Problem playing specific mkv on D-series - need help
PJusa
Post Fri Aug 16, 2013 3:49 pm
I cant figure out why this mkv-file wont play on my d-series, samsung reports it cant play the video codec - what am i missing?
i am on serviio 1.3 and am using the samsung C/D/E/F-series profile with one modification:
this line is disabled under <Video targetContainer="mpegts" targetACodec="ac3" targetVCodec="mpeg2video">
== ffmpeg.exe -i ==
Input #0, matroska,webm, from '*.mkv':
title : *
creation_time : 2012-03-09 13:39:39
Duration: 01:34:13.41, start: 0.000000, bitrate: 3074 kb/s
Stream #0:0(fre): Video: h264 (High), yuv420p, 1200x720 [SAR 1:1 DAR 5:3], 24 fps, 24 tbr, 1k tbn, 48 tbc (default)
title : *
Stream #0:1(fre): Audio: ac3, 48000 Hz, stereo, fltp, 384 kb/s (default)
title : French
Stream #0:2(eng): Audio: ac3, 48000 Hz, stereo, fltp, 192 kb/s
title : English
Stream #0:3(eng): Subtitle: subrip
title : English
my guess is that the problem is the h264 - profile which VLC reports as H264 - MPEG-4 AVC (part 10) (avc1) but I'm not sure what & where to change (profile or the encoding of the file). any pointers would be much appreciated!
vlaskal
Post Sat Aug 17, 2013 8:24 am
Re: Problem playing specific mkv on D-series - need help
I have same problem with new Serviio 1.3. I am not able to play any mkv file which I have :( .
There is error: Unsupported file ...
I had to reinstall Serviio back to version 1.2.1 and it works fine.
I have two Samsungs C-Series TV and I use same profile as above Samsung C/D/E/F-series without any modification.
Samsung UE40C6000 & UE32C6000
Win7 & Serviio 1.2.1
PJusa
Post Sat Aug 17, 2013 2:05 pm
i can play almost all mkv files without problem. it's really only this one and i think another mkv file i have.
i you cant play any mkv files at - did you check that the player supports them (dont know what the c- series can play natively). you could try to set all mkv's to transcoding that might work.
vlaskal
Post Sat Aug 17, 2013 5:40 pm
You are lucky man.
I use Serviio for a long time without problem. I think from version 1.0.
When you read carefully my last post then you will know that I installed Serviio 1.2.1 back, because it works well.
I did not find any format which my TV cannot play.
So problem is not in TV because it works with version 1.2.1 but not with 1.3.
Thanks for reply
Post Sat Aug 17, 2013 7:27 pm
vlaskal wrote:Hi,
I assume you're using a wrong profile.
vlaskal
Post Sun Aug 18, 2013 1:48 pm
Thanks for reply.
I installed new version 1.3.1 and it works. It is likely that I had a bad profile. I installed update as different user.
Thanks for help.
