LG TV APP
Besugo
Post Thu Nov 28, 2013 3:35 pm
LG TV APP
Hi!
Please make an app for the LG/Samsung smart TV's, similar to Serviigo for the android. LG tv's have the magic remote, and it would be sweet to have all the movies, descriptions, etc right there on the tv!
Thanks and keep up the good work!
Post Fri Nov 29, 2013 12:17 am
Re: LG TV APP
I'm unsure if it's even possible for a 3rd party to write apps for TVs. Most that I am aware of only offer apps through their own portals. I don't know of any way to install a private app on a TV.
Xmantium
Post Sun Dec 01, 2013 2:08 am
Re: LG TV APP
With LG Smart Tv anyone can - http://developer.lge.com/main/Intro.dev
Iveky
Post Sun Dec 01, 2013 6:11 am
Re: LG TV APP
it is documented for Samsung too, but it is not easy job what you ask...
wieri347
Post Fri Jan 31, 2014 6:29 pm
Re: LG TV APP
Can you please elaborate on your question, because I don't get it. I mean, my LG TV has built-in support for DLNA and I don't seem to miss any features (apart from the search function but I believe that's on Serviio's to-do-list). In other words, what would need an app for if the LG tv already does it all straight out of the box?
Iveky
Post Fri Jan 31, 2014 7:33 pm
Re: LG TV APP
you ask special application (widget) on TV....
we are out of scope of serviio forum... go here (for samsung tv's):
http://www.samsungdforum.com/guide/
similar exist also for LG, i am sure.
spudy12
Post Sun Feb 02, 2014 1:57 pm
Re: LG TV APP
The benefit to having a dedicated app on the TV as I see it would be to work like Servigo (Android Phone App) and use the API to be able to access content over the internet (ie outside your home network where DLNA wouldn't work)
Whilst I think a feature like this would be great, learning how to write the software for each tv would be quite a task.
Return to Feature requests
