[Resolved] 1.2.1 Do not add any video
D-Kalck
Post Fri May 10, 2013 11:53 am
I just installed Serviio 1.2.1 but it doesn't add any video to the library when I watch the log file I see many :
WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video file type.
Is it me or Serviio ? If it's me could somebody help me ? If it's Serviio, is there any workaround or a new version coming ?
EDIT : Do not install Serviio in a location where there is a '&' in the path.
Post Fri May 10, 2013 12:09 pm
Re: 1.2.1 Do not add any video
Can you post ffmpeg -i of a file that's not added?
D-Kalck
Post Fri May 10, 2013 1:01 pm
Thanks for the quick reply, here is the output of ffmpeg -i :
ffmpeg version 1.1.1 Copyright (c) 2000-2013 the FFmpeg developers
  built on Feb  5 2013 21:59:54 with gcc 4.7.2 (GCC)
  configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --enable-libass --enable-librtmp
 --enable-fontconfig --enable-libfreetype --enable-zlib --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --enable-ru
ntime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-mingw32- --pkg-config=pkg-config
  libavutil      52. 13.100 / 52. 13.100
  libavcodec     54. 86.100 / 54. 86.100
  libavformat    54. 59.106 / 54. 59.106
  libavdevice    54.  3.102 / 54.  3.102
  libavfilter     3. 32.100 /  3. 32.100
  libswscale      2.  1.103 /  2.  1.103
Input #0, matroska,webm, from 'F:\Castle - Saison 5\Castle.S05E10.FRENCH.720p.WEB-DL.H264-MiND.mkv':
    title           : Castle.S05E10.FRENCH.720p.WEB-DL.H264-MiND
    creation_time   : 2013-04-24 20:59:06
  Duration: 00:41:26.72, start: 0.000000, bitrate: 4402 kb/s
    Stream #0:0(fre): Video: h264 (High), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 25 fps, 25 tbr, 1k tbn, 2k tbc (default)
    Stream #0:1(fre): Audio: ac3, 48000 Hz, stereo, fltp, 192 kb/s (default)
Post Fri May 10, 2013 4:20 pm
can you enable detailed log and post it here, incl the error messages?
D-Kalck
Post Fri May 10, 2013 4:54 pm
It's 37Mb now, so I quote the part I think it could interest you :
2013-05-10 18:48:40,825 DEBUG [MediaItemDAOImpl] Getting file of media item 7466
2013-05-10 18:48:40,825 DEBUG [LibraryAdditionsCheckerThread] Found file 'Castle.S05E10.FRENCH.720p.WEB-DL.H264-MiND.mkv', checking if it's already in the Library
2013-05-10 18:48:40,825 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Castle.S05E10.FRENCH.720p.WEB-DL.H264-MiND.mkv
2013-05-10 18:48:40,825 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: F:\Castle - Saison 5\Castle.S05E10.FRENCH.720p.WEB-DL.H264-MiND.mkv, ignore case: true
2013-05-10 18:48:40,825 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7466) and extractor EMBEDDED
2013-05-10 18:48:40,825 DEBUG [MediaItemDAOImpl] Media item Castle.S05E10.FRENCH.720p.WEB-DL.H264-MiND.mkv doesn't exist in DB yet
2013-05-10 18:48:40,825 DEBUG [LibraryAdditionsCheckerThread] File not in Library, will add it
2013-05-10 18:48:40,825 DEBUG [MediaItemDAOImpl] Getting file of media item 7467
2013-05-10 18:48:40,825 DEBUG [VideoExtractionStrategy] Extracting metadata of video file: F:\Castle - Saison 5\Castle.S05E10.FRENCH.720p.WEB-DL.H264-MiND.mkv
2013-05-10 18:48:40,825 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: F:\Castle - Saison 5\Castle.S05E10.FRENCH.720p.WEB-DL.H264-MiND.mkv
2013-05-10 18:48:40,825 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7467) and extractor EMBEDDED
2013-05-10 18:48:40,825 DEBUG [ProcessExecutor] Starting D:\Image & Video (x64)\Serviio\bin\\..\lib/ffmpeg.exe -i F:\Castle - Saison 5\Castle.S05E10.FRENCH.720p.WEB-DL.H264-MiND.mkv
2013-05-10 18:48:40,825 DEBUG [MediaItemDAOImpl] Getting file of media item 7468
2013-05-10 18:48:40,825 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7468) and extractor EMBEDDED
2013-05-10 18:48:40,826 DEBUG [MediaItemDAOImpl] Getting file of media item 7469
2013-05-10 18:48:40,826 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7469) and extractor EMBEDDED
2013-05-10 18:48:40,826 DEBUG [MediaItemDAOImpl] Getting file of media item 7470
2013-05-10 18:48:40,826 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7470) and extractor EMBEDDED
2013-05-10 18:48:40,826 DEBUG [MediaItemDAOImpl] Getting file of media item 7471
2013-05-10 18:48:40,826 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7471) and extractor EMBEDDED
2013-05-10 18:48:40,827 DEBUG [MediaItemDAOImpl] Getting file of media item 7472
2013-05-10 18:48:40,827 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7472) and extractor EMBEDDED
2013-05-10 18:48:40,827 DEBUG [MediaItemDAOImpl] Getting file of media item 7473
2013-05-10 18:48:40,827 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7473) and extractor EMBEDDED
2013-05-10 18:48:40,827 DEBUG [MediaItemDAOImpl] Getting file of media item 7474
2013-05-10 18:48:40,828 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7474) and extractor EMBEDDED
2013-05-10 18:48:40,828 DEBUG [MediaItemDAOImpl] Getting file of media item 7475
2013-05-10 18:48:40,828 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7475) and extractor EMBEDDED
2013-05-10 18:48:40,828 DEBUG [MediaItemDAOImpl] Getting file of media item 7476
2013-05-10 18:48:40,828 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7476) and extractor EMBEDDED
2013-05-10 18:48:40,828 DEBUG [MediaItemDAOImpl] Getting file of media item 7477
2013-05-10 18:48:40,828 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7477) and extractor EMBEDDED
2013-05-10 18:48:40,829 DEBUG [MediaItemDAOImpl] Getting file of media item 7478
2013-05-10 18:48:40,829 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7478) and extractor EMBEDDED
2013-05-10 18:48:40,829 DEBUG [MediaItemDAOImpl] Getting file of media item 7479
2013-05-10 18:48:40,829 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7479) and extractor EMBEDDED
2013-05-10 18:48:40,829 DEBUG [MediaItemDAOImpl] Getting file of media item 7480
2013-05-10 18:48:40,829 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7480) and extractor EMBEDDED
2013-05-10 18:48:40,829 DEBUG [MediaItemDAOImpl] Getting file of media item 7481
2013-05-10 18:48:40,830 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7481) and extractor EMBEDDED
2013-05-10 18:48:40,830 DEBUG [MediaItemDAOImpl] Getting file of media item 7482
2013-05-10 18:48:40,830 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7482) and extractor EMBEDDED
2013-05-10 18:48:40,830 DEBUG [MediaItemDAOImpl] Getting file of media item 7483
2013-05-10 18:48:40,830 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7483) and extractor EMBEDDED
2013-05-10 18:48:40,831 DEBUG [MediaItemDAOImpl] Getting file of media item 7484
2013-05-10 18:48:40,831 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7484) and extractor EMBEDDED
2013-05-10 18:48:40,831 DEBUG [MediaItemDAOImpl] Getting file of media item 7485
2013-05-10 18:48:40,831 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7485) and extractor EMBEDDED
2013-05-10 18:48:40,831 DEBUG [MediaItemDAOImpl] Getting file of media item 7486
2013-05-10 18:48:40,831 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7486) and extractor EMBEDDED
2013-05-10 18:48:40,832 DEBUG [MediaItemDAOImpl] Getting file of media item 7487
2013-05-10 18:48:40,832 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7487) and extractor EMBEDDED
2013-05-10 18:48:40,832 DEBUG [MediaItemDAOImpl] Getting file of media item 7488
2013-05-10 18:48:40,832 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7488) and extractor EMBEDDED
2013-05-10 18:48:40,832 DEBUG [MediaItemDAOImpl] Getting file of media item 7489
2013-05-10 18:48:40,833 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7489) and extractor EMBEDDED
2013-05-10 18:48:40,833 DEBUG [MediaItemDAOImpl] Getting file of media item 7490
2013-05-10 18:48:40,833 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7490) and extractor EMBEDDED
2013-05-10 18:48:40,833 DEBUG [MediaItemDAOImpl] Getting file of media item 7491
2013-05-10 18:48:40,833 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7491) and extractor EMBEDDED
2013-05-10 18:48:40,834 DEBUG [MediaItemDAOImpl] Getting file of media item 7492
2013-05-10 18:48:40,834 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7492) and extractor EMBEDDED
2013-05-10 18:48:40,834 DEBUG [MediaItemDAOImpl] Getting file of media item 7493
2013-05-10 18:48:40,834 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7493) and extractor EMBEDDED
2013-05-10 18:48:40,835 DEBUG [MediaItemDAOImpl] Getting file of media item 7494
2013-05-10 18:48:40,835 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7494) and extractor EMBEDDED
2013-05-10 18:48:40,835 WARN  [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video file type.
Post Sat May 11, 2013 5:59 pm
Works for my tests. It may be something I've fixed in the meantime. Try to rename the file to something like test.mp4.
D-Kalck
Post Sat May 11, 2013 7:08 pm
When will you release the next version ? Did you test with 1.2.1 ? My Serviio is pretty useless if it can't add any video to it's database.
What's the purpose of renaming that file ? I have hundreds of video file (mkv, flv, avi...) but none of them is added to the database.
Post Sun May 12, 2013 1:07 am
I just wanted to try if the file will be added when renamed.
Next version is a long time off.
D-Kalck
Post Sun May 12, 2013 1:33 am
Ok, tried to rename the file to test.mp4, still not added. Did you test with 1.2.1 ?
Post Sun May 12, 2013 1:18 pm
No, I only tried to use the FFmpeg output in my current code base, which worked.
Are you saying you can't see any videos, no matter what format? Can you enable detailed log (but use TRACE instead of DEBUG), rename the file agian to trigger library adding, and post the log - it should show the FFmpeg command result.
D-Kalck
Post Sun May 12, 2013 7:18 pm
zip wrote:Are you saying you can't see any videos, no matter what format?
Yes.
zip wrote:Can you enable detailed log (but use TRACE instead of DEBUG), rename the file agian to trigger library adding, and post the log - it should show the FFmpeg command result.
2013-05-12 21:15:55,812 DEBUG [LibraryUpdatesCheckerThread] Looking for removed playlist files in repository: E:\Test Serviio
2013-05-12 21:15:55,812 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: E:\Test Serviio
2013-05-12 21:15:55,812 DEBUG [PlaylistDAOImpl] Reading Playlists for Repository (id = 7)
2013-05-12 21:15:55,812 DEBUG [LibraryAdditionsCheckerThread] Found file 'Person.of.Interest.S01E02.FRENCH.720p.BluRay.x264-SODAPOP.mkv', checking if it's already in the Library
2013-05-12 21:15:55,814 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Person.of.Interest.S01E02.FRENCH.720p.BluRay.x264-SODAPOP.mkv
2013-05-12 21:15:55,814 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: E:\Test Serviio\Person.of.Interest.S01E02.FRENCH.720p.BluRay.x264-SODAPOP.mkv, ignore case: true
2013-05-12 21:15:55,823 DEBUG [LibraryUpdatesCheckerThread] Looking for removed/updated files in repository: E:\Test Serviio
2013-05-12 21:15:55,823 DEBUG [MediaItemDAOImpl] Reading MediaItems for Repository (id = 7)
2013-05-12 21:15:55,854 DEBUG [MediaItemDAOImpl] Media item Person.of.Interest.S01E02.FRENCH.720p.BluRay.x264-SODAPOP.mkv doesn't exist in DB yet
2013-05-12 21:15:55,854 DEBUG [LibraryAdditionsCheckerThread] File not in Library, will add it
2013-05-12 21:15:55,856 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 7)
2013-05-12 21:15:55,858 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type AUDIO
2013-05-12 21:15:55,900 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type VIDEO
2013-05-12 21:15:55,901 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type IMAGE
2013-05-12 21:15:55,901 DEBUG [RepositoryDAOImpl] Marking Repository 7 as scanned with current timestamp
2013-05-12 21:15:55,906 DEBUG [VideoExtractionStrategy] Extracting metadata of video file: E:\Test Serviio\Person.of.Interest.S01E02.FRENCH.720p.BluRay.x264-SODAPOP.mkv
2013-05-12 21:15:55,908 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: E:\Test Serviio\Person.of.Interest.S01E02.FRENCH.720p.BluRay.x264-SODAPOP.mkv
2013-05-12 21:15:55,908 DEBUG [ProcessExecutor] Starting D:\Image & Video (x64)\Serviio\bin\\..\lib/ffmpeg.exe -i E:\Test Serviio\Person.of.Interest.S01E02.FRENCH.720p.BluRay.x264-SODAPOP.mkv
2013-05-12 21:15:55,921 WARN  [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video file type.
Post Sun May 12, 2013 7:42 pm
I forgot to say you have to also change this in log4j.xml
<param name="Threshold" value="DEBUG"/>
to
<param name="Threshold" value="TRACE"/>
You should see some TRACE entries in the log after the FFmpeg invocation
D-Kalck
Post Sun May 12, 2013 8:46 pm
2013-05-12 22:43:50,084 DEBUG [LibraryAdditionsCheckerThread] Found file 'Person.of.Interest.S01E03.FRENCH.720p.BluRay.x264-SODAPOP.mkv', checking if it's already in the Library
2013-05-12 22:43:50,085 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Person.of.Interest.S01E03.FRENCH.720p.BluRay.x264-SODAPOP.mkv
2013-05-12 22:43:50,086 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: E:\Test Serviio\Person.of.Interest.S01E03.FRENCH.720p.BluRay.x264-SODAPOP.mkv, ignore case: true
2013-05-12 22:43:50,086 TRACE [DBConnectionPool] Getting pooled connection from pool Serviio DB Pool
2013-05-12 22:43:50,096 TRACE [DBConnectionPool] Releasing connection from pool Serviio DB Pool
2013-05-12 22:43:50,097 DEBUG [LibraryUpdatesCheckerThread] Looking for removed/updated files in repository: E:\Test Serviio
2013-05-12 22:43:50,097 DEBUG [MediaItemDAOImpl] Reading MediaItems for Repository (id = 7)
2013-05-12 22:43:50,097 TRACE [DBConnectionPool] Getting pooled connection from pool Serviio DB Pool
2013-05-12 22:43:50,212 TRACE [DBConnectionPool] Releasing connection from pool Serviio DB Pool
2013-05-12 22:43:50,212 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 7)
2013-05-12 22:43:50,212 TRACE [DBConnectionPool] Getting pooled connection from pool Serviio DB Pool
2013-05-12 22:43:50,220 TRACE [DBConnectionPool] Releasing connection from pool Serviio DB Pool
2013-05-12 22:43:50,220 DEBUG [MediaItemDAOImpl] Media item Person.of.Interest.S01E03.FRENCH.720p.BluRay.x264-SODAPOP.mkv doesn't exist in DB yet
2013-05-12 22:43:50,220 DEBUG [LibraryAdditionsCheckerThread] File not in Library, will add it
2013-05-12 22:43:50,225 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type AUDIO
2013-05-12 22:43:50,225 TRACE [DBConnectionPool] Getting pooled connection from pool Serviio DB Pool
2013-05-12 22:43:50,235 TRACE [DBConnectionPool] Releasing connection from pool Serviio DB Pool
2013-05-12 22:43:50,235 DEBUG [RepositoryDAOImpl] Marking Repository 7 as scanned with current timestamp
2013-05-12 22:43:50,235 TRACE [DBConnectionPool] Getting pooled connection from pool Serviio DB Pool
2013-05-12 22:43:50,238 TRACE [DBConnectionPool] Releasing connection from pool Serviio DB Pool
2013-05-12 22:43:50,240 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type VIDEO
2013-05-12 22:43:50,240 TRACE [DBConnectionPool] Getting pooled connection from pool Serviio DB Pool
2013-05-12 22:43:50,241 TRACE [DBConnectionPool] Releasing connection from pool Serviio DB Pool
2013-05-12 22:43:50,241 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type IMAGE
2013-05-12 22:43:50,241 TRACE [DBConnectionPool] Getting pooled connection from pool Serviio DB Pool
2013-05-12 22:43:50,243 DEBUG [VideoExtractionStrategy] Extracting metadata of video file: E:\Test Serviio\Person.of.Interest.S01E03.FRENCH.720p.BluRay.x264-SODAPOP.mkv
2013-05-12 22:43:50,245 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: E:\Test Serviio\Person.of.Interest.S01E03.FRENCH.720p.BluRay.x264-SODAPOP.mkv
2013-05-12 22:43:50,245 DEBUG [ProcessExecutor] Starting D:\Image & Video (x64)\Serviio\bin\\..\lib/ffmpeg.exe -i E:\Test Serviio\Person.of.Interest.S01E03.FRENCH.720p.BluRay.x264-SODAPOP.mkv
2013-05-12 22:43:50,245 TRACE [DBConnectionPool] Releasing connection from pool Serviio DB Pool
2013-05-12 22:43:50,245 TRACE [ProcessExecutor] Env variables: {ProgramData=C:\ProgramData, USERPROFILE=C:\Windows\system32\config\systemprofile, PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC, ProgramFiles(x86)=C:\Program Files (x86), SystemDrive=C:, TEMP=C:\Windows\TEMP, ProgramFiles=C:\Program Files, Path=C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;D:\Travail & Decouverte (x86)\Komodo IDE 7\;D:\Travail & Decouverte (x86)\Komodo IDE 6\;%CommonProgramFiles%\Microsoft Shared\Windows Live;C:\Windows\SYSTEM32;C:\Windows;C:\Windows\SYSTEM32\WBEM;D:\DEV-(X64)\PYTHON27;D:\SYSTEME (X86)\BLUESOLEIL\MOBILE;D:\TRAVAIL & DECOUVERTE (X86)\JAVA\JDK1.6.0_23\BIN;D:\Dev-(x86)\android-sdk\platform-tools;D:\Dev-(x86)\android-sdk\tools;C:\Program Files\Common Files\Microsoft Shared\Windows Live;d:\travail & decouverte (x64)\java\jre7\bin, HOMEDRIVE=C:, JENV_2="E:\Test Serviio\Person.of.Interest.S01E03.FRENCH.720p.BluRay.x264-SODAPOP.mkv", PROCESSOR_REVISION=1e05, JENV_1=-i, USERDOMAIN=SPRINGFIELD, ALLUSERSPROFILE=C:\ProgramData, ProgramW6432=C:\Program Files, PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 30 Stepping 5, GenuineIntel, FONTCONFIG_PATH=D:\Image & Video (x64)\Serviio\config\fonts, TMP=C:\Windows\TEMP, PROCESSOR_ARCHITECTURE=AMD64, CommonProgramFiles=C:\Program Files\Common Files, FP_NO_HOST_CHECK=NO, OS=Windows_NT, HOMEPATH=\Windows\TEMP\, PROCESSOR_LEVEL=6, CommonProgramW6432=C:\Program Files\Common Files, LOCALAPPDATA=C:\Windows\system32\config\systemprofile\AppData\Local, FONTCONFIG_FILE=fonts.conf, COMPUTERNAME=MILHOUSE, SystemRoot=C:\Windows, windir=C:\Windows, NUMBER_OF_PROCESSORS=8, PUBLIC=C:\Users\Public, PSModulePath=C:\Windows\system32\WindowsPowerShell\v1.0\Modules\, USERNAME=MILHOUSE$, CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files, ComSpec=C:\Windows\system32\cmd.exe, APPDATA=C:\Windows\system32\config\systemprofile\AppData\Roaming}
2013-05-12 22:43:50,286 TRACE [OutputTextReader] 'D:\Image' n'est pas reconnu en tant que commande interne
2013-05-12 22:43:50,286 TRACE [OutputTextReader] ou externe, un programme ex‚cutable ou un fichier de commandes.
2013-05-12 22:43:50,287 TRACE [OutputTextReader] 'Video' n'est pas reconnu en tant que commande interne
2013-05-12 22:43:50,287 TRACE [OutputTextReader] ou externe, un programme ex‚cutable ou un fichier de commandes.
2013-05-12 22:43:50,288 WARN  [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video file type.
Well, I guess I should install Serviio somewhere else, seems it doesn't like the "&" in the path.
Thanks for helping me figuring that out.
Could it be fixed for a future version ?
Post Tue May 14, 2013 6:05 pm
Re: [Resolved] 1.2.1 Do not add any video
Ah ok, will have a look.
Users browsing this forum: Google [Bot] and 44 guests
