Vizio E241-A1 Smart TV won't play large MP4s
thoughtlover
Post Mon Oct 14, 2013 11:28 pm
I recently obtained a new Vizio E241-A1 Smart TV, and it appears to handle all AVIs just fine using the "LG TV/player" profile on Win-7 Serviio 1.3.1.
It also handles shorter (10-20 minute) mp4 files fine, but whenever I choose a longer/larger mp4 file (40+minutes), the TV states "Audio Codec not support. Video Codec not support."
I cycled through about 40 files to notice this pattern. I think it has to do with file size, probably 256mb.
I've picked 2 files, both very similar, the first which will play and the second which wont:
Will play (Legend.mp4):
Complete name                            : C:\Users\Public\Videos\legend.mp4
Format profile                           : Base Media
Codec ID                                 : isom
File size                                : 92.0 MiB
Duration                                 : 23mn 1s
Overall bit rate                         : 559 Kbps
Encoded date                             : UTC 2013-10-12 14:29:00
Tagged date                              : UTC 2013-10-12 14:29:00
Format profile                           : High@L3.1
Format settings, ReFrames                : 5 frames
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Duration                                 : 23mn 1s
Bit rate                                 : 425 Kbps
Maximum bit rate                         : 2 015 Kbps
Width                                    : 720 pixels
Height                                   : 404 pixels
Bits/(Pixel*Frame)                       : 0.061
Stream size                              : 70.0 MiB (76%)
Title                                    : Ì
Writing library                          : x264 core 138 r2358 9e941d1
Encoding settings                        : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=19.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Tagged date                              : UTC 2013-10-12 14:29:11
Codec ID                                 : 40
Duration                                 : 23mn 1s
Bit rate                                 : 129 Kbps
Maximum bit rate                         : 157 Kbps
Stream size                              : 21.3 MiB (23%)
Encoded date                             : UTC 2013-10-12 14:29:09
Won't play(people.mp4):
Complete name                            : C:\Users\Public\Videos\people.mp4
Codec ID                                 : isom
File size                                : 288 MiB
Duration                                 : 42mn 36s
Overall bit rate                         : 944 Kbps
Encoded date                             : UTC 2013-10-09 00:00:41
Tagged date                              : UTC 2013-10-09 00:00:41
Codec ID                                 : avc1
Duration                                 : 42mn 36s
Bit rate                                 : 818 Kbps
Maximum bit rate                         : 3 467 Kbps
Width                                    : 720 pixels
Height                                   : 406 pixels
Bits/(Pixel*Frame)                       : 0.117
Stream size                              : 249 MiB (87%)
Encoding settings                        : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=18 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=19.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Tagged date                              : UTC 2013-10-09 00:00:52
Codec ID                                 : 40
Duration                                 : 42mn 36s
Bit rate                                 : 122 Kbps
Maximum bit rate                         : 158 Kbps
Stream size                              : 37.1 MiB (13%)
Encoded date                             : UTC 2013-10-09 00:00:47
Any ideas to get this working? I'm thinking I'll have to transcode all mp4s on-the-fly, but I've not had any luck getting that working yet.
Logs:
Legend.mp4
2013-10-14 17:00:53,672 DEBUG [ServiioHttpService] Incoming request from /192.168.1.116:42626: GET /resource/718/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5-0/ORIGINAL HTTP/1.1, headers = [HOST: 192.168.1.147:8895,DATE: Mon, 14 Oct 2013 23:00:56 GMT,CONNECTION: Keep-Alive,USER-AGENT: IPI/1.0 UPnP/1.0 DLNADOC/1.50,transferMode.dlna.org: Streaming,RANGE: bytes=0-]]
2013-10-14 17:00:53,673 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.116
2013-10-14 17:00:53,676 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.116
2013-10-14 17:00:53,678 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.116, Profile=Vizio E241-A1'
2013-10-14 17:00:53,678 DEBUG [ResourceDeliveryProcessor] Request for resource 718 and type 'MEDIA_ITEM' received
2013-10-14 17:00:53,679 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 718 (local)
2013-10-14 17:00:53,679 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 718)
2013-10-14 17:00:53,681 DEBUG [VideoDAOImpl] Reading a Video (id = 718)
2013-10-14 17:00:53,686 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 718, format AVC_MP4_MP_SD_AAC_MULT5 and profile Vizio E241-A1
2013-10-14 17:00:53,687 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 718 (local)
2013-10-14 17:00:53,687 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 718)
2013-10-14 17:00:53,690 DEBUG [VideoDAOImpl] Reading a Video (id = 718)
2013-10-14 17:00:53,693 DEBUG [VideoDeliveryEngine] Delivering item '718' for client 'Identifier=192.168.1.116, Profile=Vizio E241-A1'
2013-10-14 17:00:53,695 DEBUG [VideoDeliveryEngine] Delivering file 'legend.mp4' in native format
2013-10-14 17:00:53,695 DEBUG [MediaItemDAOImpl] Getting file of media item 718
2013-10-14 17:00:53,698 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 718) as read
2013-10-14 17:00:53,710 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-10-14 17:00:53,711 DEBUG [GETMethodProcessor] Stream entity has length: 96452047
2013-10-14 17:00:53,712 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Content-Length: 96452047,Date: Mon, 14 Oct 2013 23:00:53 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,Content-Range: bytes 0-96452046/96452047,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-14 17:00:53,950 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-10-14 17:00:54,013 DEBUG [ServiioHttpService] Incoming request from /192.168.1.116:42627: GET /resource/718/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5-0/ORIGINAL HTTP/1.1, headers = [HOST: 192.168.1.147:8895,DATE: Mon, 14 Oct 2013 23:00:56 GMT,CONNECTION: Keep-Alive,USER-AGENT: IPI/1.0 UPnP/1.0 DLNADOC/1.50,transferMode.dlna.org: Streaming,RANGE: bytes=0-]]
2013-10-14 17:00:54,014 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.116
2013-10-14 17:00:54,017 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.116
2013-10-14 17:00:54,019 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.116, Profile=Vizio E241-A1'
2013-10-14 17:00:54,019 DEBUG [ResourceDeliveryProcessor] Request for resource 718 and type 'MEDIA_ITEM' received
2013-10-14 17:00:54,020 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 718 (local)
2013-10-14 17:00:54,020 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 718)
2013-10-14 17:00:54,023 DEBUG [VideoDAOImpl] Reading a Video (id = 718)
2013-10-14 17:00:54,027 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 718, format AVC_MP4_MP_SD_AAC_MULT5 and profile Vizio E241-A1
2013-10-14 17:00:54,028 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 718 (local)
2013-10-14 17:00:54,028 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 718)
2013-10-14 17:00:54,031 DEBUG [VideoDAOImpl] Reading a Video (id = 718)
2013-10-14 17:00:54,033 DEBUG [LibraryManager] Metadata found via extractor EMBEDDED: VideoMetadata [title=Once.Upon.a.Time.S02E09.480p.HDTV.x264-mSD.www.RapidMovieZ.com, filePath=C:\Users\Public\Videos\Once\Season2\once.mkv, fileSize=210480772, audioBitrate=null, audioCodec=AAC, audioStreamIndex=0, bitrate=648, channels=2, container=MATROSKA, contentType=UNKNOWN, duration=2596, episodeNumber=null, fps=23.976, frequency=48000, h264Levels={RF=2.2, H=3.1}, h264Profile=HIGH, ftyp=null, height=480, seasonNumber=null, seriesName=null, timestampType=null, videoBitrate=null, videoCodec=H264, videoFourCC=null, videoStreamIndex=1, width=852, embeddedSubtitles=[]]
2013-10-14 17:00:54,034 DEBUG [VideoDeliveryEngine] Delivering item '718' for client 'Identifier=192.168.1.116, Profile=Vizio E241-A1'
2013-10-14 17:00:54,034 DEBUG [VideoDeliveryEngine] Delivering file 'legend.mp4' in native format
2013-10-14 17:00:54,034 DEBUG [MediaItemDAOImpl] Getting file of media item 718
people.mp4:
2013-10-14 17:01:13,511 DEBUG [VideoDeliveryEngine] Delivering item '718' for client 'Identifier=192.168.1.116, Profile=Vizio E241-A1'
2013-10-14 17:01:13,513 DEBUG [VideoDeliveryEngine] Delivering file 'legend.mp4' in native format
2013-10-14 17:01:13,514 DEBUG [MediaItemDAOImpl] Getting file of media item 718
2013-10-14 17:01:13,528 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 718) as read
2013-10-14 17:01:13,559 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-10-14 17:01:13,561 DEBUG [GETMethodProcessor] Stream entity has length: 96189903
2013-10-14 17:01:13,576 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Content-Length: 96189903,Date: Mon, 14 Oct 2013 23:01:13 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,Content-Range: bytes 262144-96452046/96452047,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-14 17:01:16,385 DEBUG [ServiioHttpService] Incoming request from /192.168.1.116:42644: GET /resource/719/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5-0/ORIGINAL HTTP/1.1, headers = [HOST: 192.168.1.147:8895,DATE: Mon, 14 Oct 2013 23:01:18 GMT,CONNECTION: Keep-Alive,USER-AGENT: IPI/1.0 UPnP/1.0 DLNADOC/1.50,transferMode.dlna.org: Streaming,RANGE: bytes=0-]]
2013-10-14 17:01:16,468 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.116
2013-10-14 17:01:16,488 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.116
2013-10-14 17:01:16,504 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.116, Profile=Vizio E241-A1'
2013-10-14 17:01:16,507 DEBUG [ResourceDeliveryProcessor] Request for resource 719 and type 'MEDIA_ITEM' received
2013-10-14 17:01:16,509 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 719 (local)
2013-10-14 17:01:16,510 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 719)
2013-10-14 17:01:16,538 DEBUG [VideoDAOImpl] Reading a Video (id = 719)
2013-10-14 17:01:16,558 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 719, format AVC_MP4_MP_SD_AAC_MULT5 and profile Vizio E241-A1
2013-10-14 17:01:16,563 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 719 (local)
2013-10-14 17:01:16,564 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 719)
2013-10-14 17:01:16,593 DEBUG [VideoDAOImpl] Reading a Video (id = 719)
2013-10-14 17:01:16,619 DEBUG [VideoDeliveryEngine] Delivering item '719' for client 'Identifier=192.168.1.116, Profile=Vizio E241-A1'
2013-10-14 17:01:16,623 DEBUG [VideoDeliveryEngine] Delivering file 'people.mp4' in native format
2013-10-14 17:01:16,624 DEBUG [MediaItemDAOImpl] Getting file of media item 719
2013-10-14 17:01:16,670 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 719) as read
2013-10-14 17:01:16,718 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-10-14 17:01:16,720 DEBUG [GETMethodProcessor] Stream entity has length: 301646643
2013-10-14 17:01:16,728 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Content-Length: 301646643,Date: Mon, 14 Oct 2013 23:01:16 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,Content-Range: bytes 0-301646642/301646643,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-14 17:01:17,549 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-10-14 17:01:17,594 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-10-14 17:01:17,703 DEBUG [ServiioHttpService] Incoming request from /192.168.1.116:42645: GET /resource/719/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5-0/ORIGINAL HTTP/1.1, headers = [HOST: 192.168.1.147:8895,DATE: Mon, 14 Oct 2013 23:01:20 GMT,CONNECTION: Keep-Alive,USER-AGENT: IPI/1.0 UPnP/1.0 DLNADOC/1.50,transferMode.dlna.org: Streaming,RANGE: bytes=0-]]
2013-10-14 17:01:17,708 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.116
2013-10-14 17:01:17,744 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.116
2013-10-14 17:01:17,760 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.116, Profile=Vizio E241-A1'
2013-10-14 17:01:17,764 DEBUG [ResourceDeliveryProcessor] Request for resource 719 and type 'MEDIA_ITEM' received
2013-10-14 17:01:17,766 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 719 (local)
2013-10-14 17:01:17,767 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 719)
2013-10-14 17:01:17,782 DEBUG [VideoDAOImpl] Reading a Video (id = 719)
2013-10-14 17:01:17,804 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 719, format AVC_MP4_MP_SD_AAC_MULT5 and profile Vizio E241-A1
2013-10-14 17:01:17,810 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 719 (local)
2013-10-14 17:01:17,811 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 719)
2013-10-14 17:01:17,834 DEBUG [VideoDAOImpl] Reading a Video (id = 719)
2013-10-14 17:01:17,860 DEBUG [VideoDeliveryEngine] Delivering item '719' for client 'Identifier=192.168.1.116, Profile=Vizio E241-A1'
2013-10-14 17:01:17,862 DEBUG [VideoDeliveryEngine] Delivering file 'people.mp4' in native format
2013-10-14 17:01:17,864 DEBUG [MediaItemDAOImpl] Getting file of media item 719
2013-10-14 17:01:17,877 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 719) as read
2013-10-14 17:01:18,017 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-10-14 17:01:18,045 DEBUG [GETMethodProcessor] Stream entity has length: 301646643
2013-10-14 17:01:18,050 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Content-Length: 301646643,Date: Mon, 14 Oct 2013 23:01:18 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,Content-Range: bytes 0-301646642/301646643,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-14 17:01:18,417 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2013-10-14 17:01:18,430 DEBUG [ServiioHttpService] Incoming request from /192.168.1.116:42646: GET /resource/719/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5-0/ORIGINAL HTTP/1.1, headers = [HOST: 192.168.1.147:8895,DATE: Mon, 14 Oct 2013 23:01:21 GMT,CONNECTION: Keep-Alive,USER-AGENT: IPI/1.0 UPnP/1.0 DLNADOC/1.50,transferMode.dlna.org: Streaming,RANGE: bytes=0-]]
2013-10-14 17:01:18,435 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.116
2013-10-14 17:01:18,452 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.116
2013-10-14 17:01:18,483 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.116, Profile=Vizio E241-A1'
2013-10-14 17:01:18,530 DEBUG [ResourceDeliveryProcessor] Request for resource 719 and type 'MEDIA_ITEM' received
2013-10-14 17:01:18,532 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 719 (local)
2013-10-14 17:01:18,534 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 719)
2013-10-14 17:01:18,567 DEBUG [VideoDAOImpl] Reading a Video (id = 719)
2013-10-14 17:01:18,588 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 719, format AVC_MP4_MP_SD_AAC_MULT5 and profile Vizio E241-A1
2013-10-14 17:01:18,592 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 719 (local)
2013-10-14 17:01:18,593 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 719)
2013-10-14 17:01:18,609 DEBUG [VideoDAOImpl] Reading a Video (id = 719)
2013-10-14 17:01:18,627 DEBUG [VideoDeliveryEngine] Delivering item '719' for client 'Identifier=192.168.1.116, Profile=Vizio E241-A1'
2013-10-14 17:01:18,630 DEBUG [VideoDeliveryEngine] Delivering file 'people.mp4' in native format
2013-10-14 17:01:18,631 DEBUG [MediaItemDAOImpl] Getting file of media item 719
2013-10-14 17:01:18,645 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 719) as read
2013-10-14 17:01:18,801 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-10-14 17:01:18,803 DEBUG [GETMethodProcessor] Stream entity has length: 301646643
2013-10-14 17:01:18,809 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Content-Length: 301646643,Date: Mon, 14 Oct 2013 23:01:18 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,Content-Range: bytes 0-301646642/301646643,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-14 17:01:19,136 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-10-14 17:01:19,313 DEBUG [ServiioHttpService] Incoming request from /192.168.1.116:42647: GET /resource/719/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5-0/ORIGINAL HTTP/1.1, headers = [HOST: 192.168.1.147:8895,DATE: Mon, 14 Oct 2013 23:01:21 GMT,CONNECTION: Keep-Alive,USER-AGENT: IPI/1.0 UPnP/1.0 DLNADOC/1.50,transferMode.dlna.org: Streaming,RANGE: bytes=1323008-301646642]]
2013-10-14 17:01:19,378 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.116
2013-10-14 17:01:19,399 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.116
2013-10-14 17:01:19,415 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.116, Profile=Vizio E241-A1'
2013-10-14 17:01:19,418 DEBUG [ResourceDeliveryProcessor] Request for resource 719 and type 'MEDIA_ITEM' received
2013-10-14 17:01:19,420 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 719 (local)
2013-10-14 17:01:19,421 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 719)
2013-10-14 17:01:19,446 DEBUG [VideoDAOImpl] Reading a Video (id = 719)
2013-10-14 17:01:19,470 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 719, format AVC_MP4_MP_SD_AAC_MULT5 and profile Vizio E241-A1
2013-10-14 17:01:19,481 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 719 (local)
2013-10-14 17:01:19,483 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 719)
2013-10-14 17:01:19,528 DEBUG [VideoDAOImpl] Reading a Video (id = 719)
2013-10-14 17:01:19,546 DEBUG [VideoDeliveryEngine] Delivering item '719' for client 'Identifier=192.168.1.116, Profile=Vizio E241-A1'
2013-10-14 17:01:19,549 DEBUG [VideoDeliveryEngine] Delivering file 'people.mp4' in native format
2013-10-14 17:01:19,551 DEBUG [MediaItemDAOImpl] Getting file of media item 719
2013-10-14 17:01:19,565 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 719) as read
2013-10-14 17:01:19,714 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-10-14 17:01:19,717 DEBUG [GETMethodProcessor] Stream entity has length: 300323635
2013-10-14 17:01:19,724 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Content-Length: 300323635,Date: Mon, 14 Oct 2013 23:01:19 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,Content-Range: bytes 1323008-301646642/301646643,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-14 17:01:20,153 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2013-10-14 17:01:20,174 DEBUG [ServiioHttpService] Incoming request from /192.168.1.116:42648: GET /resource/719/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5-0/ORIGINAL HTTP/1.1, headers = [HOST: 192.168.1.147:8895,DATE: Mon, 14 Oct 2013 23:01:22 GMT,CONNECTION: Keep-Alive,USER-AGENT: IPI/1.0 UPnP/1.0 DLNADOC/1.50,transferMode.dlna.org: Streaming,RANGE: bytes=483328-301646642]]
2013-10-14 17:01:20,181 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.116
2013-10-14 17:01:20,197 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.116
2013-10-14 17:01:20,212 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.116, Profile=Vizio E241-A1'
2013-10-14 17:01:20,215 DEBUG [ResourceDeliveryProcessor] Request for resource 719 and type 'MEDIA_ITEM' received
2013-10-14 17:01:20,217 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 719 (local)
2013-10-14 17:01:20,218 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 719)
2013-10-14 17:01:20,233 DEBUG [VideoDAOImpl] Reading a Video (id = 719)
2013-10-14 17:01:20,254 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 719, format AVC_MP4_MP_SD_AAC_MULT5 and profile Vizio E241-A1
2013-10-14 17:01:20,264 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 719 (local)
2013-10-14 17:01:20,265 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 719)
2013-10-14 17:01:20,291 DEBUG [VideoDAOImpl] Reading a Video (id = 719)
2013-10-14 17:01:20,351 DEBUG [VideoDeliveryEngine] Delivering item '719' for client 'Identifier=192.168.1.116, Profile=Vizio E241-A1'
2013-10-14 17:01:20,354 DEBUG [VideoDeliveryEngine] Delivering file 'people.mp4' in native format
2013-10-14 17:01:20,358 DEBUG [MediaItemDAOImpl] Getting file of media item 719
2013-10-14 17:01:20,373 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 719) as read
2013-10-14 17:01:20,441 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-10-14 17:01:20,444 DEBUG [GETMethodProcessor] Stream entity has length: 301163315
2013-10-14 17:01:20,450 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Content-Length: 301163315,Date: Mon, 14 Oct 2013 23:01:20 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,Content-Range: bytes 483328-301646642/301646643,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-14 17:01:20,659 DEBUG [SearchManager] Committing search index
2013-10-14 17:01:21,149 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-10-14 17:01:21,325 DEBUG [ServiioHttpService] Incoming request from /192.168.1.116:42649: GET /resource/719/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5-0/ORIGINAL HTTP/1.1, headers = [HOST: 192.168.1.147:8895,DATE: Mon, 14 Oct 2013 23:01:23 GMT,CONNECTION: Keep-Alive,USER-AGENT: IPI/1.0 UPnP/1.0 DLNADOC/1.50,transferMode.dlna.org: Streaming,RANGE: bytes=1302528-301646642]]
2013-10-14 17:01:21,330 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.116
2013-10-14 17:01:21,347 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.116
2013-10-14 17:01:21,439 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.116, Profile=Vizio E241-A1'
2013-10-14 17:01:21,442 DEBUG [ResourceDeliveryProcessor] Request for resource 719 and type 'MEDIA_ITEM' received
2013-10-14 17:01:21,452 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 719 (local)
2013-10-14 17:01:21,457 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 719)
2013-10-14 17:01:21,516 DEBUG [VideoDAOImpl] Reading a Video (id = 719)
2013-10-14 17:01:21,539 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 719, format AVC_MP4_MP_SD_AAC_MULT5 and profile Vizio E241-A1
2013-10-14 17:01:21,543 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 719 (local)
2013-10-14 17:01:21,545 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 719)
2013-10-14 17:01:21,560 DEBUG [VideoDAOImpl] Reading a Video (id = 719)
2013-10-14 17:01:21,578 DEBUG [VideoDeliveryEngine] Delivering item '719' for client 'Identifier=192.168.1.116, Profile=Vizio E241-A1'
2013-10-14 17:01:21,580 DEBUG [VideoDeliveryEngine] Delivering file 'people.mp4' in native format
2013-10-14 17:01:21,581 DEBUG [MediaItemDAOImpl] Getting file of media item 719
2013-10-14 17:01:21,679 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 719) as read
2013-10-14 17:01:21,824 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-10-14 17:01:21,829 DEBUG [GETMethodProcessor] Stream entity has length: 300344115
2013-10-14 17:01:21,838 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Content-Length: 300344115,Date: Mon, 14 Oct 2013 23:01:21 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,Content-Range: bytes 1302528-301646642/301646643,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-14 17:01:22,041 DEBUG [ServiioHttpService] Incoming request from /192.168.1.116:42650: GET /resource/719/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5-0/ORIGINAL HTTP/1.1, headers = [HOST: 192.168.1.147:8895,DATE: Mon, 14 Oct 2013 23:01:24 GMT,CONNECTION: Keep-Alive,USER-AGENT: IPI/1.0 UPnP/1.0 DLNADOC/1.50,transferMode.dlna.org: Streaming,RANGE: bytes=1323008-301646642]]
2013-10-14 17:01:22,053 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.116
2013-10-14 17:01:22,085 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.116
2013-10-14 17:01:22,111 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.116, Profile=Vizio E241-A1'
2013-10-14 17:01:22,114 DEBUG [ResourceDeliveryProcessor] Request for resource 719 and type 'MEDIA_ITEM' received
2013-10-14 17:01:22,116 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 719 (local)
2013-10-14 17:01:22,122 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 719)
2013-10-14 17:01:22,138 DEBUG [VideoDAOImpl] Reading a Video (id = 719)
2013-10-14 17:01:22,166 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 719, format AVC_MP4_MP_SD_AAC_MULT5 and profile Vizio E241-A1
2013-10-14 17:01:22,172 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 719 (local)
2013-10-14 17:01:22,174 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 719)
2013-10-14 17:01:22,190 DEBUG [VideoDAOImpl] Reading a Video (id = 719)
2013-10-14 17:01:22,211 DEBUG [VideoDeliveryEngine] Delivering item '719' for client 'Identifier=192.168.1.116, Profile=Vizio E241-A1'
2013-10-14 17:01:22,214 DEBUG [VideoDeliveryEngine] Delivering file 'people.mp4' in native format
2013-10-14 17:01:22,215 DEBUG [MediaItemDAOImpl] Getting file of media item 719
2013-10-14 17:01:22,232 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 719) as read
2013-10-14 17:01:22,275 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-10-14 17:01:22,279 DEBUG [GETMethodProcessor] Stream entity has length: 300323635
2013-10-14 17:01:22,285 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Content-Length: 300323635,Date: Mon, 14 Oct 2013 23:01:22 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,Content-Range: bytes 1323008-301646642/301646643,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-14 17:01:22,927 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2013-10-14 17:01:23,003 DEBUG [ServiioHttpService] Incoming request from /192.168.1.116:42651: GET /resource/719/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5-0/ORIGINAL HTTP/1.1, headers = [HOST: 192.168.1.147:8895,DATE: Mon, 14 Oct 2013 23:01:25 GMT,CONNECTION: Keep-Alive,USER-AGENT: IPI/1.0 UPnP/1.0 DLNADOC/1.50,transferMode.dlna.org: Streaming,RANGE: bytes=483328-301646642]]
2013-10-14 17:01:23,010 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.116
2013-10-14 17:01:23,027 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.116
2013-10-14 17:01:23,150 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.116, Profile=Vizio E241-A1'
2013-10-14 17:01:23,155 DEBUG [ResourceDeliveryProcessor] Request for resource 719 and type 'MEDIA_ITEM' received
2013-10-14 17:01:23,157 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 719 (local)
2013-10-14 17:01:23,159 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 719)
2013-10-14 17:01:23,233 DEBUG [VideoDAOImpl] Reading a Video (id = 719)
2013-10-14 17:01:23,255 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 719, format AVC_MP4_MP_SD_AAC_MULT5 and profile Vizio E241-A1
2013-10-14 17:01:23,260 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 719 (local)
2013-10-14 17:01:23,261 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 719)
2013-10-14 17:01:23,408 DEBUG [VideoDAOImpl] Reading a Video (id = 719)
2013-10-14 17:01:23,551 DEBUG [VideoDeliveryEngine] Delivering item '719' for client 'Identifier=192.168.1.116, Profile=Vizio E241-A1'
2013-10-14 17:01:23,553 DEBUG [VideoDeliveryEngine] Delivering file 'people.mp4' in native format
2013-10-14 17:01:23,557 DEBUG [MediaItemDAOImpl] Getting file of media item 719
2013-10-14 17:01:23,573 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 719) as read
2013-10-14 17:01:23,796 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-10-14 17:01:23,824 DEBUG [GETMethodProcessor] Stream entity has length: 301163315
2013-10-14 17:01:23,831 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Content-Length: 301163315,Date: Mon, 14 Oct 2013 23:01:23 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,Content-Range: bytes 483328-301646642/301646643,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-14 17:01:24,116 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-10-14 17:01:24,175 DEBUG [ServiioHttpService] Incoming request from /192.168.1.116:42652: GET /resource/719/MEDIA_ITEM/AVC_MP4_MP_SD_AAC_MULT5-0/ORIGINAL HTTP/1.1, headers = [HOST: 192.168.1.147:8895,DATE: Mon, 14 Oct 2013 23:01:26 GMT,CONNECTION: Keep-Alive,USER-AGENT: IPI/1.0 UPnP/1.0 DLNADOC/1.50,transferMode.dlna.org: Streaming,RANGE: bytes=1302528-301646642]]
2013-10-14 17:01:24,180 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.116
2013-10-14 17:01:24,194 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.116
2013-10-14 17:01:24,207 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.116, Profile=Vizio E241-A1'
2013-10-14 17:01:24,210 DEBUG [ResourceDeliveryProcessor] Request for resource 719 and type 'MEDIA_ITEM' received
2013-10-14 17:01:24,211 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 719 (local)
2013-10-14 17:01:24,212 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 719)
2013-10-14 17:01:24,227 DEBUG [VideoDAOImpl] Reading a Video (id = 719)
2013-10-14 17:01:24,247 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 719, format AVC_MP4_MP_SD_AAC_MULT5 and profile Vizio E241-A1
2013-10-14 17:01:24,254 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 719 (local)
2013-10-14 17:01:24,256 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 719)
2013-10-14 17:01:24,271 DEBUG [VideoDAOImpl] Reading a Video (id = 719)
2013-10-14 17:01:24,288 DEBUG [VideoDeliveryEngine] Delivering item '719' for client 'Identifier=192.168.1.116, Profile=Vizio E241-A1'
2013-10-14 17:01:24,290 DEBUG [VideoDeliveryEngine] Delivering file 'people.mp4' in native format
2013-10-14 17:01:24,292 DEBUG [MediaItemDAOImpl] Getting file of media item 719
2013-10-14 17:01:24,305 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 719) as read
2013-10-14 17:01:24,347 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-10-14 17:01:24,351 DEBUG [GETMethodProcessor] Stream entity has length: 300344115
2013-10-14 17:01:24,357 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Content-Length: 300344115,Date: Mon, 14 Oct 2013 23:01:24 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,Content-Range: bytes 1302528-301646642/301646643,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
The "Vizio E241-A1" profile is just the "LG TV/player" profile that I've been tweaking to familiarize myself with profile.xml.
thoughtlover
Post Wed Oct 16, 2013 4:19 am
Re: Vizio E241-A1 Smart TV won't play large MP4s
Nevermind:) My wife took the Vizio back and bought a Samsung instead, which has been no problem to get working with Serviio.
Users browsing this forum: Google [Bot] and 27 guests
