Re: Unable to See Serviio after Upgrade to 1.2
Thanks!
That solved it in my case. Is it possible to set Serviio to automatically accept new devices instead of blocking them all by default?
bjurran wrote:
Thanks!
zip wrote:bjurran wrote:
Thanks!
It is accepting them. But if you're running WHS plugin for 0.6.x it'll have this effect. There is not 1.2 WHS plugin AFAIK, you'll have to run the console in Remote Desktop or use an app like ServiiDroid.
Users browsing this forum: Baidu [Spider] and 21 guests
