exlude filetypes / resize jpg / dvd image?
Monnem
Post Fri May 24, 2013 4:18 pm
Hi there,
first off all thanks for this nice piece of software!
I came along from the mediaserver "fuppes" which unfortunately lacks some development in the last time...
After getting started and 80% is working as expected, there are some questions left. Maybe some of you can help me:
1) Is it possible to exclude some filetype from being presented to the clients? Actually my image pool has always two versions of the same pic, the big raw data (Nikon NEF File) and the corrosponding jpg.
I would like to suppress the NEF Files, because showing the jpg is much faster.
2) Is it possible to resize the jpgs on the fly? I saw an option for resizing, but as far as i understand this will only works with pics bigger than 4096²? Can i set a limit, so that for the TV the pics are always be resized to 1080?
3) I've a Samsung C-Series TV and i saw, that there is already a nice profile for it. So mkv will be transcoded to avi, i think. Is it possible to switch the audio streams from TV or will only the first Audio send to the TV?
4) Is it possible to work with isos from DVDs/Blueray? I have testet a folder with the structure of a DVD and this works not as i expected: First i got for every vob one file, second the TV complains about the audio and do not play any of the vobs.
Thanks and regards
Monnem
Post Sun May 26, 2013 5:49 pm
Re: exlude filetypes / resize jpg / dvd image?
1) No
2) Serviio serves 3 versionsof am image, it's up to the device to pick which is the best suited
3) No
4) That's how it currently works, will try to implement something better in future.
