missing videos
• Page 1 of 1
Some of the videos I added to the library are showing up on the online MediaBrowser, but not in the list of my Sony KDL-46NX720 TV. Profile in the console is currently set to Sony Bravia TV (2011). Anyone know why?
Re: missing videos
What type of files are they ? avi ? mkv ? mp4 ? something else ?
Have you got transcoding enabled ?
Re: missing videos
NX3 wrote:What type of files are they ? avi ? mkv ? mp4 ? something else ?
Transcoding is enabled. So far I found 3 missing MP4 videos out of 19, and 2 missing MKV videos out of 17.
Re: missing videos
Your Sony KDL-46NX720 TV, is it a US or European model ?
Re: missing videos
Illico wrote:Your Sony KDL-46NX720 TV, is it a US or European model ?
Should be European.
Re: missing videos
Could you provide information about one MP4 and one MKV file ? see signature link.
Re: missing videos
Illico wrote:Could you provide information about one MP4 and one MKV file ? see signature link.
AN MP4:
e:\Servio\Serviio\lib>ffmpeg.exe -i "f:\movies 4 me\Video 1.mp4"
ffmpeg version 1.1.1 Copyright (c) 2000-2013 the FFmpeg developers
built on Feb 5 2013 21:59:54 with gcc 4.7.2 (GCC)
p --enable-fontconfig --enable-libfreetype --enable-zlib --extra-libs='-lrtmp -l
polarssl -lws2_32 -lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --enable-
runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-
mingw32- --pkg-config=pkg-config
libavutil 52. 13.100 / 52. 13.100
libavcodec 54. 86.100 / 54. 86.100
libavformat 54. 59.106 / 54. 59.106
libavdevice 54. 3.102 / 54. 3.102
libavfilter 3. 32.100 / 3. 32.100
libswscale 2. 1.103 / 2. 1.103
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'f:\movies 4 me\Video 1.mp4':
major_brand : isom
minor_version : 512
compatible_brands: mp41
creation_time : 1970-01-01 00:00:00
Duration: 01:31:39.35, start: 0.000000, bitrate: 600 kb/s
Stream #0:0(und): Video: mpeg4 (Simple Profile) (mp4v / 0x7634706D), yuv420p
, 640x368 [SAR 23:30 DAR 4:3], 531 kb/s, 23.98 fps, 23.98 tbr, 24k tbn, 24k tbc
handler_name : VideoHandler
Stream #0:1(und): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 64
kb/s
handler_name : SoundHandler
-Mediainfo:
Complete name : F:\Movies 4 Me\Video 1.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 394 MiB
Duration : 1h 31mn
Overall bit rate : 601 Kbps
Format : MPEG-4 Visual
Format profile : Simple@L1
Format settings, BVOP : No
Format settings, QPel : No
Format settings, GMC : No warppoints
Codec ID : 20
Duration : 1h 31mn
Bit rate : 532 Kbps
Width : 640 pixels
Height : 368 pixels
Display aspect ratio : 1.739
Original display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.094
Stream size : 349 MiB (89%)
Writing library : Lavc51.44.0
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 1h 31mn
Bit rate mode : Variable
Bit rate : 64.2 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 42.1 MiB (11%)
__________________________________________________________________
AN MKV:
e:\Servio\Serviio\lib>ffmpeg.exe -i "f:\movies 4 me\Video 2.mkv"
[matroska,webm @ 0161E8E0] Unknown entry 0x53B9
Input #0, matroska,webm, from 'f:\movies 4 me\Video 2.mkv':
creation_time : 2008-05-25 02:00:49
Duration: 00:52:09.12, start: 0.000000, bitrate: 1876 kb/s
Stream #0:0: Video: h264 (High), yuv420p, 688x368, SAR 1:1 DAR 43:23, 25 fps
, 25 tbr, 1k tbn, 50 tbc (default)
Stream #0:1(fre): Audio: ac3, 48000 Hz, 5.1(side), fltp, 384 kb/s (default)
title : French
Stream #0:2(rum): Subtitle: dvd_subtitle (default)
title : Romanian
Stream #0:3(rum): Subtitle: dvd_subtitle
title : Romanian
Stream #0:4(eng): Subtitle: dvd_subtitle
title : English
-Mediainfo:
Unique ID : 224902896204724689173994755343362949640 (0xA932B8E497162BE3A62AA55B5EC60208)
Complete name : F:\Movies 4 Me\Video 2.mkv
Format : Matroska
Format version : Version 1
File size : 700 MiB
Duration : 52mn 9s
Overall bit rate : 1 877 Kbps
Encoded date : UTC 2008-05-25 02:00:49
Writing application : mkvmerge v2.2.0 ('Turn It On Again') built on Mar 4 2008 12:58:26
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Format : AVC
Format profile : High@L5.1
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 52mn 9s
Bit rate : 1 424 Kbps
Width : 688 pixels
Height : 368 pixels
Display aspect ratio : 1.85:1
Frame rate : 25.000 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.225
Stream size : 543 MiB (78%)
Writing library : x264 core 59 r859M ce13bb6
Encoding settings : cabac=1 / ref=3 / deblock=1:-2:-1 / analyse=0x3:0x133 / me=umh / subme=6 / me-prepass=0 / brdo=0 / mixed_ref=0 / me_range=12 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=2 / deadzone=21,11 / chroma_qp_offset=0 / threads=6 / nr=0 / decimate=1 / mbaff=0 / fgo=0 / bframes=16 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=0 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=1424 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=1.00 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=2:1.00
Default : Yes
Forced : No
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 52mn 9s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Bit depth : 16 bits
Stream size : 143 MiB (20%)
Title : French
Language : French
Default : Yes
Forced : No
Text #1
Format : VobSub
Muxing mode : zlib
Codec ID : S_VOBSUB
Codec ID/Info : The same subtitle format used on DVDs
Title : Romanian
Language : Romanian
Default : Yes
Forced : No
Text #2
Format : VobSub
Muxing mode : zlib
Codec ID : S_VOBSUB
Title : Romanian
Language : Romanian
Default : No
Forced : No
Text #3
Format : VobSub
Muxing mode : zlib
Codec ID : S_VOBSUB
Title : English
Language : English
Default : No
Forced : No
Re: missing videos
Actually the videos might be in the list on my TV but appearing under a different name. Is there a way to make the filename appear in the list instead of the title Serviio assigns to the video?
Re: missing videos
Go into 'folders' if you have that enabled in serviio presentation.
Re: missing videos
Sorry to add to this posting but I have the same issue. After upgrading to 1.2 I can no longer see files on my Sony TV (my Sony Bluray player works ok with same files)
The same files were working perfectly prior to upgrade. I have tried both Sony 2012 and Sony 2012 US but both give errors saying No Items to Display.
TV is a Sony Bravia 2012 KDL-55EX645 (Canadian)
Windows 8 (64bit)
Here is an example of one of the files showing the error from ffmpeg.exe
Microsoft Windows [Version 6.2.9200]
(c) 2012 Microsoft Corporation. All rights reserved.
C:\Users\Gwen>cd "\Program Files\Serviio\lib
C:\Program Files\Serviio\lib>ffmpeg.exe -i "T:\TV\Absolutely Fabulous\Series 1\A
bsolutely Fabulous - 1x01 - Fashion.avi"
[mpeg4 @ 002DD920] Invalid and inefficient vfw-avi packed B frames detected
Input #0, avi, from 'T:\TV\Absolutely Fabulous\Series 1\Absolutely Fabulous - 1x
01 - Fashion.avi':
encoder : Nandub v1.0rc2
Duration: 00:29:22.84, start: 0.000000, bitrate: 1250 kb/s
Stream #0:0: Video: mpeg4 (Simple Profile) (XVID / 0x44495658), yuv420p, 640
x480 [SAR 1:1 DAR 4:3], 25 tbr, 25 tbn, 25 tbc
Stream #0:1: Audio: mp3 (U[0][0][0] / 0x0055), 48000 Hz, stereo, s16p, 128 k
b/s
Windows 8 (64bit)
01 - Fashion.avi':
b/s
Sony Bravia KDL-55EX645
Sony BDVE190
Serviio 1.4.1.2
Windows 8.1 Pro 64bit
Sony BDVE190
Serviio 1.4.1.2
Re: missing videos
@GTUKie
With "Sony Bravia TV (2012) - US" selected on serviio console (save after selection), this file should be transcoded to mpeg2video and should be supported by your Bravia model.
Could you enable detailed logging?
Could you simply rename your file, force a library refresh and try to play it? (post log section where file name appears)
@MoviesOverWifi
Any news...did you try "folders" ?
@MoviesOverWifi
Re: missing videos
@Illico
Thank you so much, that did the trick. I thought I had tried everything but maybe didnt leave it long enough.
Having the confirmation of the correct profile to use helped a lot. Since its not a US device but a Canadian one I wasnt confident on which option to choose.
Anyway I appreciate your fast and accurate help!
Sony BDVE190
Serviio 1.4.1.2
Sony BDVE190
Serviio 1.4.1.2
Re: missing videos
@Illico
I had to reinstall Serviio and now the file which I provided details of in the earlier post in this thread will play on my Sony Bravia TV but not on my Sony BluRay.
Please could you advise the correct profile to use with a Sony BDVE190?
This file and many others now give the error "File corrupted or unsupported"
The files were previously playing with an edited version of profile to allow .avi .dvix and .xvid to play.
Please advise which profile to choose and also if any manual edits need to be made?
Sony BDVE190
Serviio 1.4.1.2
Sony BDVE190
Serviio 1.4.1.2
• Page 1 of 1
