READYSHARE and SERVIIO
movieman49707
Post Mon Nov 18, 2013 12:48 am
I'm not sure if this has been answered but I'm gonna ask again. My external hard drive id connected to my Netgear N600 WNDR3400. I use ReadyShare to access the hard drive through my XBOX 360. I'm connected in SERVIIO but when I got to "MOVIES" it says no files found.... but when I go to "FOLDERS" every thing is there. Is there a process to fix this? I miss my easy access and DVD covers. Please Help
Post Mon Nov 18, 2013 1:25 am
Re: READYSHARE and SERVIIO
The Folders category is populated using the filename for your media file. In contrast, the Movies category is populated using metadata - either metadata you provide in the form of an .nfo file, or more commonly, metadata downloaded automatically from the web by Serviio. Have a read of the wiki article: http://www.serviio.org/component/conten ... extraction.
If you are using Online metadata sources you need to rename your files according to the file naming scheme in that article. This allows Serviio to match the filename for the movie/series to the online data sources. For movies it's simple "movie name (year).xxx". Once you have done that refresh your library and you should now have titles in your Movies category (and Actors, Directors, Genre etc categories). Also see my post here: viewtopic.php?f=5&t=10626&p=70544#p70544 for further info and for info on using the Filebot tool to help rename your files.
movieman49707
Post Mon Nov 18, 2013 2:31 am
Thank you for your response. I believe Serviio has created the metadata info for me because when I go into the folders and pick a movie the DVD cover is there. Are you saying I need to change something so that the "Movies" folder will recognize it?
Post Mon Nov 18, 2013 4:01 am
No, Serviio doesn't store posters in the folder - it stores all data, including posters, in its own database. The poster in your folder must have been created by something else, or commonly, downloaded with the movie.
To use online metadata sources, in Serviio Console:
  • On the Library tab, ensure that Metadata is ticked (under the M symbol) for your shared folder. Press Save if you change anything;
  • On the Metadata tab (Video), ensure top two checkboxes are ticked, dropdown box is set to "Online metadata sources" and "Retrieve DVD Cover Image" is checked. Press Save if you change anything.
For each movie in your library, ensure that the filename complies with the schema (ie. name the file as "movie name (year).xxx" - for example "Toy Story 1 (1995).mkv").
Then go back into Serviio Console and force refresh your library (on the Library tab, press Force Refresh).
movieman49707
Post Mon Nov 18, 2013 8:16 am
All folders have metadata info for them now. But still nothing under the movies section. Only in last added and under folders. Could it be a a file sharing issue?
Post Mon Nov 18, 2013 11:12 am
No it wouldn't be file sharing, if it were, you wouldn't see them under the Folders category.
What changed? Depending on what you did you may need press both the Force Refresh button (on the Library to press tab) and the Rescan Video Metadata button (on the Metadata tab).
movieman49707
Post Mon Nov 18, 2013 1:31 pm
I dont know what I did but the movies are there happy happy happy. Thanks for your help.....
Users browsing this forum: No registered users and 86 guests
