my windows 8 with serviio server, turn off suddenly...help
maguen
Post Tue Jun 11, 2013 11:19 am
All with the server works well, i can see mkv,avi,mp4
The best program that i test.
until it turn off suddenly.
Like i would push the off button.
i need help. Before purchase the pro versión.
My pc runs windows 8.
Post Tue Jun 11, 2013 3:42 pm
Re: my windows 8 with serviio server, turn off suddenly...he
Could you enable detailed logging and post serviio.log here?
maguen
Post Wed Jun 12, 2013 1:04 am
2013-06-12 02:54:18,486 ERROR [ProcessExecutor] Fatal error in process starting: Cannot run program "cmd": CreateProcess error=19, El medio está protegido contra escritura
java.io.IOException: Cannot run program "cmd": CreateProcess error=19, El medio está protegido contra escritura
at java.lang.ProcessBuilder.start(Unknown Source)
at org.serviio.external.ProcessExecutor.run(ProcessExecutor.java:135)
Caused by: java.io.IOException: CreateProcess error=19, El medio está protegido contra escritura
at java.lang.ProcessImpl.create(Native Method)
at java.lang.ProcessImpl.<init>(Unknown Source)
at java.lang.ProcessImpl.start(Unknown Source)
... 2 more
2013-06-12 02:54:18,899 WARN [ProcessExecutor] Cannot retrieve results, output reader is null
2013-06-12 02:54:18,900 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video file type.
2013-06-12 02:54:19,198 ERROR [ProcessExecutor] Fatal error in process starting: Cannot run program "cmd": CreateProcess error=2, El sistema no puede encontrar el archivo especificado
java.io.IOException: Cannot run program "cmd": CreateProcess error=2, El sistema no puede encontrar el archivo especificado
Caused by: java.io.IOException: CreateProcess error=2, El sistema no puede encontrar el archivo especificado
... 2 more
2013-06-12 02:54:19,199 WARN [ProcessExecutor] Cannot retrieve results, output reader is null
2013-06-12 02:54:19,199 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video file type.
2013-06-12 02:54:19,204 ERROR [ProcessExecutor] Fatal error in process starting: Cannot run program "cmd": CreateProcess error=2, El sistema no puede encontrar el archivo especificado
... 2 more
2013-06-12 02:54:19,204 WARN [ProcessExecutor] Cannot retrieve results, output reader is null
2013-06-12 02:54:19,205 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video file type.
2013-06-12 02:54:19,260 ERROR [ProcessExecutor] Fatal error in process starting: Cannot run program "cmd": CreateProcess error=2, El sistema no puede encontrar el archivo especificado
... 2 more
2013-06-12 02:54:19,261 WARN [ProcessExecutor] Cannot retrieve results, output reader is null
2013-06-12 02:54:19,261 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video file type.
2013-06-12 02:57:27,061 INFO [MediaServer] ------------------------------------------------------------------------
2013-06-12 02:57:27,170 INFO [MediaServer] Serviio DLNA media streaming server v 1.2.1 (rev. a2aa56064460+)
2013-06-12 02:57:27,170 INFO [MediaServer] Petr Nejedly 2009-2013
2013-06-12 02:57:27,170 INFO [MediaServer] http://www.serviio.org
2013-06-12 02:57:27,170 INFO [MediaServer] Java 1.7.0_05-Oracle Corporation
2013-06-12 02:57:27,170 INFO [MediaServer] OS Windows NT (unknown) amd64 6.2
2013-06-12 02:57:27,170 INFO [MediaServer] File encoding: windows-1252
2013-06-12 02:57:27,201 INFO [MediaServer] Headless mode enabled: true
2013-06-12 02:57:27,201 INFO [MediaServer] User: LTDM$
2013-06-12 02:57:27,201 INFO [MediaServer] User home dir: C:\
2013-06-12 02:57:27,201 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2013-06-12 02:57:27,201 INFO [MediaServer] ------------------------------------------------------------------------
2013-06-12 02:57:31,757 INFO [WebServer] Socket buffer set to 65535 bytes
2013-06-12 02:57:31,835 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2013-06-12 02:57:32,677 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2013-06-12 02:57:32,677 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2013-06-12 02:57:32,927 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2013-06-12 02:58:04,923 INFO [ServiioConsole] Starting Serviio Console
2013-06-12 02:58:05,141 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
Enviado desde mi Nexus 4 usando Tapatalk 2
maguen
Post Wed Jun 12, 2013 1:08 am
Thank you.
I copy the log from where it says Error ... I've reinstalled java several times also. It looks to be related to java ... the first time to install it gave me this error screenshot attached
Post Wed Jun 12, 2013 7:38 am
Its something about security access.
Do you install serviio with all admin privilege ?
maguen
Post Wed Jun 12, 2013 11:21 pm
Yes.
Server start and no problem.
Until it conects to any devices them PC turns off
Post Mon Jun 17, 2013 8:56 am
yep, Servii-Console cannot find the jar files with the classes. NO idea why, maybe corrupted download? Can you browse contents of Servii-Console.app and does it include serviio-client.jar file?
Users browsing this forum: Baidu [Spider], Google [Bot] and 89 guests
