3D subtitles *.idx / *.xml
Meelis
Post Wed Apr 03, 2013 9:39 pm
For first i tryed to search from forum about 3D subtitles but no result... Seems 3D is too short word for search. Okey, i will go on with my request / question...
I have one 3D movie. I added subtitle file *.srt and its working but to read it its not good... its like not in focus or something like that. So, here is my request / question. Is it possible to add to serviio possibility to read out / support 3d subtitle files like *.idx and *.xml? Why those files. Cos its easy way to convert *.srt file to 3D subtitle file as *.idx /*.xml with program 3D-Subtitler. But the problem is that serviio or TV cant read out it correctly. Actually i dont cnow, is it a DLNA server problem or TV problem why system cant read it out. I tryed to mux subtitle file into *.mkv file... yes, it will read out the text but without correct font. Its just like usual text from *.srt file.
:roll:
Meelis
Post Mon Apr 08, 2013 10:54 am
Re: 3D subtitles *.idx / *.xml
hmm.... I am the onlyone who have this problem? Nobody watching 3D movies?
Meelis
Post Mon Apr 15, 2013 10:48 pm
Still no news about 3D subtitles support? Any hint, tips or experience?
Post Tue Apr 16, 2013 8:30 am
I assume they are bitmap based files, so not supported by Seviio atm.
Meelis
Post Tue Apr 16, 2013 8:36 pm
zip wrote:I assume they are bitmap based files, so not supported by Seviio atm.
Tnx for reply!
I try to you make a fast and short overview. Then you can see and say as expert is it a some sort of abitmap based files or not. Also those two files attached to the post.
*.idx file
# VobSub index file, v7 (do not modify this line!)
# Created by BDSup2Sub 4.0.0
# Frame size
# Origin - upper-left corner
org: 0, 0
# Scaling
scale: 100%, 100%
# Alpha blending
alpha: 100%
# Smoothing
smooth: OFF
# Fade in/out in milliseconds
fadein/out: 0, 0
# Force subtitle placement relative to (org.x, org.y)
align: OFF at LEFT TOP
# For correcting non-progressive desync. (in millisecs or hh:mm:ss:ms)
time offset: 0
# ON: displays only forced subtitles, OFF: shows everything
forced subs: OFF
# The palette of the generated file
palette: 000000, f0f0f0, cccccc, 999999, 3333fa, 1111bb, fa3333, bb1111, 33fa33, 11bb11, fafa33, bbbb11, fa33fa, bb11bb, 33fafa, 11bbbb
# Custom colors (transp idxs and the four colors)
custom colors: OFF, tridx: 1000, colors: 000000, 444444, 888888, cccccc
# Language index in use
langidx: 0
# English
id: en, index: 0
# Decomment next line to activate alternative name in DirectVobSub / Windows Media Player 6.x
# alt: English
# Vob/Cell ID: 1, 1 (PTS: 0)
timestamp: 00:00:00:959, filepos: 000000000
timestamp: 00:00:21:730, filepos: 000005800
timestamp: 00:00:23:857, filepos: 000008800
timestamp: 00:01:21:164, filepos: 00000f000
timestamp: 00:01:25:210, filepos: 000015800
timestamp: 00:01:30:966, filepos: 00001b000
timestamp: 00:01:44:438, filepos: 00001f800
timestamp: 00:01:49:359, filepos: 000025800
timestamp: 00:01:53:572, filepos: 000028000
timestamp: 00:01:57:618, filepos: 00002c000
timestamp: 00:02:00:871, filepos: 000031000
timestamp: 00:02:05:500, filepos: 000039000
timestamp: 00:02:08:587, filepos: 00003e000
timestamp: 00:02:11:173, filepos: 000040800
timestamp: 00:03:13:402, filepos: 000042000
timestamp: 00:03:41:012, filepos: 000043000
timestamp: 00:03:45:183, filepos: 000048800
timestamp: 00:03:48:645, filepos: 00004f000
timestamp: 00:03:52:566, filepos: 000056000
timestamp: 00:04:25:807, filepos: 000058000
timestamp: 00:04:28:852, filepos: 00005d800
timestamp: 00:04:31:730, filepos: 000061000
timestamp: 00:04:35:692, filepos: 000066800
timestamp: 00:04:40:322, filepos: 00006c800
timestamp: 00:04:42:199, filepos: 000070000
timestamp: 00:04:47:245, filepos: 000076000
timestamp: 00:04:49:581, filepos: 000079800
timestamp: 00:04:52:918, filepos: 00007f000
timestamp: 00:04:56:213, filepos: 000084000
timestamp: 00:04:59:966, filepos: 000089000
timestamp: 00:05:04:095, filepos: 00008e000
timestamp: 00:05:48:431, filepos: 000090800
timestamp: 00:05:51:601, filepos: 000093000
timestamp: 00:05:55:105, filepos: 000096800
timestamp: 00:05:57:148, filepos: 00009a000
timestamp: 00:06:00:235, filepos: 00009f000
timestamp: 00:06:03:572, filepos: 0000a2000
timestamp: 00:06:05:532, filepos: 0000a4000
timestamp: 00:06:09:244, filepos: 0000aa000
timestamp: 00:06:13:081, filepos: 0000ad000
timestamp: 00:06:16:793, filepos: 0000af000
timestamp: 00:06:29:681, filepos: 0000b0800
timestamp: 00:06:31:850, filepos: 0000b2000
timestamp: 00:06:34:561, filepos: 0000b5000
timestamp: 00:06:37:564, filepos: 0000bb000
timestamp: 00:06:39:566, filepos: 0000bd000
timestamp: 00:06:42:110, filepos: 0000c1800
timestamp: 00:06:45:113, filepos: 0000c4800
timestamp: 00:06:48:783, filepos: 0000c9800
timestamp: 00:06:51:578, filepos: 0000cc800
timestamp: 00:07:20:231, filepos: 0000ce000
timestamp: 00:07:23:526, filepos: 0000d4000
timestamp: 00:07:27:405, filepos: 0000db000
timestamp: 00:07:30:575, filepos: 0000e0000
timestamp: 00:07:34:037, filepos: 0000e6800
timestamp: 00:07:36:831, filepos: 0000eb000
timestamp: 00:07:40:418, filepos: 0000f1000
timestamp: 00:07:44:506, filepos: 0000f5000
timestamp: 00:07:47:342, filepos: 0000fa800
timestamp: 00:07:50:929, filepos: 0000fd800
timestamp: 00:08:03:483, filepos: 000101800
timestamp: 00:08:17:163, filepos: 000103000
timestamp: 00:08:20:250, filepos: 000105800
timestamp: 00:08:22:711, filepos: 000107800
timestamp: 00:08:25:505, filepos: 00010d000
timestamp: 00:08:29:050, filepos: 000115000
timestamp: 00:08:33:263, filepos: 00011c000
timestamp: 00:08:36:433, filepos: 000121800
timestamp: 00:08:39:394, filepos: 000127000
timestamp: 00:08:42:856, filepos: 00012d000
timestamp: 00:08:45:483, filepos: 00012f800
timestamp: 00:08:49:612, filepos: 000135000
timestamp: 00:08:52:032, filepos: 00013a000
timestamp: 00:08:54:409, filepos: 00013e800
timestamp: 00:08:58:204, filepos: 000142000
timestamp: 00:09:00:915, filepos: 000145000
timestamp: 00:09:03:877, filepos: 000149800
timestamp: 00:09:06:171, filepos: 00014d000
timestamp: 00:09:08:965, filepos: 000150800
timestamp: 00:09:13:762, filepos: 000152000
timestamp: 00:09:18:516, filepos: 000159800
timestamp: 00:09:25:023, filepos: 00015c800
timestamp: 00:09:30:779, filepos: 000163800
timestamp: 00:09:36:993, filepos: 00016b800
timestamp: 00:09:38:453, filepos: 00016d800
timestamp: 00:09:41:331, filepos: 000172000
timestamp: 00:09:44:250, filepos: 000178800
timestamp: 00:09:47:796, filepos: 00017f800
timestamp: 00:09:50:924, filepos: 000184800
timestamp: 00:09:55:303, filepos: 00018a800
timestamp: 00:10:00:308, filepos: 000192800
timestamp: 00:10:02:477, filepos: 000196000
timestamp: 00:10:05:146, filepos: 00019a000
timestamp: 00:10:08:817, filepos: 00019b800
timestamp: 00:10:12:529, filepos: 0001a1000
timestamp: 00:10:14:697, filepos: 0001a4800
timestamp: 00:10:17:575, filepos: 0001a9800
timestamp: 00:10:21:663, filepos: 0001af000
timestamp: 00:10:24:833, filepos: 0001b5000
timestamp: 00:10:29:212, filepos: 0001bd800
timestamp: 00:10:34:509, filepos: 0001c5800
timestamp: 00:10:37:762, filepos: 0001cc000
timestamp: 00:10:41:933, filepos: 0001d2000
timestamp: 00:10:47:021, filepos: 0001d9800
timestamp: 00:10:50:024, filepos: 0001de800
timestamp: 00:10:55:822, filepos: 0001e7000
timestamp: 00:10:59:200, filepos: 0001ed000
timestamp: 00:11:03:288, filepos: 0001f3000
timestamp: 00:11:06:207, filepos: 0001f8800
timestamp: 00:11:10:628, filepos: 000200800
timestamp: 00:11:14:132, filepos: 000207800
timestamp: 00:11:16:634, filepos: 00020b800
timestamp: 00:11:20:096, filepos: 000210000
timestamp: 00:11:33:026, filepos: 000213000
timestamp: 00:11:34:277, filepos: 000214800
timestamp: 00:11:45:038, filepos: 000218000
timestamp: 00:11:47:916, filepos: 00021e000
timestamp: 00:11:51:753, filepos: 000225800
timestamp: 00:11:55:089, filepos: 00022c000
timestamp: 00:11:56:799, filepos: 00022f800
timestamp: 00:12:00:762, filepos: 000237000
timestamp: 00:12:05:308, filepos: 00023e000
timestamp: 00:12:11:105, filepos: 000242000
timestamp: 00:12:13:483, filepos: 000244000
timestamp: 00:12:46:766, filepos: 000246000
timestamp: 00:12:49:477, filepos: 00024b800
timestamp: 00:12:52:313, filepos: 00024f800
timestamp: 00:12:54:774, filepos: 000252800
timestamp: 00:12:59:195, filepos: 000257800
timestamp: 00:13:03:324, filepos: 00025a800
timestamp: 00:13:05:827, filepos: 00025d800
timestamp: 00:13:09:872, filepos: 00025f000
timestamp: 00:13:12:000, filepos: 000261800
timestamp: 00:13:18:089, filepos: 000262800
timestamp: 00:13:43:781, filepos: 000264000
timestamp: 00:13:46:868, filepos: 000268000
timestamp: 00:13:52:582, filepos: 00026d800
timestamp: 00:14:01:007, filepos: 000274000
timestamp: 00:14:04:052, filepos: 000275000
timestamp: 00:14:07:263, filepos: 000278800
timestamp: 00:14:10:892, filepos: 00027f800
timestamp: 00:14:14:729, filepos: 000282000
timestamp: 00:14:23:863, filepos: 000284000
timestamp: 00:14:25:656, filepos: 000285800
timestamp: 00:14:38:961, filepos: 000287800
timestamp: 00:14:49:597, filepos: 00028a000
timestamp: 00:14:52:600, filepos: 00028b000
timestamp: 00:14:59:524, filepos: 00028d800
timestamp: 00:15:02:068, filepos: 000291000
timestamp: 00:15:05:905, filepos: 000292000
timestamp: 00:15:08:324, filepos: 000297800
timestamp: 00:15:11:661, filepos: 00029d800
timestamp: 00:15:15:540, filepos: 0002a5800
timestamp: 00:15:18:376, filepos: 0002ab000
timestamp: 00:15:21:504, filepos: 0002b1000
timestamp: 00:15:26:050, filepos: 0002b6000
timestamp: 00:15:32:932, filepos: 0002bd800
timestamp: 00:15:41:441, filepos: 0002c0800
timestamp: 00:15:44:819, filepos: 0002c6800
timestamp: 00:15:48:823, filepos: 0002cc800
timestamp: 00:15:53:244, filepos: 0002d3800
timestamp: 00:15:56:122, filepos: 0002d8800
timestamp: 00:15:58:416, filepos: 0002dc000
timestamp: 00:16:02:879, filepos: 0002e1800
timestamp: 00:16:05:214, filepos: 0002e4000
timestamp: 00:16:07:758, filepos: 0002e6000
timestamp: 00:16:12:013, filepos: 0002e9000
timestamp: 00:16:17:268, filepos: 0002ee800
timestamp: 00:16:23:316, filepos: 0002f0000
timestamp: 00:16:27:612, filepos: 0002f7800
timestamp: 00:16:31:449, filepos: 0002fb800
timestamp: 00:16:34:410, filepos: 000300800
timestamp: 00:16:36:621, filepos: 000302800
timestamp: 00:16:42:960, filepos: 00030a000
timestamp: 00:16:48:424, filepos: 000310000
timestamp: 00:16:50:885, filepos: 000313800
timestamp: 00:16:53:095, filepos: 000316000
timestamp: 00:16:55:139, filepos: 000318000
timestamp: 00:16:57:892, filepos: 00031a800
timestamp: 00:17:01:062, filepos: 00031d000
timestamp: 00:17:34:303, filepos: 00031e800
timestamp: 00:17:39:016, filepos: 000326000
timestamp: 00:17:44:063, filepos: 00032e000
timestamp: 00:17:48:859, filepos: 000336000
timestamp: 00:17:52:113, filepos: 00033a000
timestamp: 00:17:55:533, filepos: 00033d000
timestamp: 00:17:57:451, filepos: 00033e800
timestamp: 00:18:01:414, filepos: 000341800
timestamp: 00:18:03:583, filepos: 000344000
timestamp: 00:18:06:669, filepos: 000347000
timestamp: 00:18:10:339, filepos: 00034c000
timestamp: 00:18:15:136, filepos: 00034f000
timestamp: 00:18:18:973, filepos: 000356000
timestamp: 00:18:21:934, filepos: 00035b800
timestamp: 00:18:24:145, filepos: 00035e800
timestamp: 00:18:28:149, filepos: 000365000
timestamp: 00:18:32:987, filepos: 00036c000
timestamp: 00:18:35:281, filepos: 000370800
timestamp: 00:18:38:492, filepos: 000376000
timestamp: 00:18:41:704, filepos: 000377000
timestamp: 00:18:46:626, filepos: 000379000
timestamp: 00:18:49:462, filepos: 00037f000
timestamp: 00:18:51:964, filepos: 000383800
timestamp: 00:18:54:675, filepos: 000388800
timestamp: 00:18:59:221, filepos: 00038f000
timestamp: 00:19:03:184, filepos: 000395000
timestamp: 00:19:14:487, filepos: 000396800
timestamp: 00:19:16:447, filepos: 000398000
timestamp: 00:19:20:034, filepos: 00039c000
timestamp: 00:19:24:538, filepos: 0003a4000
timestamp: 00:19:30:836, filepos: 0003a6800
timestamp: 00:19:32:755, filepos: 0003a9800
timestamp: 00:19:37:134, filepos: 0003b1000
timestamp: 00:19:41:639, filepos: 0003b9000
timestamp: 00:19:46:811, filepos: 0003bf000
timestamp: 00:19:51:482, filepos: 0003c3800
timestamp: 00:19:55:778, filepos: 0003c7000
timestamp: 00:21:54:730, filepos: 0003cb000
timestamp: 00:21:59:693, filepos: 0003d2800
timestamp: 00:22:02:738, filepos: 0003d7000
timestamp: 00:22:07:243, filepos: 0003de800
timestamp: 00:22:11:205, filepos: 0003e5000
timestamp: 00:22:15:835, filepos: 0003eb800
timestamp: 00:22:19:213, filepos: 0003f1800
timestamp: 00:22:22:341, filepos: 0003f7800
timestamp: 00:22:25:010, filepos: 0003fa000
timestamp: 00:22:28:097, filepos: 0003ff800
timestamp: 00:22:32:309, filepos: 000407000
timestamp: 00:22:35:855, filepos: 00040c800
timestamp: 00:22:39:942, filepos: 000413800
timestamp: 00:22:43:445, filepos: 000419800
timestamp: 00:22:46:156, filepos: 00041e000
timestamp: 00:23:13:851, filepos: 000424800
timestamp: 00:23:31:327, filepos: 000426800
timestamp: 00:23:35:664, filepos: 000427800
timestamp: 00:23:43:589, filepos: 000429800
timestamp: 00:23:46:550, filepos: 00042d000
timestamp: 00:23:49:011, filepos: 00042f000
timestamp: 00:23:51:388, filepos: 000433000
timestamp: 00:23:59:021, filepos: 000435800
timestamp: 00:24:02:107, filepos: 00043a000
timestamp: 00:24:05:527, filepos: 00043e800
timestamp: 00:24:10:449, filepos: 000445800
timestamp: 00:24:13:494, filepos: 000449000
timestamp: 00:24:16:997, filepos: 00044c800
timestamp: 00:24:20:501, filepos: 000450800
timestamp: 00:24:24:004, filepos: 000455000
timestamp: 00:24:27:383, filepos: 000459800
timestamp: 00:24:30:302, filepos: 00045f800
timestamp: 00:24:36:016, filepos: 000465800
timestamp: 00:24:39:061, filepos: 000469800
timestamp: 00:24:42:606, filepos: 00046e800
timestamp: 00:24:45:317, filepos: 000471800
timestamp: 00:24:52:199, filepos: 000473800
timestamp: 00:26:26:210, filepos: 000475000
timestamp: 00:26:28:128, filepos: 000478000
timestamp: 00:26:31:131, filepos: 00047d000
timestamp: 00:26:33:884, filepos: 000480800
timestamp: 00:26:37:221, filepos: 000486000
timestamp: 00:26:44:770, filepos: 00048c000
timestamp: 00:26:48:524, filepos: 000491800
timestamp: 00:26:54:655, filepos: 000499000
timestamp: 00:26:56:406, filepos: 00049a000
timestamp: 00:26:58:784, filepos: 00049c000
timestamp: 00:27:01:787, filepos: 0004a0000
timestamp: 00:27:25:269, filepos: 0004a1800
timestamp: 00:27:30:983, filepos: 0004a6000
timestamp: 00:27:38:157, filepos: 0004a8000
timestamp: 00:27:41:577, filepos: 0004ae800
timestamp: 00:27:45:956, filepos: 0004b5000
timestamp: 00:27:50:878, filepos: 0004ba800
timestamp: 00:27:57:926, filepos: 0004bd800
timestamp: 00:28:01:680, filepos: 0004be800
timestamp: 00:28:05:184, filepos: 0004c4000
timestamp: 00:28:08:353, filepos: 0004c8000
timestamp: 00:28:10:981, filepos: 0004cd000
timestamp: 00:28:13:984, filepos: 0004d0800
timestamp: 00:28:17:571, filepos: 0004d5000
timestamp: 00:28:19:531, filepos: 0004d8800
timestamp: 00:28:22:826, filepos: 0004dd800
timestamp: 00:28:27:331, filepos: 0004df800
timestamp: 00:28:29:291, filepos: 0004e2000
timestamp: 00:28:32:419, filepos: 0004e5000
timestamp: 00:28:34:296, filepos: 0004e6800
timestamp: 00:28:37:591, filepos: 0004e8800
timestamp: 00:28:41:929, filepos: 0004eb000
timestamp: 00:28:45:224, filepos: 0004f1000
timestamp: 00:28:48:894, filepos: 0004f7800
timestamp: 00:28:51:980, filepos: 0004fd800
timestamp: 00:28:53:941, filepos: 000500000
timestamp: 00:28:59:029, filepos: 000507800
timestamp: 00:29:05:953, filepos: 00050d800
timestamp: 00:29:08:664, filepos: 000511800
timestamp: 00:29:17:881, filepos: 000517800
timestamp: 00:29:28:392, filepos: 00051b000
timestamp: 00:29:31:395, filepos: 00051e800
timestamp: 00:29:33:855, filepos: 000523800
timestamp: 00:29:42:781, filepos: 000527800
timestamp: 00:29:45:701, filepos: 00052c800
timestamp: 00:29:53:375, filepos: 000535000
timestamp: 00:29:55:752, filepos: 000538000
timestamp: 00:29:58:088, filepos: 000539000
timestamp: 00:30:05:929, filepos: 00053a000
timestamp: 00:30:10:100, filepos: 00053d800
timestamp: 00:30:15:397, filepos: 000542800
timestamp: 00:30:19:151, filepos: 00054a000
timestamp: 00:30:22:446, filepos: 000550000
timestamp: 00:30:27:367, filepos: 000558000
timestamp: 00:30:31:621, filepos: 00055e800
timestamp: 00:30:34:458, filepos: 000563800
timestamp: 00:30:36:126, filepos: 000564800
timestamp: 00:30:41:006, filepos: 00056d000
timestamp: 00:30:44:051, filepos: 000571000
timestamp: 00:30:46:595, filepos: 000575000
timestamp: 00:30:49:222, filepos: 000579800
timestamp: 00:30:51:558, filepos: 00057e000
timestamp: 00:30:55:479, filepos: 000583800
timestamp: 00:30:58:065, filepos: 000586000
timestamp: 00:31:02:319, filepos: 00058e800
timestamp: 00:31:04:863, filepos: 000592800
timestamp: 00:31:08:158, filepos: 000598000
timestamp: 00:31:12:454, filepos: 00059f800
timestamp: 00:31:15:123, filepos: 0005a3000
timestamp: 00:31:17:542, filepos: 0005a7800
timestamp: 00:31:21:755, filepos: 0005ab000
timestamp: 00:31:25:926, filepos: 0005ad000
timestamp: 00:31:30:347, filepos: 0005b5000
timestamp: 00:31:32:599, filepos: 0005b7000
timestamp: 00:31:35:894, filepos: 0005ba800
timestamp: 00:31:38:730, filepos: 0005bf800
timestamp: 00:31:41:566, filepos: 0005c4800
timestamp: 00:31:43:693, filepos: 0005c8800
timestamp: 00:31:46:780, filepos: 0005cb000
timestamp: 00:31:51:034, filepos: 0005cc800
timestamp: 00:31:55:330, filepos: 0005d2800
timestamp: 00:32:00:752, filepos: 0005db000
timestamp: 00:32:02:921, filepos: 0005de000
timestamp: 00:32:05:424, filepos: 0005e2800
timestamp: 00:32:11:304, filepos: 0005e4000
timestamp: 00:32:14:015, filepos: 0005e8800
timestamp: 00:32:24:609, filepos: 0005eb800
timestamp: 00:32:29:114, filepos: 0005f1000
timestamp: 00:32:33:702, filepos: 0005f3800
timestamp: 00:32:37:831, filepos: 0005f6000
timestamp: 00:32:39:833, filepos: 0005fa000
timestamp: 00:32:44:004, filepos: 0005fd800
timestamp: 00:32:49:551, filepos: 000605000
timestamp: 00:32:53:430, filepos: 000609000
timestamp: 00:32:55:015, filepos: 00060a800
timestamp: 00:32:56:975, filepos: 00060d800
timestamp: 00:32:59:811, filepos: 000611000
timestamp: 00:33:04:107, filepos: 000615800
timestamp: 00:33:17:621, filepos: 00061b000
timestamp: 00:33:21:458, filepos: 00061f000
timestamp: 00:33:24:836, filepos: 000625800
timestamp: 00:33:28:673, filepos: 00062b000
timestamp: 00:33:31:510, filepos: 00062b800
timestamp: 00:33:35:847, filepos: 000631800
timestamp: 00:33:41:019, filepos: 000633000
timestamp: 00:33:45:315, filepos: 000637800
timestamp: 00:33:50:695, filepos: 000638800
timestamp: 00:33:54:324, filepos: 00063c800
timestamp: 00:33:58:578, filepos: 000642000
timestamp: 00:34:02:832, filepos: 00064a800
timestamp: 00:34:05:752, filepos: 00064f000
timestamp: 00:34:09:506, filepos: 000651000
timestamp: 00:34:14:219, filepos: 000658800
timestamp: 00:34:17:347, filepos: 00065c000
timestamp: 00:34:21:017, filepos: 000663800
timestamp: 00:34:24:312, filepos: 000669000
timestamp: 00:34:26:314, filepos: 00066c800
timestamp: 00:34:31:528, filepos: 000674800
timestamp: 00:34:33:822, filepos: 000677000
timestamp: 00:34:38:410, filepos: 00067c000
timestamp: 00:34:40:412, filepos: 00067e800
timestamp: 00:34:45:125, filepos: 000686800
timestamp: 00:34:48:670, filepos: 00068d000
timestamp: 00:34:52:257, filepos: 000694800
timestamp: 00:34:57:971, filepos: 00069d000
timestamp: 00:35:03:476, filepos: 0006a5800
timestamp: 00:35:08:189, filepos: 0006ae000
timestamp: 00:35:12:652, filepos: 0006b4800
timestamp: 00:35:15:488, filepos: 0006b9800
timestamp: 00:35:18:700, filepos: 0006c0000
timestamp: 00:35:21:703, filepos: 0006c6000
timestamp: 00:35:25:040, filepos: 0006cc000
timestamp: 00:35:30:462, filepos: 0006d0000
timestamp: 00:35:34:132, filepos: 0006d6800
timestamp: 00:35:47:896, filepos: 0006d9800
timestamp: 00:35:50:231, filepos: 0006de000
timestamp: 00:35:53:610, filepos: 0006e4000
timestamp: 00:35:55:278, filepos: 0006e7000
timestamp: 00:36:06:373, filepos: 0006ec000
timestamp: 00:36:07:749, filepos: 0006ed800
timestamp: 00:36:10:293, filepos: 0006f2800
timestamp: 00:36:18:301, filepos: 0006f9000
timestamp: 00:36:20:804, filepos: 0006fc800
timestamp: 00:36:23:515, filepos: 000701000
timestamp: 00:36:26:142, filepos: 000707000
timestamp: 00:36:29:145, filepos: 000708000
timestamp: 00:36:31:147, filepos: 000709000
timestamp: 00:36:35:610, filepos: 00070f800
timestamp: 00:36:42:534, filepos: 000715000
timestamp: 00:36:48:957, filepos: 00071c800
timestamp: 00:36:53:586, filepos: 000721800
timestamp: 00:36:57:632, filepos: 000728000
timestamp: 00:37:02:679, filepos: 00072b000
timestamp: 00:37:06:850, filepos: 00072f800
timestamp: 00:37:11:688, filepos: 000738000
timestamp: 00:37:15:817, filepos: 00073f800
timestamp: 00:37:19:112, filepos: 000743000
timestamp: 00:37:21:906, filepos: 000747800
timestamp: 00:37:24:826, filepos: 00074d000
timestamp: 00:37:28:580, filepos: 000754800
timestamp: 00:37:32:292, filepos: 00075b000
timestamp: 00:37:36:004, filepos: 000762000
timestamp: 00:37:46:181, filepos: 000764000
timestamp: 00:37:49:392, filepos: 000769000
timestamp: 00:37:51:478, filepos: 00076c800
timestamp: 00:37:55:732, filepos: 000774000
timestamp: 00:37:59:152, filepos: 00077a800
timestamp: 00:38:01:571, filepos: 00077d000
timestamp: 00:38:03:281, filepos: 00077e800
timestamp: 00:38:05:450, filepos: 000780800
timestamp: 00:38:07:577, filepos: 000782000
timestamp: 00:38:11:164, filepos: 000784800
timestamp: 00:38:13:291, filepos: 000788000
timestamp: 00:38:16:211, filepos: 00078d000
timestamp: 00:38:19:464, filepos: 000793000
timestamp: 00:38:23:510, filepos: 000797000
timestamp: 00:38:27:430, filepos: 00079e000
timestamp: 00:38:31:142, filepos: 0007a3800
timestamp: 00:38:36:481, filepos: 0007ab800
timestamp: 00:38:38:650, filepos: 0007ad800
timestamp: 00:38:42:654, filepos: 0007b5000
timestamp: 00:38:45:657, filepos: 0007ba000
timestamp: 00:38:48:660, filepos: 0007bf000
timestamp: 00:38:52:121, filepos: 0007c2800
timestamp: 00:38:54:999, filepos: 0007c4800
timestamp: 00:39:41:838, filepos: 0007c6000
timestamp: 00:40:08:323, filepos: 0007c7800
timestamp: 00:40:47:820, filepos: 0007ca000
timestamp: 00:40:51:407, filepos: 0007d0800
timestamp: 00:40:54:869, filepos: 0007d5000
timestamp: 00:40:58:665, filepos: 0007dd000
timestamp: 00:41:01:250, filepos: 0007e0800
timestamp: 00:41:03:753, filepos: 0007e4000
timestamp: 00:41:07:340, filepos: 0007e9000
timestamp: 00:41:12:220, filepos: 0007ef800
timestamp: 00:41:15:682, filepos: 0007f5800
timestamp: 00:41:17:850, filepos: 0007f7000
timestamp: 00:41:21:437, filepos: 0007fc000
timestamp: 00:41:25:358, filepos: 000803800
timestamp: 00:41:28:736, filepos: 00080a000
timestamp: 00:41:33:574, filepos: 00080f800
timestamp: 00:41:36:369, filepos: 000815000
timestamp: 00:41:39:872, filepos: 00081b000
timestamp: 00:41:52:510, filepos: 000821000
timestamp: 00:41:55:847, filepos: 000825000
timestamp: 00:42:00:518, filepos: 00082b800
timestamp: 00:42:03:438, filepos: 00082d800
timestamp: 00:42:06:816, filepos: 000831800
timestamp: 00:42:09:360, filepos: 000833800
timestamp: 00:42:11:821, filepos: 000839000
timestamp: 00:42:16:284, filepos: 000840800
timestamp: 00:42:20:788, filepos: 000847800
timestamp: 00:42:29:964, filepos: 00084b800
timestamp: 00:42:33:301, filepos: 00084e000
timestamp: 00:42:36:179, filepos: 000851000
timestamp: 00:42:39:140, filepos: 000856000
timestamp: 00:42:40:892, filepos: 000857000
timestamp: 00:42:43:352, filepos: 000858800
timestamp: 00:42:52:487, filepos: 00085e000
timestamp: 00:42:56:074, filepos: 000862000
timestamp: 00:43:00:328, filepos: 000864800
timestamp: 00:43:04:290, filepos: 000868800
timestamp: 00:43:12:965, filepos: 00086e800
timestamp: 00:43:16:469, filepos: 000873000
timestamp: 00:43:18:930, filepos: 000878000
timestamp: 00:43:20:932, filepos: 00087a000
timestamp: 00:43:23:643, filepos: 00087c800
timestamp: 00:43:26:062, filepos: 000880000
timestamp: 00:43:30:358, filepos: 000887800
timestamp: 00:43:33:152, filepos: 00088b000
timestamp: 00:43:35:947, filepos: 000890000
timestamp: 00:43:43:371, filepos: 000893800
timestamp: 00:43:47:166, filepos: 00089a000
timestamp: 00:43:49:460, filepos: 00089e000
timestamp: 00:43:54:507, filepos: 0008a5800
timestamp: 00:43:56:843, filepos: 0008a8800
timestamp: 00:44:01:097, filepos: 0008b0800
timestamp: 00:44:04:851, filepos: 0008b8000
timestamp: 00:44:08:729, filepos: 0008c0000
timestamp: 00:44:12:567, filepos: 0008c5800
timestamp: 00:44:15:403, filepos: 0008c9800
timestamp: 00:44:19:740, filepos: 0008d1800
timestamp: 00:44:22:577, filepos: 0008d5000
timestamp: 00:44:25:580, filepos: 0008da000
timestamp: 00:44:32:753, filepos: 0008e2800
timestamp: 00:44:44:140, filepos: 0008e7000
timestamp: 00:44:47:435, filepos: 0008ea000
timestamp: 00:44:50:855, filepos: 0008f1000
timestamp: 00:44:56:360, filepos: 0008f7000
timestamp: 00:44:59:572, filepos: 0008fc800
timestamp: 00:45:02:575, filepos: 0008ff800
timestamp: 00:45:04:660, filepos: 000902000
timestamp: 00:45:09:248, filepos: 000908000
timestamp: 00:45:11:626, filepos: 00090c000
timestamp: 00:45:14:879, filepos: 000910800
timestamp: 00:45:18:132, filepos: 000916000
timestamp: 00:45:21:594, filepos: 000917000
timestamp: 00:45:24:180, filepos: 000919800
timestamp: 00:45:29:101, filepos: 000921800
timestamp: 00:45:31:103, filepos: 000924800
timestamp: 00:45:33:856, filepos: 000928000
timestamp: 00:45:38:236, filepos: 00092e800
timestamp: 00:45:42:448, filepos: 000935800
timestamp: 00:45:46:369, filepos: 00093c800
timestamp: 00:45:50:331, filepos: 000943000
timestamp: 00:45:54:085, filepos: 00094a000
timestamp: 00:45:59:006, filepos: 000952000
timestamp: 00:46:02:009, filepos: 000957800
timestamp: 00:46:06:264, filepos: 00095d800
timestamp: 00:46:09:976, filepos: 000964800
timestamp: 00:46:12:979, filepos: 000969000
timestamp: 00:46:16:732, filepos: 00096f000
timestamp: 00:46:22:154, filepos: 000975800
timestamp: 00:46:25:449, filepos: 000979800
timestamp: 00:46:27:159, filepos: 00097b800
timestamp: 00:46:30:162, filepos: 000980800
timestamp: 00:46:33:541, filepos: 000983800
timestamp: 00:47:04:155, filepos: 000987800
timestamp: 00:47:06:115, filepos: 000989800
timestamp: 00:47:08:993, filepos: 00098e800
timestamp: 00:47:15:624, filepos: 000992800
timestamp: 00:47:18:252, filepos: 000995800
timestamp: 00:47:22:256, filepos: 000999000
timestamp: 00:47:26:677, filepos: 00099f800
timestamp: 00:47:29:805, filepos: 0009a5000
timestamp: 00:47:32:141, filepos: 0009a6000
timestamp: 00:47:35:227, filepos: 0009ac000
timestamp: 00:47:39:065, filepos: 0009b1800
timestamp: 00:47:42:526, filepos: 0009b8800
timestamp: 00:47:45:988, filepos: 0009be800
timestamp: 00:47:48:991, filepos: 0009c2800
timestamp: 00:47:53:204, filepos: 0009c9800
timestamp: 00:47:55:331, filepos: 0009cd000
timestamp: 00:47:58:167, filepos: 0009d2000
timestamp: 00:48:01:295, filepos: 0009d7800
timestamp: 00:48:06:300, filepos: 0009de800
timestamp: 00:48:09:595, filepos: 0009e4000
timestamp: 00:48:20:189, filepos: 0009eb800
timestamp: 00:48:23:442, filepos: 0009f0000
timestamp: 00:48:31:617, filepos: 0009f2000
timestamp: 00:48:44:130, filepos: 0009f3800
timestamp: 00:48:47:174, filepos: 0009f7000
timestamp: 00:48:54:390, filepos: 0009fd000
timestamp: 00:49:00:396, filepos: 0009ff800
timestamp: 00:49:06:694, filepos: 000a01000
timestamp: 00:49:17:580, filepos: 000a02800
timestamp: 00:49:24:211, filepos: 000a04000
timestamp: 00:50:53:592, filepos: 000a05800
timestamp: 00:50:56:679, filepos: 000a09000
timestamp: 00:51:00:349, filepos: 000a0f000
timestamp: 00:51:03:143, filepos: 000a14800
timestamp: 00:51:11:068, filepos: 000a1a800
timestamp: 00:51:24:290, filepos: 000a1c000
timestamp: 00:51:28:502, filepos: 000a24800
timestamp: 00:52:34:568, filepos: 000a2a800
timestamp: 00:52:40:866, filepos: 000a2e800
timestamp: 00:52:43:952, filepos: 000a34800
timestamp: 00:52:48:207, filepos: 000a3c800
timestamp: 00:52:50:668, filepos: 000a40800
timestamp: 00:52:53:003, filepos: 000a44000
timestamp: 00:52:55:005, filepos: 000a47800
timestamp: 00:52:59:510, filepos: 000a4d000
timestamp: 00:53:04:264, filepos: 000a55000
timestamp: 00:53:07:351, filepos: 000a5a000
timestamp: 00:53:10:688, filepos: 000a5d800
timestamp: 00:53:15:192, filepos: 000a62800
timestamp: 00:53:18:821, filepos: 000a6a000
timestamp: 00:53:22:449, filepos: 000a70000
timestamp: 00:53:24:660, filepos: 000a71000
timestamp: 00:53:28:205, filepos: 000a75000
timestamp: 00:54:08:078, filepos: 000a7a800
timestamp: 00:54:19:673, filepos: 000a7c800
timestamp: 00:54:24:928, filepos: 000a84000
timestamp: 00:54:28:015, filepos: 000a86000
timestamp: 00:54:34:688, filepos: 000a8c000
timestamp: 00:54:43:363, filepos: 000a8e000
timestamp: 00:54:46:784, filepos: 000a93800
timestamp: 00:54:56:919, filepos: 000a9c000
timestamp: 00:54:59:004, filepos: 000a9e800
timestamp: 00:55:02:508, filepos: 000aa4800
timestamp: 00:55:25:781, filepos: 000aa7800
timestamp: 00:55:28:575, filepos: 000aac000
timestamp: 00:55:37:501, filepos: 000ab4800
timestamp: 00:55:40:087, filepos: 000ab9800
timestamp: 00:55:42:464, filepos: 000abe800
timestamp: 00:55:47:970, filepos: 000ac3800
timestamp: 00:56:19:376, filepos: 000ac7800
timestamp: 00:56:32:097, filepos: 000ac8800
timestamp: 00:56:34:516, filepos: 000ac9800
timestamp: 00:56:37:311, filepos: 000acb800
timestamp: 00:56:57:915, filepos: 000ace000
timestamp: 00:57:03:128, filepos: 000ad6000
timestamp: 00:57:07:174, filepos: 000ad9800
timestamp: 00:57:20:103, filepos: 000adb800
timestamp: 00:57:22:731, filepos: 000adc800
timestamp: 00:57:27:819, filepos: 000ae4000
timestamp: 00:57:32:115, filepos: 000aeb000
timestamp: 00:57:36:828, filepos: 000af3800
timestamp: 00:57:38:914, filepos: 000af7000
timestamp: 00:57:42:501, filepos: 000afc800
timestamp: 00:57:54:888, filepos: 000aff000
timestamp: 00:58:00:227, filepos: 000b02800
timestamp: 00:59:03:248, filepos: 000b04800
timestamp: 00:59:06:001, filepos: 000b07000
timestamp: 00:59:10:672, filepos: 000b08800
timestamp: 00:59:14:051, filepos: 000b0c000
timestamp: 00:59:16:803, filepos: 000b0e000
timestamp: 00:59:20:140, filepos: 000b13800
timestamp: 00:59:22:684, filepos: 000b15000
timestamp: 00:59:27:731, filepos: 000b1c000
timestamp: 00:59:30:400, filepos: 000b20800
timestamp: 00:59:32:235, filepos: 000b22000
timestamp: 00:59:35:238, filepos: 000b28000
timestamp: 01:00:16:071, filepos: 000b2c800
timestamp: 01:00:40:929, filepos: 000b2f000
timestamp: 01:00:44:683, filepos: 000b35800
timestamp: 01:00:46:643, filepos: 000b37000
timestamp: 01:00:59:614, filepos: 000b38800
timestamp: 01:01:04:452, filepos: 000b3d800
timestamp: 01:01:15:672, filepos: 000b41000
timestamp: 01:01:18:842, filepos: 000b45800
timestamp: 01:01:23:346, filepos: 000b47800
timestamp: 01:01:25:348, filepos: 000b4a000
timestamp: 01:01:29:936, filepos: 000b4d000
timestamp: 01:01:35:692, filepos: 000b52800
timestamp: 01:01:38:153, filepos: 000b56000
timestamp: 01:01:40:906, filepos: 000b5a800
timestamp: 01:01:46:077, filepos: 000b60000
timestamp: 01:01:48:205, filepos: 000b64000
timestamp: 01:01:51:791, filepos: 000b67000
timestamp: 01:01:56:213, filepos: 000b6a800
timestamp: 01:02:04:763, filepos: 000b6e800
timestamp: 01:02:07:724, filepos: 000b70800
timestamp: 01:02:16:983, filepos: 000b71800
timestamp: 01:02:36:628, filepos: 000b73000
timestamp: 01:02:38:630, filepos: 000b75000
timestamp: 01:02:48:974, filepos: 000b79800
timestamp: 01:02:50:517, filepos: 000b7a800
timestamp: 01:02:53:186, filepos: 000b7f000
timestamp: 01:02:55:647, filepos: 000b83000
timestamp: 01:03:00:026, filepos: 000b8a000
timestamp: 01:03:03:989, filepos: 000b90800
timestamp: 01:03:06:116, filepos: 000b93800
timestamp: 01:03:18:712, filepos: 000b94800
timestamp: 01:03:22:716, filepos: 000b9a800
timestamp: 01:03:26:011, filepos: 000b9f800
timestamp: 01:03:30:265, filepos: 000ba4800
timestamp: 01:03:35:895, filepos: 000ba6000
timestamp: 01:03:38:606, filepos: 000ba7000
timestamp: 01:03:42:152, filepos: 000bab800
timestamp: 01:03:48:366, filepos: 000bb4000
timestamp: 01:03:52:120, filepos: 000bba800
timestamp: 01:03:56:499, filepos: 000bc1000
timestamp: 01:04:02:422, filepos: 000bc3000
timestamp: 01:04:06:926, filepos: 000bc4800
timestamp: 01:04:10:055, filepos: 000bc9800
timestamp: 01:04:13:224, filepos: 000bcf000
timestamp: 01:04:16:811, filepos: 000bd6800
timestamp: 01:04:22:942, filepos: 000bd9800
timestamp: 01:04:24:694, filepos: 000bdc800
timestamp: 01:04:39:584, filepos: 000bdf800
timestamp: 01:04:50:804, filepos: 000be2000
timestamp: 01:04:53:640, filepos: 000be5800
timestamp: 01:04:57:185, filepos: 000be8000
timestamp: 01:04:59:604, filepos: 000bec800
timestamp: 01:05:02:232, filepos: 000bee000
timestamp: 01:05:05:735, filepos: 000bf0800
timestamp: 01:05:09:489, filepos: 000bf6800
timestamp: 01:05:11:741, filepos: 000bf7800
timestamp: 01:05:15:745, filepos: 000bfd000
timestamp: 01:05:19:082, filepos: 000c00000
timestamp: 01:05:21:376, filepos: 000c02000
timestamp: 01:05:23:628, filepos: 000c03800
timestamp: 01:05:28:716, filepos: 000c0c000
timestamp: 01:05:46:651, filepos: 000c12800
timestamp: 01:06:28:401, filepos: 000c18000
timestamp: 01:06:35:617, filepos: 000c1f000
timestamp: 01:06:39:370, filepos: 000c20800
timestamp: 01:06:41:873, filepos: 000c22000
timestamp: 01:06:45:126, filepos: 000c25000
timestamp: 01:06:47:712, filepos: 000c28800
timestamp: 01:06:50:924, filepos: 000c2a800
timestamp: 01:06:54:052, filepos: 000c2e800
timestamp: 01:06:56:679, filepos: 000c32000
timestamp: 01:07:00:350, filepos: 000c38800
timestamp: 01:07:04:312, filepos: 000c3f800
timestamp: 01:07:12:362, filepos: 000c45800
timestamp: 01:07:15:532, filepos: 000c48800
timestamp: 01:07:19:077, filepos: 000c4e800
timestamp: 01:07:21:663, filepos: 000c52800
timestamp: 01:07:23:665, filepos: 000c55800
timestamp: 01:07:26:167, filepos: 000c5a800
timestamp: 01:07:29:212, filepos: 000c60000
timestamp: 01:07:32:549, filepos: 000c66000
timestamp: 01:07:34:968, filepos: 000c6a800
timestamp: 01:07:39:764, filepos: 000c72800
timestamp: 01:07:43:268, filepos: 000c78800
timestamp: 01:07:53:570, filepos: 000c7b800
timestamp: 01:07:56:781, filepos: 000c81000
timestamp: 01:07:58:992, filepos: 000c86000
timestamp: 01:08:03:329, filepos: 000c8d000
timestamp: 01:08:06:291, filepos: 000c93800
timestamp: 01:08:13:089, filepos: 000c9a800
timestamp: 01:08:15:216, filepos: 000c9b800
timestamp: 01:08:33:276, filepos: 000c9f000
timestamp: 01:08:37:113, filepos: 000ca1800
timestamp: 01:08:41:701, filepos: 000ca5800
timestamp: 01:08:44:829, filepos: 000cab800
timestamp: 01:08:48:541, filepos: 000cb3000
timestamp: 01:08:51:711, filepos: 000cba000
timestamp: 01:08:53:671, filepos: 000cbd000
timestamp: 01:08:58:134, filepos: 000cc4800
timestamp: 01:09:01:179, filepos: 000cc6800
timestamp: 01:09:07:310, filepos: 000ccd800
timestamp: 01:09:08:895, filepos: 000ccf800
timestamp: 01:09:12:148, filepos: 000cd4800
timestamp: 01:09:15:985, filepos: 000cda800
timestamp: 01:09:20:365, filepos: 000ce1800
timestamp: 01:09:22:408, filepos: 000ce5000
timestamp: 01:09:25:495, filepos: 000ce8000
timestamp: 01:09:28:665, filepos: 000cec000
timestamp: 01:09:32:835, filepos: 000cf2800
timestamp: 01:09:37:048, filepos: 000cf9000
timestamp: 01:10:22:427, filepos: 000cfe000
timestamp: 01:10:26:806, filepos: 000d04000
timestamp: 01:10:59:630, filepos: 000d08000
timestamp: 01:11:01:549, filepos: 000d0c000
timestamp: 01:11:03:593, filepos: 000d0f800
timestamp: 01:11:05:803, filepos: 000d14800
timestamp: 01:11:07:138, filepos: 000d16000
timestamp: 01:11:10:767, filepos: 000d18800
timestamp: 01:11:13:770, filepos: 000d1d000
timestamp: 01:11:17:648, filepos: 000d1e000
timestamp: 01:11:20:193, filepos: 000d23000
timestamp: 01:11:22:320, filepos: 000d26000
timestamp: 01:11:24:989, filepos: 000d28000
timestamp: 01:11:28:493, filepos: 000d29800
timestamp: 01:11:52:058, filepos: 000d2b800
timestamp: 01:11:54:727, filepos: 000d2f000
timestamp: 01:11:58:189, filepos: 000d32000
timestamp: 01:12:01:692, filepos: 000d37800
timestamp: 01:12:04:403, filepos: 000d3d800
timestamp: 01:12:09:408, filepos: 000d46000
timestamp: 01:12:14:080, filepos: 000d4e000
timestamp: 01:12:18:960, filepos: 000d55800
timestamp: 01:12:25:758, filepos: 000d56800
timestamp: 01:12:28:678, filepos: 000d58000
timestamp: 01:12:31:556, filepos: 000d5a800
timestamp: 01:12:34:517, filepos: 000d60000
timestamp: 01:12:38:437, filepos: 000d63800
timestamp: 01:13:00:251, filepos: 000d67000
timestamp: 01:13:04:714, filepos: 000d6d000
timestamp: 01:13:07:717, filepos: 000d70000
timestamp: 01:13:09:927, filepos: 000d73000
timestamp: 01:13:39:415, filepos: 000d75000
timestamp: 01:13:42:710, filepos: 000d76000
timestamp: 01:13:44:045, filepos: 000d77800
timestamp: 01:13:47:673, filepos: 000d7b000
timestamp: 01:13:51:552, filepos: 000d7e800
timestamp: 01:14:01:437, filepos: 000d80800
timestamp: 01:14:06:025, filepos: 000d86800
timestamp: 01:14:11:238, filepos: 000d8c000
timestamp: 01:14:19:121, filepos: 000d8e800
timestamp: 01:15:10:673, filepos: 000d91000
timestamp: 01:15:19:056, filepos: 000d92800
timestamp: 01:15:25:855, filepos: 000d95000
timestamp: 01:15:28:607, filepos: 000d98000
timestamp: 01:15:33:195, filepos: 000d9e800
timestamp: 01:15:50:463, filepos: 000da2000
timestamp: 01:15:52:840, filepos: 000da3000
timestamp: 01:16:19:742, filepos: 000da4800
timestamp: 01:16:24:997, filepos: 000dad000
timestamp: 01:16:28:459, filepos: 000db3000
timestamp: 01:16:30:461, filepos: 000db4800
timestamp: 01:16:32:463, filepos: 000db6800
timestamp: 01:16:35:549, filepos: 000db9000
timestamp: 01:16:38:803, filepos: 000dbd000
timestamp: 01:16:43:182, filepos: 000dc1800
timestamp: 01:16:47:645, filepos: 000dc8800
timestamp: 01:16:53:776, filepos: 000dcd800
timestamp: 01:16:58:197, filepos: 000dd5000
timestamp: 01:17:01:283, filepos: 000dd9000
timestamp: 01:17:28:519, filepos: 000ddc800
timestamp: 01:17:31:105, filepos: 000ddf000
timestamp: 01:17:42:158, filepos: 000de2000
timestamp: 01:17:50:207, filepos: 000de5800
timestamp: 01:17:53:002, filepos: 000de9000
timestamp: 01:17:57:423, filepos: 000df1000
timestamp: 01:18:00:176, filepos: 000df6000
timestamp: 01:18:04:972, filepos: 000dfe000
timestamp: 01:18:08:767, filepos: 000e04000
timestamp: 01:18:10:728, filepos: 000e07000
timestamp: 01:18:14:648, filepos: 000e0a000
timestamp: 01:18:17:818, filepos: 000e0f000
timestamp: 01:18:20:863, filepos: 000e12000
timestamp: 01:18:23:866, filepos: 000e17000
timestamp: 01:18:25:868, filepos: 000e1a800
timestamp: 01:18:29:914, filepos: 000e1c000
timestamp: 01:18:32:208, filepos: 000e1e800
timestamp: 01:18:35:044, filepos: 000e20800
timestamp: 01:18:40:174, filepos: 000e23000
timestamp: 01:18:44:220, filepos: 000e27000
timestamp: 01:18:47:514, filepos: 000e2b000
timestamp: 01:18:50:935, filepos: 000e30000
timestamp: 01:18:53:771, filepos: 000e31800
timestamp: 01:18:57:816, filepos: 000e38800
timestamp: 01:18:59:777, filepos: 000e3a800
timestamp: 01:19:03:113, filepos: 000e41800
timestamp: 01:19:05:115, filepos: 000e43800
timestamp: 01:19:09:912, filepos: 000e4a000
timestamp: 01:19:11:622, filepos: 000e4c000
timestamp: 01:19:14:458, filepos: 000e51800
timestamp: 01:19:18:295, filepos: 000e59000
timestamp: 01:19:20:256, filepos: 000e5c000
timestamp: 01:19:22:967, filepos: 000e5f000
timestamp: 01:19:27:680, filepos: 000e65000
timestamp: 01:19:37:648, filepos: 000e66800
timestamp: 01:19:44:863, filepos: 000e68000
timestamp: 01:19:50:035, filepos: 000e69000
timestamp: 01:19:55:708, filepos: 000e6d000
timestamp: 01:20:04:091, filepos: 000e6f800
timestamp: 01:20:07:344, filepos: 000e75000
timestamp: 01:20:11:557, filepos: 000e79000
timestamp: 01:20:16:645, filepos: 000e80800
timestamp: 01:20:18:605, filepos: 000e83800
timestamp: 01:20:22:359, filepos: 000e8a800
timestamp: 01:20:26:030, filepos: 000e91000
timestamp: 01:20:29:658, filepos: 000e97800
timestamp: 01:20:32:369, filepos: 000e9c000
timestamp: 01:20:34:997, filepos: 000ea1000
timestamp: 01:20:37:666, filepos: 000ea6000
timestamp: 01:20:40:419, filepos: 000ea9800
timestamp: 01:20:45:549, filepos: 000eb2000
timestamp: 01:20:47:551, filepos: 000eb5000
timestamp: 01:20:51:388, filepos: 000ebc000
timestamp: 01:20:55:809, filepos: 000ec3800
timestamp: 01:20:59:563, filepos: 000ec9800
timestamp: 01:21:02:066, filepos: 000ecc800
timestamp: 01:21:14:620, filepos: 000ed5000
timestamp: 01:21:17:373, filepos: 000ed7000
timestamp: 01:21:22:336, filepos: 000edf000
timestamp: 01:21:24:505, filepos: 000ee2800
timestamp: 01:21:28:300, filepos: 000ee8800
timestamp: 01:21:41:897, filepos: 000eef800
timestamp: 01:21:50:781, filepos: 000ef0800
timestamp: 01:21:55:160, filepos: 000ef6000
timestamp: 01:22:00:207, filepos: 000efd800
timestamp: 01:22:06:088, filepos: 000f04800
timestamp: 01:22:08:966, filepos: 000f06000
*.xml file (i cuted this code shorter)
<BDN Version="0.93" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="BD-03-006-0093b BDN File Format.xsd">
<Description>
<Name Title="Dark Angel - eng" Content=""/>
<Language Code="eng"/>
<Format VideoFormat="1080p" FrameRate="23.976" DropFrame="False"/>
<Events Type="Graphic" FirstEventInTC="00:00:00:24" LastEventOutTC="01:22:07:05" NumberofEvents="863"/>
</Description>
<Events>
<Event InTC="00:00:00:23" OutTC="00:00:04:01" Forced="False">
<Graphic Width="1800" Height="94" X="60" Y="874">subtitle_1.png</Graphic>
</Event>
<Event InTC="00:00:21:17" OutTC="00:00:23:14" Forced="False">
<Graphic Width="1447" Height="94" X="236" Y="874">subtitle_2.png</Graphic>
</Event>
<Event InTC="00:00:23:20" OutTC="00:00:27:06" Forced="False">
<Graphic Width="1533" Height="194" X="193" Y="774">subtitle_3.png</Graphic>
</Event>
<Event InTC="00:01:21:02" OutTC="00:01:25:01" Forced="False">
<Graphic Width="1585" Height="194" X="167" Y="774">subtitle_4.png</Graphic>
</Event>
<Event InTC="00:01:25:03" OutTC="00:01:28:15" Forced="False">
<Graphic Width="1500" Height="179" X="210" Y="789">subtitle_5.png</Graphic>
</Event>
<Event InTC="00:01:30:21" OutTC="00:01:33:13" Forced="False">
<Graphic Width="1692" Height="94" X="114" Y="874">subtitle_6.png</Graphic>
</Event>
<Event InTC="00:01:44:08" OutTC="00:01:48:13" Forced="False">
<Graphic Width="1507" Height="194" X="206" Y="774">subtitle_7.png</Graphic>
</Event>
<Event InTC="00:01:49:06" OutTC="00:01:52:01" Forced="False">
<Graphic Width="1335" Height="79" X="292" Y="889">subtitle_8.png</Graphic>
</Event>
<Event InTC="00:01:53:11" OutTC="00:01:55:15" Forced="False">
<Graphic Width="1582" Height="94" X="169" Y="874">subtitle_9.png</Graphic>
</Event>
<Event InTC="00:01:57:12" OutTC="00:02:00:16" Forced="False">
<Graphic Width="1422" Height="194" X="249" Y="774">subtitle_10.png</Graphic>
</Event>
<Event InTC="00:02:00:18" OutTC="00:02:05:07" Forced="False">
<Graphic Width="1662" Height="194" X="129" Y="774">subtitle_11.png</Graphic>
</Event>
<Event InTC="00:02:05:09" OutTC="00:02:08:08" Forced="False">
<Graphic Width="1507" Height="194" X="206" Y="774">subtitle_12.png</Graphic>
</Event>
<Event InTC="00:02:08:11" OutTC="00:02:10:23" Forced="False">
<Graphic Width="1302" Height="94" X="309" Y="874">subtitle_13.png</Graphic>
</Event>
<Event InTC="00:02:11:01" OutTC="00:02:12:22" Forced="False">
<Graphic Width="1162" Height="79" X="379" Y="889">subtitle_14.png</Graphic>
</Event>
<Event InTC="00:03:13:05" OutTC="00:03:14:23" Forced="False">
<Graphic Width="1042" Height="79" X="439" Y="889">subtitle_15.png</Graphic>
</Event>
<Event InTC="00:03:40:19" OutTC="00:03:44:08" Forced="False">
<Graphic Width="1428" Height="189" X="246" Y="779">subtitle_16.png</Graphic>
</Event>
<Event InTC="00:03:44:23" OutTC="00:03:48:08" Forced="False">
<Graphic Width="1527" Height="179" X="196" Y="789">subtitle_17.png</Graphic>
</Event>
<Event InTC="00:03:48:10" OutTC="00:03:52:06" Forced="False">
<Graphic Width="1645" Height="194" X="137" Y="774">subtitle_18.png</Graphic>
</Event>
<Event InTC="00:03:52:08" OutTC="00:03:54:11" Forced="False">
<Graphic Width="1205" Height="79" X="357" Y="889">subtitle_19.png</Graphic>
</Event>
<Event InTC="00:04:25:13" OutTC="00:04:28:12" Forced="False">
<Graphic Width="1450" Height="194" X="235" Y="774">subtitle_20.png</Graphic>
</Event>
<Event InTC="00:04:28:14" OutTC="00:04:31:08" Forced="False">
<Graphic Width="1505" Height="94" X="207" Y="874">subtitle_21.png</Graphic>
</Event>
<Event InTC="00:04:31:11" OutTC="00:04:35:08" Forced="False">
<Graphic Width="1482" Height="194" X="219" Y="774">subtitle_22.png</Graphic>
</Event>
<Event InTC="00:04:35:10" OutTC="00:04:39:23" Forced="False">
<Graphic Width="1533" Height="194" X="193" Y="774">subtitle_23.png</Graphic>
</Event>
<Event InTC="00:04:40:01" OutTC="00:04:41:20" Forced="False">
<Graphic Width="1572" Height="94" X="174" Y="874">subtitle_24.png</Graphic>
</Event>
<Event InTC="00:04:41:22" OutTC="00:04:45:13" Forced="False">
<Graphic Width="1458" Height="194" X="231" Y="774">subtitle_25.png</Graphic>
</Event>
<Event InTC="00:04:46:23" OutTC="00:04:49:05" Forced="False">
<Graphic Width="1527" Height="94" X="196" Y="874">subtitle_26.png</Graphic>
</Event>
<Event InTC="00:04:49:07" OutTC="00:04:52:13" Forced="False">
<Graphic Width="1385" Height="194" X="267" Y="774">subtitle_27.png</Graphic>
</Event>
<Event InTC="00:04:52:15" OutTC="00:04:55:20" Forced="False">
<Graphic Width="1475" Height="194" X="222" Y="774">subtitle_28.png</Graphic>
</Event>
<Event InTC="00:04:55:22" OutTC="00:04:59:13" Forced="False">
<Graphic Width="1353" Height="189" X="283" Y="779">subtitle_29.png</Graphic>
</Event>
<Event InTC="00:04:59:16" OutTC="00:05:03:17" Forced="False">
<Graphic Width="1443" Height="194" X="238" Y="774">subtitle_30.png</Graphic>
</Event>
<Event InTC="00:05:03:19" OutTC="00:05:05:17" Forced="False">
<Graphic Width="1293" Height="94" X="313" Y="874">subtitle_31.png</Graphic>
</Event>
<Event InTC="00:05:48:02" OutTC="00:05:50:09" Forced="False">
<Graphic Width="1200" Height="179" X="360" Y="789">subtitle_32.png</Graphic>
</Event>
<Event InTC="00:05:51:06" OutTC="00:05:54:01" Forced="False">
<Graphic Width="1580" Height="94" X="170" Y="874">subtitle_33.png</Graphic>
</Event>
<Event InTC="00:05:54:18" OutTC="00:05:56:17" Forced="False">
<Graphic Width="1555" Height="94" X="182" Y="874">subtitle_34.png</Graphic>
</Event>
<Event InTC="00:05:56:19" OutTC="00:05:59:19" Forced="False">
<Graphic Width="1398" Height="194" X="261" Y="774">subtitle_35.png</Graphic>
</Event>
<Event InTC="00:05:59:21" OutTC="00:06:02:03" Forced="False">
<Graphic Width="1383" Height="94" X="268" Y="874">subtitle_36.png</Graphic>
</Event>
<Event InTC="00:06:03:05" OutTC="00:06:05:02" Forced="False">
<Graphic Width="1265" Height="94" X="327" Y="874">subtitle_37.png</Graphic>
</Event>
<Event InTC="00:06:05:04" OutTC="00:06:08:19" Forced="False">
<Graphic Width="1492" Height="194" X="214" Y="774">subtitle_38.png</Graphic>
</Event>
<Event InTC="00:06:08:21" OutTC="00:06:10:22" Forced="False">
<Graphic Width="1437" Height="79" X="241" Y="889">subtitle_39.png</Graphic>
</Event>
<Event InTC="00:06:12:17" OutTC="00:06:14:15" Forced="False">
<Graphic Width="1295" Height="79" X="312" Y="889">subtitle_40.png</Graphic>
</Event>
<Event InTC="00:06:16:10" OutTC="00:06:17:20" Forced="False">
<Graphic Width="1197" Height="89" X="361" Y="879">subtitle_41.png</Graphic>
</Event>
<Event InTC="00:06:29:07" OutTC="00:06:31:05" Forced="False">
<Graphic Width="1195" Height="89" X="362" Y="879">subtitle_42.png</Graphic>
</Event>
<Event InTC="00:06:31:11" OutTC="00:06:34:02" Forced="False">
<Graphic Width="1437" Height="94" X="241" Y="874">subtitle_43.png</Graphic>
</Event>
<Event InTC="00:06:34:04" OutTC="00:06:37:02" Forced="False">
<Graphic Width="1492" Height="194" X="214" Y="774">subtitle_44.png</Graphic>
</Event>
<Event InTC="00:06:37:04" OutTC="00:06:39:02" Forced="False">
<Graphic Width="1205" Height="79" X="357" Y="889">subtitle_45.png</Graphic>
</Event>
<Event InTC="00:06:39:04" OutTC="00:06:41:15" Forced="False">
<Graphic Width="1715" Height="94" X="102" Y="874">subtitle_46.png</Graphic>
</Event>
<Event InTC="00:06:41:17" OutTC="00:06:44:11" Forced="False">
<Graphic Width="1452" Height="89" X="234" Y="879">subtitle_47.png</Graphic>
</Event>
<Event InTC="00:06:44:17" OutTC="00:06:47:16" Forced="False">
<Graphic Width="1383" Height="194" X="268" Y="774">subtitle_48.png</Graphic>
</Event>
<Event InTC="00:06:48:09" OutTC="00:06:51:02" Forced="False">
<Graphic Width="1278" Height="179" X="321" Y="789">subtitle_49.png</Graphic>
</Event>
<Event InTC="00:06:51:04" OutTC="00:06:52:22" Forced="False">
<Graphic Width="1180" Height="94" X="370" Y="874">subtitle_50.png</Graphic>
</Event>
<Event InTC="00:07:19:19" OutTC="00:07:23:00" Forced="False">
<Graphic Width="1555" Height="194" X="182" Y="774">subtitle_51.png</Graphic>
</Event>
<Event InTC="00:07:23:02" OutTC="00:07:26:20" Forced="False">
<Graphic Width="1567" Height="179" X="176" Y="789">subtitle_52.png</Graphic>
</Event></BDN>
3D sub files.rar
two files converted from *.srt
(19.9 KiB) Downloaded 535 times
Post Tue Apr 16, 2013 11:01 pm
ok, I will look if FFmpeg supports it for 1.3
Meelis
Post Wed Apr 17, 2013 4:02 pm
zip wrote:ok, I will look if FFmpeg supports it for 1.3
Good, cos seems that 3D movies are coming more popular. I readed that plex is supporting it and tryed that. I dont knov, didnt worked for me and looks like it have a lot of bugs. (i tryed with samsung smart tv app). Still serviio the best and 3D subtitles support will make it more popular cos not much DLNA servers supporting 3D subtitles. 8-)
Post Wed Apr 17, 2013 11:20 pm
All my 3D movies play fine with .srt subs, but they must be played by the TV which recognizes the stream as 3D and lays the sub line on both pictures so they display correctly on the rendered 3D screen. If you play them through a DVD player which does not recognize the stream as 3D and , it will lay a single sub line across both pictures before passing it to the tv and they will not display correctly. i assume the same will happen with .idx subs.
Meelis
Post Thu Apr 18, 2013 8:30 pm
jhb50 wrote:All my 3D movies play fine with .srt subs, but they must be played by the TV which recognizes the stream as 3D and lays the sub line on both pictures so they display correctly on the rendered 3D screen. If you play them through a DVD player which does not recognize the stream as 3D and , it will lay a single sub line across both pictures before passing it to the tv and they will not display correctly. i assume the same will happen with .idx subs.
*.srt working well but that is not a 3d sub. In some point in a movie they are like out of focus or something like that. I dont know how to explain that :) My english is not so good to describe that. Its just not comfortable to read that text. if you compare that srt text to some blueray movi original text then you will see difference. I googled about that 3D subtitles a lot and srt is not a 3D text like it must be.
Return to Feature requests
