Serviio
jpgvmm
Post Fri Feb 22, 2013 4:36 pm
Serviio
I dont understand, it took me quite a while of time to download and install java on synology, then install serviio, then figure it out how to put the movies, but once im done, I turn on the TV I tried to load an mkv, and there we go again, audio not supported.
if serviio is supposed to transcode the files, why is it that I cant still not play mkv with dts on my tv????????
Post Tue Feb 26, 2013 6:45 pm
Re: Serviio
LG TV's have problems with transcoded files from Serviio, at least the older ones. The transcoding block is commented out in the LG profile, try to uncomment it.
Return to LG
