[SOLVED] Sony 4k xbr-55x900a TV & Serviio DLNA profile
anmol
Post Sun Nov 10, 2013 12:00 am
Hi Guys
I have recently purchased a sony xbr-55x900a. Unfortunately Serviio DLNA server does not get detected by this Sony TV. I have tried supplied profiles with no luck. This is not a networking issue as i can ping TV ip address from serviio server. Sony XBR TV has no issues detecting other dlna server on network- seagate Network attached storage running DLNA server- Seagate central. I quite like serviio and would like to use it with XBR TV. Any help is most appreciated. Many Thanks
- Anmol
Post Sun Nov 10, 2013 6:26 pm
Re: Sony 4k xbr-55x900a TV & Serviio DLNA profile
Is the TV detected in the console? If yes, make sure it's enabled.
anmol
Post Sun Nov 10, 2013 7:53 pm
The TV is detected in console and is green. I have no access restrictions setup. All devices are allowed access.
PS- If it helps- I have a sony bluray player which does detect serviio fine and works a treat. This blu ray player is on same serviio server as above and settings are identical to that of TV except that profile is for specific bluray model.
With new TV, I have tried beta sony 2013 bravia TV profile (available in this forum's other sections) with no luck. Many Thanks for your help.
Post Sun Nov 10, 2013 8:36 pm
are they all on the same subnet?
anmol
Post Sun Nov 10, 2013 8:44 pm
They are on same subnet. I am professionally an experienced networking specialist and network is a non issue here. I can ping TV etc and everything is hard wired via cat6 cabling so its not a flaking wireless signal either.
Post Sun Nov 10, 2013 9:03 pm
could you post a detailed log and specify the IP of the TV and the server?
anmol
Post Mon Nov 11, 2013 7:53 am
ip address of TV 192.168.2.213/24
Ip address of Serviio 192.168.2.222/24
Many Thanks
serviio.zip
(476.66 KiB) Downloaded 360 times
Post Mon Nov 11, 2013 11:55 am
Please do not duplicate post...
See here : viewtopic.php?f=11&t=13886#p82214
I will move this post to Sony section.
