Need help for transcoding this m3u8 stream.
meensu
Post Mon Jul 15, 2013 4:08 am
The target tv is samsung d. Input stream is an m3u8 file.
Problem with standard profile is I get no audio but video is fine.
ffmpeg command line uses "-an" option. Looks like transcoding is ruling out audio. I need help to figure out why.
Here is the detail of the input stream:
    Stream #0:0: Video: h264 (Baseline) ([27][0][0][0] / 0x001B), yuv420p, 512x288 [SAR 1:1 DAR 16:9], 12.50 fps, 25 tbr, 90k tbn, 50 tbc
    Stream #0:1: Audio: aac ([15][0][0][0] / 0x000F), 44100 Hz, stereo, fltp, 127 kb/s
Serviio uses ffmpeg with the below command line:
ffmpeg  -analyzeduration 10000000 -fflags +genpts -threads 1 -i http://.../playlist.m3u8 -y -c:v copy -an -map 0:0 -sn -f mpegts pipe:
For some reason, serviio decides to mute this.
If I dump this file like below and play it from TV it plays fine.
ffmpeg.tsk -i http://.../playlist.m3u8 -f mpegts -c:v copy -c:a copy pipe: > t.avi
My question is, since t.avi plays fine on TV, how to get the online stream through to the TV *with audio* using serviio. Why does serviio mute? From the log file I see that the TV wants AVC_TS_MP_AC3_ISO.
Any help is greatly appreciated.
Post Mon Jul 15, 2013 10:55 pm
Re: Need help for transcoding this m3u8 stream.
can you post full ffmpeg -i for the stream?
meensu
Post Tue Jul 16, 2013 4:01 am
I guess the issue is if the source m3u8 plays another m3u8 file. Am facing issues only for such m3u8 files. I will shortly give you the link.
Users browsing this forum: Baidu [Spider] and 3 guests
