SKYSPORTSPLUS - A SPORTS STREAM WEBRESOURCE
Post Sun Feb 24, 2013 7:31 am
Re: SKYSPORTSPLUS - A SPORTS STREAM WEBRESOURCE
Uploaded V18 again due to error. If you (3 people) downloaded before this timestamp do it again.
Post Thu Feb 28, 2013 5:02 am
Version 19 posted to support new Cast4You source feeds.
Rufus McDufus
Post Sun Mar 03, 2013 2:40 pm
Hi - using v19 of the plugin (for the first time) on Serviio 1.1 on Qnap. I'm trying to view F1 testing at the moment which is currently listed and viewable on cricfree.tv. For some reason the folder listing only ever seems to list a maximum of 16 items (and doesn't include what I want to watch naturally :( ). If I set noevents=1 I see non-current events in the list, but still only a total of 16. Am I missing a vital setting somewhere?
Oh in Serviio I have Max number of feed items to retrieve set to 50, and in Presentation 'Number of items in dynamic categories' is set to 10 (not sure if this is relevant).
Post Sun Mar 03, 2013 3:56 pm
Beats me. Tested here and everything is working fine. If you post a debug log showing the refresh of the plugin it might show why.
Post Mon Mar 11, 2013 5:19 am
Version 20 posted to add SkySports F1 channel
Post Mon Mar 11, 2013 5:21 am
Version 21 posted to increase item extract timeout to 60 seconds. Serviio version 2.1 is prereq.
Rufus McDufus
Post Thu Mar 14, 2013 11:51 am
Sky Sports F1 isn't showing up. Worked for a while but no longer (running v21 of the plugin). I'm just looking through the code.
Log error is:
2013-03-14 12:00:53,330 DEBUG [FeedItemUrlExtractor] skysportsplus: Starting extraction of url for item: sf1*0:45 GMT-Australian Grand Prix Preview*1:00 GMT-Australian F1 GP - 1st Practice
2013-03-14 12:00:53,331 DEBUG [FeedItemUrlExtractor] skysportsplus: Source Link: http://www.cricfree.tv//sky-sports-f1-live-stream.php
2013-03-14 12:00:53,435 DEBUG [FeedItemUrlExtractor] skysportsplus: Source Link 2: http://cricfree.tv/update/skysf1.php
2013-03-14 12:00:53,539 DEBUG [FeedItemUrlExtractor] skysportsplus: http://cricfree.tv/update/skysf1.php - http://www.castalba.tv/js/embed.js NOTFOUND
2013-03-14 12:00:53,539 DEBUG [FeedItemUrlExtractor] skysportsplus: Finished extraction of url: no result
2013-03-14 12:00:53,539 WARN [WebResourceParser] Plugin skysportsplus returned no value for resource item 'null'
2013-03-14 12:00:53,539 DEBUG [WebResourceParser] Skipping web resource item 'sf1*0:45 GMT-Australian Grand Prix Preview*1:00 GMT-Australian F1 GP - 1st Practice' because it's not of type VIDEO
Both source links play ok.
Rufus McDufus
Post Fri Mar 15, 2013 5:51 am
Sky Sports F1 HD back - must've been a feed issue.
Post Fri Mar 15, 2013 2:46 pm
Yes, they were using Castalba which I was not supporting. I will add it in next version.
Post Fri Mar 15, 2013 6:38 pm
Version 22 posted to support new sources. Note that I am unable to access jimey.tv and hdmytv streams so channels using these sources will not appear. If anyone can figure them out I will add them.
Chrisnewton
Post Sun Mar 17, 2013 2:03 pm
Hi all
I am a newbie to all this..i have downloaded the groovy and put it in the plugin folder..what do i need to do next to get this to work via my ps3?
Thanks all
Chris
Chrisnewton
Post Sun Mar 17, 2013 2:11 pm
Update...
I went into the folder on my ps3 and now 3 channels have apprered...skysports 2, Skysports news and espn,
Sky sports 2 works great, but the other 2 say media server error.
Does this mean i can only get sports 2??
Post Sun Mar 17, 2013 2:41 pm
Follow the instructions in the first post and if does not work, post in or read some ps3 threads. Its not a plugin problem.
Chrisnewton
Post Sun Mar 17, 2013 3:42 pm
I dont think for one minute its a plug in fault, i know its something i am not doing.
It lists about 10 channels now but only say 3 or 4 work..for example its now only showing skysports 4 and not the rest...i thought it would show them all??
Sorry i know im being thick here !!
hazmatt
Post Sun Mar 17, 2013 3:54 pm
Having PS3 problems too; I think it's because http://www.skysports.plus is down.
Post Sun Mar 17, 2013 5:43 pm
That is just a dummy url used to invoke the plugin. See the first post. As I said before AFAIC these are PS3 problems.
Chrisnewton
Post Sun Mar 17, 2013 5:47 pm
this is working fine now....i have lots of channels and most seem to work.
Thank you all
Iveky
Post Wed Mar 20, 2013 2:40 pm
something has changed... very few channel in list lately (since yesterday).
Post Wed Mar 20, 2013 2:54 pm
Works fine for me.
Iveky
Post Wed Mar 20, 2013 4:13 pm
but this one already 2 days doesn't appear anymore:
http://cricfree.tv/sky-sports-f1-live-stream.php
and others are sometimes there in list but samsung can't cope with them :(
later will check what happened to mine PC :(
Return to Available plugins
