Configuration Backup
paniko
Post Fri Mar 01, 2013 3:59 pm
Hi Guys,
I wanted to know if is possible to implement a configuration backup features for the Library and Online resources and for the other setting..
regards
Paniko
Sumsung EU46D6500 | XBox 360 | Samsung Galaxy S 6 Edge | Windows 10 - i7 64bit | Serviio 1.5.2 Pro
Beta Tester
Post Fri Mar 01, 2013 4:30 pm
Re: Configuration Backup
paniko wrote:Hi Guys,
regards
For online resources, it is planned to use export/import feature (in xml format).
For library (media info, servio conf), not sure that Zip planned something.
paniko
Post Fri Mar 01, 2013 5:37 pm
regards
OK thanks for the information
Paniko
Beta Tester
jidrobbins
Post Sat Mar 09, 2013 4:30 am
You can backup your library/online resources by making a copy of the library folder where your program is installed. This is how I transfer my library settings to a new computer - same idea.
On a windows OS it's usually located on your main hard drive
C:/program files/serviio/library (if memory serves me properly)
Thank you everyone involved in developing Serviio and the Plugins!!
SYSTEM INFO:
Using Serviio 1.4 to stream to my Sony BDV-E570 Blu-Ray via
wireless network using a Netgear N600 Wireless-N modem
My computer (connected directly to my Roadrunner broadband cable modem):
Dell Inspiron
Processor Intel(R) Core(TM) i7-3632QM CPU @ 2.20GHz
Memory (RAM) 8.00 GB
Windows 8 (64-bit operating system)
Return to Feature requests
Users browsing this forum: No registered users and 53 guests
