UE40ES7000 + Fedora 10 : .flv & .webm
fortissimo
Post Thu Jan 31, 2013 9:12 pm
I've connected my Samsung UE40ES7000 with an old Fedora 10 computer which has movies, music and pictures.
The movies are:
.avi
.vob (DVD as complete dir in VIDEO_TS)
.mkv
.flv
.webm
I was able to play the first 4, but couldn't get the .webm shown on my tv (not even in the listing).
But the next day I can't play the .flv either.
I get a message that the file is not recognized at the moment.
I tried some settings I already found at the forum, but they didn't help either.
Got any hints?
Post Fri Feb 01, 2013 10:10 pm
Re: UE40ES7000 + Fedora 10 : .flv & .webm
try renaming the .webm to .mkv
fortissimo
Post Fri Feb 01, 2013 10:15 pm
I tried that, but the file didn't show after that either.
Is there a way to see which files are indexed and are being indexed?
Post Sun Feb 03, 2013 11:55 am
In the log.
Post ffmpeg -I for the file.
fortissimo
Post Sun Feb 03, 2013 12:57 pm
The file isn't mentioned in the logs.
ffmpeg -i:
FFmpeg version SVN-r15261, Copyright (c) 2000-2008 Fabrice Bellard, et al.
configuration: --prefix=/usr --bindir=/usr/bin --datadir=/usr/share/ffmpeg --incdir=/usr/include/ffmpeg --libdir=/usr/lib --mandir=/usr/share/man --arch=i386 --extra-cflags=-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m32 -march=i386 -mtune=generic -fasynchronous-unwind-tables --enable-bzlib --enable-libdc1394 --enable-libfaac --enable-libfaad --enable-libgsm --enable-libmp3lame --enable-libschroedinger --enable-libtheora --enable-libvorbis --enable-libx264 --enable-libxvid --enable-x11grab --enable-avfilter --enable-avfilter-lavf --enable-postproc --enable-swscale --enable-pthreads --disable-static --enable-shared --enable-gpl --disable-debug --disable-stripping --shlibdir=/usr/lib --cpu=i386
libavutil 49.11. 0 / 49.11. 0
libavcodec 51.71. 0 / 51.71. 0
libavformat 52.22. 1 / 52.22. 1
libavdevice 52. 1. 0 / 52. 1. 0
libavfilter 0. 1. 0 / 0. 1. 0
libswscale 0. 6. 1 / 0. 6. 1
built on Oct 27 2009 13:55:46, gcc: 4.3.2 20081105 (Red Hat 4.3.2-7)
Post Mon Feb 04, 2013 1:57 pm
First, your FFmpeg is super old. You will have to upgrade it.
Second, you have to pass the file path to the ffmpeg -i command, see here: viewtopic.php?f=5&t=1123
fortissimo
Post Tue Feb 05, 2013 7:32 am
Hope this is better...
ffmpeg version N-49578-g81f2549 Copyright (c) 2000-2013 the FFmpeg developers
built on Feb 4 2013 19:45:46 with gcc 4.3.2 (GCC) 20081105 (Red Hat 4.3.2-7)
configuration:
libavutil 52. 17.101 / 52. 17.101
libavcodec 54. 91.100 / 54. 91.100
libavformat 54. 61.104 / 54. 61.104
libavdevice 54. 3.103 / 54. 3.103
libavfilter 3. 35.101 / 3. 35.101
libswscale 2. 2.100 / 2. 2.100
[mpegts @ 0xa84f720] Stream #5: not enough frames to estimate rate; consider increasing probesize
[mpegts @ 0xa84f720] Stream #6: not enough frames to estimate rate; consider increasing probesize
[mpegts @ 0xa84f720] Stream #7: not enough frames to estimate rate; consider increasing probesize
[mpegts @ 0xa84f720] Stream #8: not enough frames to estimate rate; consider increasing probesize
[mpegts @ 0xa84f720] Stream #9: not enough frames to estimate rate; consider increasing probesize
[mpegts @ 0xa84f720] Stream #10: not enough frames to estimate rate; consider increasing probesize
[mpegts @ 0xa84f720] Stream #11: not enough frames to estimate rate; consider increasing probesize
[mpegts @ 0xa84f720] Could not find codec parameters for stream 5 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size
Consider increasing the value for the 'analyzeduration' and 'probesize' options
[mpegts @ 0xa84f720] Could not find codec parameters for stream 6 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size
[mpegts @ 0xa84f720] Could not find codec parameters for stream 7 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size
[mpegts @ 0xa84f720] Could not find codec parameters for stream 8 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size
[mpegts @ 0xa84f720] Could not find codec parameters for stream 9 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size
[mpegts @ 0xa84f720] Could not find codec parameters for stream 10 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size
[mpegts @ 0xa84f720] Could not find codec parameters for stream 11 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size
[NULL @ 0xa855b20] start time is not set in estimate_timings_from_pts
[NULL @ 0xa856300] start time is not set in estimate_timings_from_pts
[NULL @ 0xa856ae0] start time is not set in estimate_timings_from_pts
[NULL @ 0xa8572c0] start time is not set in estimate_timings_from_pts
[NULL @ 0xa8a2d00] start time is not set in estimate_timings_from_pts
[NULL @ 0xa8a8dc0] start time is not set in estimate_timings_from_pts
[NULL @ 0xa8af0e0] start time is not set in estimate_timings_from_pts
Input #0, mpegts, from '/media/usb-filmmuziek/films/BD/00001.m2ts':
Duration: 02:41:41.70, start: 1.991000, bitrate: 28317 kb/s
Program 1
Stream #0:0[0x1011]: Video: h264 (High) (HDMV / 0x564D4448), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 90k tbn, 47.95 tbc
Stream #0:1[0x1100]: Audio: dts (DTS-HD MA) ([134][0][0][0] / 0x0086), 48000 Hz, 5.1(side), fltp, 1536 kb/s
Stream #0:2[0x1101]: Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, 5.1(side), fltp, 384 kb/s
Stream #0:3[0x1102]: Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, 5.1(side), fltp, 384 kb/s
Stream #0:4[0x1103]: Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, 5.1(side), fltp, 384 kb/s
Stream #0:5[0x1200]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Stream #0:6[0x1201]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Stream #0:7[0x1202]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Stream #0:8[0x1203]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Stream #0:9[0x1204]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Stream #0:10[0x1205]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Stream #0:11[0x1206]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Post Wed Feb 06, 2013 12:15 am
is this the webm file? If yes, rename it to .mpg (it is actually just mpegts/h264/dts file) and it should play
