Win7x64/Console Synology/Server problems
warrenjb
Post Thu Aug 15, 2013 7:11 pm
Just upgraded the console to the newest version and now the console will not launch. The log is below. Any help is much appreciated!
2013-08-15 15:02:10,672 INFO [ServiioConsole] Initializing Serviio Console
2013-08-15 15:02:10,688 INFO [ServiioConsole] Starting Serviio Console
2013-08-15 15:02:10,766 INFO [ServiioConsole] Connecting to Serviio REST on 192.168.15.23:23423
2013-08-15 15:02:11,858 INFO [Messages] Loaded console message bundle for locale: en
2013-08-15 15:02:15,929 ERROR [ServiioConsole] Unexpected exception occured: null
at org.serviio.ui.view.swing.StatusView.initComponents(StatusView.java:150)
at org.serviio.ui.view.swing.StatusView.<init>(StatusView.java:108)
at org.serviio.ui.view.swing.ServiioFrameView.<init>(ServiioFrameView.java:72)
at org.serviio.console.ServiioConsole.main(ServiioConsole.java:110)
at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
at com.exe4j.runtime.WinLauncher.main(Unknown Source)
2013-08-15 15:02:15,945 INFO [ServiioConsole] Exitting Serviio Console
Post Thu Aug 15, 2013 7:29 pm
Re: Win7x64/Console Synology/Server problems
The server and console must be the same version. You will need to go back to 1.2.1 until 1.3 is available for your NAS.
@zip, maybe put a version check at console startup to avoid these problems?
warrenjb
Post Thu Aug 15, 2013 7:31 pm
Thanks. I was just thinking that might be my problem. Do you know where I can download the correct console version? I don't see it on the Serviio Download page
Post Thu Aug 15, 2013 7:52 pm
Users browsing this forum: No registered users and 72 guests
