Invalid file - LG 42LM5800 - Quicktime file
doodle
Post Sun Aug 25, 2013 5:43 pm
Serviio has been working perfectly with all my files.
But now I found a format that is being a pain: two .mov files.
Here are the ffmpeg details:
C:\Program Files\Serviio\lib>ffmpeg.exe -i "C:\Files\Downloads\video.mov"
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'C:\Files\Downloads\video.mov':
    major_brand     : qt
    minor_version   : 537199360
    compatible_brands: qt
    creation_time   : 2011-08-26 16:53:58
    timecode        : 01:00:00:00
  Duration: 00:07:33.92, start: 0.000000, bitrate: 4183 kb/s
    Stream #0:0(eng): Video: h264 (Main) (avc1 / 0x31637661), yuv420p, 1280x720,
 4052 kb/s, 25 fps, 25 tbr, 2500 tbn, 5k tbc
      handler_name    : Gestor de contenido de vÆdeo Apple
    Stream #0:1(eng): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 12
9 kb/s
      handler_name    : Gestor de contenido de sonido Apple
    Stream #0:2(eng): Data: none (tmcd / 0x64636D74)
      handler_name    : Gestor de cùdigos de tiempo
And here, the MediaInfo details:
Complete name                            : C:\Files\Downloads\video.mov
Format profile                           : QuickTime
Format settings                          : Compressed header
Codec ID                                 : qt
File size                                : 226 MiB
Duration                                 : 7mn 33s
Overall bit rate                         : 4 184 Kbps
Encoded date                             : UTC 2011-08-26 16:53:58
Tagged date                              : UTC 2011-08-26 16:54:13
Writing library                          : Apple QuickTime
Media/UUID                               : 3624D2A8-0A52-42D8-AA23-8C394255EC4C
Media/History/UUID                       : FF0BD8F7-370C-4717-BAE3-4884E620878D
Format profile                           : Main@L3.1
Format settings, CABAC                   : No
Format settings, ReFrames                : 2 frames
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Duration                                 : 7mn 33s
Bit rate                                 : 4 053 Kbps
Width                                    : 1 248 pixels
Original width                           : 1 280 pixels
Height                                   : 702 pixels
Original height                          : 720 pixels
Frame rate                               : 25.000 fps
Bits/(Pixel*Frame)                       : 0.185
Stream size                              : 219 MiB (97%)
Title                                    : Gestor de contenido de v’deo Apple
Encoded date                             : UTC 2011-08-26 16:53:57
Codec ID                                 : 40
Duration                                 : 7mn 33s
Source duration                          : 7mn 33s
Bit rate                                 : 128 Kbps
Stream size                              : 6.99 MiB (3%)
Source stream size                       : 6.99 MiB (3%)
Title                                    : Gestor de contenido de sonido Apple
Other
Type                                     : Time code
Format                                   : QuickTime TC
Duration                                 : 7mn 33s
Time code of first frame                 : 01:00:00:00
Time code settings                       : Striped
Title                                    : Gestor de c—digos de tiempo
Tagged date                              : UTC 2011-08-26 16:54:14
OS: Windows 7
TV: LG 42LM5800
Any help is appreciated!
Thanks!
Post Mon Aug 26, 2013 12:26 pm
Re: Invalid file - LG 42LM5800 - Quicktime file
MIght be the compressed headers.
Try to remux the files again using some tool
Return to LG
