Naming double/triple episodes
Darkfalz
Post Sun Aug 18, 2013 11:05 am
I'm working through renaming all my TV series.
I have some TV series with double / triple episodes (ie. episode 22-23 will be in one file). How to name these?
Sony KDL-55HX750 and BDV-N990W (Home Theatre)
Sony KDL-40D3100 and BDP-S390 (Loungeroom)
Post Sun Aug 18, 2013 11:22 am
Re: Naming double/triple episodes
whatever it is on thetvdb.org
Darkfalz
Post Sun Aug 18, 2013 12:53 pm
tvdb lists as separate episodes. I guess if it just picks up the first episode, that's good enough.
Post Sun Aug 18, 2013 1:07 pm
That's what I normally do
marky9074
Post Fri Jun 17, 2016 9:56 am
I've been doing some testing to try and get Kodi & Plex naming to coexist (and hoping Serviio too). For some illogical reason Plex wants a from/to relationship, whereas Kodi wants each individual episode. To throw something else into the mix, I use MediaElch to create the NFO files, and that too baulks at some Kodi formats...
Battlestar Galactica (1978) S01E01-02-03 only shows E01 in Plex
Battlestar Galactica (1978) S01E01E02E03 shows E01 & E02 in Plex
Battlestar Galactica (1978) S01E01_02_03 only shows E01 in Plex
Battlestar Galactica (1978) S01E01_S01E02_S01E03 not recognised in MediaElch
Battlestar Galactica (1978) S01E01.S01E02.S01E03 not recognised in MediaElch
In the above example (with three episodes) I could not find any combination that worked (everywhere), so ended up using a MKV splitter to create three episodes. For double episodes, I have used the following format:
Heroes S04E01E02
Teenage Mutant Ninja Turtles - Rise of the Turtles S01E01E02
Battlestar Galactica (1978) S01E19E20
However these are not picked up at all by serviio :?: :idea: any suggestions would be much appreciated.
To be honest if I could find timestamps to split these files I would do that (I just chopped by nearest chapter on BSG)...
Return to General discussion
Users browsing this forum: Google [Bot] and 2 guests
