iPlayer issues since 1.2.1 (Xbox XBMC Profile Related?)
Urza
Post Wed Jun 19, 2013 10:52 am
I've been having trouble streaming iPlayer content from my Serviio PC server to an original Xbox running XBMC.
I recently noticed that all my iPlayer folders were empty, so I checked the iPlayer thread and found that iPlayer.groovy had been updated. I installed that and updated from Serviio 1.1 to 1.2.1 at the same time.
Now, all of my iPlayer folders have the correct content, and it is all fully playable to all devices in my house with the exception of my original Xbox running XBMC. I had a custom profile for the XBMC Xbox as per Zip's post here: http://forum.serviio.org/viewtopic.php?f=7&t=6938&p=49728&hilit=xbox+xbmc+profile#p49764
ie:
   <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" maxHeight="480">
      <Matches container="*" />
I have successfully used the above code to make an XBMC Xbox profile, using Serviio Profile 1 as the basis. This profile transcoded everything (no matter what codec, container or resolution) to mpeg2, and where required changed the resolution to 480p maximum.
However, ever since I updated Serviio to 1.2.1 and updated the iPlayer.groovy, all iPlayer streams to my XBMC Xbox cut out at random. The only error I'm seeing in the debug logs is a 'Connection reset' error (I'll try to capture some decent output later, I'm at work at the moment).
I know the XBMC Xbox is an old piece of kit and don't expect miracles from it. However I used to be able to stream iPlayer content to it from Serviio 1.1 without any issues, and now under 1.2.1 the stream cuts out anywhere from 1min-25mins in.. :(
Does anyone know if there were any major changes to the basic Serviio transcoding profiles (specifically Profile 1) that could be causing this problem?
Xmantium
Post Wed Jun 19, 2013 7:21 pm
Re: iPlayer issues since 1.2.1 (Xbox XBMC Profile Related?)
are you sure your using version 2 of the iplayer plugin? just got updated recently by zip
Urza
Post Wed Jun 19, 2013 7:44 pm
The one he uploaded on 9/6/2013? Thats the one I have installed.
Urza
Post Wed Jun 19, 2013 8:41 pm
I downloaded the iPlayer.groovy again just to be sure. I'm still getting the same problem - the iPlayer feed just freezes on my XBMC Xbox (I have to power-cycle the XBMC Xbox to unfreeze it).
The only error I can see in the log is the following:
2013-06-19 21:36:37,043 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
I've added the full DEBUG logs to this post. I have zipped them as the first log was just over 500kb.
pc5dczc_logs.zip
Serviio DEBUG Logs.
(57.63 KiB) Downloaded 479 times
Xmantium
Post Wed Jun 19, 2013 8:58 pm
Try to change the quality setting, i used to have XBMC on my good old xbox, AFIK xbmc4xbox doesnt support HD content
I use iPlayer groovy everyday without a miss cos my kids using CBeebies, its working perfectly fine, so the groovy has no issues.
Issues maybe serviio to xbmc
Urza
Post Wed Jun 19, 2013 9:15 pm
Hi Xmantium,
Thanks, I'll give it a try. It is already set to Medium, so I'll give Low a try.
However, the transcoding profile I made for the XBMC Xbox should be transcoding everything to 480p MPEG2, and it was working perfectly before I updated the iPlayer.groovy & Serviio to their latest version.
I'm wondering if something has been tweaked in the profiles.xml between 1.1 and 1.2.1 which means that my custom XBMC Xbox profile is no longer doing the job that it used to.
This is my XBMC Xbox profile, as you can see it extends Profile 1:
<Profile id="XBMC-Xbox" name="Xbox XBMC" extendsProfileId="1">
This is Profile 1 from Serviio 1.2.1:
<Profile id="1" name="Generic DLNA profile">
      <ContentDirectoryMessageBuilder>org.serviio.upnp.service.contentdirectory.GenericDLNAMessageBuilder</ContentDirectoryMessageBuilder>
      <ProtocolInfo>DLNA</ProtocolInfo>
      <DeviceDescription>
         <FriendlyName>Serviio ({computerName})</FriendlyName>
         <ModelName>Serviio Media Server</ModelName>
         <Manufacturer>Petr Nejedly</Manufacturer>
      </DeviceDescription>
      <MediaFormatProfiles>
         <MediaFormatProfile mime-type="audio/mpeg">MP3</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/L16;rate=44100;channels=1" name="LPCM">LPCM16_44_MONO</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/L16;rate=44100;channels=2" name="LPCM">LPCM16_44_STEREO</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/L16;rate=48000;channels=1" name="LPCM">LPCM16_48_MONO</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/L16;rate=48000;channels=2" name="LPCM">LPCM16_48_STEREO</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/x-ms-wma">WMA_BASE</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/x-ms-wma">WMA_FULL</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/mp4">AAC_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/mp4">AAC_ISO_320</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/vnd.dlna.adts">AAC_ADTS</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/vnd.dlna.adts">AAC_ADTS_320</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/flac">FLAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/ogg">OGG</MediaFormatProfile>
         <MediaFormatProfile mime-type="image/jpeg">JPEG_SM</MediaFormatProfile>
         <MediaFormatProfile mime-type="image/jpeg">JPEG_MED</MediaFormatProfile>
         <MediaFormatProfile mime-type="image/jpeg">JPEG_LRG</MediaFormatProfile>
         <MediaFormatProfile mime-type="image/jpeg">JPEG_TN</MediaFormatProfile>
         <MediaFormatProfile mime-type="image/png">PNG_LRG</MediaFormatProfile>
         <MediaFormatProfile mime-type="image/png">PNG_TN</MediaFormatProfile>
         <MediaFormatProfile mime-type="image/gif">GIF_LRG</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">MPEG1</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">MPEG_PS_PAL</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">MPEG_PS_NTSC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_SD_EU</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_SD_EU_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">MPEG_TS_SD_EU_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_SD_NA</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_SD_NA_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">MPEG_TS_SD_NA_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_SD_KO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_SD_KO_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">MPEG_TS_SD_KO_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_JP_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-msvideo">AVI</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-matroska">MATROSKA</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-flv">FLV</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-dvr">DVR_MS</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/wtv">WTV</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/ogg">OGV</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.rn-realvideo">REAL_VIDEO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_SD_AAC_MULT5</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_SD_MPEG1_L3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_SD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_HD_720p_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_HD_1080i_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_HP_HD_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_LPCM</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">MPEG4_P2_MP4_ASP_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">MPEG4_P2_MP4_SP_L6_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">MPEG4_P2_MP4_NDSD</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG4_P2_TS_ASP_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG4_P2_TS_ASP_AAC_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">MPEG4_P2_TS_ASP_AAC_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG4_P2_TS_ASP_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG4_P2_TS_ASP_AC3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">MPEG4_P2_TS_ASP_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG4_P2_TS_ASP_MPEG1_L3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG4_P2_TS_ASP_MPEG1_L3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">MPEG4_P2_TS_ASP_MPEG2_L2_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG4_P2_TS_ASP_MPEG2_L2</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG4_P2_TS_ASP_MPEG2_L2_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">MPEG4_P2_TS_ASP_MPEG1_L3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_AAC_MULT5</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_AAC_MULT5_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_SD_AAC_MULT5_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_MPEG1_L3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_MPEG1_L3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_SD_MPEG1_L3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_AC3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_SD_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_AAC_MULT5</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_AAC_MULT5_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_HD_AAC_MULT5_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_MPEG1_L3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_MPEG1_L3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_HD_MPEG1_L3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_AC3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_HD_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_HD_DTS_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">AVC_TS_HD_DTS_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_HD_50_LPCM_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">AVC_TS_HP_SD_MPEG1_L2_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_HP_SD_MPEG1_L2_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">AVC_TS_HP_HD_MPEG1_L2_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_HP_HD_MPEG1_L2_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-wmv">WMVMED_BASE</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-wmv">WMVMED_FULL</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-wmv">WMVHIGH_FULL</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-wmv">WMVMED_PRO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-wmv">WMVHIGH_PRO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-asf">VC1_ASF_AP_L1_WMA</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-asf">VC1_ASF_AP_L2_WMA</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-asf">VC1_ASF_AP_L3_WMA</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">VC1_TS_AP_L1_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">VC1_TS_AP_L2_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">VC1_TS_HD_DTS_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">VC1_TS_HD_DTS_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/3gpp">MPEG4_P2_3GPP_SP_L0B_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/3gpp">MPEG4_P2_3GPP_SP_L0B_AMR</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/3gpp">AVC_3GPP_BL_QCIF15_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/3gpp">MPEG4_H263_3GPP_P0_L10_AMR</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/3gpp">MPEG4_H263_MP4_P0_L10_AAC</MediaFormatProfile>
      </MediaFormatProfiles>
      <H264LevelCheck>ANY</H264LevelCheck>
         <Image forceInheritance="true">
            <Matches container="raw"/>
         </Image>
      <OnlineTranscoding>
            <Matches container="mp4"/>
            <Matches container="flv" vCodec="h264"/>
             <Matches container="applehttp" vCodec="h264"/>
         <Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="384" forceInheritance="true">
            <Matches container="rtp"/>
            <Matches container="rtsp"/>
            <Matches container="applehttp"/>
         <Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="384">
            <Matches container="asf"/> <!-- to support mms:// streams -->
            <Matches container="flv"/>
         <Audio targetContainer="mp3" aBitrate="384" forceInheritance="true">
            <Matches container="mp3"/>
         </Audio>
      </OnlineTranscoding>
      <HardSubsTranscoding>
         <Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="384" />
      </HardSubsTranscoding>
      <AutomaticImageRotation>false</AutomaticImageRotation>
      <LimitImageResolution>true</LimitImageResolution>
      <Subtitles>
         <SoftSubs mime-type="text/srt" />
         <HardSubs>
            <RequiredFor container="*" />
         </HardSubs>
      </Subtitles>
And this is the Profile 1 from Serviio 1.1:
      <DeviceDescription>
         </Image>
      <OnlineTranscoding>
         </Audio>
Is there any difference?
Post Wed Jun 19, 2013 10:16 pm
You might need to add a similar OnlineTranscoding section, otherwise it's inherited from the Generic profile.
Urza
Post Thu Jun 20, 2013 5:31 am
Thanks Zip.
Something like this?
   <OnlineTranscoding>
Urza
Post Thu Jun 20, 2013 11:09 am
Hi all,
The updated profile above doesn't appear to have made any difference - the feed still freezes the XBMC Xbox somewhere between 2-30 minutes into a TV program. I restarted the Serviio Service after adding the updated profile, and made sure that the profile was selected for the XBMC Xbox in the Devices Section.
The Online Feed Quality has been set to Low too.
Have I written the profile correctly?
Added a new Debug Serviio Log (attached).
serviio.zip
Serviio Log
(89.56 KiB) Downloaded 464 times
Post Thu Jun 20, 2013 2:29 pm
Yes, it's all good. You might try to change FFMpeg to the latest version or the one from previous Serviio version.
Urza
Post Thu Jun 20, 2013 4:39 pm
Hmmm.. It still crashes when using the ffmpeg.exe from Serviio 1.1.
I'll give ffmpeg-20130620-git-f9739a3-win64-static (the latest ffmpeg build on http://ffmpeg.zeranoe.com/builds/) a go and let you know how I get on.
Urza
Post Thu Jun 20, 2013 5:00 pm
Update: freezing still occurs with ffmpeg-20130620-git-f9739a3-win64-static.. :(
turls2201
Post Fri Jun 21, 2013 7:53 pm
That log file does not contain any reference to xbox.
Have you set the temp directory up and referenced it on Delivery tab "Transcoded files location: " and can you save there. Does it have a lot of space?
Ian
Urza
Post Sat Jun 22, 2013 10:51 am
Hi Ian,
My Serviio temp directory is set to C:\ServiioTEMP\ - I currently have 177Gb free on that drive.
I am able to save large files (5.6gb for example) to that folder without any problems. The folder (and it's sub folders) have Full Access permissions for SYSTEM and Administrators.
turls2201
Post Sat Jun 22, 2013 11:09 am
OK - what is your network setup and broadband speed?
Urza
Post Sat Jun 22, 2013 3:45 pm
turls2201, thanks for the input, but Broadband speed & network setup aren't relevant. It was working perfectly before I upgraded from Serviio 1.1 to 1.2.1, and updated the iPlayer.groovy at the same time.
Also, I am able to stream BBC iPlayer content from Serviio to my Samsung LE40C580 TV without any issues, which rules out broadband/LAN problems.
The issue is that when I stream BBC iPlayer content from Serviio to my original Xbox (running XBMC4Xbox 3.2.1), the stream freezes, and causes the Xbox to crash. This did not happen prior to my upgrading from Serviio 1.1 to 1.2.1, and updated the iPlayer.groovy at the same time.
turls2201
Post Sat Jun 22, 2013 6:44 pm
Does sound like a transcoding issue - is it picking the correct profile? do you still have the old profile.xml to try?
Urza
Post Sat Jun 22, 2013 7:18 pm
Yeah, I've tried both - I still get the same issue with either profile.
I've attached both so you can take a look to see if I've done anything wrong.
profiles.xml.zip
XBMC-Xbox Profiles.xml for both Serviio 1.1 & 1.2.1
(20.92 KiB) Downloaded 462 times
Urza
Post Thu Jun 27, 2013 3:03 pm
Update: I've given up on this.
The latest version of XBMC4Xbox has a plugin to stream iPlayer etc directly to it from the internet, so I'm using that instead.
Users browsing this forum: No registered users and 65 guests
