Folder Presentation
Movies
- Kid Movie Folder
| Display Movies under this folder.
- Movies Folder
| Display Movies Under this folder.
- Series Folder
MasterFrost wrote:I beleve the best solution is to have each of your Library folder as a presentation category that way you can choose how you want the folder to display or if you want to use some of the pre defined category displays.
