[SOLVED] BDP-S390 connection under Win 7 and Win XP
arkie
Post Fri May 03, 2013 9:25 am
Hi
I never could connect BDP-S390 via wifi with a desktop running Win 7 and Serviio or Homestream. Firewalls were switched off – no change, empty server list in player’s menu and the same in Serviio console. Just out of curiosity, installed Homestream on an old laptop running XP. To my surprise, connection established, at that same settings in player menu. Everything worked great. The question is “what’s wrong with Win 7?” The desktop is a part of a home network and is accessible from other computers with no problem.
The desktop is linked to DLink DSL 2460U router by wire and the laptop by wifi.
Just for the case, here is a log (switched on the player and started Homestream) :
2013-05-03 14:42:49,983 INFO [MediaServer] ------------------------------------------------------------------------
2013-05-03 14:42:49,983 INFO [MediaServer] Homestream DLNA media streaming server v 1.1 (rev. d545abee9a9a)
2013-05-03 14:42:49,983 INFO [MediaServer] (c) 2012 Penline Consulting Ltd.
2013-05-03 14:42:49,983 INFO [MediaServer] Powered by Serviio (http://www.serviio.org)
2013-05-03 14:42:49,983 INFO [MediaServer] Java 1.7.0_21-Oracle Corporation
2013-05-03 14:42:49,983 INFO [MediaServer] OS Windows 7 x86 6.1
2013-05-03 14:42:49,983 INFO [MediaServer] File encoding: windows-1251
2013-05-03 14:42:49,983 INFO [MediaServer] Headless mode enabled: true
2013-05-03 14:42:49,983 INFO [MediaServer] User home dir: C:\
2013-05-03 14:42:49,983 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2013-05-03 14:42:50,077 INFO [RestletServer] Starting Restlet server exposed on port 23423
2013-05-03 14:42:50,108 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2013-05-03 14:42:50,951 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2013-05-03 14:42:51,231 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2013-05-03 14:42:51,372 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2013-05-03 14:42:51,653 INFO [ProfilesDefinitionParser] Added profile 'Sony BRAVIA' (id=9)
2013-05-03 14:42:52,043 INFO [ProfilesDefinitionParser] Added profile 'Sony Blu-ray / Blu-ray Home Theatre' (id=10)
2013-05-03 14:42:52,277 INFO [ProfilesDefinitionParser] Added profile 'Sony Netbox (SMP-Nx00)' (id=11)
2013-05-03 14:42:52,542 INFO [WebServer] Socket buffer set to 65535 bytes
2013-05-03 14:42:52,542 INFO [Device] Created UPnP Device with UUID: 87187334-e8fc-3aa8-9bc8-78ac0108cc9c, bound address: 192.168.1.3
2013-05-03 14:42:52,557 INFO [PluginCompilerThread] Looking for plugins at D:\Homestream\bin\..\plugins
2013-05-03 14:42:52,620 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2013-05-03 14:42:52,651 INFO [WebServer] WebServer starting on port 8895
2013-05-03 14:42:52,651 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-05-03 14:42:52,651 INFO [EventDispatcher] Starting EventDispatcher
2013-05-03 14:42:52,651 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-05-03 14:42:52,651 INFO [RendererSearchSender] Searching for Renderer devices
2013-05-03 14:42:52,651 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2013-05-03 14:42:52,667 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (‘¥⥢ ï ª àâ  Realtek RTL8168D/8111D Family PCI-E Gigabit Ethernet NIC (NDIS) and address 192.168.1.3, timeout = 0
2013-05-03 14:43:17,209 INFO [ServiioConsole] Starting Serviio Console
2013-05-03 14:43:17,287 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2013-05-03 14:43:17,802 INFO [Messages] Loaded console message bundle for locale: en
2013-05-03 14:43:17,833 INFO [UpdateChecker] Checking if a new version is available
2013-05-03 14:43:18,879 INFO [FeedUpdaterThread] Started looking for information about online resources
2013-05-03 14:43:18,894 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2013-05-03 14:43:18,910 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2013-05-03 14:43:20,376 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2013-05-03 14:43:20,766 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
slyguy42o
Post Mon May 06, 2013 5:31 pm
Re: BDP-S390 connection under Win 7 and Win XP
enabled detailed logging and repost your logs please
arkie
Post Mon May 06, 2013 6:44 pm
The log is attached. IP address of the player is 192.168.1.7 and the PC 192.168.1.3
homestream.log
(33.96 KiB) Downloaded 456 times
arkie
Post Tue May 07, 2013 5:11 pm
Don't know how but the problem SOLVED!
All I did was just updated router firmware. Then I loaded old settings (saved before). Nothing more. Now Win 7 sees 390 and vice versa. The secret remains why Win XP worked with old FW?
Thanks to slyguy42o and all who visited.
Post Tue May 07, 2013 5:56 pm
Router, reboot probably solved your problem...
