Separate profiles for renderer and remote control
dionysys
Post Mon Aug 05, 2013 12:16 pm
I'm trying to set up a simple home setup and struggling. I'm running serviio on a PC, using a Panason PVR as a renderer and using an android app (BubbleUPnP) to control. The renderer can't open (for example) MKVs so I created a profile that transcoded them (and others) to MPEG2 streams. That works fine for browsing the serviio media server via the DLNA client in the PVR, but if I use bubbleupnp to send the video to the PVR it fails. If I force the same crippled renderer profile on my phone as the PVR uses it works fine, but I'd really rather have a profile for my phone and a different one for the PVR. Am I missing something obvious here?
I've included the logs below if that helps.
worked (PC -> PVR via PVR DLNA client)
2013-08-05 21:18:07,187 DEBUG [ServiioHttpService] Incoming request from /192.168.1.2:3052: GET /resource/294/MEDIA_ITEM/MPEG_TS_SD_EU_ISO-0/ORIGINAL HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=0.000-,HOST: 192.168.1.3:8895,transferMode.dlna.org: Streaming,getcontentFeatures.dlna.org: 1]]
2013-08-05 21:18:07,187 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.2
2013-08-05 21:18:07,188 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.2
2013-08-05 21:18:07,189 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.2, Profile=Panasonic DMR-HW220 (hughesy)'
2013-08-05 21:18:07,190 DEBUG [ResourceDeliveryProcessor] Request for resource 294 and type 'MEDIA_ITEM' received
2013-08-05 21:18:07,190 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 294 (local)
2013-08-05 21:18:07,190 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 294)
2013-08-05 21:18:07,199 DEBUG [VideoDAOImpl] Reading a Video (id = 294)
2013-08-05 21:18:07,200 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 294, format MPEG_TS_SD_EU_ISO and profile Panasonic DMR-HW220 (hughesy)
2013-08-05 21:18:07,200 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file top_gear.20x04.hdtv_x264-fov.mp4
2013-08-05 21:18:07,200 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file top_gear.20x04.hdtv_x264-fov.mp4: MPEG_TS_SD_EU_ISO
2013-08-05 21:18:07,200 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file top_gear.20x04.hdtv_x264-fov.mp4: MPEG_TS_SD_NA_ISO
2013-08-05 21:18:07,200 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file top_gear.20x04.hdtv_x264-fov.mp4: MPEG_TS_SD_KO_ISO
2013-08-05 21:18:07,201 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 294 (local)
2013-08-05 21:18:07,201 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 294)
2013-08-05 21:18:07,201 DEBUG [VideoDAOImpl] Reading a Video (id = 294)
2013-08-05 21:18:07,201 DEBUG [VideoDeliveryEngine] Delivering item '294' for client 'Identifier=192.168.1.2, Profile=Panasonic DMR-HW220 (hughesy)'
2013-08-05 21:18:07,201 DEBUG [VideoDeliveryEngine] Delivering file 'top_gear.20x04.hdtv_x264-fov.mp4' using transcoding
2013-08-05 21:18:07,202 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'Identifier=192.168.1.2, Profile=Panasonic DMR-HW220 (hughesy)'
2013-08-05 21:18:07,202 DEBUG [MediaItemDAOImpl] Getting file of media item 294
2013-08-05 21:18:07,203 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: C:\Users\hugheses\Downloads\TV Shows\Top_Gear.20x04.HDTV_x264-FoV[rarbg]\top_gear.20x04.hdtv_x264-fov.mp4
2013-08-05 21:18:07,203 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -threads auto -i C:\Users\hugheses\Downloads\TV Shows\Top_Gear.20x04.HDTV_x264-FoV[rarbg]\top_gear.20x04.hdtv_x264-fov.mp4 -y -c:v mpeg2video -qscale:v 1 -r 25 -g 15 -c:a ac3 -b:a 128k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts C:\Windows\TEMP\Serviio\transcoding-temp-294-dmrhw220-ORIGINAL.stf
2013-08-05 21:18:07,706 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2013-08-05 21:18:07,706 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file top_gear.20x04.hdtv_x264-fov.mp4: MPEG_TS_SD_EU_ISO
2013-08-05 21:18:07,707 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file top_gear.20x04.hdtv_x264-fov.mp4: MPEG_TS_SD_NA_ISO
2013-08-05 21:18:07,707 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file top_gear.20x04.hdtv_x264-fov.mp4: MPEG_TS_SD_KO_ISO
2013-08-05 21:18:07,707 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 294) as read
Failed (PC -> PVR via bubbleupnp):
2013-08-05 21:24:19,009 DEBUG [ServiioHttpService] Incoming request from /192.168.1.2:4593: GET /resource/294/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5-0/ORIGINAL HTTP/1.1, headers = [Range: bytes=0-,HOST: 192.168.1.3:8895,transferMode.dlna.org: Streaming,getcontentFeatures.dlna.org: 1]]
2013-08-05 21:24:19,010 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.2
2013-08-05 21:24:19,011 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.2, Profile=Panasonic DMR-HW220 (hughesy)'
2013-08-05 21:24:19,011 DEBUG [ResourceDeliveryProcessor] Request for resource 294 and type 'MEDIA_ITEM' received
2013-08-05 21:24:19,011 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 294 (local)
2013-08-05 21:24:19,011 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 294)
2013-08-05 21:24:19,013 DEBUG [VideoDAOImpl] Reading a Video (id = 294)
2013-08-05 21:24:19,015 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 294, format AVC_MP4_MP_SD_AAC_MULT5 and profile Panasonic DMR-HW220 (hughesy)
2013-08-05 21:24:19,016 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file top_gear.20x04.hdtv_x264-fov.mp4
2013-08-05 21:24:19,016 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file top_gear.20x04.hdtv_x264-fov.mp4: MPEG_TS_SD_EU_ISO
2013-08-05 21:24:19,016 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file top_gear.20x04.hdtv_x264-fov.mp4: MPEG_TS_SD_NA_ISO
2013-08-05 21:24:19,016 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file top_gear.20x04.hdtv_x264-fov.mp4: MPEG_TS_SD_KO_ISO
2013-08-05 21:24:19,016 WARN  [ResourceDeliveryProcessor] Invalid request, sending back 500 error
org.serviio.dlna.UnsupportedDLNAMediaFileFormatException: No media description available for required version: AVC_MP4_MP_SD_AAC_MULT5
   at org.serviio.delivery.resource.AbstractDeliveryEngine.findMediaInfoForFileProfile(AbstractDeliveryEngine.java:290)
   at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedMediaInfoForVersion(AbstractTranscodingDeliveryEngine.java:147)
   at org.serviio.delivery.resource.AbstractDeliveryEngine.getMediaInfoForMediaItem(AbstractDeliveryEngine.java:122)
   at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResourceInfo(MediaResourceRetrievalStrategy.java:151)
   at org.serviio.delivery.ResourceDeliveryProcessor.deliverContent(ResourceDeliveryProcessor.java:79)
   at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:85)
   at org.serviio.upnp.webserver.ServiioHttpService.doService(ServiioHttpService.java:77)
Post Tue Aug 06, 2013 9:40 pm
Re: Separate profiles for renderer and remote control
No, that's unfortunately how it works. DLNA doesn't have the concept of profiles so this is the workaround when using controllers.
Users browsing this forum: Baidu [Spider] and 13 guests
