CentOS 6.4 - Videos not showing
darkcloud784
Post Thu Oct 10, 2013 12:58 am
I recently installed serviio 1.3.1 on my CentOS 6.4 box. I have built and installed the newest version of FFMpeg and got everything running. Only issue I'm having is serviio is not seeing ANY of my videos. None, nada, not one. It can see all my music, pictures, and everything else. I used this tutorial on installing the newest version of ffmpeg, I also tried whats on the serviio wiki. The only error I see for all the movies is below. Keep in mind, I have tried to run serviio as root and even as its own independant user. I've tried to install everything as the independant user and chmod/chown ffmpeg... I've still got no luck. Any ideas on how to fix this?
2013-10-09 19:56:20,458 WARN  [ProcessExecutor] Cannot retrieve results, output reader is null
2013-10-09 19:56:20,458 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (ParaNorman (2012).mkv). Message: Unknown video file type.
2013-10-09 19:56:20,460 ERROR [ProcessExecutor] Fatal error in process starting: Cannot run program "/yasm-1.2.0/x264/fdk-aac/lame-3.99.5/opus-1.0.3/libogg-1.3.1/libvorbis-1.3.3/libvpx/ffmpeg": error=13, Permission denied
java.io.IOException: Cannot run program "/yasm-1.2.0/x264/fdk-aac/lame-3.99.5/opus-1.0.3/libogg-1.3.1/libvorbis-1.3.3/libvpx/ffmpeg": error=13, Permission denied
        at java.lang.ProcessBuilder.start(Unknown Source)
        at org.serviio.external.ProcessExecutor.run(ProcessExecutor.java:135)
Caused by: java.io.IOException: error=13, Permission denied
        at java.lang.UNIXProcess.forkAndExec(Native Method)
        at java.lang.UNIXProcess.<init>(Unknown Source)
        at java.lang.ProcessImpl.start(Unknown Source)
        ... 2 more
2013-10-09 19:56:20,461 WARN  [ProcessExecutor] Cannot retrieve results, output reader is null
2013-10-09 19:56:20,461 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (James and the Giant Peach (1996).avi). Message: Unknown video file type.
2013-10-09 19:56:20,463 ERROR [ProcessExecutor] Fatal error in process starting: Cannot run program "/yasm-1.2.0/x264/fdk-aac/lame-3.99.5/opus-1.0.3/libogg-1.3.1/libvorbis-1.3.3/libvpx/ffmpeg": error=13, Permission denied
        ... 2 more
2013-10-09 19:56:20,463 WARN  [ProcessExecutor] Cannot retrieve results, output reader is null
2013-10-09 19:56:20,463 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (Abraham Lincoln Vampire Hunter (2012).mkv). Message: Unknown video file type.
2013-10-09 19:56:20,465 ERROR [ProcessExecutor] Fatal error in process starting: Cannot run program "/yasm-1.2.0/x264/fdk-aac/lame-3.99.5/opus-1.0.3/libogg-1.3.1/libvorbis-1.3.3/libvpx/ffmpeg": error=13, Permission denied
        ... 2 more
2013-10-09 19:56:20,465 WARN  [ProcessExecutor] Cannot retrieve results, output reader is null
2013-10-09 19:56:20,466 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (All in Good Time (2012).mkv). Message: Unknown video file type.
2013-10-09 19:56:20,468 ERROR [ProcessExecutor] Fatal error in process starting: Cannot run program "/yasm-1.2.0/x264/fdk-aac/lame-3.99.5/opus-1.0.3/libogg-1.3.1/libvorbis-1.3.3/libvpx/ffmpeg": error=13, Permission denied
        ... 2 more
2013-10-09 19:56:20,468 WARN  [ProcessExecutor] Cannot retrieve results, output reader is null
2013-10-09 19:56:20,468 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (Beauty and the Beast (1987).mkv). Message: Unknown video file type.
2013-10-09 19:56:20,470 ERROR [ProcessExecutor] Fatal error in process starting: Cannot run program "/yasm-1.2.0/x264/fdk-aac/lame-3.99.5/opus-1.0.3/libogg-1.3.1/libvorbis-1.3.3/libvpx/ffmpeg": error=13, Permission denied
        ... 2 more
Example ffmpeg output:
[root@Beast Movies]# ffmpeg -i "Argo (2012).mkv"
ffmpeg version git-2013-10-10-5ac6b60 Copyright (c) 2000-2013 the FFmpeg developers
  built on Oct  9 2013 19:30:18 with gcc 4.4.7 (GCC) 20120313 (Red Hat 4.4.7-3)
  configuration: --prefix=/root/ffmpeg_build --extra-cflags=-I/root/ffmpeg_build/include --extra-ldflags=-L/root/ffmpeg_build/lib --bindir=/root/bin --extra-libs=-ldl --enable-gpl --enable-nonfree --enable-libfdk_aac --enable-libmp3lame --enable-libopus --enable-libvorbis --enable-libvpx --enable-libx264
  libavutil      52. 46.101 / 52. 46.101
  libavcodec     55. 35.100 / 55. 35.100
  libavformat    55. 19.100 / 55. 19.100
  libavdevice    55.  4.100 / 55.  4.100
  libavfilter     3. 88.101 /  3. 88.101
  libswscale      2.  5.101 /  2.  5.101
  libswresample   0. 17.103 /  0. 17.103
Input #0, matroska,webm, from 'Argo (2012).mkv':
    creation_time   : 2013-03-16 11:06:06
  Duration: 02:09:35.65, start: 0.000000, bitrate: 9654 kb/s
    Chapter #0.0: start 0.000000, end 759.717000
      title           : 00:00:00.000
    Chapter #0.1: start 759.717000, end 1335.459000
      title           : 00:12:39.717
    Chapter #0.2: start 1335.459000, end 2013.345000
      title           : 00:22:15.459
    Chapter #0.3: start 2013.345000, end 3010.299000
      title           : 00:33:33.345
    Chapter #0.4: start 3010.299000, end 3515.262000
      title           : 00:50:10.299
    Chapter #0.5: start 3515.262000, end 4113.776000
      title           : 00:58:35.262
    Chapter #0.6: start 4113.776000, end 4663.242000
      title           : 01:08:33.776
    Chapter #0.7: start 4663.242000, end 5300.545000
      title           : 01:17:43.242
    Chapter #0.8: start 5300.545000, end 5958.160000
      title           : 01:28:20.545
    Chapter #0.9: start 5958.160000, end 6484.895000
      title           : 01:39:18.160
    Chapter #0.10: start 6484.895000, end 7248.116000
      title           : 01:48:04.895
    Chapter #0.11: start 7248.116000, end 7775.648000
      title           : 02:00:48.116
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1920x800, SAR 1:1 DAR 12:5, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
    Stream #0:1(eng): Subtitle: subrip (default) (forced)
    Stream #0:2: Audio: dts (DTS), 48000 Hz, 5.1(side), fltp, 1536 kb/s (default)
Post Fri Oct 11, 2013 11:25 am
Re: CentOS 6.4 - Videos not showing
Ignoring the spam bot, make sure Serviio is using the same version of ffmpeg.
Use 'which ffmpeg' to find where it is installed, then add -Dffmpeg.location=/path/to/ffmpeg to the JAVA_OPTS in serviio.sh file
