PS3 and Sony Bravia 2010 TV does not recognize WTV files
mjchoi00
Post Tue Apr 16, 2013 8:13 am
PS3 sees no files that are WTV files, but sees MP4s
Here is the ffmpeg -i file.
C:\Program Files\Serviio\lib>ffmpeg.exe -i "M:\Recorded TV\Curious George_KPBSDT_2012_11_08_07_58_00.wtv"
ffmpeg version 1.1.1 Copyright (c) 2000-2013 the FFmpeg developers
built on Feb 5 2013 21:59:54 with gcc 4.7.2 (GCC)
p --enable-fontconfig --enable-libfreetype --enable-zlib --extra-libs='-lrtmp -l
polarssl -lws2_32 -lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --enable-
runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-
mingw32- --pkg-config=pkg-config
libavutil 52. 13.100 / 52. 13.100
libavcodec 54. 86.100 / 54. 86.100
libavformat 54. 59.106 / 54. 59.106
libavdevice 54. 3.102 / 54. 3.102
libavfilter 3. 32.100 / 3. 32.100
libswscale 2. 1.103 / 2. 1.103
[mpeg2video @ 0161DAE0] 0x0 is invalid
Last message repeated 1 times
Input #0, wtv, from 'M:\Recorded TV\Curious George_KPBSDT_2012_11_08_07_58_00.wtv':
WM/MediaClassPrimaryID: db9830bd-3ab3-4fab-8a371a995f7ff74
WM/MediaClassSecondaryID: ba7f258a-62f7-47a9-b21f4651c42a000
Title : Curious George
WM/SubTitle : Robot Monkey Hullabalo; Curious George and the Slithery Day
WM/SubTitleDescription: George decides to make himself into a robot to play with Hundley; Bruno the snake escapes from his cage.
genre : Kids;General;Educational;Series;Family/Children;Children
WM/OriginalReleaseTime: 0
WM/MediaCredits : Frank Welker;;;
service_provider: KPBSDT
service_name : KPBSDT (KPBS-DT)
WM/MediaNetworkAffiliation: PBS Affiliate
WM/MediaOriginalChannel: 15
WM/MediaOriginalChannelSubNumber: 1
WM/MediaOriginalBroadcastDateTime: 2008-01-24T08:00:00Z
WM/MediaOriginalRunTime: 20923509998
WM/MediaIsStereo: true
WM/MediaIsRepeat: true
WM/MediaIsLive : false
WM/MediaIsTape : false
WM/MediaIsDelay : false
WM/MediaIsSubtitled: false
WM/MediaIsMovie : false
WM/MediaIsPremiere: false
WM/MediaIsFinale: false
WM/MediaIsSAP : false
WM/MediaIsSport : false
WM/ParentalRating: TV-Y
WM/Provider : MediaCenterDefault
WM/VideoClosedCaptioning: true
WM/WMRVEncodeTime: 2012-11-08 15:58:07
WM/WMRVSeriesUID: !MCSeries!166032377
WM/WMRVServiceID: !MCService!28456176
WM/WMRVProgramID: !MCProgram!183397383
WM/WMRVRequestID: 0
WM/WMRVScheduleItemID: 0
WM/WMRVQuality : 3
WM/WMRVOriginalSoftPrePadding: 420
WM/WMRVOriginalSoftPostPadding: 180
WM/WMRVHardPrePadding: -300
WM/WMRVHardPostPadding: 0
WM/WMRVATSCContent: true
WM/WMRVDTVContent: true
WM/WMRVHDContent: false
Duration : 20928747056
WM/WMRVEndTime : 2012-11-08 16:33:00
WM/WMRVBitrate : 15.451514
WM/WMRVKeepUntil: -1
WM/WMRVActualSoftPrePadding: 412
WM/WMRVActualSoftPostPadding: 180
WM/WMRVContentProtected: false
WM/WMRVContentProtectedPercent: 0
WM/WMRVExpirationSpan: 9223372036854775807
WM/WMRVInBandRatingSystem: 255
WM/WMRVInBandRatingLevel: 255
WM/WMRVInBandRatingAttributes: 0
WM/WMRVWatched : false
WM/MediaThumbType: 3
Duration: 00:34:51.56, start: 2.154667, bitrate: 15461 kb/s
Stream #0:0[0x11]: Audio: ac3, 48000 Hz, 5.1(side), fltp, 384 kb/s
Stream #0:1[0x12]: Video: mpeg2video (Main), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], 29.97 fps, 29.97 tbr, 10000k tbn, 59.94 tbc
Stream #0:2[0x13]: Subtitle: eia_608
Stream #0:3[0x0]: Attachment: mjpeg
title : TV Thumbnail
Have profiles.xml open and it has the transcoding for wtv.
Thank you for the help.
Michael
Post Tue Apr 16, 2013 11:54 am
Re: PS3 and Sony Bravia 2010 TV does not recognize WTV files
On PS3 profile, WTV are only remuxed, not transcoded...
On your ffmpeg output I saw :
So you probably have to force mpeg2video transcoding...
Add this custom profile on profiles.xml just before the last </Profiles> element:
   <Profile id="PS3wtv" name="Playstation 3 - WTV record" extendsProfileId="4">
         <!-- Transcode all recorded WTV -->
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" forceVTranscoding="true" targetACodec="ac3" aBitrate="384">
            <Matches container="wtv" />
And select it on serviio console.
mjchoi00
Post Tue Apr 16, 2013 3:54 pm
Thank you for your help.
I added those lines and restarted the server and selected the new Profile.
Still can't see the WTV files on PS3.
I redid the ffmpeg -i and it came with the same error.
[mpeg2video @ 0030DA20] 0x0 is invalid
v':
y
WM/WMRVRequestID: 0
WM/WMRVQuality : 3
Not certain I'm doing something wrong.
Thank you again for your help.
Michael
Post Tue Apr 16, 2013 3:58 pm
mjchoi00 wrote:I added those lines and restarted the server and selected the new Profile.
After a profiles.xml edition, you have to restart serviio services (or reboot), restart server does not reload profiles.xml...then select the new profile "Playstation 3 - WTV record"
mjchoi00
Post Tue Apr 16, 2013 4:10 pm
I did reboot and selected Playstation 3 - WTV record - still can't see WTV files.
Sorry I wasn't more clear. I not good with the programming languages and probably are saying things inaccurately.
You mentioned before that this is muxing and not transcoding. Why am I adding lines that include/forcing transcoding?
Thank you so much for your help. I appreciate the time you have given me.
Michael
