Sony Bravia
scottrotton
Post Mon Apr 08, 2013 10:52 am
Sony Bravia
Model 46ex520
Hi All,
I have just downloaded this for my mac, im trying to play an MP4 file but I only get sound and no video
Does this program support Mp4 out the box or do I need to buy a codec online?
Thank for any help, sorry for the obvious questions im a windows man really, I cant find an equivelant to kazaa codec pack for mac
Post Mon Apr 08, 2013 12:03 pm
Re: Sony Bravia
Serviio is based on ffmpeg encoder that supports lot of formats (http://www.serviio.org/features), no external codec is needed.
Sony Bravia / Serviio should support MP4 files.
Could you provide information about your file format ? see my signature link (ffmpeg -i or MediaInfo tools result).
scottrotton
Post Mon Apr 08, 2013 12:42 pm
Re: Sony Bravia
Thanks for your quick reply.
please see media file export attached
MediaInfo.txt
(3.73 KiB) Downloaded 620 times
Post Mon Apr 08, 2013 2:32 pm
Re: Sony Bravia
"High 10" profile of h264 video codec is not supported by Sony Bravia TV. This video stream should be transcoded.
Post Mon Apr 08, 2013 2:38 pm
Re: Sony Bravia
@scottrotton
Could you find and edit the ./serviio/config/profiles.xml file ? (make a backup)
Find the <Profile id="sony2012" name="Sony Bravia TV (2012)" extendsProfileId="1"> section on profiles.xml file
On <Transcoding>...</Transcoding> subsection, replace the first <Video>...</Video> element like this :
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="17000" targetACodec="ac3" aBitrate="384" DAR="16:9" forceInheritance="true">
            <Matches container="*" vCodec="h264" profile="high_10" /><!-- High 10@L4.1 not supported by Bravia devices -->
            <Matches container="mpegts" vCodec="vc1" />
Save.
And restart serviio services or reboot.
Post Tue Apr 09, 2013 1:47 pm
Re: Sony Bravia
@scottrotton, did you try the modification above ?
Post Tue Apr 09, 2013 6:57 pm
Re: Sony Bravia
So I tested with some samples files : http://www.koi-sama.net/files/hi10/
1 [1080p][16_REF_L5.1][FLAC_5.1]Suzumiya Haruhi no Shoushitsu BD OP.mkv 167.56 MB ==> Transcoding OK
2 [1080p][16_REF_L5.1][mp3_2.0]Suzumiya Haruhi no Shoushitsu BD OP.mkv 122.97 MB ==> Transcoding OK
3 [720p][07_REF_L4.0]Sword Art Online BD Opening.mkv 65.81 MB ==> Transcoding OK
4 [720p][08_REF_L4.0]Girls Und Panzer TV EP1 Cut.mkv 89.44 MB ==> Transcoding OK
5 [720p][08_REF_L4.1]Shinsekai Yori BD Ending.mkv 51.26 MB ==> Transcoding OK
6 [720p][08_REF_L5.1]Guilty Crown BD Opening.mkv 63.35 MB ==> Transcoding OK
7 [720p][09_REF_L4.1]AKB0048 TV EP3 Insert Song.mkv 94.47 MB ==> Transcoding OK
8 [720p][16_REF_L5.1]Muv-Luv Alternative Total Eclipse BD Opening EP2.mkv 55.97 MB ==> Transcoding OK
Zip, could you add this line on next release on Sony2012 profile ?
scottrotton
Post Wed Apr 10, 2013 10:52 am
Re: Sony Bravia
tried it, but didnt work, still no video only sound.
Post Wed Apr 10, 2013 10:57 am
Re: Sony Bravia
scottrotton wrote:tried it, but didnt work, still no video only sound.
Try with this profiles.xml
profiles.xml
Add high_10 on Sony2012 profile
(91.7 KiB) Downloaded 754 times
Reboot your system and retry.
scottrotton
Post Wed Apr 10, 2013 10:58 am
Re: Sony Bravia
top of my code looks like this
<!-- 2012 models
- Still images: JPEG, MPO
- Music: MP3, linear PCM, WMA, MP4
- Video: AVCHD, MPEG2, MPEG1, MP4 (AVC), MP4 (MPEG4), DivX, WMV -->
<Detection>
<UPnPSearch>
<FriendlyName>BRAVIA KDL-\d{2}[A-Z]X\d5(\d|G).*</FriendlyName>
</UPnPSearch>
</Detection>
<DeviceDescription>
<!-- act as WMP so that the TV doesn't show root categories -->
<ModelName>Windows Media Player Sharing</ModelName>
<ModelNumber>3.0</ModelNumber>
<Manufacturer>Microsoft Corporation</Manufacturer>
</DeviceDescription>
<ContentDirectoryMessageBuilder>org.serviio.upnp.service.contentdirectory.SonyDLNAMessageBuilder</ContentDirectoryMessageBuilder>
<ContentDirectoryDefinitionFilter>org.serviio.upnp.service.contentdirectory.definition.WMPContentDirectoryDefinitionFilter</ContentDirectoryDefinitionFilter>
<MediaFormatProfiles>
<!-- rename native WMA formats to those supported by the tv -->
<MediaFormatProfile mime-type="audio/x-ms-wma" name="WMABASE">WMA_BASE</MediaFormatProfile>
<MediaFormatProfile mime-type="audio/x-ms-wma" name="WMAFULL">WMA_FULL</MediaFormatProfile>
<!-- rename 3gp profiles that can be played as AVC -->
<MediaFormatProfile mime-type="video/mp4" name="AVC_MP4_MP_SD_AAC_MULT5">AVC_3GPP_BL_QCIF15_AAC</MediaFormatProfile>
<!-- Rename native avi formats to those supported by the tv -->
<MediaFormatProfile mime-type="video/avi" name="">AVI</MediaFormatProfile>
<!-- Rename native mpeg2ts with h264+ac3/aac formats to those supported by the tv (aac support is not advertised by the renderer but it works) -->
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3,AVC_TS_HD_50_AC3,AVC_TS_HD_60_AC3,AVC_TS_HD_EU">AVC_TS_MP_HD_AC3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3,AVC_TS_HD_50_AC3,AVC_TS_HD_60_AC3,AVC_TS_HD_EU">AVC_TS_MP_SD_AC3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3,AVC_TS_HD_50_AC3,AVC_TS_HD_60_AC3,AVC_TS_HD_EU">AVC_TS_MP_HD_AAC_MULT5</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3,AVC_TS_HD_50_AC3,AVC_TS_HD_60_AC3,AVC_TS_HD_EU">AVC_TS_MP_SD_AAC_MULT5</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_HD_AC3_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_SD_AC3_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_HP_HD_MPEG1_L2_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_HP_SD_MPEG1_L2_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_HD_AAC_MULT5_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_SD_AAC_MULT5_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_SD_MPEG1_L3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_SD_MPEG1_L3_T</MediaFormatProfile>
<!-- Rename transcoded mpeg2ts with h264 to one of the TV's supported profiles -->
<MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_HD_AC3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_SD_AC3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_HP_HD_MPEG1_L2_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_HP_SD_MPEG1_L2_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_HD_AAC_MULT5_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_SD_AAC_MULT5_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_SD_MPEG1_L3_ISO</MediaFormatProfile>
</MediaFormatProfiles>
<!-- Transcode all h264 video with HIGH/MAIN > Level 4.1 on MPEG-TS stream with MPEG2VIDEO and ac3 audio transcoding -->
<!-- expected profile MPEG_TS_SD_EU/MPEG_TS_SD_NA/MPEG_TS_SD_KO -->
<!-- Remux containers with h264 video + AC3/AAC audio to MPEG-TS stream without transcoding -->
<Video targetContainer="mpegts" forceInheritance="true">
<Matches container="avi" vCodec="h264" aCodec="ac3" />
<Matches container="avi" vCodec="h264" aCodec="aac" />
<Matches container="matroska" vCodec="h264" aCodec="ac3" />
<Matches container="matroska" vCodec="h264" aCodec="aac" />
<Matches container="flv" vCodec="h264" aCodec="ac3" />
<Matches container="flv" vCodec="h264" aCodec="aac" />
<!-- Remux all other h264 video to MPEG-TS stream with ac3 audio transcoding -->
<!-- expected profile AVC_TS_MP_HD_AC3_ISO -->
<Video targetContainer="mpegts" targetACodec="ac3" aBitrate="384" forceInheritance="true">
<Matches container="mp4" vCodec="h264" aCodec="mp3" />
<Matches container="mp4" vCodec="h264" aCodec="lpcm" />
<!-- if audio different to ac3/aac, it must be transcoded -->
<Matches container="mpegts" aCodec="mp3" />
<Matches container="mpegts" aCodec="dca" />
<Matches container="mpegts" aCodec="lpcm" />
<Matches container="mpeg" aCodec="dca" />
<!-- VC1_ASF_AP_L3_WMA not supported : TODO find a match -->
<!-- <Video targetContainer="asf" targetACodec="wmav2" forceStereo="true"> -->
<!-- <Matches container="asf" vCodec="vc1" maxHeight="720"/> -->
<!-- </Video> -->
<!-- DVR-MS -->
<!-- force mpeg2video transcoding to fix monotone timestamps problems -->
scottrotton
Post Wed Apr 10, 2013 11:12 am
Re: Sony Bravia
stll isnt working, ill try restarting but, i restarted the services already
scottrotton
Post Wed Apr 10, 2013 11:28 am
Re: Sony Bravia
since the restart it can no longer see anyy of my files, the path shows up but displays as empty
Post Wed Apr 10, 2013 6:03 pm
Re: Sony Bravia
Is it ok now ?
Users browsing this forum: Google [Bot] and 8 guests
