can't acces web console?
ikkeenjij36
Post Sat Nov 09, 2013 8:06 pm
Hi there installed and running serviio on my freebsd nas,but though it's running i can't connect ot hte wbinterface on other machine.
I am trying to reach it by nasip:23423 but not possibl for me.
Is there anyone who can help me with this?
Xmantium
Post Mon Nov 11, 2013 12:47 am
Re: can't acces web console?
You must install a web server and the unofficial web UI.
http://wiki.serviio.org/doku.php?id=phpwebui
There's no official web UI.
You could always remotely connect the Windows console or download the apps in my signature for your smartphone
ikkeenjij36
Post Mon Nov 11, 2013 8:54 pm
Xmantium wrote:You must install a web server and the unofficial web UI.
Hi thanks for taking the time to answer me.
Got serviio installed on my server running zfsguru running on freebsd,installed the zip file on diffwerent places in the serviio directory but no luck of starting the webgui.
Php and apche running ass well on the server.
Don't know how to go on from here,maybe you could give advice?
Can't buy the app for android cause don't have cc.
Post Mon Nov 11, 2013 9:00 pm
You can install Serviio on your Desktop/laptop (if windows, select just the console during installation) and then point it at your server http://www.serviio.org/component/conten ... e?id=21#q2
else you can use ServiiDroid for Android which is free on Google Play.
ikkeenjij36
Post Mon Nov 11, 2013 10:31 pm
will wrote:You can install Serviio on your Desktop/laptop (if windows, select just the console during installation) and then point it at your server http://www.serviio.org/component/conten ... e?id=21#q2
Allright did that again but in wich file do have to add or change something so i can refer it to the ip of my server??
Xmantium
Post Fri Nov 15, 2013 11:20 pm
Theres three ways to upload the licence (its a .lic file when you buy the Pro licenc)
1: Remote access with windows console
You would simple have to download the new Windows Serviio v1.3.1 from http://www.serviio.org/download
Only install the console, then edit C:\Program Files\Serviio\bin\ServiioConsole.exe.vmoptions with a text editor by adding:
-Dserviio.remoteHost=XXX.XXX.X.XXX
Replacing XXX.XXX.X.XXX with the IP Address your Serviio server
2: Use your Android phone
Use ServiiDroid for Android which is v1.3.1 compatible - https://play.google.com/store/apps/deta ... erviidroid
3: Install the unofficial web ui
TheZero
Post Thu Jan 09, 2014 1:28 pm
I have a problem with the console .
I have the WebGui my NAS ( DS213 +) tries .
Since I can but unfortunately not create new paths.
Then I tried the Android app . But the work is not particularly comfortable.
Therefore was to use the Console for windows my last hope .
But unfortunately, no window opens .
The log file tells me , unfortunately, not much.
2014-01-09 14:21:47,745 INFO [ServiioConsole] Initializing Serviio Console
2014-01-09 14:21:47,764 INFO [ServiioConsole] Starting Serviio Console
2014-01-09 14:21:47,849 INFO [ServiioConsole] Connecting to Serviio REST on 192.168.1.20:23423
2014-01-09 14:23:58,044 WARN [ServiioConsole] Cannot connect to the server to get DB initialization info
2014-01-09 14:26:08,072 WARN [ServiioConsole] Cannot connect to server: Connection Error (1000) - Connection timed out: connect
2014-01-09 14:26:08,086 INFO [Messages] Loaded console message bundle for locale: en
2014-01-09 14:26:19,294 INFO [ServiioConsole] Exitting Serviio Console
Can anyone of you help .
Translated by Google
