COOLSPORT - A SPORTS STREAM WEBRESOURCE
• Page 5 of 5 • 1, 2, 3, 4, 5
Re: COOLSPORT - A SPORTS STREAM WEBRESOURCE
I've been waiting for a fix for this plugin since it broke due to coolsport.tv locking down there streams but i thought i'd post the fix for it that I've just done for myself.
Edit the groovy file, replace the line
with
and then edit the webresource url to match - i.e. http://coolsport.tv?refresh=30 or whatever
Hope that helps a few peeps out.
final VALID_RESOURCE_URL = '^http://www.coolsport.tv.*?'
with
That won't fix anything. The streams will list but will only play for 8 seconds.
SORRY
should of read earlier post's
Beta Tester
Beta Tester
Read the previous posts and delete yours.
I have a problem:
I am trying to get live streaming from my Samsung R530 laptop to my Panasonic TX-P42GT30B (Viera). I have the console configured for Coolsport and have put the groovy plugin into the plugin directory. In the library section I have selected live streamimg and put http://www.coolsport.tv/stream3.html in the box, I've tried some other addresses but they both give the red x and fail to display on my menu on TV. What do I need to put in the URL box and what type of feed is it?
Thank you.
Thank you.
OK I now have Coolsport appearing on my TV under Video/Online but it is empty, there are no streams appearing as they do on the web page. I have done this by entering http://www.coolsport.tv/schedule.html in the URL and switching the type to 'Web resource'. If I switch it to 'stream' it disappears from the TV.
billbrooks wrote:I have a problem:
Thank you.
You need to set it as a web resource, not live stream.
As posted above viewtopic.php?f=20&t=8127&start=60#p69448
Coolsport has locked up their streams, so the plugin will currently not work.
It requires a modified version of librtmp that Serviio's ffmpeg does not include.
Hi jhb50,
which modification of librtmp is needed?
Could you please tell the necessary steps for linux?
xXsamXx1991
Player: Samsung UE46C5700 | Server: Ubuntu 14.04 LTS
Player: Samsung UE40F5370
Player: Toshiba REGZA 37UL863
Intel UPnP tools | HOWTO: Turn on detailed logging | HowTo: Provide supported formats of a device | HowTo: Provide details of a video file that doesn't play | HowTo: Remove header compression
Sorry, I have no knowledge of Linux.
