Problem with Remote access
siriusblack
Post Wed May 22, 2013 2:05 pm
HI
just wondering if any one can help me please
iv'e read the wiki and followed the instructions
I'm trying to set up remote access and its coming with a red x
The spec
serviio 1.2.1, windows 8
The router is netgear DGND4000
Beta Tester
Post Wed May 22, 2013 2:17 pm
Re: Problem with Remote access
Did you read this? http://www.serviio.org/component/conten ... diabrowser
Do you have the PRO version?
siriusblack
Post Wed May 22, 2013 2:25 pm
Zip
The link you sent me is the one tried doing also I got the pro
Edition
Beta Tester
Post Wed May 22, 2013 7:15 pm
so what did you try? Did you try to do the port forwarding manually on your router?
siriusblack
Post Wed May 22, 2013 7:17 pm
Tried manual + auto Zip
went into firewall rules added serviio (tcp ) port 23424 in service table
on outbound services enabled used my wifi ip
then on port forwarding the same enabled my wifi ip
on serviio console went on remote tried external address my wifi ip + also auto both gets a red X
Beta Tester
Post Thu May 23, 2013 9:43 am
Are you using the external IP, really? check your here: http://www.whatismyip.com/
on the router enable port forwarding (router 23424 -> your serviio server IP:23424)
then try to go to
http://<your_external_ip>:23424/cds/application
from your mobile phone (or some other device that is not on your wifi network)
Post Thu May 23, 2013 10:32 am
Hi siriusblack - not sure what you mean by your wifi ip address.
Normally you will have two sets of IP addresses:
  • a single external address that is visible to everyone in the world. This address is assigned to you by your service provider. It is as shown by the web site http://www.whatismyip.com/ when run from your network.
  • a range of internal addresses that is set by your router. These normally (but not always) look like 10.x.x.x or 192.168.x.x. These addresses are only used inside your network and are not visible or reachable from the outside world. One of these addresses will be allocated to the PC you are running Serviio on. You cannot use this address for remote access (as they are not visible outside of your home network).
You do not need to change any addresses in your router - your service provider normally gives the external address to your router (and it may change from time to time). The router looks after your internal address range (which is not relevant for the purposes of remote access), not the external one (which is what you need here - for all the IP guru's, yes I am simplifying ;) )
To get remote access you must use the external address from http://www.whatismyip.com/. Further, you cannot use this address from inside your network - you must either go to someone elses house and use their network, or use your mobile phone (ensuring it is not connected to your WIFI network). Don't do it from work, as most corporates block this sort of traffic.
Hope this helps.
siriusblack
Post Thu May 23, 2013 10:37 am
Thanks Zip
will check that out now
I haven't been using the external ip address in router or on serviio console
I've been using my wifi ip
Beta Tester
siriusblack
Post Thu May 23, 2013 10:42 am
Thanks Denyall
that's why the red x is coming up the serviio console in remote when I check it
so in the external in serviio console I would put my external ip address ?
I tried to put my external ip in my phone to connect to serviio nothing happened im using 3G not wifi
this is what I did http://86.17#.###.##:23424/cds/application
Can you please tell me what I did wrong
nice1
Beta Tester
Xmantium
Post Sun Jun 30, 2013 4:33 pm
Best way to check if you port is open for remote CDS MediaBrowser/ServiiGo is to use http://www.canyouseeme.org or http://www.yougetsignal.com/tools/open-ports
Put in port 23424 and it would say its open or not :)
Users browsing this forum: Baidu [Spider] and 21 guests
