Video Codec ID issue?
janagn
Post Sat Jul 20, 2013 1:45 am
I have some video files from my Fuji Camera that I cannot play on serviio. Doing mediainfo on the files i get Video codec ID MJPG. I noticed that this format is supported in the profile but (correct me if I am wrong) as MJPEG. I conculde that the file is not playable because of this. So I tried to add one more "matches" with vCodec MJPG but I got an error about the value not been part of the enumaror (I guess somewhere there is an enum of these string). Is there any way we can add the MJPG Code ID to the collection or somehow alias it to put to the MJPEG?
Kind Regards
Yiannis
Post Sun Jul 21, 2013 10:27 pm
Re: Video Codec ID issue?
It's one and the same codec. Adding transcoding for mjpeg should fix it for you.
janagn
Post Fri Aug 02, 2013 8:45 am
Thank you, I will give it a try and will get back to you :)
Regards
Yiannis
