Help with Samsung smart tv LED55
angelmarlo
Post Sun Aug 04, 2013 6:56 pm
okay i just downloaded serviio and have no idea how to connect it to my samsung smart tv. there is no render profiles available.
angelmarlo
Post Sun Aug 04, 2013 6:59 pm
Re: Help with Samsung smart tv LED55
also i have a mac pro
Post Sun Aug 04, 2013 7:23 pm
can you post some screenshots of what you mean?
angelmarlo
Post Mon Aug 05, 2013 4:34 pm
how do you take a screen shot on mac?
krayzee
Post Mon Aug 05, 2013 6:57 pm
If you've set serviio up with your media all you should need to do is turn on your TV press the Source button and select serviio from the list at the top.
espen
Post Tue Aug 06, 2013 6:31 pm
I have the same TV and Serviio will simply do not work (it worked one time), but never again. It will not show up in the TV, but Twonky works every time.
Machine: iMAc
Router: ZyXEL P2812
Firewall: Little Snitch (accepting all connections)
Swb62
Post Thu Aug 15, 2013 7:27 pm
Can someone help. I have downloaded 1.3 for mac and it keeps crashing or does not work at all!
