[SOLVED] Sony BDP-S3100 No Audio
oldyin
Post Wed Nov 20, 2013 12:13 pm
Hi looking for some help,
My player has stopped playing audio except 5.1 dts no mp3 will show in folders , mp4 will play with no audio (aac) avi with mp3 will play video but no sound these where all working yesterday today nothing.
*EDIT*
it's a streaming issue codecs i think, put file's on a usb stick played no prob,
only thing is i dunno what codec have changed .
file i'm trying to watch
Format profile                           : Base Media
Codec ID                                 : isom
File size                                : 229 MiB
Duration                                 : 43mn 59s
Overall bit rate                         : 726 Kbps
Encoded date                             : UTC 2013-11-19 14:43:19
Tagged date                              : UTC 2013-11-19 14:43:19
Format profile                           : High@L3.1
Format settings, ReFrames                : 5 frames
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Duration                                 : 43mn 59s
Bit rate                                 : 606 Kbps
Maximum bit rate                         : 3 105 Kbps
Width                                    : 720 pixels
Height                                   : 404 pixels
Bits/(Pixel*Frame)                       : 0.087
Stream size                              : 191 MiB (83%)
Writing library                          : x264 core 140 r2377 1ca7bb9
Encoding settings                        : cabac=1 / ref=5 / deblock=1:1:1 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=16 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=19.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Encoded date                             : UTC 2013-11-19 14:24:09
Tagged date                              : UTC 2013-11-19 14:43:20
Codec ID                                 : 40
Duration                                 : 43mn 59s
Bit rate                                 : 116 Kbps
Maximum bit rate                         : 146 Kbps
Channel count                            : 2 channels
Delay relative to video                  : -255ms
Stream size                              : 36.5 MiB (16%)
Encoded date                             : UTC 2013-11-19 14:43:20
mp3 that wont play.
Format                                   : MPEG Audio
File size                                : 5.10 MiB
Duration                                 : 3mn 49s
Overall bit rate                         : 186 Kbps
Album                                    : 21
Track name                               : Rolling In The Deep
Track name/Position                      : 1
Performer                                : Adele
Encoded by                               : LAME 3.97
Genre                                    : Pop
Recorded date                            : 2011
Writing library                          : LAME3.97
Format                                   : MPEG Audio
Format version                           : Version 1
Format profile                           : Layer 3
Mode                                     : Joint stereo
Duration                                 : 3mn 49s
Bit rate                                 : 186 Kbps
Minimum bit rate                         : 32.0 Kbps
Sampling rate                            : 44.1 KHz
Stream size                              : 5.09 MiB (100%)
Encoding settings                        : -m j -V 2 -q 3 -lowpass 18.6 --vbr-new -b 32
cheers
old
Post Wed Nov 20, 2013 1:46 pm
Re: Sony BDP-S3100 No Audio
For the experts here to assist, they will need a couple of bits of info. What version of Serviio are you using, and what profile is selected for your S3100? It's probably something to do with the selected profile. There are several Sony profiles, and Serviio sometimes does not select the best one automatically. Not the fault of Serviio, there are just too many flavors out there to get everything right the first time.
oldyin
Post Wed Nov 20, 2013 1:53 pm
thanks for quick reply will need to edit first post as it's a streaming issue codecs i think, put file's on a usb stick played no prob,
version 1.3.1
Profile Sony BDP-Sx70/SMP-N100 (2010)
cheers
old
Post Wed Nov 20, 2013 6:31 pm
Do you try with other Sony profiles (BDP 2012, Bravia,etc.) ?
Post Thu Nov 21, 2013 1:00 am
oldyin wrote:thanks for quick reply will need to edit first post as it's a streaming issue codecs i think, put file's on a usb stick played no prob,
version 1.3.1
cheers
old
That Sony profile is for (I believe) an older player. Now that I'm home, I realize that I have a BDP-S3100 as well. Silly me, forgot my equipment :oops:
I use the Sony BDP-Sx90 profile. I find that it plays my MKV files natively very well, including some very high bitrate BluRay rips. Still have a few that hiccup, but overall works quite well.
oldyin
Post Thu Nov 21, 2013 8:18 am
got it going again uninstalled Serviio & k-lite pack reboot re-install k-lite then serviio all working again :D
Post Thu Nov 21, 2013 8:42 am
oldyin wrote:got it going again uninstalled Serviio & k-lite pack reboot re-install k-lite then serviio all working again :D
For your information, serviio does not need k-lite pack to be installed...
Enjoy-it !
