profiles - subtitles not working anymore
sparx
Post Sun Mar 31, 2013 8:28 am
I have a panasonic GT30, which worked perfect, after update to never version of Serviio, some avi files not supported and subtitles not working.
I used a profile I got from this forum earlier, however, if I try to put it into the profile file, it is not seen in the menu:
It was this one:
<Profile id="24" name="Panasonic Viera With AVI Support" extendsProfileId="1">
<MediaFormatProfiles>
</MediaFormatProfiles>
<!-- Transcode h264 videos with profile level > 4.1 to mpegts with ac3 audio -->
<Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" maxVBitrate="20000">
<Matches container="avi" vCodec="h264" profile="high" levelGreaterThan="4.2" />
<Matches container="avi" vCodec="h264" profile="main" levelGreaterThan="4.2" />
<Matches container="matroska" vCodec="h264" profile="high" levelGreaterThan="4.2" />
<Matches container="matroska" vCodec="h264" profile="main" levelGreaterThan="4.2" />
<!-- remux VORBIS/FLAC/LPCM in MKV/MP4 to AC3 -->
<Video targetContainer="mpegts" targetACodec="ac3" >
<Matches container="mp4" vCodec="h264" aCodec="lpcm"/>
<Matches container="mp4" vCodec="h264" aCodec="aac"/>
<!-- Remux MPEG-TS with no transcoding -->
<Matches container="matroska" vCodec="mpeg2video"/>
<!-- Remux WTV files to MPEG-PS with no transcoding-->
<Matches container="wtv" />
<!-- unsupported codecs will be transcoded into mpeg-ts, mpeg2 video and ac3 audio -->
<Matches container="mp4" vCodec="mpeg4" />
<Matches container="mpeg" vCodec="mpeg1video" />
<Matches container="matroska" vCodec="mpeg4" />
<Matches container="asf" />
<Matches container="flv" />
<Matches container="ogg" />
<Matches container="3gp" />
<!-- unsupported audio will be transcoded into lpcm audio -->
<Matches container="flac" />
<Matches container="adts" />
</Audio>
Has profile setup changed , so I need to rewrite it to be seen by serviio?
sparx
Post Sun Mar 31, 2013 7:35 pm
Re: profiles - subtitles not working anymore
Just found out, if I add this to the default profile.xml, and stop and start serviio service - it will not start, so something must be wrong in it - in the syntax.
But it used to (in version 0.6.2) give me all videos + subtitles, and the default (1.2.1) profile does not.
Any help appreciated, running on Pana GT30
Post Sun Mar 31, 2013 8:12 pm
The SubtitlesMimeType element changed, look at the other profiles for the new syntax.
Post Sun Mar 31, 2013 11:58 pm
This profile is very similar to "Panasonic Viera G/GT/DT/UT/VT (2011/2012)"
Can you chose that one and provide details (ffmpeg -i) of files that don't play (and that used to play with the other profile)?
sparx
Post Mon Apr 01, 2013 6:51 am
Here is ffmpeg output
C:\Program Files\Serviio\lib>ffmpeg.exe -i "2011.avi"
ffmpeg version 1.1.1 Copyright (c) 2000-2013 the FFmpeg developers
built on Feb 5 2013 21:59:54 with gcc 4.7.2 (GCC)
p --enable-fontconfig --enable-libfreetype --enable-zlib --extra-libs='-lrtmp -l
polarssl -lws2_32 -lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --enable-
runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-
mingw32- --pkg-config=pkg-config
libavutil 52. 13.100 / 52. 13.100
libavcodec 54. 86.100 / 54. 86.100
libavformat 54. 59.106 / 54. 59.106
libavdevice 54. 3.102 / 54. 3.102
libavfilter 3. 32.100 / 3. 32.100
libswscale 2. 1.103 / 2. 1.103
Input #0, avi, from ' (2011).avi':
encoder : VirtualDubMod 1.5.10.2 (build 2542/release)
Duration: 01:31:16.44, start: 0.000000, bitrate: 1068 kb/s
Stream #0:0: Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv
420p, 608x256 [SAR 1:1 DAR 19:8], 23.98 tbr, 23.98 tbn, 23.98 tbc
Stream #0:1: Audio: mp3 (U[0][0][0] / 0x0055), 48000 Hz, stereo, s16p, 32 kb
/s
sparx
Post Mon Apr 01, 2013 6:53 am
will wrote:The SubtitlesMimeType element changed, look at the other profiles for the new syntax.
Thanks, will try to modify this... (no clue of what I am doing - but copy/paste might work...
sparx
Post Mon Apr 01, 2013 2:44 pm
Tried it now, and file still will not play, and no subtitles worked.
Was something fundamental changed from vers 0.6 rg subtitles since it used to work, but have not been able to get it to work afterwards with any of my movies?
pls. help
Post Tue Apr 02, 2013 8:53 pm
post detailed log of playing the file
Leonmeijer
Post Wed Nov 06, 2013 1:48 pm
I also have a Panasonic TV (actually, don't know the exact model).
Actually the TV is not playing almost all types so I discovered Serviio and since I'm using serviio almost everything is playing.
But now I've updated to the latest version and.... nothing is playing the TV says: "This file type is not supported" to files it certainly played before.
I'm not known to profiles (can't even find an option in the console) because it just worked fine untill the update.
Subtitles never worked though but I don't use that quite much.
Also online media is no longer playing.
Using serviio on a Synology NAS.
Any ideas?
Did not yet go trough the changelogs.
Return to Panasonic
