Serviio Pro seems to have broke serviio
Angelikfear
Post Mon Nov 04, 2013 10:28 pm
When I upgraded to Pro I didnt use my serviio web access sortly after upgrading but now I cant access serviio at all. It keeps saying that it cannot connect to serviio server. I have done alot of the fixes people have suggested, (update java, uninstall and reinstall, etc.) but nothing has worked. i have tried to start the service by going into services and select start (as restart and stop were not available) and it gave me the same message. i have tried to create a log but...... I cant start serviio to spit out a log. I really feel like I was taken advantage of since I hate buying "pro" versions. But I was REALLY happy with how serviio performed and wanted to be able to access my music and movies from anywhere.
Any useful help would be appreciated as I am not a fan of XBMC or Playstation media server.
Post Mon Nov 04, 2013 11:07 pm
Re: Serviio Pro seems to have broke serviio
Turn on detailed logging (click link for details) and then try and start the Serviio service. Post the log to the forum.
Angelikfear
Post Tue Nov 05, 2013 12:28 am
Thats what I was talking about when i mentioned I couldnt restart the service. It only says Start and when i select that it says could not connect to server and failed to start service
Post Tue Nov 05, 2013 12:53 am
When you press Start (in services.msc) you should still get a log file produced until it fails. It will only be a short log showing Serviio starting and then failing, but it may shed some light on why it is failing. The log file is in your Serviio\Log folder.
Do you get any error messages from Windows, or in the Windows event viewer (System log)? Have you changed your profiles.xml file at all? When you re-installed Serviio did it work before you re-installed your licence file?
Angelikfear
Post Tue Nov 05, 2013 1:08 am
I will check the log file for the log and no it didnt work when I reinstalled it. I didnt even put the pro key back in.
Angelikfear
Post Tue Nov 05, 2013 1:28 am
I have attached the log file.
(11.63 KiB) Downloaded 359 times
Post Tue Nov 05, 2013 4:45 am
Unfortunately this is not a detailed log file - you need to turn detailed logging on (click on link and follow the instructions). I can see Serviio shutting down but not why.
Angelikfear
Post Tue Nov 05, 2013 2:01 pm
I followed those instructions. i can take a screen shot and show you the changes.
Angelikfear
Post Tue Nov 05, 2013 2:37 pm
Here is the snip of it.
Post Tue Nov 05, 2013 4:59 pm
This is just the configuration file. You did make the right change, now you have to restart the PC, try to start Serviio and then find serviio.log file in your Serviio installation directory (probably c:\Program Files\Serviio\log) and attach it here.
Angelikfear
Post Tue Nov 05, 2013 5:30 pm
This will have to be done this evening. I will check back in roughly 6 and a half hours.
Angelikfear
Post Wed Nov 06, 2013 12:15 am
It started this time. Here is the log that was generated. It looks longer. please keep in mind that this is the free version as I have not put the pro version in yet and there is no media added so its a fresh install of serviio.
(71.89 KiB) Downloaded 346 times
Post Wed Nov 06, 2013 12:35 am
Bugger :D - needed to see the log when it failed to start.
I'd suggest:
  • Add your license key. Restart Serviio/your PC to make sure its still good
  • Add your shared folders one at a time. Force a refresh and when finished restart Serviio/your PC to make sure its still good. Repeat for other shared folders.
  • Add any online sources one at a time.
Keep detailed logging on - this will result in a massive log file but you can delete it after all this is finished and (hopefully) all working.
Angelikfear
Post Wed Nov 06, 2013 12:55 am
what do you need from log its too big
Post Wed Nov 06, 2013 12:58 am
Did it fail again? At what stage?
Try zipping the log up posting the zipped file as an attachment. If not, post from the last restart of Serviio.
Angelikfear
Post Wed Nov 06, 2013 1:01 am
There is an icon in the system tray but it said it failed..... services show the status as empty.
Angelikfear
Post Wed Nov 06, 2013 1:04 am
so ya it definately failed I cant even get to local host.
Angelikfear
Post Wed Nov 06, 2013 1:06 am
Please hurry and get the full log from here: It can be downloaded only once.
http://www.justbeamit.com/9i4q6
Nevermind.... the link expired. please let me know when you will be available to recieve the file.
Post Wed Nov 06, 2013 12:26 pm
Time zone differences will make that near impossible. Can you zip it up and then add as an attachment to your next post? That way @zip can also look into it if needed.
