Only Audio and Black Screen in online sources - KDL-46z5500
I can hear only the audio, no video in online sources futubox sports channels.
I have Serviio 1.2.1 and in profile I use "Sony Bravia TV (2009)".
Someone can help me?
Server NGINX RTMP (github.com/arut/nginx-rtmp-module)
width 1280.00
height 720.00
displayWidth 1280.00
displayHeight 720.00
duration 0.00
framerate 25.00
fps 25.00
videodatarate 0.00
videocodecid 0.00
audiodatarate 0.00
audiocodecid 0.00
Input #0, flv, from 'rtmp://s01.futubox.to/live?lp=............ live=1':
Server : NGINX RTMP (github.com/arut/nginx-rtmp-module)
displayWidth : 1280
displayHeight : 720
fps : 25
profile :
level :
Duration: 00:00:00.00, start: 0.000000, bitrate: N/A
Stream #0:0: Video: h264 (Main), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 25 tb
r, 1k tbn, 50 tbc
Stream #0:1: Audio: aac, 48000 Hz, stereo, fltp
At least one output file must be specifiedMetadata:
width 1024.00
height 576.00
displayWidth 1024.00
displayHeight 576.00
duration 0.00
framerate 25.00
fps 25.00
videodatarate 0.00
videocodecid 0.00
audiodatarate 0.00
audiocodecid 0.00
Input #0, flv, from 'rtmp://s01.futubox.to/live?lp=........... live=1':
displayWidth : 1024
displayHeight : 576
fps : 25
profile :
level :
Duration: 00:00:00.00, start: 677.494000, bitrate: N/A
Stream #0:0: Video: h264 (Main), yuv420p, 1024x576 [SAR 1:1 DAR 16:9], 25 tb
r, 1k tbn, 50 tbc
<Profile id="sony2009" name="Sony Bravia TV (2009)" extendsProfileId="sony2010">
<!-- 2009 and earlier models need a separate profile -->
<Detection>
<UPnPSearch>
<!-- 2009 models known to support UPnPSearch -->
<FriendlyName>BRAVIA KDL-\d{2}(WE5|(E53|E55|V55|V56|W55|W57|Z55|Z57)\d0) *</FriendlyName>
</UPnPSearch>
<HttpHeaders>
<!-- 2008 models, and possibly older or different region 2009 firmwares which may not support UPnPSearch -->
<X-AV-Client-Info>.*BRAVIA KDL-\d{2}(([A-Z](1|5|E1|R1|BR45|BR9|[1357]0\d{2}|4\d{3}))|(S55|S57|W51|Z51|Z58)\d0).*</X-AV-Client-Info>
</HttpHeaders>
</Detection>
<!-- Transcode baseline h264 in mp4/non-isom container -->
<Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="17000" targetACodec="ac3" aBitrate="192" DAR="16:9">
<Matches container="mp4" vCodec="h264" profile="baseline" ftypNotIn="isom" />
<Video targetContainer="mpeg" targetACodec="ac3">
<Matches container="mpeg" vCodec="mpeg2video" aCodec="mp2" />
<OnlineTranscoding>
<Matches container="mp4" vCodec="h264" profile="baseline" ftypNotIn="isom" /> <!-- Transcode baseline h264 in mp4/non-isom container -->
<Matches container="*" vCodec="h264"/><!-- Some h264 resolution not supported -->
</OnlineTranscoding>
</Profile>nichibus wrote:Why ServiioService after some minuts go to 50% of my CPU?
nichibus wrote:I solved the problem of ServiioService.exe that overload my CPU installing Serviio 1.0.1)
nichibus wrote:ffmpeg.exe is ok, is max 50% of CPU.
I saw that the problem of video jerky and the TV Sony Message there are after about 10 minutes i turn on my PC.
I think the problem is ServiioService.exe.
When ServiioService.exe is about 2% of my CPU is all OK and I can stream online video. But after some minutes ServioService.exe process go to 50%-60% of CPU and my CPU goes overload with ffmpeg encoding process.
Even if I turn off the streaming from my TV, the ServiioService.exe remain 50%-60% of CPU until I turn off my PC.
Why ServiioService after some minuts go to 50% of my CPU? When I start my PC ServvioService is only 2-3% and all is Ok.
