Twitch.tv/Justin.tv
Worked! Many many thanks.
Re: Twitch.tv/Justin.tv
When using v1.4 I get the following error:
Stream is working with v1.3.
- Code:
rtmp://justintvlivefs.fplive.net/justintv3live-live playpath=stream_480p_user_guardsmanbob swfUrl=http://www-cdn.jtvnw.net/widgets/live_embed_player.r560e9566f58ea10b4444d04bda339f685fc88f5b.swf swfVfy=1 live=1: Invalid data found when processing input
2013-06-19 17:42:25,957 WARN [ProcessExecutor] Process cmd has a return code of 1! This is a possible error. Detailed output follows.
libavfilter 3. 32.100 / 3. 32.100
libswscale 2. 1.103 / 2. 1.103
Closing connection: NetStream.Play.Failed
rtmp://199.9.255.43/app: Unknown error occurred
So I set this up for use on my PS3, and when I go to video->online-> on the PS3 I find the folders for the twitch.tv streams, but when I open the folders themselves it just says "no titles." I've double checked the urls and watched the youtube video several times to make sure I have everything set up the same way as web sources and all that but to no avail. I reset my PC and the service and forced refresh on the streams multiple times. Any possible explanation I'm missing?
tyrant00 wrote:When using v1.4 I get the following error:
- Code:
Joshmvii7 wrote:So I set this up for use on my PS3, and when I go to video->online-> on the PS3 I find the folders for the twitch.tv streams, but when I open the folders themselves it just says "no titles." I've double checked the urls and watched the youtube video several times to make sure I have everything set up the same way as web sources and all that but to no avail. I reset my PC and the service and forced refresh on the streams multiple times. Any possible explanation I'm missing?
Whenever I try to view www.twitch.tv/riotgames, I am constantly getting the error of "Media Server Error: A network error has occurred. (80710723)"
Below is my log:
Below is my log:
- Code:
2013-06-20 14:29:15,536 WARN [ProcessExecutor] Process cmd has a return code of 1! This is a possible error. Detailed output follows.
rtmp://199.9.248.169/app: Unknown error occurred
do a force refresh, retry
I've done a force refresh many times. How long does it take to refresh? It's the only reason why I use Serviio so I don't have any other things in the library.
it takes between 15-45 seconds for me. what OS are you using, which version of serviio?
Windows 7
Serviio 1.2.1
Serviio 1.2.1
hi!
thx for the plugin!
i get this message:
can you help me? it is a ffmpeg error?
system: linux --> qnap nas (x86)
edit:
directory in Video/Online successfully created but no files in it.
edit 2:
it seems i compiled ffmpeg without librtmp enabled. will do it again, and test it.
thx for the plugin!
i get this message:
- Code:
2013-06-21 19:46:54,890 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmp://199.9.255.168/app playpath=jtv_z4iFoQe_h2uRKaPs swfUrl=http://www-cdn.jtvnw.net/widgets/live_embed_player.rba44673091039dd7a2493939d027fcdaf5aa465f.swf swfVfy=1 jtv=ae28aa0f0b020e0989f250a2a428d5cc7ebb4bfd:{"swfDomains":\20["justin.tv",\20"jtvx.com",\20"xarth.com",\20"twitchtv.com",\20"twitch.tv",\20"newjtv.com",\20"jtvnw.net",\20"wdtinc.com",\20"imapweather.com",\20"facebook.com",\20"starcrafting.com"],\20"streamName":\20"jtv_z4iFoQe_h2uRKaPs",\20"expiration":\201371847613,\20"server":\20"video4-1.ams01"} live=1. It might not play.
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:292)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:209)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:102)
at org.serviio.library.metadata.FFmpegMetadataRetriever.validateMandatoryMetadata(FFmpegMetadataRetriever.java:453)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:94)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:132)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:269)
... 2 more
edit:
edit 2:
jules wrote:that doesn't look like it's the whole log, as http://x.y.z.t/app is nowhere in that line.tyrant00 wrote:When using v1.4 I get the following error:
- Code:
Okay. I will do some verbose logging tomorrow and post logs here.
Serviio 1.2.1
Windows 7
Samsung TV and PS3
plugin V4
same result on both devices Video / Online / TwitchName Folder / no streams show
tested with several http://www.twitch.tv/*********
i've been trying http://www.twitch.tv/taketv and TaKeTV
PS3 returns "There are no tracks"
Samsung TV just gives the option to go to Upper Folder
any suggestions?
Windows 7
Samsung TV and PS3
plugin V4
any suggestions?
- Code:
2013-06-22 16:50:13,401 WARN [FeedUpdaterThread] Failed to retrieve online item information for null playpath=null swfUrl=http://www-cdn.jtvnw.net/widgets/live_embed_player.re1dfd1845e13c8c3b9af4aa989a353052d87139a.swf swfVfy=1 live=1. It might not play.
... 2 more
2013-06-22 16:50:14,644 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmp://192.16.70.39/app playpath=jtv_RBlR6aDyosGY1ZK9 swfUrl=http://www-cdn.jtvnw.net/widgets/live_embed_player.re1dfd1845e13c8c3b9af4aa989a353052d87139a.swf swfVfy=1 jtv=bcabdc24e5dd45cfe3317f673cabf93ebefe321f:{\"swfDomains\":\20[\"justin.tv\",\20\"jtvx.com\",\20\"xarth.com\",\20\"twitchtv.com\",\20\"twitch.tv\",\20\"newjtv.com\",\20\"jtvnw.net\",\20\"wdtinc.com\",\20\"imapweather.com\",\20\"facebook.com\",\20\"starcrafting.com\"],\20\"streamName\":\20\"jtv_RBlR6aDyosGY1ZK9\",\20\"expiration\":\201371937812,\20\"server\":\20\"video10-2.iad02\"} live=1. It might not play.
... 2 more
2013-06-22 16:50:16,050 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmp://192.16.70.27/app playpath=jtv_SMb5emAHI0B4zi9J swfUrl=http://www-cdn.jtvnw.net/widgets/live_embed_player.re1dfd1845e13c8c3b9af4aa989a353052d87139a.swf swfVfy=1 jtv=29df19b610ddc601575604a19c33c0810749e10d:{\"swfDomains\":\20[\"justin.tv\",\20\"jtvx.com\",\20\"xarth.com\",\20\"twitchtv.com\",\20\"twitch.tv\",\20\"newjtv.com\",\20\"jtvnw.net\",\20\"wdtinc.com\",\20\"imapweather.com\",\20\"facebook.com\",\20\"starcrafting.com\"],\20\"streamName\":\20\"jtv_SMb5emAHI0B4zi9J\",\20\"expiration\":\201371937812,\20\"server\":\20\"video4-1.iad02\"} live=1. It might not play.
... 2 more
2013-06-22 16:50:16,468 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmp://192.16.70.36/app playpath=jtv_Y3lsS_T6skMdhmtX swfUrl=http://www-cdn.jtvnw.net/widgets/live_embed_player.re1dfd1845e13c8c3b9af4aa989a353052d87139a.swf swfVfy=1 jtv=a9f7031a1b04d6f242e940bd6c12135c3d522b80:{\"swfDomains\":\20[\"justin.tv\",\20\"jtvx.com\",\20\"xarth.com\",\20\"twitchtv.com\",\20\"twitch.tv\",\20\"newjtv.com\",\20\"jtvnw.net\",\20\"wdtinc.com\",\20\"imapweather.com\",\20\"facebook.com\",\20\"starcrafting.com\"],\20\"streamName\":\20\"jtv_Y3lsS_T6skMdhmtX\",\20\"expiration\":\201371937812,\20\"server\":\20\"video7-2.iad02\"} live=1. It might not play.
... 2 more
2013-06-22 16:50:16,897 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmp://192.16.70.33/app playpath=jtv_xQ7s_AJH_iVS_t1W swfUrl=http://www-cdn.jtvnw.net/widgets/live_embed_player.re1dfd1845e13c8c3b9af4aa989a353052d87139a.swf swfVfy=1 jtv=74e3773e5a62d161bf8fbdc6af6372972d314610:{\"swfDomains\":\20[\"justin.tv\",\20\"jtvx.com\",\20\"xarth.com\",\20\"twitchtv.com\",\20\"twitch.tv\",\20\"newjtv.com\",\20\"jtvnw.net\",\20\"wdtinc.com\",\20\"imapweather.com\",\20\"facebook.com\",\20\"starcrafting.com\"],\20\"streamName\":\20\"jtv_xQ7s_AJH_iVS_t1W\",\20\"expiration\":\201371937812,\20\"server\":\20\"video4-2.iad02\"} live=1. It might not play.
I get the same error, with stream items not showing up, just the folder
Latest Serviio 1.2.1
Windows 7
Tested using a Playstation 3 and an android DLNA browser.
Logs begginging with the forced refresh:
Windows 7
- Code:
2013-06-22 20:03:17,805 WARN [EventDispatcher] Couldn't send event message for subscription 5cd336c1-a21b-4803-b7d7-24588b94ebb3, will keep trying until subscription expires
2013-06-22 20:07:41,683 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2013-06-22 20:07:41,782 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2013-06-22 20:07:41,882 INFO [PlaylistMaintainerThread] Finished looking for playlist changes
2013-06-22 20:07:41,908 WARN [EventDispatcher] Couldn't send event message for subscription 5cd336c1-a21b-4803-b7d7-24588b94ebb3, will keep trying until subscription expires
2013-06-22 20:07:41,999 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2013-06-22 20:07:42,000 INFO [PlaylistMaintainerThread] Started looking playlist changes
2013-06-22 20:07:42,000 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2013-06-22 20:07:46,679 WARN [EventDispatcher] Couldn't send event message for subscription 5cd336c1-a21b-4803-b7d7-24588b94ebb3, will keep trying until subscription expires
2013-06-22 20:08:47,046 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmp://199.9.254.168/app playpath=jtv_ugIPPwRKytxRiCHH swfUrl=http://www-cdn.jtvnw.net/widgets/live_embed_player.re1dfd1845e13c8c3b9af4aa989a353052d87139a.swf swfVfy=1 jtv=dcbe4df41031532a480975682e2c577482549684:{\"swfDomains\":\20[\"justin.tv\",\20\"jtvx.com\",\20\"xarth.com\",\20\"twitchtv.com\",\20\"twitch.tv\",\20\"newjtv.com\",\20\"jtvnw.net\",\20\"wdtinc.com\",\20\"imapweather.com\",\20\"facebook.com\",\20\"starcrafting.com\"],\20\"streamName\":\20\"jtv_ugIPPwRKytxRiCHH\",\20\"expiration\":\201371951612,\20\"server\":\20\"video12-2.lax01\"} live=1. It might not play.
... 2 more
2013-06-22 20:08:52,273 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmp://199.9.254.18/app playpath=jtv_Npc7Mj8iF5DHdkvB swfUrl=http://www-cdn.jtvnw.net/widgets/live_embed_player.re1dfd1845e13c8c3b9af4aa989a353052d87139a.swf swfVfy=1 jtv=193ee2dc22d609a939fdae19db3a876db3fea6fe:{\"swfDomains\":\20[\"justin.tv\",\20\"jtvx.com\",\20\"xarth.com\",\20\"twitchtv.com\",\20\"twitch.tv\",\20\"newjtv.com\",\20\"jtvnw.net\",\20\"wdtinc.com\",\20\"imapweather.com\",\20\"facebook.com\",\20\"starcrafting.com\"],\20\"streamName\":\20\"jtv_Npc7Mj8iF5DHdkvB\",\20\"expiration\":\201371951612,\20\"server\":\20\"video14-1.dfw01\"} live=1. It might not play.
... 2 more
2013-06-22 20:08:55,604 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmp://199.9.255.18/app playpath=jtv_VgYx_DO5VOPswkeT swfUrl=http://www-cdn.jtvnw.net/widgets/live_embed_player.re1dfd1845e13c8c3b9af4aa989a353052d87139a.swf swfVfy=1 jtv=5405f5b78a47641b733fe889d3f8d14b17fcb6f2:{\"swfDomains\":\20[\"justin.tv\",\20\"jtvx.com\",\20\"xarth.com\",\20\"twitchtv.com\",\20\"twitch.tv\",\20\"newjtv.com\",\20\"jtvnw.net\",\20\"wdtinc.com\",\20\"imapweather.com\",\20\"facebook.com\",\20\"starcrafting.com\"],\20\"streamName\":\20\"jtv_VgYx_DO5VOPswkeT\",\20\"expiration\":\201371951612,\20\"server\":\20\"video6-2.mia01\"} live=1. It might not play.
... 2 more
2013-06-22 20:09:00,970 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmp://199.9.255.10/app playpath=jtv_3G8_SAnOYq586rNb swfUrl=http://www-cdn.jtvnw.net/widgets/live_embed_player.re1dfd1845e13c8c3b9af4aa989a353052d87139a.swf swfVfy=1 jtv=e8a6274a0de529a35e78ebf1fbdbe17f63754d8b:{\"swfDomains\":\20[\"justin.tv\",\20\"jtvx.com\",\20\"xarth.com\",\20\"twitchtv.com\",\20\"twitch.tv\",\20\"newjtv.com\",\20\"jtvnw.net\",\20\"wdtinc.com\",\20\"imapweather.com\",\20\"facebook.com\",\20\"starcrafting.com\"],\20\"streamName\":\20\"jtv_3G8_SAnOYq586rNb\",\20\"expiration\":\201371951612,\20\"server\":\20\"video6-1.mia01\"} live=1. It might not play.
... 2 more
2013-06-22 20:09:05,262 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmp://199.9.255.11/app playpath=jtv_VWFlKlitNbdoZ7XJ swfUrl=http://www-cdn.jtvnw.net/widgets/live_embed_player.re1dfd1845e13c8c3b9af4aa989a353052d87139a.swf swfVfy=1 jtv=f4023bd4777438cf8a405c020eee67be58f35f99:{\"swfDomains\":\20[\"justin.tv\",\20\"jtvx.com\",\20\"xarth.com\",\20\"twitchtv.com\",\20\"twitch.tv\",\20\"newjtv.com\",\20\"jtvnw.net\",\20\"wdtinc.com\",\20\"imapweather.com\",\20\"facebook.com\",\20\"starcrafting.com\"],\20\"streamName\":\20\"jtv_VWFlKlitNbdoZ7XJ\",\20\"expiration\":\201371951612,\20\"server\":\20\"video7-1.mia01\"} live=1. It might not play.
... 2 more
jmrainwa wrote:Serviio 1.2.1
Windows 7
Samsung TV and PS3
plugin V4
any suggestions?
- Code:
... 2 more
... 2 more
... 2 more
... 2 more
that first entry looks wrong (playpath=null), but the rest of them look good. aside from that, serviio clearly fails to open them.
please try this:
- do a force refresh while the stream is running
- take a look at the log again and copy out the line that looks like this:
- Code:
- open up a command prompt (win key+r -> "cmd") and cd C:\Program Files\Serviio\lib
- run this command:
- Code:
ffmpeg -i "rtmp://192.16.70.36/app playpath=jtv_Y3lsS_T6skMdhmtX swfUrl=http://www-cdn.jtvnw.net/widgets/live_embed_player.re1dfd1845e13c8c3b9af4aa989a353052d87139a.swf swfVfy=1 jtv=a9f7031a1b04d6f242e940bd6c12135c3d522b80:{\"swfDomains\":\20[\"justin.tv\",\20\"jtvx.com\",\20\"xarth.com\",\20\"twitchtv.com\",\20\"twitch.tv\",\20\"newjtv.com\",\20\"jtvnw.net\",\20\"wdtinc.com\",\20\"imapweather.com\",\20\"facebook.com\",\20\"starcrafting.com\"],\20\"streamName\":\20\"jtv_Y3lsS_T6skMdhmtX\",\20\"expiration\":\201371937812,\20\"server\":\20\"video7-2.iad02\"} live=1"
see that the \20 and \" are escaped like here. then give me the entire output of that.
drbomb: you too, please.
and while you're at it, make a backup of the above mentioned "bin" folder, then download this archive and drag the ffmpeg.exe-file from this one's bin folder into the one from serviio, then force a refresh and try again.
I am trying to use the following stream http://www.twitch.tv/riotgames, I have installed serviio 1.2.1 and the latest version of your plugin (4).
I get the following errors in the logs when using force refresh:
I thought it might come from my Java install, but even uninstalling it and installing only the one proposed from serviio gets the same errors. Movies from a Local folder work correctly.
Thanks a lot for your time.
- Code:
2013-06-23 17:48:35,945 ERROR [ContainerNode] Cannot retrieve results of action command: Cannot execute library command for list: null
org.serviio.upnp.service.contentdirectory.command.CommandExecutionException: Cannot execute library command for list: null
at org.serviio.upnp.service.contentdirectory.command.AbstractCommand.retrieveItemList(AbstractCommand.java:135)
at org.serviio.upnp.service.contentdirectory.definition.ContainerNode.executeListAction(ContainerNode.java:241)
at org.serviio.upnp.service.contentdirectory.definition.ActionNode.retrieveContainerItems(ActionNode.java:131)
at org.serviio.upnp.service.contentdirectory.ContentDirectoryEngine.browse(ContentDirectoryEngine.java:102)
at org.serviio.upnp.service.contentdirectory.ContentDirectory.Browse(ContentDirectory.java:152)
at org.serviio.upnp.protocol.soap.ServiceInvoker.invokeOperation(ServiceInvoker.java:253)
at org.serviio.upnp.protocol.soap.ServiceInvoker.invokeService(ServiceInvoker.java:93)
at org.serviio.upnp.webserver.ServiceControlRequestHandler.handleRequest(ServiceControlRequestHandler.java:66)
at org.serviio.upnp.webserver.ServiioHttpService.doService(ServiioHttpService.java:77)
Caused by: java.lang.NullPointerException
at org.serviio.library.online.OnlineItemService.getListOfFeedItems(OnlineItemService.java:163)
at org.serviio.upnp.service.contentdirectory.command.AbstractListOnlineObjectsByHierarchyCommand.getItemsForMediaType(AbstractListOnlineObjectsByHierarchyCommand.java:254)
at org.serviio.upnp.service.contentdirectory.command.AbstractListOnlineObjectsByHierarchyCommand.retrieveList(AbstractListOnlineObjectsByHierarchyCommand.java:118)
at org.serviio.upnp.service.contentdirectory.command.AbstractCommand.retrieveItemList(AbstractCommand.java:129)
... 16 more
2013-06-23 17:48:35,947 WARN [ContentDirectory] Browse for object id V_OF^FOL_FD1 failed with exception: org.serviio.upnp.service.contentdirectory.command.CommandExecutionException: Cannot execute library command for list: null
java.lang.RuntimeException: org.serviio.upnp.service.contentdirectory.command.CommandExecutionException: Cannot execute library command for list: null
at org.serviio.upnp.service.contentdirectory.definition.ContainerNode.executeListAction(ContainerNode.java:244)
Caused by: org.serviio.upnp.service.contentdirectory.command.CommandExecutionException: Cannot execute library command for list: null
... 15 more
... 16 more
can you remove the plugin, delete the log file and restart serviio and check if the errors persist? i've never seen this one and can't quite place it.
edit: hang on, this might happen if you're inside of a directory on a UPNP client after you've done a refresh in serviio, and then try to refresh the folder on the upnp client. what you have to do is go one folder up, refresh that folder and go back into the (here) riotgames folder.
Thanks for your quick answer, here is what I get when the plugin is uninstalled and I force refresh the item:
So looks ok : /
Upon installing the plugin I correctly get the following:
I then click "force refresh" but the log does not display anything for it, so maybe it is not on "force refresh" that the bug occurs.
Now when I try to browse the item I only get "loading files" on my UpNp device.
Only thing I get after the twitch installed is this:
So unable to reproduce the bug, but still does not work (the riotgames feed runs as I am posting) : /
I have added the reset log file to my post.
PS: saw your edit, indeed what you said did reproduce the bug, however still cant make it work : /
- Code:
2013-06-23 18:39:57,009 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Cannot parse resource from http://www.twitch.tv/riotgames. Message: No plugin for web resource http://www.twitch.tv/riotgames has been found.
at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:179)
So looks ok : /
Ok, the issue comes from my device, I was able to make it work using BubleUpnp with my phone.
The device I want to run it on is a box from my internet provider "Freebox", Ill try to find what could be the problem (the youtube plugin does not work either : /)
yeah, bubbleupnp is awesome
ran the command and got the following:
replaced the ffmpeg.exe and tried again:
tried the ffmpeg command again after this attempt and got a different result:
Thanks for taking the time to help me try and figure this out
- Code:
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\No One>cd c:\Program Files\serviio\lib
c:\Program Files\Serviio\lib>ffmpeg -i "rtmp://192.16.70.36/app playpath=jtv_Y3l
ffmpeg version 1.1.1 Copyright (c) 2000-2013 the FFmpeg developers
built on Feb 5 2013 21:59:54 with gcc 4.7.2 (GCC)
p --enable-fontconfig --enable-libfreetype --enable-zlib --extra-libs='-lrtmp -l
polarssl -lws2_32 -lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --enable-
runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-
mingw32- --pkg-config=pkg-config
libavutil 52. 13.100 / 52. 13.100
libavcodec 54. 86.100 / 54. 86.100
libavformat 54. 59.106 / 54. 59.106
libavdevice 54. 3.102 / 54. 3.102
fVfy=1 jtv=a9f7031a1b04d6f242e940bd6c12135c3d522b80:{"swfDomains":\20["justin.tv
afting.com"],\20"streamName":\20"jtv_Y3lsS_T6skMdhmtX",\20"expiration":\20137193
7812,\20"server":\20"video7-2.iad02"} live=1: Unknown error occurred
- Code:
2013-06-23 14:27:50,819 INFO [ServiioConsole] Starting Serviio Console
2013-06-23 14:27:50,889 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2013-06-23 14:27:51,339 INFO [Messages] Loaded console message bundle for locale: en
2013-06-23 14:29:09,674 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmp://199.9.255.12/app playpath=jtv_NXcIMpzpRYU93AFt swfUrl=http://www-cdn.jtvnw.net/widgets/live_embed_player.re1dfd1845e13c8c3b9af4aa989a353052d87139a.swf swfVfy=1 jtv=fd29304d45213d0f79d0cb5aed67e22834f8c1b7:{\"swfDomains\":\20[\"justin.tv\",\20\"jtvx.com\",\20\"xarth.com\",\20\"twitchtv.com\",\20\"twitch.tv\",\20\"newjtv.com\",\20\"jtvnw.net\",\20\"wdtinc.com\",\20\"imapweather.com\",\20\"facebook.com\",\20\"starcrafting.com\"],\20\"streamName\":\20\"jtv_NXcIMpzpRYU93AFt\",\20\"expiration\":\201372015746,\20\"server\":\20\"video8-1.mia01\"} live=1. It might not play.
... 2 more
2013-06-23 14:29:10,524 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmp://199.9.254.52/app playpath=jtv_Q_bUw4ILMgpuFYKH swfUrl=http://www-cdn.jtvnw.net/widgets/live_embed_player.re1dfd1845e13c8c3b9af4aa989a353052d87139a.swf swfVfy=1 jtv=d66bbb18c9175dfcd0e5072488e7fd49839724b8:{\"swfDomains\":\20[\"justin.tv\",\20\"jtvx.com\",\20\"xarth.com\",\20\"twitchtv.com\",\20\"twitch.tv\",\20\"newjtv.com\",\20\"jtvnw.net\",\20\"wdtinc.com\",\20\"imapweather.com\",\20\"facebook.com\",\20\"starcrafting.com\"],\20\"streamName\":\20\"jtv_Q_bUw4ILMgpuFYKH\",\20\"expiration\":\201372015746,\20\"server\":\20\"video24-2.dfw01\"} live=1. It might not play.
... 2 more
2013-06-23 14:29:11,804 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmp://199.9.255.12/app playpath=jtv_g3aYF_vM6bF5y91p swfUrl=http://www-cdn.jtvnw.net/widgets/live_embed_player.re1dfd1845e13c8c3b9af4aa989a353052d87139a.swf swfVfy=1 jtv=81de3abb6537929950130e80bd809951d382fe26:{\"swfDomains\":\20[\"justin.tv\",\20\"jtvx.com\",\20\"xarth.com\",\20\"twitchtv.com\",\20\"twitch.tv\",\20\"newjtv.com\",\20\"jtvnw.net\",\20\"wdtinc.com\",\20\"imapweather.com\",\20\"facebook.com\",\20\"starcrafting.com\"],\20\"streamName\":\20\"jtv_g3aYF_vM6bF5y91p\",\20\"expiration\":\201372015746,\20\"server\":\20\"video8-1.mia01\"} live=1. It might not play.
... 2 more
2013-06-23 14:29:13,274 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmp://199.9.255.17/app playpath=jtv_cfV9Crc179REmuun swfUrl=http://www-cdn.jtvnw.net/widgets/live_embed_player.re1dfd1845e13c8c3b9af4aa989a353052d87139a.swf swfVfy=1 jtv=0b105a9df826d0b0f8b59d6ff0a4cfc1a2f5e73f:{\"swfDomains\":\20[\"justin.tv\",\20\"jtvx.com\",\20\"xarth.com\",\20\"twitchtv.com\",\20\"twitch.tv\",\20\"newjtv.com\",\20\"jtvnw.net\",\20\"wdtinc.com\",\20\"imapweather.com\",\20\"facebook.com\",\20\"starcrafting.com\"],\20\"streamName\":\20\"jtv_cfV9Crc179REmuun\",\20\"expiration\":\201372015746,\20\"server\":\20\"video5-2.mia01\"} live=1. It might not play.
... 2 more
2013-06-23 14:29:14,414 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmp://199.9.255.17/app playpath=jtv_GDmqBEIEyx3EAMaL swfUrl=http://www-cdn.jtvnw.net/widgets/live_embed_player.re1dfd1845e13c8c3b9af4aa989a353052d87139a.swf swfVfy=1 jtv=395b332057d59fbb0c719c210129ce35865d8788:{\"swfDomains\":\20[\"justin.tv\",\20\"jtvx.com\",\20\"xarth.com\",\20\"twitchtv.com\",\20\"twitch.tv\",\20\"newjtv.com\",\20\"jtvnw.net\",\20\"wdtinc.com\",\20\"imapweather.com\",\20\"facebook.com\",\20\"starcrafting.com\"],\20\"streamName\":\20\"jtv_GDmqBEIEyx3EAMaL\",\20\"expiration\":\201372015746,\20\"server\":\20\"video5-2.mia01\"} live=1. It might not play.
... 2 more
- Code:
C:\Users\No One>cd C:\Program Files\Serviio\lib
C:\Program Files\Serviio\lib>ffmpeg -i "rtmp://199.9.255.17/app playpath=jtv_GDm
server\":\20\"video5-2.mia01\"} live=1"
ffmpeg version N-54143-gb6ce50a Copyright (c) 2000-2013 the FFmpeg developers
built on Jun 22 2013 15:27:20 with gcc 4.7.3 (GCC)
configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-av
isynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enab
le-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetyp
e --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --ena
ble-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-l
ibopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libsp
eex --enable-libtheora --enable-libtwolame --enable-libvo-aacenc --enable-libvo-
amrwbenc --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --
enable-libxvid --enable-zlib
duration 0.00
width 1280.00
height 720.00
videodatarate 1464.84
framerate 30.00
videocodecid 7.00
audiodatarate 92.77
audiosamplerate 44100.00
audiosamplesize 16.00
stereo TRUE
audiocodecid 10.00
presetname Custom
creationdate Sun Jun 23 09:05:39 2013
videodevice XSplitBroadcaster
avclevel 31
avcprofile 100
videokeyframe_frequency0
audiodevice VHAudioCustom
audiochannels 2
audioinputvolume 100
bufferSize 1500k
maxBitrate 1500k
xsplitBroadcasterVersion1.3.0.95
xsplitCoreVersion 1.2.1303.0101 Version 1.2
xsplitGameSourceVersion1.1.1.30
xsplitMediaLibVersion 2.0.0.209
encoder Lavf54.59.106
filesize 0.00
Input #0, flv, from 'rtmp://199.9.255.17/app playpath=jtv_GDmqBEIEyx3EAMaL swfUr
a353052d87139a.swf swfVfy=1 jtv=395b332057d59fbb0c719c210129ce35865d8788:{"swfDo
ebook.com",\20"starcrafting.com"],\20"streamName":\20"jtv_GDmqBEIEyx3EAMaL",\20"
expiration":\201372015746,\20"server":\20"video5-2.mia01"} live=1':
author :
copyright :
description :
keywords :
rating :
title :
presetname : Custom
creationdate : Sun Jun 23 09:05:39 2013
videodevice : XSplitBroadcaster
avclevel : 31
avcprofile : 100
videokeyframe_frequency: 0
audiodevice : VHAudioCustom
audiochannels : 2
audioinputvolume: 100
bufferSize : 1500k
maxBitrate : 1500k
xsplitBroadcasterVersion: 1.3.0.95
xsplitCoreVersion: 1.2.1303.0101 Version 1.2
xsplitGameSourceVersion: 1.1.1.30
xsplitMediaLibVersion: 2.0.0.209
encoder : Lavf54.59.106
Duration: 00:00:00.00, start: 0.000000, bitrate: N/A
Stream #0:0: Video: h264 (Constrained Baseline), yuv420p, 1280x720 [SAR 1:1
DAR 16:9], 1500 kb/s, 30 tbr, 1k tbn, 60 tbc
Stream #0:1: Audio: aac, 44100 Hz, stereo, fltp, 95 kb/s
Users browsing this forum: Google [Bot] and 18 guests
