Avi Files that play in Version 1.0.1 does not play in 1.2
andreasvenios
Post Sun Mar 10, 2013 10:24 am
Hi all again,
I have two pc's in my home and the one is running the 1.2 Version of Serviio while the other the 1.0.1. The same Avi file that plays in 1.0.1 version does not play in 1.2. Is there something I can do to fix that???
Thanks again,
Andreas.
Post Sun Mar 10, 2013 11:34 am
Re: Avi Files that play in Version 1.0.1 does not play in 1.
What is your device renderer model (TV, Blurayplayer,etc) and profile selected on serviio console ?
In 1.0.1 your avi probably been transcoded, with 1.2 it should be delivered in natice format.
andreasvenios
Post Sun Mar 10, 2013 9:10 pm
Hi again Illico,
my tv model is a sony bravia kdl40lx-900 and the profile selected in serviio console is Sony Bravia TV (2010).
Andreas.
Post Mon Mar 11, 2013 8:11 am
Could you post information about your AVI file see my signature links) ?
I suspect your file is an AVI/MJPEG video format. I saw that the latest ffmpeg version had problems with some MJPEG, It's a regression...
andreasvenios
Post Mon Mar 11, 2013 5:34 pm
Dear Illico,
The file info:
Complete name : \\MyBookLive\Public\Shared Pictures\Antonis Photos\Γενέθλια3.AVI
Format : AVI
File size : 59.2 MiB
Duration : 2mn 37s
Overall bit rate : 3 163 Kbps
Writing application : SONY DSC MJPEG 0100
Format : JPEG
Codec ID : MJPG
Duration : 2mn 37s
Bit rate : 3 069 Kbps
Width : 320 pixels
Height : 240 pixels
Display aspect ratio : 4:3
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:2
Bit depth : 8 bits
Compression mode : Lossy
Bits/(Pixel*Frame) : 1.333
Stream size : 57.4 MiB (97%)
Title : SONY DSC MOVIE
Format : ADPCM
Format profile : U-Law
Codec ID : 7
Codec ID/Hint : CCITT
Duration : 2mn 36s
Bit rate mode : Constant
Bit rate : 88.2 Kbps
Channel(s) : 1 channel
Sampling rate : 11.025 KHz
Bit depth : 8 bits
Stream size : 1.65 MiB (3%)
Interleave, duration : 498 ms (14.94 video frames)
Post Mon Mar 11, 2013 5:39 pm
Illico wrote:I suspect your file is an AVI/MJPEG video format. I saw that the latest ffmpeg version had problems with some MJPEG, It's a regression...
Bingo!
@andreas, if you are on windows system, could you try with latest ffmpeg version (make a backup of official ./serviio/lib/ffmpeg.exe) ?
Download latest ffmpeg.exe here: http://ffmpeg.zeranoe.com/builds/
andreasvenios
Post Tue Mar 12, 2013 11:04 am
Illico,
I downloaded the file, extract from the zip the ffmpeg.exe to "/serviio/lib/ffmpeg.exe" and replaced the old file. Now when I try to play the avi file it does not play it at all(in the previous situation you could hear the file but you could not see it). Waiting for new instructions.
Andreas.
mbarnig
Post Tue Mar 12, 2013 12:56 pm
Post Sun Mar 17, 2013 11:50 am
Bingo!
Looks like something has been fixed related to mjpeg. Not sure when it'll be available in the Zeranoe build, but if it works I'll wait a few days to get it to 1.2.1
https://ffmpeg.org/trac/ffmpeg/ticket/2353
Users browsing this forum: Google [Bot] and 40 guests
