Automatic Title Switching
crabsoda
Post Thu Apr 18, 2013 3:17 pm
I have the PN64E8000. Lately when I will be watching an episode of something and right in the middle of an episode it will just skip to the next episode. There is no error and no network drop out. I am on a wired network. I can go right back to the episode I was watching and finish it without any problems. It seems as though it may have started happening just since I enabled transcoding. The files I am watching are MP4's with AC3 audio so I don't think they are getting transcoded anyway. The PN64E8000 works fine with transcoding turned off completely, I only turned it on so I could listen to FLAC files on the Xbox 360. If transcoding could be the reason for these episode interruptions, is there a way I could just leave the transcoding on for the Xbox profile and delete it completely from the Samsung profile. Thanks for your help.
Post Fri Apr 19, 2013 12:58 pm
Re: Automatic Title Switching
It won't transcode anything unless it has to, even with transcoding on. So your file is delivered natively in both cases. It might be the quality of your network / router, or the file. But considering you were able to play it later, it looks like the network issue.
Copsdonuts
Post Sun Oct 27, 2013 9:22 pm
I have also been experiencing this issue.
I am watching on a Samsung UE32F5500 .avi files (x-msvideo) and files regularly skip onto the next one in the folder half way through.
This doesn't appear to be a connectivity issue as it maintains connection to move onto the next file/episode .
Are there Serviio/Router settings I can modify to address this issue?
Any help appreciated.
*Both the PC and TV are connected wirelessly to my home network via my Virgin Media router.
Users browsing this forum: No registered users and 65 guests
