some AVI files will not play on P50ST50
palmachnick
Post Tue Mar 12, 2013 1:40 am
Hello
Any help is appreciated.
I posted below an example of an AVI that works and a sample of an AVI that doesn't work.
Thanks again,
Mo
Working AVI:
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Moti>cd "\program Files\Serviio\Lib"
C:\Program Files\Serviio\lib>ffmpeg -i C:\Temp\WORK.AVI
ffmpeg version 1.1.1 Copyright (c) 2000-2013 the FFmpeg developers
built on Feb 5 2013 21:59:54 with gcc 4.7.2 (GCC)
p --enable-fontconfig --enable-libfreetype --enable-zlib --extra-libs='-lrtmp -l
polarssl -lws2_32 -lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --enable-
runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-
mingw32- --pkg-config=pkg-config
libavutil 52. 13.100 / 52. 13.100
libavcodec 54. 86.100 / 54. 86.100
libavformat 54. 59.106 / 54. 59.106
libavdevice 54. 3.102 / 54. 3.102
libavfilter 3. 32.100 / 3. 32.100
libswscale 2. 1.103 / 2. 1.103
[avi @ 03995AE0] non-interleaved AVI
[mpeg4 @ 0163DE80] Invalid and inefficient vfw-avi packed B frames detected
Input #0, avi, from 'C:\Temp\WORK.AVI':
encoder : FairUse Wizard - http://fairusewizard.com
Duration: 00:13:01.75, start: 0.000000, bitrate: 4934 kb/s
Stream #0:0: Video: mpeg4 (DX50 / 0x30355844), yuv420p, 640x464 [SAR 1:1 DAR
40:29], 29.97 fps, 29.97 tbr, 29.97 tbn, 30k tbc
Stream #0:1: Audio: mp3 (U[0][0][0] / 0x0055), 48000 Hz, stereo, s16p, 128 k
b/s
Non-Working AVI:
C:\Program Files\Serviio\lib>ffmpeg -i c:\Temp\NOTWORK.avi
Input #0, avi, from 'c:\Temp\NOTWORK.avi':
Duration: 00:09:35.88, start: 0.000000, bitrate: 28777 kb/s
Stream #0:0: Video: dvvideo, yuv411p, 720x480 [SAR 8:9 DAR 4:3], 28771 kb/s,
29.97 tbr, 29.97 tbn, 29.97 tbc
Stream #0:1: Audio: pcm_s16le, 48000 Hz, stereo, s16, 1536 kb/s
Post Tue Mar 12, 2013 5:55 pm
Re: some AVI files will not play on P50ST50
post detailed log for the non working file (when playing)
palmachnick
Post Tue Mar 12, 2013 11:37 pm
Thanks for your help....here you go.....had to trim it down for only today's activity due to size..... please let me know if it is not sufficient....
The AVI is pixalized but the sound is good.
serviio COPY.txt
(10.29 KiB) Downloaded 673 times
Post Wed Mar 13, 2013 7:49 am
palmachnick wrote:The AVI is pixalized but the sound is good.
I have th same problem with MJEPG codec on latest ffmpeg version.
Please provide log file when you play the file
palmachnick
Post Wed Mar 13, 2013 11:31 pm
not sure why the previous log didnt capture the play. Please see attached.
Mo
serviio COPY.txt
(472.95 KiB) Downloaded 616 times
Post Thu Mar 21, 2013 11:31 am
Hi palmachnick - Not sure if this will help but see my post here.
Let me know one way or the other. Thanks.
Return to Panasonic
