no sound on bdp ( SOLVED)
siriusblack
Post Thu May 09, 2013 7:32 pm
Re: no sound on bdp
M8
don't work on c/d/e profile
it's working on generic dlna but no sound
it saids not supported audio codecs
checked the codec details
AUDIO
original id: 68
Codec MPEG Audio layer 1/2/3/ (mpga)
VIDEO
original id:69
Codec H264 - MPEG - 4 AVC (PART 10) (h264)
hope this helps
also checked it on my Samsung tv video + sound works
nice1
Beta Tester
slyguy42o
Post Fri May 10, 2013 9:29 pm
Re: no sound on bdp
ok so just to confirm.. it played without sounds before the profile update and now it wont play at all?
siriusblack
Post Fri May 10, 2013 9:35 pm
Re: no sound on bdp
on Acestream
it would not play on both profiles but now it plays with no sound on generic
Beta Tester
Post Tue May 14, 2013 7:01 am
Re: no sound on bdp
Could you provide "ffmpeg -i" result of this file (see signature link) ?
To be clear, could you confirm :
- On Samsung TV : video OK + audio OK
- On Samsung BDP (with samsung profile) : video failed + audio failed
- On Samsung BDP (with generic profile) : video OK + audio failed
siriusblack
Post Tue May 14, 2013 8:01 am
Re: no sound on bdp
On the tv - video + sound works on library + online contents
On the bdp - c/d/e profile on library works video + sound Don't work online content + rss files (not supported file format)
On the bdp - generic profile on library works video + sound Don't work online content +rss files (not supported file format) except Chelsea tv works video + sound +
also Acestream works video no sound when the audio mpeg 1/2/3 ( mpga)
Here is my mediainfo c:\Users\Mark\Downloads\Acestream Recordings\vlc-record-2013-05-12-17h05m41s-Bloodzeed-ts
mpeg-ts: 791 mib, 1h 13mn
1 avc
1mpeg audio
1 345 kbps, 1280*720 (16:9) at 25.000fps avc (high@l3.1) (cabac / 5 ref frames)
80.0 kbps 48.0 kHz 2 channels mpeg audio (version 1) (layer 3) (joint stereo / ms stereo)
here is my profile.xml
profiles (2).xml
(91.9 KiB) Downloaded 525 times
will try to do a ffmpeg -I result
Thanks a lot appreciate it
Beta Tester
Post Tue May 14, 2013 11:43 am
Re: no sound on bdp
Hi siriusblack.
The way you have written it, its still a little confusing. To confirm my understanding - on the BDP using the Generic Profile:
  1. Local files in your library work fine (both video and sound)
  2. For online sources - no video or sound, except:
    1. Online Chelsea TV - works fine, video and sound.
    2. Online Aceplayer - video but no sound.
Also just for completeness, confirm that the TV is fine, so we need not worry about that any more.
siriusblack
Post Tue May 14, 2013 11:47 am
Re: no sound on bdp
Hi Denyall
The tv is fine
everything you said then is correct yes
Beta Tester
Post Tue May 14, 2013 12:12 pm
Re: no sound on bdp
Thanks - I'm going to take the sledgehammer approach and try to transcode all online sources for now. Can you add this to your profiles.xml:
<Profile id="sb" name="siriusblack" extendsProfileId="1">
   <OnlineTranscoding>
         <Matches container="*" />
   </OnlineTranscoding>
In Serviio console, set your device to use this profile and press save. Restart your PC (or restart the Serviio services if you know how to do that). If this doesn't work, try it again changing the "mpegts" to "mpeg" in the above.
siriusblack
Post Wed May 15, 2013 9:15 am
Re: no sound on bdp
just waiting for all the media to load up so I can try it out
just tried it not working at mo going to change mpegts to mpeg
let you no then
Beta Tester
siriusblack
Post Wed May 15, 2013 9:40 am
Re: no sound on bdp
Excellent
ive tested the rss files all work + tested some streams all work
Thanks for everything
ill let you no when I test the other streams
Beta Tester
siriusblack
Post Thu May 16, 2013 7:32 am
Re: no sound on bdp
Just a quick update all streams work
Thanks again
Beta Tester
Post Thu May 16, 2013 8:33 am
Re: no sound on bdp ( SOLVED)
Cool. Bear in mind this is transcoding everything; while this gets you going it's likely that it is transcoding stuff it doesn't need to.
You can refine this profile over time to only transcode those media types you need to. You can play with the profile at your convenience. Have a read of the wiki and have a go at it - you can always revert back to this profile if things go astray. Good luck.
Previous
Users browsing this forum: Baidu [Spider] and 41 guests
