when I play an MKV file with subtitle is my video stutters
alfredogoncalvesjr
Post Sun Mar 31, 2013 12:18 am
when I play an MKV file with subtitle (SRT) is my video stutters.
I use a Sony Blueray purchased in Brazil and I've tried all the profiles and not resolved.
Model: Home Theater 3D Blu-ray Sony BDVE290
Serviio Version: 1.2.1
When I turn off the subtitles, the video works normally.
Have tried several movies and all have problems
I've used the program SRTWiz to fix subtitles, but not solved.
I've used the program mkclean to fix the video, but not solved.
Attached the servvio log.
Can someone help me?
Alfredo
(174.33 KiB) Downloaded 559 times
slyguy42o
Post Sun Mar 31, 2013 4:18 am
Re: when I play an MKV file with subtitle is my video stutte
are you using the burned subtitle option?
Post Sun Mar 31, 2013 11:13 am
Strange...you have too devices with 192.168.1.52 IP address, could you cleanup the serviio device list in console?
2013-03-30 15:15:40,947 INFO [RendererManager] Stored a new renderer: uuid='eba7e916-60a9-4239-ae4f-dcde58925fb6', name = 'Sony BDP-Sx70/SMP-N100 (2010)', ipAddress='192.168.1.52', profile = 'bdp2010'
2013-03-30 15:15:47,822 INFO [RendererManager] Stored a new renderer: uuid='00000000-0000-1010-8000-3c07711455c1', name = 'BDV', ipAddress='192.168.1.52', profile = 'bdp2010'
Post Sun Mar 31, 2013 11:49 pm
Most likely it's because the file is transcoded and your PC is not powerful enough.
tsmithf
Post Tue May 21, 2013 7:44 pm
i have the same problem. i have serviio 1.2.1, sony bravia 2012
Computer
windows 7 64
256GB SSD Corsair
Intel I5 2,8Ghz
8GB RAM
Geforce GTX 560
disable subs movie play just fine, enable subs movie stutter
i allready install the latest FFMPEG
any ideas?
Post Wed May 22, 2013 1:31 pm
http://www.serviio.org/index.php?option ... icle&id=33
Read the first couple paragraphs. Confirms what was said above.
tsmithf
Post Wed May 22, 2013 3:00 pm
so what do you recommend for external subtitles?
tsmithf
Post Wed May 22, 2013 3:21 pm
im using a sony bravia 2012 kdl-40ex655
Post Wed May 22, 2013 7:13 pm
This is the only way on the Bravia TVs. Other than burn the subtitle into the video beforehand manually, using some tool.
NX3
Post Sat May 25, 2013 6:09 pm
Is your i5 dual core? Do you know the extract model?
You'd think i5 would be enough for transcoding but so many factors and not all i5 CPUs are that great.
Sent from my Nexus 7 using Tapatalk 2
tsmithf
Post Sun May 26, 2013 9:15 pm
Intel Core i5-2300 CPU 2.8GHZ
NX3
Post Mon May 27, 2013 8:17 am
My cpu benchmarks about half yours. I can do burnt in subs real time on SD material only, any higher resolution or bit rate it just can't cope.
Sony sets don't deal with subs very well so you can burn them in yourself using handbrake https://www.google.co.uk/search?q=handbrake+burn+in+subtitles or get a different media device with better sub support. You can get hdmi sticks with android on quite cheap and xbmc then installed as an app or stand alone boxes.
