no sound on bdp ( SOLVED)
siriusblack
Post Sat May 04, 2013 3:48 pm
Hi
just wondering if any one has had this problem no sound on acestream
I tried the Samsung c/d/e profile also the generic dlna profile no sound on both with acestream
here is my log
bdp log.txt
(28.19 KiB) Downloaded 566 times
also here is another log if this helps
no sound.txt
(2.7 KiB) Downloaded 659 times
I did change my profile to this Code:<Matches container="mp4" vCodec="mpeg4" aCodec="lpcm" />
<Matches container="mpegts" vCodec="h264" /> <!-- jhb50 fixes serviio h264.ts to h264.ts transcode bug -->
<Matches container="mpeg" vCodec="h264" /> <!-- optional --> <!-- h264 mpegps as well as h264 mpegts and wmv.asf streams will transcode to MPEG2VIDEO -->
Beta Tester
siriusblack
Post Tue May 07, 2013 7:13 pm
Re: no sound on bdp
Sorry don't understand
Can you please send it In English
Beta Tester
slyguy42o
Post Tue May 07, 2013 7:28 pm
Re: no sound on bdp
he's a dirty illiterate spammer!! :) just ignore until the ops can cleanup his posts.
slyguy42o
Post Tue May 07, 2013 7:32 pm
Re: no sound on bdp
what is an acestream btw?
siriusblack
Post Tue May 07, 2013 7:47 pm
Re: no sound on bdp
Acestream is the same as sopcast live streams
Beta Tester
slyguy42o
Post Tue May 07, 2013 7:54 pm
Re: no sound on bdp
so your having sounds issues with just this one stream type? Have you tested through VLC to make sure it's not a problem with the stream itself?
siriusblack
Post Tue May 07, 2013 8:23 pm
Re: no sound on bdp
Yer it works with vlc, My Samsung tv + ps3
its only on this bdp
I also tried it today and I cant get it to play at all now on the bdp
it comes up unsupported file format with Samsung c/d/e or generic dlna profile
Hope this can help here is my log
unsupported file format.txt
(6.49 KiB) Downloaded 567 times
since I changed my profile.xml to :<Matches container="mp4" vCodec="mpeg4" aCodec="lpcm" />
I don't get any disconnect on my tv now only on this bdp
Beta Tester
slyguy42o
Post Wed May 08, 2013 3:11 pm
Re: no sound on bdp
did you make sure to make those changes under the online transcoding section?
siriusblack
Post Wed May 08, 2013 3:25 pm
Re: no sound on bdp
I think so i did it where it saids to do it
On the first page of sopcast web resource plugin in the available plugins
Also m8 it stopped my tv disconnecting since I did it
Beta Tester
slyguy42o
Post Wed May 08, 2013 4:48 pm
Re: no sound on bdp
can you post the full modified profile section so we can see where you made your changes?
siriusblack
Post Wed May 08, 2013 5:00 pm
Re: no sound on bdp
I'm in work at the mo finish at 8 will do it as soon as I get in
Thxs
Beta Tester
siriusblack
Post Wed May 08, 2013 7:42 pm
Re: no sound on bdp
Here is my profile
profiles.xml
(91.99 KiB) Downloaded 646 times
Thanks really appreciate this
Beta Tester
slyguy42o
Post Wed May 08, 2013 8:52 pm
Re: no sound on bdp
which profile did you edit? the C/D/E one?
siriusblack
Post Wed May 08, 2013 8:59 pm
Re: no sound on bdp
Yer the C/D/E one I think m8
Is this the right place to change ?
Beta Tester
slyguy42o
Post Thu May 09, 2013 3:32 pm
Re: no sound on bdp
I am not sure why the online trancoding was split up.. it was using the same containers for both sections. I combined them and simplified it a bit, try replacing your online transcoding section with the following.
         <OnlineTranscoding>
            <Matches container="mp4" />
            <Matches container="asf" />
            <Matches container="applehttp" vCodec="h264"/>
            <Matches container="flv" vCodec="h264"/>
         </OnlineTranscoding>
siriusblack
Post Thu May 09, 2013 3:51 pm
Re: no sound on bdp
Thanks m8
Really appreciate all of this
Will try this wen I get in from work
Do I just copy + paste this on to the trancodein section ?
If so where do I put it
Thxs again
Beta Tester
slyguy42o
Post Thu May 09, 2013 6:14 pm
Re: no sound on bdp
here you go.
profiles (2).xml
(91.9 KiB) Downloaded 639 times
siriusblack
Post Thu May 09, 2013 6:34 pm
Re: no sound on bdp
Thxs a lot m8
Really appreciated
Do you think the BDP been disconnecting
Cause of the split transcoding ?
Beta Tester
slyguy42o
Post Thu May 09, 2013 7:11 pm
Re: no sound on bdp
there are normally lots of splits depending on the transcoding config.. but in this case.. it was split but I couldn't see a reason why. Try this out and see if it makes a difference.. if not we will try some more tweaking.
siriusblack
Post Thu May 09, 2013 7:12 pm
Re: no sound on bdp
ok
nice1 will try it now
Beta Tester
