Problem linking iMac to Sony KDL 32HX753
MASCCW
Post Sun Apr 07, 2013 1:14 pm
I can't seem to get my iMac to connect to my Sony KDL 32HX753. Screen shots of the Seviio console and the wireless data connection of my TV are attached. I have turned off the firewall, rebooted, done everything I can think of, but I can't seem to get any renderer profiles loaded. Any suggestions? Apologies if i am missing something really obvious...
Thanks in advance.
Sony TV screen shot.JPG (214.6 KiB) Viewed 6367 times
Serviio console 1.1.tiff
Serviio console 1.1.tiff (87.82 KiB) Viewed 6367 times
MASCCW
Post Sun Apr 07, 2013 5:28 pm
Re: Problem linking iMac to Sony KDL 32HX753
Serviio console 1.1.jpg (29.93 KiB) Viewed 6360 times
Post Mon Apr 08, 2013 9:56 am
What is the IP address of the Serviio PC?
MASCCW
Post Wed Apr 24, 2013 8:56 am
IP address of desktop is 192.168.1.70
Post Wed Apr 24, 2013 9:34 am
If you use two NICs on your PC (wired and wifi), I suggest to :
- Fix IP address of all your NICs on your PC (or look at your rooter settings to fix IP address according to devices MAC address).
- On serviio console, set wifi NIC IP address value on "Bound IP address" field.
- On sony device network menu, clear/clean server list an make a refresh list or diagnostic.
