16 21:50:52,394 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,400 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForInitialCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,408 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_M, titleKey=movies, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-16 21:50:52,414 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListMovieVideosByNameCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,420 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_S, titleKey=series, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-16 21:50:52,426 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListSeriesByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=SER, recursive=false, cacheRegion=local_resetafterplay
2013-01-16 21:50:52,432 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListSeasonsForSeriesCommand, containerClass=CONTAINER, itemClass=null, idPrefix=SSN, recursive=false, cacheRegion=local_resetafterplay
2013-01-16 21:50:52,438 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListEpisodesForSeriesSeasonCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_resetafterplay
2013-01-16 21:50:52,444 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-16 21:50:52,452 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=VIDEO_ITEM, idPrefix=FOL, recursive=true, cacheRegion=local_default
2013-01-16 21:50:52,458 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_LV, titleKey=last_viewed, class=CONTAINER, cacheRegion=local_resetafterplay, browsable = null, editable = true
2013-01-16 21:50:52,465 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListLastViewedVideosCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_resetafterplay
2013-01-16 21:50:52,471 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_LA, titleKey=last_added, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-16 21:50:52,478 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListLastAddedVideosCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,484 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_G, titleKey=genres, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-16 21:50:52,492 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoGenresByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=GEN, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,498 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForGenreCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,505 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_A, titleKey=actors, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-16 21:50:52,511 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListActorInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,518 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListActorsForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,524 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForActorCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,531 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_D, titleKey=directors, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-16 21:50:52,537 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListDirectorInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,544 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListDirectorsForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,551 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForDirectorCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,557 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_P, titleKey=producers, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-16 21:50:52,564 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducerInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,570 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducersForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,578 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForProducerCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,584 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_PL, titleKey=playlists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-01-16 21:50:52,593 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoPlaylistsCommand, containerClass=PLAYLIST_CONTAINER, itemClass=null, idPrefix=PL, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,599 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForPlaylistCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=S, recursive=false, cacheRegion=local_default
2013-01-16 21:50:52,606 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_OF, titleKey=online, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2013-01-16 21:50:52,613 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoOnlineContentCommand, containerClass=STORAGE_FOLDER, itemClass=VIDEO_ITEM, idPrefix=FOL, recursive=true, cacheRegion=no_cache
2013-01-16 21:50:52,617 INFO  [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: es
2013-01-16 21:50:53,185 DEBUG [RepositoryDAOImpl] Reading all Repositories
2013-01-16 21:50:53,186 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups for Repository (id = 1)
2013-01-16 21:50:53,187 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-01-16 21:50:53,252 DEBUG [ServiioConsole] Reading application data
2013-01-16 21:50:53,252 DEBUG [RepositoryView$LibraryStatusCheckerThread] Starting library status checking thread
2013-01-16 21:50:53,694 DEBUG [DiscoveryAdvertisementNotifier] Found 1 network interfaces to advertise on
2013-01-16 21:50:53,694 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.1.25, timeout = 0
2013-01-16 21:50:53,694 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device df29ffd2-c48d-3270-8b52-589b786ca617
2013-01-16 21:50:55,494 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:07 (advertisement duration is 1800 sec.)
2013-01-16 21:51:03,684 DEBUG [DiscoveryAdvertisementNotifier] Found 1 network interfaces to advertise on
2013-01-16 21:51:03,684 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.1.25, timeout = 0
2013-01-16 21:51:03,684 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device df29ffd2-c48d-3270-8b52-589b786ca617
2013-01-16 21:51:05,484 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:04:00 (advertisement duration is 1800 sec.)
2013-01-16 21:51:09,787 INFO  [FeedUpdaterThread] Started looking for information about online resources
2013-01-16 21:51:09,788 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-01-16 21:51:09,788 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-01-16 21:51:09,788 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2013-01-16 21:51:09,788 DEBUG [RepositoryDAOImpl] Reading all Repositories
2013-01-16 21:51:09,789 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2013-01-16 21:51:09,789 DEBUG [RepositoryDAOImpl] Reading all Repositories
2013-01-16 21:51:09,789 INFO  [PlaylistMaintainerThread] Started looking playlist changes
2013-01-16 21:51:09,792 DEBUG [PlaylistDAOImpl] Reading all Playlists
2013-01-16 21:51:09,792 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Peliculas
2013-01-16 21:51:09,793 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Peliculas\Alta Definicion
2013-01-16 21:51:09,793 DEBUG [LibraryUpdatesCheckerThread] Looking for removed playlist files in repository: D:\Peliculas
2013-01-16 21:51:09,793 DEBUG [PlaylistDAOImpl] Reading Playlists for Repository (id = 1)
2013-01-16 21:51:09,793 DEBUG [LibraryAdditionsCheckerThread] Found file 'Contagio [DVDrip][AC3 5.1 Español Castellano][2011][www.newpct.com].avi', checking if it's already in the Library
2013-01-16 21:51:09,795 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Contagio [DVDrip][AC3 5.1 Español Castellano][2011][www.newpct.com].avi
2013-01-16 21:51:09,795 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Peliculas\Contagio [DVDrip][AC3 5.1 Español Castellano][2011][www.newpct.com].avi, ignore case: true
2013-01-16 21:51:09,810 DEBUG [LibraryUpdatesCheckerThread] Looking for removed/updated files in repository: D:\Peliculas
2013-01-16 21:51:09,811 DEBUG [MediaItemDAOImpl] Reading MediaItems for Repository (id = 1)
2013-01-16 21:51:09,838 DEBUG [MediaItemDAOImpl] Media item Contagio [DVDrip][AC3 5.1 Español Castellano][2011][www.newpct.com].avi already exists in DB
2013-01-16 21:51:09,839 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Peliculas\La chaqueta metálica [MicroHD][1080 px][AC3 5.1-Castellano-Ingles+Subs]
2013-01-16 21:51:09,839 DEBUG [LibraryAdditionsCheckerThread] Found file 'La Chaqueta Metálica [www.newpct.com][toni32].mkv', checking if it's already in the Library
2013-01-16 21:51:09,839 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item La Chaqueta Metálica [www.newpct.com][toni32].mkv
2013-01-16 21:51:09,839 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Peliculas\La chaqueta metálica [MicroHD][1080 px][AC3 5.1-Castellano-Ingles+Subs]\La Chaqueta Metálica [www.newpct.com][toni32].mkv, ignore case: true
2013-01-16 21:51:09,840 DEBUG [MediaItemDAOImpl] Media item La Chaqueta Metálica [www.newpct.com][toni32].mkv already exists in DB
2013-01-16 21:51:09,840 DEBUG [LibraryAdditionsCheckerThread] Found file 'Lo Imposible [DVDScreener]www.newpct.com.avi', checking if it's already in the Library
2013-01-16 21:51:09,841 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Lo Imposible [DVDScreener]www.newpct.com.avi
2013-01-16 21:51:09,841 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Peliculas\Lo Imposible [DVDScreener]www.newpct.com.avi, ignore case: true
2013-01-16 21:51:09,841 DEBUG [MediaItemDAOImpl] Media item Lo Imposible [DVDScreener]www.newpct.com.avi already exists in DB
2013-01-16 21:51:09,842 DEBUG [LibraryAdditionsCheckerThread] Found file 'Los juegos del hambre.avi', checking if it's already in the Library
2013-01-16 21:51:09,842 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Los juegos del hambre.avi
2013-01-16 21:51:09,842 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Peliculas\Los juegos del hambre.avi, ignore case: true
2013-01-16 21:51:09,842 DEBUG [MediaItemDAOImpl] Media item Los juegos del hambre.avi already exists in DB
2013-01-16 21:51:09,843 DEBUG [LibraryAdditionsCheckerThread] Found file 'Los vengadores.avi', checking if it's already in the Library
2013-01-16 21:51:09,843 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Los vengadores.avi
2013-01-16 21:51:09,843 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Peliculas\Los vengadores.avi, ignore case: true
2013-01-16 21:51:09,843 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2013-01-16 21:51:09,843 DEBUG [MediaItemDAOImpl] Media item Los vengadores.avi already exists in DB
2013-01-16 21:51:09,844 DEBUG [LibraryAdditionsCheckerThread] Found file 'Prometheus [DVDrip][AC3 5.1 Español Castellano][2012][www.newpct.com].avi', checking if it's already in the Library
2013-01-16 21:51:09,844 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Prometheus [DVDrip][AC3 5.1 Español Castellano][2012][www.newpct.com].avi
2013-01-16 21:51:09,844 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Peliculas\Prometheus [DVDrip][AC3 5.1 Español Castellano][2012][www.newpct.com].avi, ignore case: true
2013-01-16 21:51:09,845 DEBUG [MediaItemDAOImpl] Media item Prometheus [DVDrip][AC3 5.1 Español Castellano][2012][www.newpct.com].avi already exists in DB
2013-01-16 21:51:09,845 DEBUG [LibraryAdditionsCheckerThread] Found file 'Safe [BluRayRIP][Español Castellano Ac3 5.1][2012][www.newpct.com].avi', checking if it's already in the Library
2013-01-16 21:51:09,845 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Safe [BluRayRIP][Español Castellano Ac3 5.1][2012][www.newpct.com].avi
2013-01-16 21:51:09,845 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Peliculas\Safe [BluRayRIP][Español Castellano Ac3 5.1][2012][www.newpct.com].avi, ignore case: true
2013-01-16 21:51:09,846 DEBUG [MediaItemDAOImpl] Media item Safe [BluRayRIP][Español Castellano Ac3 5.1][2012][www.newpct.com].avi already exists in DB
2013-01-16 21:51:09,846 DEBUG [LibraryAdditionsCheckerThread] Found file 'Ted [BluRayRIP][Español Castellano][2012][www.newpct.com].avi', checking if it's already in the Library
2013-01-16 21:51:09,846 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Ted [BluRayRIP][Español Castellano][2012][www.newpct.com].avi
2013-01-16 21:51:09,846 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Peliculas\Ted [BluRayRIP][Español Castellano][2012][www.newpct.com].avi, ignore case: true
2013-01-16 21:51:09,847 DEBUG [MediaItemDAOImpl] Media item Ted [BluRayRIP][Español Castellano][2012][www.newpct.com].avi already exists in DB
2013-01-16 21:51:09,847 DEBUG [LibraryAdditionsCheckerThread] Found file 'The Mechanic [DVDRIP][Español Castellano][www.newpct.com].avi', checking if it's already in the Library
2013-01-16 21:51:09,847 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item The Mechanic [DVDRIP][Español Castellano][www.newpct.com].avi
2013-01-16 21:51:09,847 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Peliculas\The Mechanic [DVDRIP][Español Castellano][www.newpct.com].avi, ignore case: true
2013-01-16 21:51:09,848 DEBUG [MediaItemDAOImpl] Media item The Mechanic [DVDRIP][Español Castellano][www.newpct.com].avi already exists in DB
The error appearing on tv says "video data invalid" and freezes on this screen so i have to un-plug it (but this is the first time i've to do that)
vaki
Post Wed Jan 16, 2013 9:14 pm
Re: file does not play on B651T3W
second part:
2013-01-16 21:51:09,848 DEBUG [RepositoryDAOImpl] Marking Repository 1 as scanned with current timestamp
2013-01-16 21:51:09,951 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type AUDIO
2013-01-16 21:51:09,955 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type VIDEO
2013-01-16 21:51:09,956 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type IMAGE
2013-01-16 21:51:09,960 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1) and extractor EMBEDDED
2013-01-16 21:51:09,985 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1) and extractor COVER_IMAGE_IN_FOLDER
2013-01-16 21:51:09,987 DEBUG [MediaItemDAOImpl] Getting file of media item 2
2013-01-16 21:51:09,987 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 2) and extractor EMBEDDED
2013-01-16 21:51:09,988 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 2) and extractor COVER_IMAGE_IN_FOLDER
2013-01-16 21:51:09,990 DEBUG [MediaItemDAOImpl] Getting file of media item 3
2013-01-16 21:51:09,990 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3) and extractor EMBEDDED
2013-01-16 21:51:09,991 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3) and extractor COVER_IMAGE_IN_FOLDER
2013-01-16 21:51:09,992 DEBUG [MediaItemDAOImpl] Getting file of media item 4
2013-01-16 21:51:09,993 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 4) and extractor EMBEDDED
2013-01-16 21:51:09,993 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 4) and extractor COVER_IMAGE_IN_FOLDER
2013-01-16 21:51:09,995 DEBUG [MediaItemDAOImpl] Getting file of media item 5
2013-01-16 21:51:09,995 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 5) and extractor EMBEDDED
2013-01-16 21:51:09,996 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 5) and extractor COVER_IMAGE_IN_FOLDER
2013-01-16 21:51:09,997 DEBUG [MediaItemDAOImpl] Getting file of media item 6
2013-01-16 21:51:09,998 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 6) and extractor EMBEDDED
2013-01-16 21:51:09,998 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 6) and extractor COVER_IMAGE_IN_FOLDER
2013-01-16 21:51:09,999 DEBUG [MediaItemDAOImpl] Getting file of media item 7
2013-01-16 21:51:10,000 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7) and extractor EMBEDDED
2013-01-16 21:51:10,001 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7) and extractor COVER_IMAGE_IN_FOLDER
2013-01-16 21:51:10,002 DEBUG [MediaItemDAOImpl] Getting file of media item 94
2013-01-16 21:51:10,003 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 94) and extractor EMBEDDED
2013-01-16 21:51:10,004 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 94) and extractor COVER_IMAGE_IN_FOLDER
2013-01-16 21:51:10,006 DEBUG [MediaItemDAOImpl] Getting file of media item 95
2013-01-16 21:51:10,007 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 95) and extractor EMBEDDED
2013-01-16 21:51:10,008 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 95) and extractor COVER_IMAGE_IN_FOLDER
2013-01-16 21:51:10,009 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 1)
2013-01-16 21:51:10,028 DEBUG [RepositoryDAOImpl] Marking Repository 1 as scanned with current timestamp
2013-01-16 21:51:27,809 DEBUG [WebServer] Incoming connection from /192.168.1.40:4932
2013-01-16 21:51:27,811 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:27,812 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.40:
2013-01-16 21:51:27,812 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:28,048 DEBUG [ContentDirectory] Browse() called for renderer Samsung DTV DMR (profile 2) with parameters: objectID = 0, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2013-01-16 21:51:28,048 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-01-16 21:51:28,113 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-01-16 21:51:28,119 DEBUG [WebServer] Incoming connection from /192.168.1.40:4933
2013-01-16 21:51:28,119 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:28,120 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.40:
2013-01-16 21:51:28,120 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:28,124 DEBUG [ContentDirectory] Browse() called for renderer Samsung DTV DMR (profile 2) with parameters: objectID = 0, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 0, count = 20, sortCriteria =
2013-01-16 21:51:28,124 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-01-16 21:51:28,133 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-01-16 21:51:28,333 DEBUG [WebServer] Incoming connection from /192.168.1.40:4934
2013-01-16 21:51:28,334 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:28,335 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.40:
2013-01-16 21:51:28,335 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:28,339 DEBUG [ContentDirectory] Browse() called for renderer Samsung DTV DMR (profile 2) with parameters: objectID = 0, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 0, count = 1, sortCriteria =
2013-01-16 21:51:28,339 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-01-16 21:51:28,345 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-01-16 21:51:28,353 DEBUG [WebServer] Incoming connection from /192.168.1.40:4935
2013-01-16 21:51:28,354 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:28,355 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.40:
2013-01-16 21:51:28,355 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:28,360 DEBUG [ContentDirectory] Browse() called for renderer Samsung DTV DMR (profile 2) with parameters: objectID = 0, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 1, count = 1, sortCriteria =
2013-01-16 21:51:28,360 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-01-16 21:51:28,365 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-01-16 21:51:28,375 DEBUG [WebServer] Incoming connection from /192.168.1.40:4936
2013-01-16 21:51:28,375 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:28,376 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.40:
2013-01-16 21:51:28,376 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:28,381 DEBUG [ContentDirectory] Browse() called for renderer Samsung DTV DMR (profile 2) with parameters: objectID = 0, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 2, count = 1, sortCriteria =
2013-01-16 21:51:28,381 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-01-16 21:51:28,386 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-01-16 21:51:29,712 DEBUG [WebServer] Incoming connection from /192.168.1.40:4937
2013-01-16 21:51:29,714 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:29,715 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.40:
2013-01-16 21:51:29,715 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:29,720 DEBUG [ContentDirectory] Browse() called for renderer Samsung DTV DMR (profile 2) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2013-01-16 21:51:29,720 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-01-16 21:51:29,729 DEBUG [VideoDAOImpl] Retrieving number of video initials [No_Restriction]
2013-01-16 21:51:29,763 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-01-16 21:51:29,770 DEBUG [WebServer] Incoming connection from /192.168.1.40:4938
2013-01-16 21:51:29,771 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:29,772 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.40:
2013-01-16 21:51:29,772 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:29,776 DEBUG [ContentDirectory] Browse() called for renderer Samsung DTV DMR (profile 2) with parameters: objectID = V, browseFlag = BrowseMetadata, filter = @parentID, startIndex = 0, count = 0, sortCriteria =
2013-01-16 21:51:29,776 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-01-16 21:51:29,781 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-01-16 21:51:29,786 DEBUG [WebServer] Incoming connection from /192.168.1.40:4939
2013-01-16 21:51:29,787 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:29,788 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.40:
2013-01-16 21:51:29,788 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
vaki
Post Wed Jan 16, 2013 9:15 pm
thrid part!!
2013-01-16 21:51:29,792 DEBUG [ContentDirectory] Browse() called for renderer Samsung DTV DMR (profile 2) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 0, count = 20, sortCriteria =
2013-01-16 21:51:29,792 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-01-16 21:51:29,793 DEBUG [VideoDAOImpl] Retrieving number of video initials [No_Restriction]
2013-01-16 21:51:29,800 DEBUG [VideoDAOImpl] Retrieving number of videos of type 2 [No_Restriction]
2013-01-16 21:51:29,829 DEBUG [SeriesDAOImpl] Retrieving number of series
2013-01-16 21:51:29,854 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [No_Restriction]
2013-01-16 21:51:29,873 DEBUG [VideoDAOImpl] Retrieving number of 10 last viewed videos [No_Restriction]
2013-01-16 21:51:29,897 DEBUG [VideoDAOImpl] Retrieving number of 10 last added videos
2013-01-16 21:51:29,897 DEBUG [VideoDAOImpl] Retrieving number of videos of type 0 [No_Restriction]
2013-01-16 21:51:29,920 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2013-01-16 21:51:29,968 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2013-01-16 21:51:29,993 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-01-16 21:51:32,222 DEBUG [WebServer] Incoming connection from /192.168.1.40:4940
2013-01-16 21:51:32,223 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:32,223 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.40:
2013-01-16 21:51:32,227 DEBUG [ContentDirectory] Browse() called for renderer Samsung DTV DMR (profile 2) with parameters: objectID = V_M, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2013-01-16 21:51:32,227 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-01-16 21:51:32,228 DEBUG [VideoDAOImpl] Retrieving list of videos of type 2 (from=0, count=1) [No_Restriction]
2013-01-16 21:51:32,277 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2013-01-16 21:51:32,310 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2013-01-16 21:51:32,321 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2013-01-16 21:51:32,324 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2013-01-16 21:51:32,339 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1 and profile Samsung TV (B-series)
2013-01-16 21:51:32,351 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 1)
2013-01-16 21:51:32,407 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2013-01-16 21:51:32,408 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2013-01-16 21:51:32,409 DEBUG [VideoDAOImpl] Retrieving number of videos of type 2 [No_Restriction]
2013-01-16 21:51:32,413 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2013-01-16 21:51:32,421 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-01-16 21:51:32,431 DEBUG [WebServer] Incoming connection from /192.168.1.40:4941
2013-01-16 21:51:32,432 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:32,432 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.40:
2013-01-16 21:51:32,437 DEBUG [ContentDirectory] Browse() called for renderer Samsung DTV DMR (profile 2) with parameters: objectID = V_M, browseFlag = BrowseMetadata, filter = @parentID, startIndex = 0, count = 0, sortCriteria =
2013-01-16 21:51:32,437 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-01-16 21:51:32,437 DEBUG [VideoDAOImpl] Retrieving number of videos of type 2 [No_Restriction]
2013-01-16 21:51:32,441 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2013-01-16 21:51:32,445 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-01-16 21:51:32,452 DEBUG [WebServer] Incoming connection from /192.168.1.40:4942
2013-01-16 21:51:32,453 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:32,453 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.40:
2013-01-16 21:51:32,457 DEBUG [ContentDirectory] Browse() called for renderer Samsung DTV DMR (profile 2) with parameters: objectID = V_M, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 0, count = 20, sortCriteria =
2013-01-16 21:51:32,457 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-01-16 21:51:32,458 DEBUG [VideoDAOImpl] Retrieving list of videos of type 2 (from=0, count=20) [No_Restriction]
2013-01-16 21:51:32,494 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2013-01-16 21:51:32,495 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2013-01-16 21:51:32,495 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2013-01-16 21:51:32,496 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2013-01-16 21:51:32,496 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1 and profile Samsung TV (B-series)
2013-01-16 21:51:32,497 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 1)
2013-01-16 21:51:32,498 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2013-01-16 21:51:32,498 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2013-01-16 21:51:32,499 DEBUG [GenreDAOImpl] Reading a Genre (id = 3)
2013-01-16 21:51:32,499 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7)
2013-01-16 21:51:32,500 DEBUG [MediaItemDAOImpl] Getting file of media item 7
2013-01-16 21:51:32,500 DEBUG [VideoDAOImpl] Reading a Video (id = 7)
2013-01-16 21:51:32,501 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 7 and profile Samsung TV (B-series)
2013-01-16 21:51:32,501 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 7)
2013-01-16 21:51:32,502 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7)
2013-01-16 21:51:32,503 DEBUG [MediaItemDAOImpl] Getting file of media item 7
2013-01-16 21:51:32,503 DEBUG [GenreDAOImpl] Reading a Genre (id = 2)
2013-01-16 21:51:32,504 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2)
2013-01-16 21:51:32,504 DEBUG [MediaItemDAOImpl] Getting file of media item 2
2013-01-16 21:51:32,505 DEBUG [VideoDAOImpl] Reading a Video (id = 2)
2013-01-16 21:51:32,506 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 2 and profile Samsung TV (B-series)
2013-01-16 21:51:32,506 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 2)
2013-01-16 21:51:32,507 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2)
2013-01-16 21:51:32,508 DEBUG [MediaItemDAOImpl] Getting file of media item 2
2013-01-16 21:51:32,508 DEBUG [GenreDAOImpl] Reading a Genre (id = 3)
2013-01-16 21:51:32,509 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 3)
2013-01-16 21:51:32,509 DEBUG [MediaItemDAOImpl] Getting file of media item 3
2013-01-16 21:51:32,510 DEBUG [VideoDAOImpl] Reading a Video (id = 3)
2013-01-16 21:51:32,511 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 3 and profile Samsung TV (B-series)
2013-01-16 21:51:32,511 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 3)
2013-01-16 21:51:32,512 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 3)
2013-01-16 21:51:32,512 DEBUG [MediaItemDAOImpl] Getting file of media item 3
2013-01-16 21:51:32,513 DEBUG [GenreDAOImpl] Reading a Genre (id = 3)
2013-01-16 21:51:32,513 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 4)
2013-01-16 21:51:32,514 DEBUG [MediaItemDAOImpl] Getting file of media item 4
2013-01-16 21:51:32,514 DEBUG [VideoDAOImpl] Reading a Video (id = 4)
2013-01-16 21:51:32,515 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 4 and profile Samsung TV (B-series)
2013-01-16 21:51:32,515 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 4)
2013-01-16 21:51:32,516 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 4)
2013-01-16 21:51:32,517 DEBUG [MediaItemDAOImpl] Getting file of media item 4
2013-01-16 21:51:32,517 DEBUG [GenreDAOImpl] Reading a Genre (id = 3)
2013-01-16 21:51:32,518 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 5)
2013-01-16 21:51:32,518 DEBUG [MediaItemDAOImpl] Getting file of media item 5
2013-01-16 21:51:32,519 DEBUG [VideoDAOImpl] Reading a Video (id = 5)
2013-01-16 21:51:32,519 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 5 and profile Samsung TV (B-series)
2013-01-16 21:51:32,520 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 5)
2013-01-16 21:51:32,521 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 5)
2013-01-16 21:51:32,521 DEBUG [MediaItemDAOImpl] Getting file of media item 5
2013-01-16 21:51:32,522 DEBUG [GenreDAOImpl] Reading a Genre (id = 4)
2013-01-16 21:51:32,523 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6)
2013-01-16 21:51:32,523 DEBUG [MediaItemDAOImpl] Getting file of media item 6
2013-01-16 21:51:32,524 DEBUG [VideoDAOImpl] Reading a Video (id = 6)
2013-01-16 21:51:32,524 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 6 and profile Samsung TV (B-series)
2013-01-16 21:51:32,525 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 6)
2013-01-16 21:51:32,526 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6)
2013-01-16 21:51:32,527 DEBUG [MediaItemDAOImpl] Getting file of media item 6
2013-01-16 21:51:32,528 DEBUG [VideoDAOImpl] Retrieving number of videos of type 2 [No_Restriction]
2013-01-16 21:51:32,531 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2013-01-16 21:51:32,549 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-01-16 21:51:32,562 DEBUG [WebServer] Incoming connection from /192.168.1.40:4943
2013-01-16 21:51:32,562 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:32,563 DEBUG [ResourceTransportRequestHandler] GET /resource/4/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.25:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2013-01-16 21:51:32,563 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:32,567 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:32,569 DEBUG [ResourceDeliveryProcessor] Request for resource 4 and type 'COVER_IMAGE' received
2013-01-16 21:51:32,570 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 4)
2013-01-16 21:51:32,570 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 4
2013-01-16 21:51:32,572 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 4)
2013-01-16 21:51:32,572 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 4
2013-01-16 21:51:32,573 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 3792
2013-01-16 21:51:32,573 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:32,574 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 3792,Date: Wed, 16 Jan 2013 20:51:32 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:32,584 DEBUG [WebServer] Incoming connection from /192.168.1.40:4944
2013-01-16 21:51:32,585 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:32,586 DEBUG [ResourceTransportRequestHandler] GET /resource/5/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.25:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2013-01-16 21:51:32,586 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:32,586 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:32,586 DEBUG [ResourceDeliveryProcessor] Request for resource 5 and type 'COVER_IMAGE' received
2013-01-16 21:51:32,586 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 5)
2013-01-16 21:51:32,587 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 5
2013-01-16 21:51:32,587 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 5)
2013-01-16 21:51:32,588 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 5
2013-01-16 21:51:32,588 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 6491
2013-01-16 21:51:32,588 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:32,588 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 6491,Date: Wed, 16 Jan 2013 20:51:32 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:32,598 DEBUG [WebServer] Incoming connection from /192.168.1.40:4945
2013-01-16 21:51:32,599 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:32,600 DEBUG [ResourceTransportRequestHandler] GET /resource/6/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.25:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2013-01-16 21:51:32,600 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:32,600 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:32,601 DEBUG [ResourceDeliveryProcessor] Request for resource 6 and type 'COVER_IMAGE' received
2013-01-16 21:51:32,601 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 6)
2013-01-16 21:51:32,601 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 6
2013-01-16 21:51:32,602 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 6
2013-01-16 21:51:32,602 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 4483
2013-01-16 21:51:32,602 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:32,602 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 4483,Date: Wed, 16 Jan 2013 20:51:32 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:32,613 DEBUG [WebServer] Incoming connection from /192.168.1.40:4946
2013-01-16 21:51:32,613 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:32,614 DEBUG [ResourceTransportRequestHandler] GET /resource/1/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.25:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2013-01-16 21:51:32,614 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:32,614 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:32,615 DEBUG [ResourceDeliveryProcessor] Request for resource 1 and type 'COVER_IMAGE' received
2013-01-16 21:51:32,615 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 1)
2013-01-16 21:51:32,615 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 1
2013-01-16 21:51:32,616 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 1
2013-01-16 21:51:32,616 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 6153
2013-01-16 21:51:32,616 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:32,616 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 6153,Date: Wed, 16 Jan 2013 20:51:32 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:32,628 DEBUG [WebServer] Incoming connection from /192.168.1.40:4947
2013-01-16 21:51:32,628 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:32,629 DEBUG [ResourceTransportRequestHandler] GET /resource/7/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.25:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2013-01-16 21:51:32,629 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:32,629 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:32,630 DEBUG [ResourceDeliveryProcessor] Request for resource 7 and type 'COVER_IMAGE' received
2013-01-16 21:51:32,630 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 7)
2013-01-16 21:51:32,630 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 7
2013-01-16 21:51:32,631 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 7
2013-01-16 21:51:32,631 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 4737
2013-01-16 21:51:32,631 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:32,631 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 4737,Date: Wed, 16 Jan 2013 20:51:32 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:32,640 DEBUG [WebServer] Incoming connection from /192.168.1.40:4948
2013-01-16 21:51:32,641 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:32,641 DEBUG [ResourceTransportRequestHandler] GET /resource/2/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.25:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2013-01-16 21:51:32,642 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:32,642 DEBUG [ResourceDeliveryProcessor] Request for resource 2 and type 'COVER_IMAGE' received
2013-01-16 21:51:32,642 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 2)
2013-01-16 21:51:32,642 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 2
2013-01-16 21:51:32,643 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 2)
2013-01-16 21:51:32,643 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 2
2013-01-16 21:51:32,643 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 5853
2013-01-16 21:51:32,643 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:32,643 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 5853,Date: Wed, 16 Jan 2013 20:51:32 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:32,655 DEBUG [WebServer] Incoming connection from /192.168.1.40:4949
2013-01-16 21:51:32,655 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:32,656 DEBUG [ResourceTransportRequestHandler] GET /resource/3/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.25:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2013-01-16 21:51:32,656 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:32,656 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:32,657 DEBUG [ResourceDeliveryProcessor] Request for resource 3 and type 'COVER_IMAGE' received
2013-01-16 21:51:32,657 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 3)
2013-01-16 21:51:32,657 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 3
2013-01-16 21:51:32,658 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 3
2013-01-16 21:51:32,658 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 6519
2013-01-16 21:51:32,658 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:32,658 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 6519,Date: Wed, 16 Jan 2013 20:51:32 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:32,670 DEBUG [WebServer] Incoming connection from /192.168.1.40:4950
2013-01-16 21:51:32,670 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:32,670 DEBUG [ResourceTransportRequestHandler] GET /resource/4/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.25:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2013-01-16 21:51:32,671 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:32,671 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:32,671 DEBUG [ResourceDeliveryProcessor] Request for resource 4 and type 'COVER_IMAGE' received
2013-01-16 21:51:32,671 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 4)
2013-01-16 21:51:32,672 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 4
2013-01-16 21:51:32,672 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 4)
2013-01-16 21:51:32,672 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 4
2013-01-16 21:51:32,672 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 3792
2013-01-16 21:51:32,672 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:32,673 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 3792,Date: Wed, 16 Jan 2013 20:51:32 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:35,145 DEBUG [WebServer] Incoming connection from /192.168.1.40:4951
2013-01-16 21:51:35,145 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:35,146 DEBUG [ResourceTransportRequestHandler] GET /resource/2/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.25:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2013-01-16 21:51:35,146 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:35,147 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:35,147 DEBUG [ResourceDeliveryProcessor] Request for resource 2 and type 'COVER_IMAGE' received
2013-01-16 21:51:35,147 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 2)
2013-01-16 21:51:35,147 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 2
2013-01-16 21:51:35,148 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 2
2013-01-16 21:51:35,148 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 5853
2013-01-16 21:51:35,148 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:35,148 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 5853,Date: Wed, 16 Jan 2013 20:51:35 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:35,170 DEBUG [WebServer] Incoming connection from /192.168.1.40:4952
2013-01-16 21:51:35,171 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:35,171 DEBUG [ResourceTransportRequestHandler] GET /resource/3/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.25:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2013-01-16 21:51:35,172 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:35,172 DEBUG [ResourceDeliveryProcessor] Request for resource 3 and type 'COVER_IMAGE' received
2013-01-16 21:51:35,172 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 3)
2013-01-16 21:51:35,173 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 3
2013-01-16 21:51:35,173 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 3)
2013-01-16 21:51:35,174 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 3
2013-01-16 21:51:35,174 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 6519
2013-01-16 21:51:35,174 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:35,174 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 6519,Date: Wed, 16 Jan 2013 20:51:35 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:35,204 DEBUG [WebServer] Incoming connection from /192.168.1.40:4953
2013-01-16 21:51:35,204 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:35,205 DEBUG [ResourceTransportRequestHandler] GET /resource/3/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.25:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2013-01-16 21:51:35,205 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:35,206 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:35,206 DEBUG [ResourceDeliveryProcessor] Request for resource 3 and type 'COVER_IMAGE' received
2013-01-16 21:51:35,206 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 3)
2013-01-16 21:51:35,207 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 3
2013-01-16 21:51:35,207 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 3)
2013-01-16 21:51:35,207 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 3
2013-01-16 21:51:35,207 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 6519
2013-01-16 21:51:35,207 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:35,207 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 6519,Date: Wed, 16 Jan 2013 20:51:35 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:35,642 DEBUG [WebServer] Incoming connection from /192.168.1.40:4954
2013-01-16 21:51:35,642 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:35,643 DEBUG [ResourceTransportRequestHandler] GET /resource/7/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.25:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2013-01-16 21:51:35,643 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:35,644 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:35,644 DEBUG [ResourceDeliveryProcessor] Request for resource 7 and type 'COVER_IMAGE' received
2013-01-16 21:51:35,644 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 7)
2013-01-16 21:51:35,644 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 7
2013-01-16 21:51:35,645 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 7
2013-01-16 21:51:35,645 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 4737
2013-01-16 21:51:35,645 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:35,645 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 4737,Date: Wed, 16 Jan 2013 20:51:35 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:36,079 DEBUG [WebServer] Incoming connection from /192.168.1.40:4955
2013-01-16 21:51:36,080 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:36,080 DEBUG [ResourceTransportRequestHandler] GET /resource/1/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.25:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2013-01-16 21:51:36,081 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:36,081 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:36,081 DEBUG [ResourceDeliveryProcessor] Request for resource 1 and type 'COVER_IMAGE' received
2013-01-16 21:51:36,081 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 1)
2013-01-16 21:51:36,082 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 1
2013-01-16 21:51:36,082 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 1)
2013-01-16 21:51:36,082 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 1
2013-01-16 21:51:36,082 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 6153
2013-01-16 21:51:36,082 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:36,082 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 6153,Date: Wed, 16 Jan 2013 20:51:36 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:38,528 DEBUG [WebServer] Incoming connection from /192.168.1.40:4956
2013-01-16 21:51:38,528 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:38,529 DEBUG [ResourceTransportRequestHandler] GET /resource/6/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.25:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2013-01-16 21:51:38,529 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:38,530 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:38,530 DEBUG [ResourceDeliveryProcessor] Request for resource 6 and type 'COVER_IMAGE' received
2013-01-16 21:51:38,530 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 6)
2013-01-16 21:51:38,530 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 6
2013-01-16 21:51:38,531 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 6
2013-01-16 21:51:38,531 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 4483
2013-01-16 21:51:38,531 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:38,531 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 4483,Date: Wed, 16 Jan 2013 20:51:38 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:38,977 DEBUG [WebServer] Incoming connection from /192.168.1.40:4957
2013-01-16 21:51:38,978 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:38,978 DEBUG [ResourceTransportRequestHandler] GET /resource/5/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.25:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2013-01-16 21:51:38,979 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:38,979 DEBUG [ResourceDeliveryProcessor] Request for resource 5 and type 'COVER_IMAGE' received
2013-01-16 21:51:38,979 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 5)
2013-01-16 21:51:38,981 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 5
2013-01-16 21:51:38,981 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 5)
2013-01-16 21:51:38,982 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 5
2013-01-16 21:51:38,982 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 6491
2013-01-16 21:51:38,982 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:38,982 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 6491,Date: Wed, 16 Jan 2013 20:51:38 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:39,421 DEBUG [WebServer] Incoming connection from /192.168.1.40:4958
2013-01-16 21:51:39,421 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:39,422 DEBUG [ResourceTransportRequestHandler] GET /resource/4/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.25:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2013-01-16 21:51:39,422 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:39,422 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:39,422 DEBUG [ResourceDeliveryProcessor] Request for resource 4 and type 'COVER_IMAGE' received
2013-01-16 21:51:39,422 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 4)
2013-01-16 21:51:39,423 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 4
2013-01-16 21:51:39,423 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 4)
2013-01-16 21:51:39,423 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 4
2013-01-16 21:51:39,424 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 3792
2013-01-16 21:51:39,424 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:39,424 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 3792,Date: Wed, 16 Jan 2013 20:51:39 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:39,775 DEBUG [WebServer] Incoming connection from /192.168.1.40:4959
2013-01-16 21:51:39,775 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:39,776 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.40:
2013-01-16 21:51:39,776 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:39,780 DEBUG [ContentDirectory] Browse() called for renderer Samsung DTV DMR (profile 2) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2013-01-16 21:51:39,780 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-01-16 21:51:39,780 DEBUG [VideoDAOImpl] Retrieving number of video initials [No_Restriction]
2013-01-16 21:51:39,787 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-01-16 21:51:39,795 DEBUG [WebServer] Incoming connection from /192.168.1.40:4960
2013-01-16 21:51:39,795 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:39,796 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.40:
2013-01-16 21:51:39,796 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:39,799 DEBUG [ContentDirectory] Browse() called for renderer Samsung DTV DMR (profile 2) with parameters: objectID = V, browseFlag = BrowseMetadata, filter = @parentID, startIndex = 0, count = 0, sortCriteria =
2013-01-16 21:51:39,799 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-01-16 21:51:39,803 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-01-16 21:51:39,810 DEBUG [WebServer] Incoming connection from /192.168.1.40:4961
2013-01-16 21:51:39,811 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:39,811 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.40:
2013-01-16 21:51:39,815 DEBUG [ContentDirectory] Browse() called for renderer Samsung DTV DMR (profile 2) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 0, count = 20, sortCriteria =
2013-01-16 21:51:39,815 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-01-16 21:51:39,816 DEBUG [VideoDAOImpl] Retrieving number of video initials [No_Restriction]
2013-01-16 21:51:39,819 DEBUG [VideoDAOImpl] Retrieving number of videos of type 2 [No_Restriction]
2013-01-16 21:51:39,823 DEBUG [SeriesDAOImpl] Retrieving number of series
2013-01-16 21:51:39,823 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [No_Restriction]
2013-01-16 21:51:39,825 DEBUG [VideoDAOImpl] Retrieving number of 10 last viewed videos [No_Restriction]
2013-01-16 21:51:39,828 DEBUG [VideoDAOImpl] Retrieving number of 10 last added videos
2013-01-16 21:51:39,828 DEBUG [VideoDAOImpl] Retrieving number of videos of type 0 [No_Restriction]
2013-01-16 21:51:39,832 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2013-01-16 21:51:39,832 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2013-01-16 21:51:39,838 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-01-16 21:51:44,719 DEBUG [WebServer] Incoming connection from /192.168.1.40:4962
2013-01-16 21:51:44,721 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:44,721 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.40:
2013-01-16 21:51:44,722 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:44,725 DEBUG [ContentDirectory] Browse() called for renderer Samsung DTV DMR (profile 2) with parameters: objectID = V_F, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2013-01-16 21:51:44,725 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-01-16 21:51:44,726 DEBUG [RepositoryDAOImpl] Retrieving list of Repositories for VIDEO (from=0, count=1) [No_Restriction]
2013-01-16 21:51:44,743 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root' (filter: ALL) [No_Restriction]
2013-01-16 21:51:44,840 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [No_Restriction]
2013-01-16 21:51:44,841 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2013-01-16 21:51:44,845 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-01-16 21:51:44,853 DEBUG [WebServer] Incoming connection from /192.168.1.40:4963
2013-01-16 21:51:44,854 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:44,854 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.40:
2013-01-16 21:51:44,859 DEBUG [ContentDirectory] Browse() called for renderer Samsung DTV DMR (profile 2) with parameters: objectID = V_F, browseFlag = BrowseMetadata, filter = @parentID, startIndex = 0, count = 0, sortCriteria =
2013-01-16 21:51:44,859 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-01-16 21:51:44,860 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [No_Restriction]
2013-01-16 21:51:44,862 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2013-01-16 21:51:44,865 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-01-16 21:51:44,872 DEBUG [WebServer] Incoming connection from /192.168.1.40:4964
2013-01-16 21:51:44,873 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:44,874 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.40:
2013-01-16 21:51:44,874 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:44,878 DEBUG [ContentDirectory] Browse() called for renderer Samsung DTV DMR (profile 2) with parameters: objectID = V_F, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 0, count = 20, sortCriteria =
2013-01-16 21:51:44,878 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-01-16 21:51:44,879 DEBUG [RepositoryDAOImpl] Retrieving list of Repositories for VIDEO (from=0, count=20) [No_Restriction]
2013-01-16 21:51:44,891 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root' (filter: ALL) [No_Restriction]
2013-01-16 21:51:44,896 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [No_Restriction]
2013-01-16 21:51:44,897 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2013-01-16 21:51:44,900 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-01-16 21:51:46,243 DEBUG [WebServer] Incoming connection from /192.168.1.40:3758
2013-01-16 21:51:46,243 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:46,244 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.40:
2013-01-16 21:51:46,244 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:46,247 DEBUG [ContentDirectory] Browse() called for renderer Samsung DTV DMR (profile 2) with parameters: objectID = V_F^FOL_R1, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2013-01-16 21:51:46,247 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-01-16 21:51:46,248 DEBUG [FolderDAOImpl] Getting number of sub-Folders in folder null [No_Restriction]
2013-01-16 21:51:46,261 DEBUG [FolderDAOImpl] Getting list of sub-Folders in folder null (from=0, count=1) [No_Restriction]
2013-01-16 21:51:46,277 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 15 (filter: ALL) [No_Restriction]
2013-01-16 21:51:46,301 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root' (filter: ALL) [No_Restriction]
2013-01-16 21:51:46,305 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2013-01-16 21:51:46,308 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-01-16 21:51:46,316 DEBUG [WebServer] Incoming connection from /192.168.1.40:3759
2013-01-16 21:51:46,317 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:46,318 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.40:
2013-01-16 21:51:46,318 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:46,323 DEBUG [ContentDirectory] Browse() called for renderer Samsung DTV DMR (profile 2) with parameters: objectID = V_F^FOL_R1, browseFlag = BrowseMetadata, filter = @parentID, startIndex = 0, count = 0, sortCriteria =
2013-01-16 21:51:46,324 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-01-16 21:51:46,324 DEBUG [RepositoryDAOImpl] Reading a Repository (id = 1)
2013-01-16 21:51:46,330 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root' (filter: ALL) [No_Restriction]
2013-01-16 21:51:46,334 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2013-01-16 21:51:46,337 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-01-16 21:51:46,342 DEBUG [WebServer] Incoming connection from /192.168.1.40:3760
2013-01-16 21:51:46,343 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:46,343 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.40:
2013-01-16 21:51:46,344 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:46,348 DEBUG [ContentDirectory] Browse() called for renderer Samsung DTV DMR (profile 2) with parameters: objectID = V_F^FOL_R1, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 0, count = 20, sortCriteria =
vaki
Post Wed Jan 16, 2013 9:16 pm
part four!
2013-01-16 21:51:46,348 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-01-16 21:51:46,349 DEBUG [FolderDAOImpl] Getting number of sub-Folders in folder null [No_Restriction]
2013-01-16 21:51:46,350 DEBUG [FolderDAOImpl] Getting list of sub-Folders in folder null (from=0, count=20) [No_Restriction]
2013-01-16 21:51:46,365 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 15 (filter: ALL) [No_Restriction]
2013-01-16 21:51:46,375 DEBUG [VideoDAOImpl] Retrieving list of videos for folder 1 (from=0, count=19) [No_Restriction]
2013-01-16 21:51:46,408 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2013-01-16 21:51:46,408 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2013-01-16 21:51:46,409 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2013-01-16 21:51:46,409 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2013-01-16 21:51:46,411 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1 and profile Samsung TV (B-series)
2013-01-16 21:51:46,411 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 1)
2013-01-16 21:51:46,412 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2013-01-16 21:51:46,413 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2013-01-16 21:51:46,414 DEBUG [GenreDAOImpl] Reading a Genre (id = 5)
2013-01-16 21:51:46,415 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 94)
2013-01-16 21:51:46,415 DEBUG [MediaItemDAOImpl] Getting file of media item 94
2013-01-16 21:51:46,416 DEBUG [VideoDAOImpl] Reading a Video (id = 94)
2013-01-16 21:51:46,417 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 94 and profile Samsung TV (B-series)
2013-01-16 21:51:46,418 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 94)
2013-01-16 21:51:46,419 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 94)
2013-01-16 21:51:46,420 DEBUG [MediaItemDAOImpl] Getting file of media item 94
2013-01-16 21:51:46,420 DEBUG [GenreDAOImpl] Reading a Genre (id = 2)
2013-01-16 21:51:46,421 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2)
2013-01-16 21:51:46,421 DEBUG [MediaItemDAOImpl] Getting file of media item 2
2013-01-16 21:51:46,422 DEBUG [VideoDAOImpl] Reading a Video (id = 2)
2013-01-16 21:51:46,423 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 2 and profile Samsung TV (B-series)
2013-01-16 21:51:46,423 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 2)
2013-01-16 21:51:46,424 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2)
2013-01-16 21:51:46,424 DEBUG [MediaItemDAOImpl] Getting file of media item 2
2013-01-16 21:51:46,425 DEBUG [GenreDAOImpl] Reading a Genre (id = 3)
2013-01-16 21:51:46,426 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 3)
2013-01-16 21:51:46,426 DEBUG [MediaItemDAOImpl] Getting file of media item 3
2013-01-16 21:51:46,427 DEBUG [VideoDAOImpl] Reading a Video (id = 3)
2013-01-16 21:51:46,428 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 3 and profile Samsung TV (B-series)
2013-01-16 21:51:46,428 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 3)
2013-01-16 21:51:46,429 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 3)
2013-01-16 21:51:46,430 DEBUG [MediaItemDAOImpl] Getting file of media item 3
2013-01-16 21:51:46,430 DEBUG [GenreDAOImpl] Reading a Genre (id = 3)
2013-01-16 21:51:46,431 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 4)
2013-01-16 21:51:46,431 DEBUG [MediaItemDAOImpl] Getting file of media item 4
2013-01-16 21:51:46,432 DEBUG [VideoDAOImpl] Reading a Video (id = 4)
2013-01-16 21:51:46,433 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 4 and profile Samsung TV (B-series)
2013-01-16 21:51:46,433 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 4)
2013-01-16 21:51:46,434 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 4)
2013-01-16 21:51:46,434 DEBUG [MediaItemDAOImpl] Getting file of media item 4
2013-01-16 21:51:46,435 DEBUG [GenreDAOImpl] Reading a Genre (id = 3)
2013-01-16 21:51:46,436 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 5)
2013-01-16 21:51:46,436 DEBUG [MediaItemDAOImpl] Getting file of media item 5
2013-01-16 21:51:46,437 DEBUG [VideoDAOImpl] Reading a Video (id = 5)
2013-01-16 21:51:46,438 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 5 and profile Samsung TV (B-series)
2013-01-16 21:51:46,438 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 5)
2013-01-16 21:51:46,439 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 5)
2013-01-16 21:51:46,440 DEBUG [MediaItemDAOImpl] Getting file of media item 5
2013-01-16 21:51:46,440 DEBUG [GenreDAOImpl] Reading a Genre (id = 4)
2013-01-16 21:51:46,441 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6)
2013-01-16 21:51:46,441 DEBUG [MediaItemDAOImpl] Getting file of media item 6
2013-01-16 21:51:46,442 DEBUG [VideoDAOImpl] Reading a Video (id = 6)
2013-01-16 21:51:46,443 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 6 and profile Samsung TV (B-series)
2013-01-16 21:51:46,443 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 6)
2013-01-16 21:51:46,444 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6)
2013-01-16 21:51:46,445 DEBUG [MediaItemDAOImpl] Getting file of media item 6
2013-01-16 21:51:46,446 DEBUG [GenreDAOImpl] Reading a Genre (id = 3)
2013-01-16 21:51:46,447 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7)
2013-01-16 21:51:46,447 DEBUG [MediaItemDAOImpl] Getting file of media item 7
2013-01-16 21:51:46,448 DEBUG [VideoDAOImpl] Reading a Video (id = 7)
2013-01-16 21:51:46,449 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 7 and profile Samsung TV (B-series)
2013-01-16 21:51:46,450 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 7)
2013-01-16 21:51:46,451 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7)
2013-01-16 21:51:46,452 DEBUG [MediaItemDAOImpl] Getting file of media item 7
2013-01-16 21:51:46,452 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root' (filter: ALL) [No_Restriction]
2013-01-16 21:51:46,457 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2013-01-16 21:51:46,471 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-01-16 21:51:46,484 DEBUG [WebServer] Incoming connection from /192.168.1.40:3761
2013-01-16 21:51:46,484 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:46,485 DEBUG [ResourceTransportRequestHandler] GET /resource/5/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.25:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2013-01-16 21:51:46,485 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:46,486 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:46,486 DEBUG [ResourceDeliveryProcessor] Request for resource 5 and type 'COVER_IMAGE' received
2013-01-16 21:51:46,486 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 5)
2013-01-16 21:51:46,489 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 5
2013-01-16 21:51:46,489 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 5)
2013-01-16 21:51:46,490 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 5
2013-01-16 21:51:46,490 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 6491
2013-01-16 21:51:46,490 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:46,490 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 6491,Date: Wed, 16 Jan 2013 20:51:46 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:46,500 DEBUG [WebServer] Incoming connection from /192.168.1.40:3762
2013-01-16 21:51:46,500 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:46,501 DEBUG [ResourceTransportRequestHandler] GET /resource/6/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.25:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2013-01-16 21:51:46,501 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:46,501 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:46,502 DEBUG [ResourceDeliveryProcessor] Request for resource 6 and type 'COVER_IMAGE' received
2013-01-16 21:51:46,502 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 6)
2013-01-16 21:51:46,502 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 6
2013-01-16 21:51:46,503 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 6
2013-01-16 21:51:46,503 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 4483
2013-01-16 21:51:46,503 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:46,503 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 4483,Date: Wed, 16 Jan 2013 20:51:46 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:46,513 DEBUG [WebServer] Incoming connection from /192.168.1.40:3763
2013-01-16 21:51:46,514 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:46,514 DEBUG [ResourceTransportRequestHandler] GET /resource/7/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.25:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2013-01-16 21:51:46,515 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:46,515 DEBUG [ResourceDeliveryProcessor] Request for resource 7 and type 'COVER_IMAGE' received
2013-01-16 21:51:46,515 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 7)
2013-01-16 21:51:46,515 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 7
2013-01-16 21:51:46,516 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 7)
2013-01-16 21:51:46,516 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 7
2013-01-16 21:51:46,516 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 4737
2013-01-16 21:51:46,516 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:46,516 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 4737,Date: Wed, 16 Jan 2013 20:51:46 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:46,526 DEBUG [WebServer] Incoming connection from /192.168.1.40:3764
2013-01-16 21:51:46,526 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:46,527 DEBUG [ResourceTransportRequestHandler] GET /resource/1/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.25:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2013-01-16 21:51:46,527 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:46,528 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:46,528 DEBUG [ResourceDeliveryProcessor] Request for resource 1 and type 'COVER_IMAGE' received
2013-01-16 21:51:46,528 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 1)
2013-01-16 21:51:46,528 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 1
2013-01-16 21:51:46,529 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 1
2013-01-16 21:51:46,529 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 6153
2013-01-16 21:51:46,529 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:46,529 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 6153,Date: Wed, 16 Jan 2013 20:51:46 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:46,541 DEBUG [WebServer] Incoming connection from /192.168.1.40:3765
2013-01-16 21:51:46,542 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:46,542 DEBUG [ResourceTransportRequestHandler] GET /resource/94/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.25:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2013-01-16 21:51:46,543 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:46,543 DEBUG [ResourceDeliveryProcessor] Request for resource 94 and type 'COVER_IMAGE' received
2013-01-16 21:51:46,543 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 94)
2013-01-16 21:51:46,543 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 94
2013-01-16 21:51:46,544 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 94)
2013-01-16 21:51:46,544 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 94
2013-01-16 21:51:46,544 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 2507
2013-01-16 21:51:46,544 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:46,544 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 2507,Date: Wed, 16 Jan 2013 20:51:46 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:46,553 DEBUG [WebServer] Incoming connection from /192.168.1.40:3766
2013-01-16 21:51:46,553 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:46,554 DEBUG [ResourceTransportRequestHandler] GET /resource/2/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.25:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2013-01-16 21:51:46,554 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:46,554 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:46,554 DEBUG [ResourceDeliveryProcessor] Request for resource 2 and type 'COVER_IMAGE' received
2013-01-16 21:51:46,554 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 2)
2013-01-16 21:51:46,555 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 2
2013-01-16 21:51:46,555 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 2)
2013-01-16 21:51:46,555 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 2
2013-01-16 21:51:46,555 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 5853
2013-01-16 21:51:46,555 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:46,556 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 5853,Date: Wed, 16 Jan 2013 20:51:46 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:46,565 DEBUG [WebServer] Incoming connection from /192.168.1.40:3767
2013-01-16 21:51:46,565 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:46,566 DEBUG [ResourceTransportRequestHandler] GET /resource/3/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.25:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2013-01-16 21:51:46,566 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:46,566 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:46,566 DEBUG [ResourceDeliveryProcessor] Request for resource 3 and type 'COVER_IMAGE' received
2013-01-16 21:51:46,566 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 3)
2013-01-16 21:51:46,567 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 3
2013-01-16 21:51:46,567 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 3)
2013-01-16 21:51:46,567 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 3
2013-01-16 21:51:46,567 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 6519
2013-01-16 21:51:46,567 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:46,567 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 6519,Date: Wed, 16 Jan 2013 20:51:46 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:47,623 DEBUG [WebServer] Incoming connection from /192.168.1.40:3768
2013-01-16 21:51:47,623 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:47,624 DEBUG [ResourceTransportRequestHandler] GET /resource/3/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.25:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2013-01-16 21:51:47,624 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:47,624 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:47,624 DEBUG [ResourceDeliveryProcessor] Request for resource 3 and type 'COVER_IMAGE' received
2013-01-16 21:51:47,625 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 3)
2013-01-16 21:51:47,625 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 3
2013-01-16 21:51:47,625 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 3
2013-01-16 21:51:47,626 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 6519
2013-01-16 21:51:47,626 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:47,626 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 6519,Date: Wed, 16 Jan 2013 20:51:47 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:48,223 DEBUG [WebServer] Incoming connection from /192.168.1.40:3769
2013-01-16 21:51:48,223 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:48,224 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.40:
2013-01-16 21:51:48,224 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:48,228 DEBUG [ContentDirectory] Browse() called for renderer Samsung DTV DMR (profile 2) with parameters: objectID = V_F^FOL_R1$F15, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2013-01-16 21:51:48,228 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-01-16 21:51:48,228 DEBUG [FolderDAOImpl] Getting number of sub-Folders in folder 15 [No_Restriction]
2013-01-16 21:51:48,239 DEBUG [VideoDAOImpl] Retrieving list of videos for folder 15 (from=0, count=1) [No_Restriction]
2013-01-16 21:51:48,266 DEBUG [GenreDAOImpl] Reading a Genre (id = 5)
2013-01-16 21:51:48,266 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:48,267 DEBUG [MediaItemDAOImpl] Getting file of media item 95
2013-01-16 21:51:48,267 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:48,268 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 95 and profile Samsung TV (B-series)
2013-01-16 21:51:48,269 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 95)
2013-01-16 21:51:48,269 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:48,270 DEBUG [MediaItemDAOImpl] Getting file of media item 95
2013-01-16 21:51:48,270 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 15 (filter: ALL) [No_Restriction]
2013-01-16 21:51:48,271 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2013-01-16 21:51:48,275 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-01-16 21:51:48,281 DEBUG [WebServer] Incoming connection from /192.168.1.40:3770
2013-01-16 21:51:48,281 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:48,282 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.40:
2013-01-16 21:51:48,282 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:48,285 DEBUG [ContentDirectory] Browse() called for renderer Samsung DTV DMR (profile 2) with parameters: objectID = V_F^FOL_R1$F15, browseFlag = BrowseMetadata, filter = @parentID, startIndex = 0, count = 0, sortCriteria =
2013-01-16 21:51:48,286 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-01-16 21:51:48,286 DEBUG [FolderDAOImpl] Reading a Folder (id = 15)
2013-01-16 21:51:48,291 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 15 (filter: ALL) [No_Restriction]
2013-01-16 21:51:48,294 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2013-01-16 21:51:48,297 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-01-16 21:51:48,303 DEBUG [WebServer] Incoming connection from /192.168.1.40:3771
2013-01-16 21:51:48,303 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:48,304 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.40:
2013-01-16 21:51:48,304 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:48,307 DEBUG [ContentDirectory] Browse() called for renderer Samsung DTV DMR (profile 2) with parameters: objectID = V_F^FOL_R1$F15, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 0, count = 20, sortCriteria =
2013-01-16 21:51:48,308 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2013-01-16 21:51:48,308 DEBUG [FolderDAOImpl] Getting number of sub-Folders in folder 15 [No_Restriction]
2013-01-16 21:51:48,309 DEBUG [VideoDAOImpl] Retrieving list of videos for folder 15 (from=0, count=20) [No_Restriction]
2013-01-16 21:51:48,336 DEBUG [GenreDAOImpl] Reading a Genre (id = 5)
2013-01-16 21:51:48,336 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:48,337 DEBUG [MediaItemDAOImpl] Getting file of media item 95
2013-01-16 21:51:48,337 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:48,338 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 95 and profile Samsung TV (B-series)
2013-01-16 21:51:48,339 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 95)
2013-01-16 21:51:48,340 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:48,340 DEBUG [MediaItemDAOImpl] Getting file of media item 95
2013-01-16 21:51:48,341 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 15 (filter: ALL) [No_Restriction]
2013-01-16 21:51:48,342 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2013-01-16 21:51:48,345 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-01-16 21:51:48,353 DEBUG [WebServer] Incoming connection from /192.168.1.40:3772
2013-01-16 21:51:48,353 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:48,354 DEBUG [ResourceTransportRequestHandler] GET /resource/95/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.25:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2013-01-16 21:51:48,354 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:48,354 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:48,354 DEBUG [ResourceDeliveryProcessor] Request for resource 95 and type 'COVER_IMAGE' received
2013-01-16 21:51:48,354 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 95)
2013-01-16 21:51:48,355 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 95
2013-01-16 21:51:48,355 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 95)
2013-01-16 21:51:48,355 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 95
2013-01-16 21:51:48,355 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 3629
2013-01-16 21:51:48,356 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:48,356 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 3629,Date: Wed, 16 Jan 2013 20:51:48 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:50,534 DEBUG [WebServer] Incoming connection from /192.168.1.40:3773
2013-01-16 21:51:50,534 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:50,535 DEBUG [ResourceTransportRequestHandler] HEAD /resource/95/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2013-01-16 21:51:50,535 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:50,535 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:50,536 DEBUG [ResourceDeliveryProcessor] Request for resource 95 and type 'MEDIA_ITEM' received
2013-01-16 21:51:50,536 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:50,536 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:50,537 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:50,538 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 95, format MATROSKA and profile Samsung TV (B-series)
2013-01-16 21:51:50,538 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:50,539 DEBUG [MediaItemDAOImpl] Getting file of media item 95
2013-01-16 21:51:50,540 DEBUG [ResourceDeliveryProcessor] Sending HEAD response back
2013-01-16 21:51:50,540 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/x-mkv,Content-Length: 4737169614,Date: Wed, 16 Jan 2013 20:51:50 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000]]
2013-01-16 21:51:50,586 DEBUG [WebServer] Incoming connection from /192.168.1.40:3341
2013-01-16 21:51:50,586 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:50,587 DEBUG [ResourceTransportRequestHandler] HEAD /resource/95/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,getMediaInfo.sec: 1,Host: 192.168.1.25:8895]]
2013-01-16 21:51:50,587 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:50,588 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:50,588 DEBUG [ResourceDeliveryProcessor] Request for resource 95 and type 'MEDIA_ITEM' received
2013-01-16 21:51:50,588 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:50,588 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:50,589 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:50,589 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 95, format MATROSKA and profile Samsung TV (B-series)
2013-01-16 21:51:50,590 DEBUG [ResourceDeliveryProcessor] Sending HEAD response back
2013-01-16 21:51:50,590 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/x-mkv,Content-Length: 4737169614,Date: Wed, 16 Jan 2013 20:51:50 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,MediaInfo.sec: SEC_Duration=6990000;]]
2013-01-16 21:51:50,601 DEBUG [WebServer] Incoming connection from /192.168.1.40:3593
2013-01-16 21:51:50,601 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:50,602 DEBUG [ResourceTransportRequestHandler] GET /resource/95/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=0-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.25:8895]]
2013-01-16 21:51:50,602 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:50,603 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:50,604 DEBUG [ResourceDeliveryProcessor] Request for resource 95 and type 'MEDIA_ITEM' received
2013-01-16 21:51:50,604 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:50,604 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:50,604 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:50,605 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 95, format MATROSKA and profile Samsung TV (B-series)
2013-01-16 21:51:50,606 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:50,606 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:50,606 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:50,607 DEBUG [VideoDeliveryEngine] Delivering item '95' for client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:50,607 DEBUG [VideoDeliveryEngine] Delivering file 'La Chaqueta Metálica [www.newpct.com][toni32].mkv' in native format
2013-01-16 21:51:50,607 DEBUG [MediaItemDAOImpl] Getting file of media item 95
2013-01-16 21:51:50,628 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 95) as read
2013-01-16 21:51:50,640 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-01-16 21:51:50,640 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 4737169614
2013-01-16 21:51:50,640 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:50,640 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Length: 4737169614,Date: Wed, 16 Jan 2013 20:51:50 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,Content-Range: bytes 0-4737169613/4737169614,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:50,658 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-01-16 21:51:50,659 DEBUG [WebServer] Incoming connection from /192.168.1.40:3713
2013-01-16 21:51:50,660 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:50,660 DEBUG [ResourceTransportRequestHandler] GET /resource/95/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=40-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.25:8895]]
2013-01-16 21:51:50,661 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:50,661 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:50,662 DEBUG [ResourceDeliveryProcessor] Request for resource 95 and type 'MEDIA_ITEM' received
2013-01-16 21:51:50,662 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:50,662 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:50,663 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:50,663 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 95, format MATROSKA and profile Samsung TV (B-series)
2013-01-16 21:51:50,664 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:50,664 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:50,665 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:50,665 DEBUG [VideoDeliveryEngine] Delivering item '95' for client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:50,666 DEBUG [VideoDeliveryEngine] Delivering file 'La Chaqueta Metálica [www.newpct.com][toni32].mkv' in native format
2013-01-16 21:51:50,666 DEBUG [MediaItemDAOImpl] Getting file of media item 95
2013-01-16 21:51:50,666 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 95) as read
2013-01-16 21:51:50,668 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-01-16 21:51:50,668 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 4737169574
2013-01-16 21:51:50,668 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:50,668 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Length: 4737169574,Date: Wed, 16 Jan 2013 20:51:50 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,Content-Range: bytes 40-4737169613/4737169614,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:50,688 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-01-16 21:51:50,690 DEBUG [WebServer] Incoming connection from /192.168.1.40:2204
2013-01-16 21:51:50,690 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:50,691 DEBUG [ResourceTransportRequestHandler] GET /resource/95/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=105-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.25:8895]]
2013-01-16 21:51:50,691 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:50,691 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:50,692 DEBUG [ResourceDeliveryProcessor] Request for resource 95 and type 'MEDIA_ITEM' received
2013-01-16 21:51:50,692 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:50,692 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:50,692 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:50,693 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 95, format MATROSKA and profile Samsung TV (B-series)
2013-01-16 21:51:50,693 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:50,693 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:50,694 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:50,694 DEBUG [VideoDeliveryEngine] Delivering item '95' for client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:50,695 DEBUG [VideoDeliveryEngine] Delivering file 'La Chaqueta Metálica [www.newpct.com][toni32].mkv' in native format
2013-01-16 21:51:50,695 DEBUG [MediaItemDAOImpl] Getting file of media item 95
2013-01-16 21:51:50,695 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 95) as read
2013-01-16 21:51:50,697 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-01-16 21:51:50,697 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 4737169509
2013-01-16 21:51:50,697 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:50,697 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Length: 4737169509,Date: Wed, 16 Jan 2013 20:51:50 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,Content-Range: bytes 105-4737169613/4737169614,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:50,714 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
vaki
Re: file does not play on B651T3W
part five
2013-01-16 21:51:50,716 DEBUG [WebServer] Incoming connection from /192.168.1.40:1327
2013-01-16 21:51:50,716 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:50,717 DEBUG [ResourceTransportRequestHandler] GET /resource/95/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=4151-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.25:8895]]
2013-01-16 21:51:50,717 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:50,717 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:50,718 DEBUG [ResourceDeliveryProcessor] Request for resource 95 and type 'MEDIA_ITEM' received
2013-01-16 21:51:50,718 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:50,718 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:50,719 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:50,720 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 95, format MATROSKA and profile Samsung TV (B-series)
2013-01-16 21:51:50,720 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:50,720 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:50,721 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:50,722 DEBUG [VideoDeliveryEngine] Delivering item '95' for client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:50,722 DEBUG [VideoDeliveryEngine] Delivering file 'La Chaqueta Metálica [www.newpct.com][toni32].mkv' in native format
2013-01-16 21:51:50,722 DEBUG [MediaItemDAOImpl] Getting file of media item 95
2013-01-16 21:51:50,723 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 95) as read
2013-01-16 21:51:50,724 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-01-16 21:51:50,724 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 4737165463
2013-01-16 21:51:50,724 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:50,725 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Length: 4737165463,Date: Wed, 16 Jan 2013 20:51:50 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,Content-Range: bytes 4151-4737169613/4737169614,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:50,741 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-01-16 21:51:50,743 DEBUG [WebServer] Incoming connection from /192.168.1.40:3292
2013-01-16 21:51:50,743 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:50,744 DEBUG [ResourceTransportRequestHandler] GET /resource/95/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=4353-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.25:8895]]
2013-01-16 21:51:50,744 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:50,745 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:50,745 DEBUG [ResourceDeliveryProcessor] Request for resource 95 and type 'MEDIA_ITEM' received
2013-01-16 21:51:50,745 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:50,745 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:50,745 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:50,746 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 95, format MATROSKA and profile Samsung TV (B-series)
2013-01-16 21:51:50,747 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:50,747 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:50,747 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:50,748 DEBUG [VideoDeliveryEngine] Delivering item '95' for client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:50,748 DEBUG [VideoDeliveryEngine] Delivering file 'La Chaqueta Metálica [www.newpct.com][toni32].mkv' in native format
2013-01-16 21:51:50,748 DEBUG [MediaItemDAOImpl] Getting file of media item 95
2013-01-16 21:51:50,749 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 95) as read
2013-01-16 21:51:50,750 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-01-16 21:51:50,750 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 4737165261
2013-01-16 21:51:50,751 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:50,752 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Length: 4737165261,Date: Wed, 16 Jan 2013 20:51:50 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,Content-Range: bytes 4353-4737169613/4737169614,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:50,770 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-01-16 21:51:50,772 DEBUG [WebServer] Incoming connection from /192.168.1.40:2391
2013-01-16 21:51:50,772 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:50,773 DEBUG [ResourceTransportRequestHandler] GET /resource/95/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=5122-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.25:8895]]
2013-01-16 21:51:50,773 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:50,773 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:50,773 DEBUG [ResourceDeliveryProcessor] Request for resource 95 and type 'MEDIA_ITEM' received
2013-01-16 21:51:50,773 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:50,773 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:50,774 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:50,775 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 95, format MATROSKA and profile Samsung TV (B-series)
2013-01-16 21:51:50,775 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:50,775 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:50,776 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:50,776 DEBUG [VideoDeliveryEngine] Delivering item '95' for client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:50,777 DEBUG [VideoDeliveryEngine] Delivering file 'La Chaqueta Metálica [www.newpct.com][toni32].mkv' in native format
2013-01-16 21:51:50,777 DEBUG [MediaItemDAOImpl] Getting file of media item 95
2013-01-16 21:51:50,778 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 95) as read
2013-01-16 21:51:50,779 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-01-16 21:51:50,779 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 4737164492
2013-01-16 21:51:50,779 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:50,779 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Length: 4737164492,Date: Wed, 16 Jan 2013 20:51:50 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,Content-Range: bytes 5122-4737169613/4737169614,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:50,796 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-01-16 21:51:50,797 DEBUG [WebServer] Incoming connection from /192.168.1.40:1496
2013-01-16 21:51:50,798 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:50,798 DEBUG [ResourceTransportRequestHandler] GET /resource/95/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=6431-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.25:8895]]
2013-01-16 21:51:50,799 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:50,799 DEBUG [ResourceDeliveryProcessor] Request for resource 95 and type 'MEDIA_ITEM' received
2013-01-16 21:51:50,799 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:50,799 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:50,800 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:50,800 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 95, format MATROSKA and profile Samsung TV (B-series)
2013-01-16 21:51:50,801 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:50,801 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:50,801 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:50,802 DEBUG [VideoDeliveryEngine] Delivering item '95' for client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:50,802 DEBUG [VideoDeliveryEngine] Delivering file 'La Chaqueta Metálica [www.newpct.com][toni32].mkv' in native format
2013-01-16 21:51:50,802 DEBUG [MediaItemDAOImpl] Getting file of media item 95
2013-01-16 21:51:50,803 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 95) as read
2013-01-16 21:51:50,805 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-01-16 21:51:50,805 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 4737163183
2013-01-16 21:51:50,805 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:50,805 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Length: 4737163183,Date: Wed, 16 Jan 2013 20:51:50 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,Content-Range: bytes 6431-4737169613/4737169614,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:50,822 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-01-16 21:51:50,824 DEBUG [WebServer] Incoming connection from /192.168.1.40:1181
2013-01-16 21:51:50,825 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:50,825 DEBUG [ResourceTransportRequestHandler] GET /resource/95/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=288098-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.25:8895]]
2013-01-16 21:51:50,826 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:50,826 DEBUG [ResourceDeliveryProcessor] Request for resource 95 and type 'MEDIA_ITEM' received
2013-01-16 21:51:50,826 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:50,826 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:50,827 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:50,827 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 95, format MATROSKA and profile Samsung TV (B-series)
2013-01-16 21:51:50,828 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:50,828 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:50,828 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:50,829 DEBUG [VideoDeliveryEngine] Delivering item '95' for client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:50,829 DEBUG [VideoDeliveryEngine] Delivering file 'La Chaqueta Metálica [www.newpct.com][toni32].mkv' in native format
2013-01-16 21:51:50,829 DEBUG [MediaItemDAOImpl] Getting file of media item 95
2013-01-16 21:51:50,830 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 95) as read
2013-01-16 21:51:50,832 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-01-16 21:51:50,832 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 4736881516
2013-01-16 21:51:50,832 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:50,832 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Length: 4736881516,Date: Wed, 16 Jan 2013 20:51:50 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,Content-Range: bytes 288098-4737169613/4737169614,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:50,850 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-01-16 21:51:50,852 DEBUG [WebServer] Incoming connection from /192.168.1.40:2019
2013-01-16 21:51:50,852 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:50,853 DEBUG [ResourceTransportRequestHandler] GET /resource/95/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=1797687-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.25:8895]]
2013-01-16 21:51:50,853 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:50,854 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:50,854 DEBUG [ResourceDeliveryProcessor] Request for resource 95 and type 'MEDIA_ITEM' received
2013-01-16 21:51:50,854 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:50,854 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:50,854 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:50,855 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 95, format MATROSKA and profile Samsung TV (B-series)
2013-01-16 21:51:50,855 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:50,855 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:50,856 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:50,857 DEBUG [VideoDeliveryEngine] Delivering item '95' for client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:50,857 DEBUG [VideoDeliveryEngine] Delivering file 'La Chaqueta Metálica [www.newpct.com][toni32].mkv' in native format
2013-01-16 21:51:50,857 DEBUG [MediaItemDAOImpl] Getting file of media item 95
2013-01-16 21:51:50,858 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 95) as read
2013-01-16 21:51:50,859 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-01-16 21:51:50,859 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 4735371927
2013-01-16 21:51:50,859 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:50,859 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Length: 4735371927,Date: Wed, 16 Jan 2013 20:51:50 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,Content-Range: bytes 1797687-4737169613/4737169614,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:50,894 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-01-16 21:51:50,895 DEBUG [WebServer] Incoming connection from /192.168.1.40:4827
2013-01-16 21:51:50,896 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:50,896 DEBUG [ResourceTransportRequestHandler] GET /resource/95/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=3300097-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.25:8895]]
2013-01-16 21:51:50,897 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:50,897 DEBUG [ResourceDeliveryProcessor] Request for resource 95 and type 'MEDIA_ITEM' received
2013-01-16 21:51:50,897 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:50,897 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:50,898 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:50,898 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 95, format MATROSKA and profile Samsung TV (B-series)
2013-01-16 21:51:50,899 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:50,899 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:50,899 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:50,900 DEBUG [VideoDeliveryEngine] Delivering item '95' for client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:50,900 DEBUG [VideoDeliveryEngine] Delivering file 'La Chaqueta Metálica [www.newpct.com][toni32].mkv' in native format
2013-01-16 21:51:50,900 DEBUG [MediaItemDAOImpl] Getting file of media item 95
2013-01-16 21:51:50,901 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 95) as read
2013-01-16 21:51:50,913 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-01-16 21:51:50,914 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 4733869517
2013-01-16 21:51:50,914 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:50,914 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Length: 4733869517,Date: Wed, 16 Jan 2013 20:51:50 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,Content-Range: bytes 3300097-4737169613/4737169614,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:50,949 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-01-16 21:51:50,950 DEBUG [WebServer] Incoming connection from /192.168.1.40:1421
2013-01-16 21:51:50,951 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:50,951 DEBUG [ResourceTransportRequestHandler] GET /resource/95/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=4832945-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.25:8895]]
2013-01-16 21:51:50,952 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:50,952 DEBUG [ResourceDeliveryProcessor] Request for resource 95 and type 'MEDIA_ITEM' received
2013-01-16 21:51:50,952 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:50,952 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:50,953 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:50,954 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 95, format MATROSKA and profile Samsung TV (B-series)
2013-01-16 21:51:50,954 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:50,954 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:50,955 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:50,956 DEBUG [VideoDeliveryEngine] Delivering item '95' for client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:50,956 DEBUG [VideoDeliveryEngine] Delivering file 'La Chaqueta Metálica [www.newpct.com][toni32].mkv' in native format
2013-01-16 21:51:50,956 DEBUG [MediaItemDAOImpl] Getting file of media item 95
2013-01-16 21:51:50,957 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 95) as read
2013-01-16 21:51:50,972 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-01-16 21:51:50,972 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 4732336669
2013-01-16 21:51:50,972 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:50,972 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Length: 4732336669,Date: Wed, 16 Jan 2013 20:51:50 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,Content-Range: bytes 4832945-4737169613/4737169614,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:51,004 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-01-16 21:51:51,005 DEBUG [WebServer] Incoming connection from /192.168.1.40:2538
2013-01-16 21:51:51,005 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:51,006 DEBUG [ResourceTransportRequestHandler] GET /resource/95/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=6350839-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.25:8895]]
2013-01-16 21:51:51,006 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:51,007 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:51,007 DEBUG [ResourceDeliveryProcessor] Request for resource 95 and type 'MEDIA_ITEM' received
2013-01-16 21:51:51,007 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:51,007 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:51,007 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:51,008 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 95, format MATROSKA and profile Samsung TV (B-series)
2013-01-16 21:51:51,009 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:51,009 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:51,009 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:51,010 DEBUG [VideoDeliveryEngine] Delivering item '95' for client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:51,010 DEBUG [VideoDeliveryEngine] Delivering file 'La Chaqueta Metálica [www.newpct.com][toni32].mkv' in native format
2013-01-16 21:51:51,010 DEBUG [MediaItemDAOImpl] Getting file of media item 95
2013-01-16 21:51:51,011 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 95) as read
2013-01-16 21:51:51,021 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-01-16 21:51:51,021 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 4730818775
2013-01-16 21:51:51,022 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:51,022 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Length: 4730818775,Date: Wed, 16 Jan 2013 20:51:51 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,Content-Range: bytes 6350839-4737169613/4737169614,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:51,056 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-01-16 21:51:51,057 DEBUG [WebServer] Incoming connection from /192.168.1.40:3237
2013-01-16 21:51:51,059 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:51,060 DEBUG [ResourceTransportRequestHandler] GET /resource/95/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=6671684-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.25:8895]]
2013-01-16 21:51:51,060 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:51,060 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:51,060 DEBUG [ResourceDeliveryProcessor] Request for resource 95 and type 'MEDIA_ITEM' received
2013-01-16 21:51:51,061 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:51,061 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:51,061 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:51,062 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 95, format MATROSKA and profile Samsung TV (B-series)
2013-01-16 21:51:51,062 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:51,062 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:51,063 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:51,063 DEBUG [VideoDeliveryEngine] Delivering item '95' for client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:51,064 DEBUG [VideoDeliveryEngine] Delivering file 'La Chaqueta Metálica [www.newpct.com][toni32].mkv' in native format
2013-01-16 21:51:51,064 DEBUG [MediaItemDAOImpl] Getting file of media item 95
2013-01-16 21:51:51,064 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 95) as read
2013-01-16 21:51:51,071 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-01-16 21:51:51,071 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 4730497930
2013-01-16 21:51:51,071 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:51,072 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Length: 4730497930,Date: Wed, 16 Jan 2013 20:51:51 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,Content-Range: bytes 6671684-4737169613/4737169614,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:51,094 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-01-16 21:51:51,096 DEBUG [WebServer] Incoming connection from /192.168.1.40:2216
2013-01-16 21:51:51,096 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:51,097 DEBUG [ResourceTransportRequestHandler] GET /resource/95/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=7466618-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.25:8895]]
2013-01-16 21:51:51,097 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:51,097 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:51,098 DEBUG [ResourceDeliveryProcessor] Request for resource 95 and type 'MEDIA_ITEM' received
2013-01-16 21:51:51,098 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:51,098 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:51,098 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:51,099 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 95, format MATROSKA and profile Samsung TV (B-series)
2013-01-16 21:51:51,099 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:51,099 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:51,100 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:51,101 DEBUG [VideoDeliveryEngine] Delivering item '95' for client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:51,101 DEBUG [VideoDeliveryEngine] Delivering file 'La Chaqueta Metálica [www.newpct.com][toni32].mkv' in native format
2013-01-16 21:51:51,101 DEBUG [MediaItemDAOImpl] Getting file of media item 95
2013-01-16 21:51:51,102 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 95) as read
2013-01-16 21:51:51,103 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-01-16 21:51:51,103 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 4729702996
2013-01-16 21:51:51,103 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:51,103 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Length: 4729702996,Date: Wed, 16 Jan 2013 20:51:51 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,Content-Range: bytes 7466618-4737169613/4737169614,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:51,135 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-01-16 21:51:51,137 DEBUG [WebServer] Incoming connection from /192.168.1.40:1410
2013-01-16 21:51:51,137 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:51,138 DEBUG [ResourceTransportRequestHandler] GET /resource/95/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=9007500-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.25:8895]]
2013-01-16 21:51:51,138 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:51,138 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:51,138 DEBUG [ResourceDeliveryProcessor] Request for resource 95 and type 'MEDIA_ITEM' received
2013-01-16 21:51:51,139 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:51,139 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:51,139 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:51,140 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 95, format MATROSKA and profile Samsung TV (B-series)
2013-01-16 21:51:51,140 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:51,140 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:51,141 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:51,142 DEBUG [VideoDeliveryEngine] Delivering item '95' for client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:51,142 DEBUG [VideoDeliveryEngine] Delivering file 'La Chaqueta Metálica [www.newpct.com][toni32].mkv' in native format
2013-01-16 21:51:51,142 DEBUG [MediaItemDAOImpl] Getting file of media item 95
2013-01-16 21:51:51,143 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 95) as read
2013-01-16 21:51:51,154 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-01-16 21:51:51,154 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 4728162114
2013-01-16 21:51:51,154 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:51,155 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Length: 4728162114,Date: Wed, 16 Jan 2013 20:51:51 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,Content-Range: bytes 9007500-4737169613/4737169614,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:51,181 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-01-16 21:51:51,183 DEBUG [WebServer] Incoming connection from /192.168.1.40:4524
2013-01-16 21:51:51,183 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:51,184 DEBUG [ResourceTransportRequestHandler] GET /resource/95/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=10486471-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.25:8895]]
2013-01-16 21:51:51,184 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:51,185 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:51,185 DEBUG [ResourceDeliveryProcessor] Request for resource 95 and type 'MEDIA_ITEM' received
2013-01-16 21:51:51,185 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:51,185 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:51,185 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:51,186 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 95, format MATROSKA and profile Samsung TV (B-series)
2013-01-16 21:51:51,187 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:51,187 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:51,187 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:51,188 DEBUG [VideoDeliveryEngine] Delivering item '95' for client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:51,188 DEBUG [VideoDeliveryEngine] Delivering file 'La Chaqueta Metálica [www.newpct.com][toni32].mkv' in native format
2013-01-16 21:51:51,188 DEBUG [MediaItemDAOImpl] Getting file of media item 95
2013-01-16 21:51:51,189 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 95) as read
2013-01-16 21:51:51,204 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-01-16 21:51:51,204 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 4726683143
2013-01-16 21:51:51,204 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:51,204 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Length: 4726683143,Date: Wed, 16 Jan 2013 20:51:51 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,Content-Range: bytes 10486471-4737169613/4737169614,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:51,237 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-01-16 21:51:51,238 DEBUG [WebServer] Incoming connection from /192.168.1.40:4452
2013-01-16 21:51:51,239 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:51,239 DEBUG [ResourceTransportRequestHandler] GET /resource/95/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=11997534-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.25:8895]]
2013-01-16 21:51:51,240 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:51,240 DEBUG [ResourceDeliveryProcessor] Request for resource 95 and type 'MEDIA_ITEM' received
2013-01-16 21:51:51,240 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:51,240 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:51,241 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:51,241 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 95, format MATROSKA and profile Samsung TV (B-series)
2013-01-16 21:51:51,242 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:51,242 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:51,242 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:51,243 DEBUG [VideoDeliveryEngine] Delivering item '95' for client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:51,243 DEBUG [VideoDeliveryEngine] Delivering file 'La Chaqueta Metálica [www.newpct.com][toni32].mkv' in native format
2013-01-16 21:51:51,243 DEBUG [MediaItemDAOImpl] Getting file of media item 95
2013-01-16 21:51:51,244 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 95) as read
2013-01-16 21:51:51,254 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-01-16 21:51:51,254 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 4725172080
2013-01-16 21:51:51,254 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:51,254 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Length: 4725172080,Date: Wed, 16 Jan 2013 20:51:51 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,Content-Range: bytes 11997534-4737169613/4737169614,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:51,284 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-01-16 21:51:51,286 DEBUG [WebServer] Incoming connection from /192.168.1.40:4881
2013-01-16 21:51:51,286 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:51,287 DEBUG [ResourceTransportRequestHandler] GET /resource/95/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=12938123-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.25:8895]]
2013-01-16 21:51:51,287 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:51,287 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:51,287 DEBUG [ResourceDeliveryProcessor] Request for resource 95 and type 'MEDIA_ITEM' received
2013-01-16 21:51:51,287 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:51,287 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:51,288 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:51,289 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 95, format MATROSKA and profile Samsung TV (B-series)
2013-01-16 21:51:51,289 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:51,289 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:51,289 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:51,290 DEBUG [VideoDeliveryEngine] Delivering item '95' for client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:51,290 DEBUG [VideoDeliveryEngine] Delivering file 'La Chaqueta Metálica [www.newpct.com][toni32].mkv' in native format
2013-01-16 21:51:51,290 DEBUG [MediaItemDAOImpl] Getting file of media item 95
2013-01-16 21:51:51,291 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 95) as read
2013-01-16 21:51:51,313 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-01-16 21:51:51,313 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 4724231491
2013-01-16 21:51:51,313 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:51,313 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Length: 4724231491,Date: Wed, 16 Jan 2013 20:51:51 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,Content-Range: bytes 12938123-4737169613/4737169614,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:51,325 DEBUG [WebServer] Incoming connection from /192.168.1.40:4225
2013-01-16 21:51:51,325 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:51,327 DEBUG [ResourceTransportRequestHandler] GET /resource/95/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=14441858-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.25:8895]]
2013-01-16 21:51:51,328 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:51,328 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:51,329 DEBUG [ResourceDeliveryProcessor] Request for resource 95 and type 'MEDIA_ITEM' received
2013-01-16 21:51:51,329 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:51,329 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:51,330 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:51,331 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 95, format MATROSKA and profile Samsung TV (B-series)
2013-01-16 21:51:51,331 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-01-16 21:51:51,331 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:51,332 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:51,332 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:51,333 DEBUG [VideoDeliveryEngine] Delivering item '95' for client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:51,333 DEBUG [VideoDeliveryEngine] Delivering file 'La Chaqueta Metálica [www.newpct.com][toni32].mkv' in native format
2013-01-16 21:51:51,333 DEBUG [MediaItemDAOImpl] Getting file of media item 95
2013-01-16 21:51:51,334 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 95) as read
2013-01-16 21:51:51,336 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-01-16 21:51:51,336 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 4722727756
2013-01-16 21:51:51,336 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:51,336 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Length: 4722727756,Date: Wed, 16 Jan 2013 20:51:51 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,Content-Range: bytes 14441858-4737169613/4737169614,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:51,371 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-01-16 21:51:51,373 DEBUG [WebServer] Incoming connection from /192.168.1.40:4734
2013-01-16 21:51:51,373 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:51,374 DEBUG [ResourceTransportRequestHandler] GET /resource/95/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=15945725-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.25:8895]]
2013-01-16 21:51:51,374 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:51,375 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:51,375 DEBUG [ResourceDeliveryProcessor] Request for resource 95 and type 'MEDIA_ITEM' received
2013-01-16 21:51:51,375 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:51,375 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:51,375 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:51,376 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 95, format MATROSKA and profile Samsung TV (B-series)
2013-01-16 21:51:51,376 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:51,377 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:51,377 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:51,378 DEBUG [VideoDeliveryEngine] Delivering item '95' for client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:51,378 DEBUG [VideoDeliveryEngine] Delivering file 'La Chaqueta Metálica [www.newpct.com][toni32].mkv' in native format
2013-01-16 21:51:51,378 DEBUG [MediaItemDAOImpl] Getting file of media item 95
2013-01-16 21:51:51,379 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 95) as read
2013-01-16 21:51:51,380 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-01-16 21:51:51,380 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 4721223889
2013-01-16 21:51:51,380 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:51,381 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Length: 4721223889,Date: Wed, 16 Jan 2013 20:51:51 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,Content-Range: bytes 15945725-4737169613/4737169614,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:51,416 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-01-16 21:51:51,417 DEBUG [WebServer] Incoming connection from /192.168.1.40:4032
2013-01-16 21:51:51,418 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:51,418 DEBUG [ResourceTransportRequestHandler] GET /resource/95/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=17482203-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.25:8895]]
2013-01-16 21:51:51,419 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:51,419 DEBUG [ResourceDeliveryProcessor] Request for resource 95 and type 'MEDIA_ITEM' received
2013-01-16 21:51:51,419 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:51,419 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:51,420 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:51,420 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 95, format MATROSKA and profile Samsung TV (B-series)
2013-01-16 21:51:51,421 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:51,421 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:51,421 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:51,422 DEBUG [VideoDeliveryEngine] Delivering item '95' for client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:51,422 DEBUG [VideoDeliveryEngine] Delivering file 'La Chaqueta Metálica [www.newpct.com][toni32].mkv' in native format
2013-01-16 21:51:51,422 DEBUG [MediaItemDAOImpl] Getting file of media item 95
2013-01-16 21:51:51,423 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 95) as read
2013-01-16 21:51:51,436 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-01-16 21:51:51,436 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 4719687411
2013-01-16 21:51:51,437 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:51,437 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Length: 4719687411,Date: Wed, 16 Jan 2013 20:51:51 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,Content-Range: bytes 17482203-4737169613/4737169614,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:51,461 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-01-16 21:51:51,463 DEBUG [WebServer] Incoming connection from /192.168.1.40:3686
2013-01-16 21:51:51,464 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:51,464 DEBUG [ResourceTransportRequestHandler] GET /resource/95/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.25:8895]]
2013-01-16 21:51:51,465 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:51,465 DEBUG [ResourceDeliveryProcessor] Request for resource 95 and type 'MEDIA_ITEM' received
2013-01-16 21:51:51,465 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:51,465 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:51,466 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:51,466 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 95, format MATROSKA and profile Samsung TV (B-series)
2013-01-16 21:51:51,467 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:51,467 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:51,467 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:51,468 DEBUG [VideoDeliveryEngine] Delivering item '95' for client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
vaki
Post Wed Jan 16, 2013 9:17 pm
part six at last!
2013-01-16 21:51:51,468 DEBUG [VideoDeliveryEngine] Delivering file 'La Chaqueta Metálica [www.newpct.com][toni32].mkv' in native format
2013-01-16 21:51:51,468 DEBUG [MediaItemDAOImpl] Getting file of media item 95
2013-01-16 21:51:51,469 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 95) as read
2013-01-16 21:51:51,478 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-01-16 21:51:51,478 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 4737169614
2013-01-16 21:51:51,478 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:51,478 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/x-mkv,Content-Length: 4737169614,Date: Wed, 16 Jan 2013 20:51:51 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:51,916 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-01-16 21:51:52,071 DEBUG [WebServer] Incoming connection from /192.168.1.40:2623
2013-01-16 21:51:52,071 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:52,072 DEBUG [ResourceTransportRequestHandler] HEAD /resource/95/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,Host: 192.168.1.25:8895]]
2013-01-16 21:51:52,072 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:52,072 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:52,073 DEBUG [ResourceDeliveryProcessor] Request for resource 95 and type 'MEDIA_ITEM' received
2013-01-16 21:51:52,073 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:52,073 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:52,073 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:52,074 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 95, format MATROSKA and profile Samsung TV (B-series)
2013-01-16 21:51:52,074 DEBUG [ResourceDeliveryProcessor] Sending HEAD response back
2013-01-16 21:51:52,074 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/x-mkv,Content-Length: 4737169614,Date: Wed, 16 Jan 2013 20:51:52 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-16 21:51:52,083 DEBUG [WebServer] Incoming connection from /192.168.1.40:4217
2013-01-16 21:51:52,083 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:52,084 DEBUG [ResourceTransportRequestHandler] GET /resource/95/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=0-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,getMediaInfo.sec: 1,Host: 192.168.1.25:8895]]
2013-01-16 21:51:52,084 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:51:52,084 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:52,084 DEBUG [ResourceDeliveryProcessor] Request for resource 95 and type 'MEDIA_ITEM' received
2013-01-16 21:51:52,084 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:52,084 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:52,085 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:52,086 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 95, format MATROSKA and profile Samsung TV (B-series)
2013-01-16 21:51:52,086 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 95 (local)
2013-01-16 21:51:52,086 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 95)
2013-01-16 21:51:52,087 DEBUG [VideoDAOImpl] Reading a Video (id = 95)
2013-01-16 21:51:52,087 DEBUG [VideoDeliveryEngine] Delivering item '95' for client 'IPAddress=/192.168.1.40, Profile=Samsung TV (B-series)'
2013-01-16 21:51:52,088 DEBUG [VideoDeliveryEngine] Delivering file 'La Chaqueta Metálica [www.newpct.com][toni32].mkv' in native format
2013-01-16 21:51:52,088 DEBUG [MediaItemDAOImpl] Getting file of media item 95
2013-01-16 21:51:52,088 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 95) as read
2013-01-16 21:51:52,090 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-01-16 21:51:52,090 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 4737169614
2013-01-16 21:51:52,090 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-16 21:51:52,090 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Length: 4737169614,Date: Wed, 16 Jan 2013 20:51:52 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,Content-Range: bytes 0-4737169613/4737169614,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,MediaInfo.sec: SEC_Duration=6990000;]]
2013-01-16 21:52:09,792 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-01-16 21:52:09,792 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-01-16 21:53:09,793 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-01-16 21:53:09,793 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-01-16 21:53:42,443 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.40:1025
2013-01-16 21:53:42,444 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:53:42,445 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.40:1025
2013-01-16 21:53:42,760 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.40:1025
2013-01-16 21:53:42,760 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:53:42,762 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.40:1025
2013-01-16 21:53:42,840 DEBUG [RendererManager] Removing renderer d77fcf8a-4085-016d-9875-c100b108b138 from list of active renderers
2013-01-16 21:53:43,071 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.40:1025
2013-01-16 21:53:43,071 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:53:43,072 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.40:1025
2013-01-16 21:53:44,202 DEBUG [RendererManager] Adding renderer Renderer [uuid=d77fcf8a-4085-016d-9875-c100b108b138, ipAddress=192.168.1.40, name=Samsung DTV DMR, profileId=2, manuallyAdded=false, forcedProfile=false, enabled=true, accessGroupId=1] to list of active renderers
2013-01-16 21:53:44,441 DEBUG [WebServer] Incoming connection from /192.168.1.40:3983
2013-01-16 21:53:44,442 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:53:44,442 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device df29ffd2-c48d-3270-8b52-589b786ca617 from 192.168.1.40 (headers = [HOST: 192.168.1.25:8895,USER-AGENT: SamsungWiselinkPro/1.0,ACCEPT-LANGUAGE: en-us])
2013-01-16 21:53:44,443 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.40
2013-01-16 21:53:44,443 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.1.25:8895,USER-AGENT: SamsungWiselinkPro/1.0,ACCEPT-LANGUAGE: en-us]
2013-01-16 21:53:44,446 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Samsung TV (B-series)'
2013-01-16 21:53:45,886 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
Post Thu Jan 17, 2013 5:09 pm
It delivers the file natively, so it's up to the TV to play it. Something in the way it's been encoded the TV doesn't like. Normally it plays files with these parameters. Also check MediaInfo output of the file to see if these is header stripping (compression).
Users browsing this forum: No registered users and 60 guests
