dvr-ms
ace315
Post Wed Jan 05, 2011 1:39 am
dvr-ms
Does anyone know how to play dvr-ms files from windows media center? I'd like to use my home computer as a dvr and then watch the shows using serviio, thanks,
Post Wed Jan 05, 2011 6:20 am
Re: dvr-ms
ace315 wrote:Does anyone know how to play dvr-ms files from windows media center? I'd like to use my home computer as a dvr and then watch the shows using serviio, thanks,
dvr-ms files can only by played using window media center and most will be copy protected and will only play on the computer that they were made on.
your best bet to dop what you want is to try something like MYTHtv ( http://www.mythtv.org/ ) rather than microsft software as then it will be encoded in a sensible formnat that serviio can then stream.
Post Wed Jan 05, 2011 9:40 am
Re: dvr-ms
it should be possible in 0.5
posith
Post Thu Jan 06, 2011 9:52 am
Re: dvr-ms
Cerberus wrote: dvr-ms files can only by played using window media center and most will be copy protected and will only play on the computer that they were made on.
zip wrote:it should be possible in 0.5
Impossible is nothing ;)
jcbyte
Post Sat Feb 12, 2011 12:23 am
Re: dvr-ms
Please explain how dvr-ms files can be played on .5 as I am having no luck.
JC
scrambler
Post Sat Feb 12, 2011 1:32 am
Re: dvr-ms
For some reason, DVR-MS files have to be transcoded, so you need to make sure that your profile includes the following transcode instructions
<Video targetContainer="mpegts" targetACodec="ac3" forceVTranscoding="true">
<Matches container="asf" vCodec="mpeg2video" />
I dont know exactly why that is, and it would be nice if we did not have to because I loose the ability to skip forward in these files because of it and it is a major bummer with the commercials.
jcbyte
Post Sat Feb 12, 2011 3:47 am
Re: dvr-ms
Where is this content included in the profile.xml file?
JC
jcbyte
Post Sat Feb 12, 2011 4:03 am
Re: dvr-ms
Solved my problem by choosing the blu ray samsung player config.
JC
scrambler
Post Sat Feb 12, 2011 5:49 pm
Re: dvr-ms
Yes that profile (in profiles.xml) already includes these instructions
patters
Post Sun Jun 17, 2012 1:25 am
Re: dvr-ms
scrambler wrote:For some reason, DVR-MS files have to be transcoded
Logically dvr-ms files should be able to be remuxed and shouldn't have to be entirely re-encoded. This has never worked though. I was just looking through the list of open FFmpeg tickets when I found this which may be of interest. Someone has raised this particular issue so hopefully it should get fixed:
https://ffmpeg.org/trac/ffmpeg/ticket/1415
