Movie rating
wanxu
Post Mon May 06, 2013 2:55 pm
Movie rating
Hi, what do you think about adding the movie rating when getting the metadata (from the same source)? It would be great to be able to see the rating with the name.
Or maybe it's possible and I don't know yet? :P
Example: "The Hobbit (7.6)"
Post Tue May 07, 2013 8:35 am
Re: Movie rating
It's been requested. Themoviedb.org has the field, but might not match imdb, for example, as there are way less people rating the movies.
wanxu
Post Thu May 09, 2013 7:53 am
Re: Movie rating
zip wrote:It's been requested. Themoviedb.org has the field, but might not match imdb, for example, as there are way less people rating the movies.
Yeah, I know it would be from TMDB instead of IMDB but it would be something, right? I mean, you already have the metadata.
Xmantium
Post Sun May 12, 2013 12:01 am
Re: Movie rating
@zip, why not use http://www.omdbapi.com/
Very accurate to IMDB ratings, used by ServiiGo and many other apps
Post Sun May 12, 2013 1:05 am
Re: Movie rating
Return to Feature requests
