Problem with Sony BDP 470
Ares
Post Thu May 30, 2013 10:55 am
I'm very pleased with this program only for some time I can't read my mkv 1080 p only 720 p movies. What's even more strange it's that i can read series, which they are in 1080 p !! Well I tried to enable/disable transcoding, but nothing changes... and I don't know what to do! Well I edited a profile for the type of material that I have:
- TV Sony KDL-46V5500 and Bluray Player Sony BDP-470
Thank you in advance...
NX3
Post Thu May 30, 2013 5:17 pm
Re: Problem with Sony BDP 470
What profile did Serviio automatically select for your device (bluray player) ?
Ares
Post Thu May 30, 2013 6:08 pm
Thank you for your answer...
The profil selected is the 'Sony BDP-Sx70/SMP-100 (2010)..
Ares
Post Fri May 31, 2013 6:58 pm
the problem is already the same !!!
can someone help me ???
Post Sat Jun 01, 2013 10:57 am
Could you enable detailed logging ?
Could you compare on log the ffmpeg command used with serie (work) and movie (failed) ?
