WDTV Online transcoding question
jukkajalava
Post Wed Jun 12, 2013 10:30 am
Hi after streaming futubox for a few days the connection disconnects every 10mins or so and audio is like 5 seconds out of sync..so i went through and changed profiles in the console to Vizio Tv and now it works awesome!. Question is can i just copy and paste the online transcode section from Vizio Tv in the XML file and replace the WDTV Lines??
Only beacuse it seems Vizio Tv needs to transcode local files where as WDTV doesnt and when i play my local files im worried its going to transcode for no reason...
Any help would be appreciated!
Post Wed Jun 12, 2013 2:03 pm
Re: WDTV Online transcoding question
Yes, just replace the OnlineTranscoding section
jukkajalava
Post Wed Jun 12, 2013 2:32 pm
Thanks for the reply though unfortunatly audio still goes out of sync but seems to be less cut out ill just leave it for now though its goiod to know i can copy and paste in for the future..
Post Wed Jun 12, 2013 5:18 pm
did you restart your PC after making the profile change?
